Intel Bay Trail J1800处理器, 6*COM, 1*LAN, 1*Mini-PCIe, DC 12V供电, Mini-ITX (170*170mm)
规格
General | |
CPU | Intel® Bay Trail J1800 CPU, Dual-core, up to 2.58 GHz, TDP10W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0, 1*mSATA |
Expansion Interface | 1*Mini-PCIe (mSATA/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux, Android |
I/O Interface | |
Serial Port | 6*RS232 (COM2 RS485, COM3 TTL optional) |
USB | 9*USB 2.0 (4*on rear I/O, 5*header) |
Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6083浏览量
34971 -
安卓
5文章
2108浏览量
56740 -
信步科技
6文章
263浏览量
7073
华硕 P2B主板英文版说明书
华硕 P2B主板英文版说明书Before installing the memory modules, please comply with the following conditions:
发表于 02-23 15:58
•0次下载
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
信步科技SV1-13716P主板规格英文版
Intel Celeron 1037U CPU with NM70, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V or ATX Input (optional)
