Intel 4代Core i3/i5/i7处理器 (LGA1150), 1*VGA, 1*HDMI, 1*LVDS, 4K超高清, 2*Mini-PCIe, DC 19V供电
- 支持Intel 4代Core i3/i5/i7处理器 (LGA1150)
- 采用Intel H81芯片组
- 支持4K超高清播放
- 提供1*VGA, 1*HDMI, 1*LVDS, 支持多种双屏异显
- 提供1*千兆LAN, 2*Mini-PCIe
- 采用DC 19V供电
规格
General | |
CPU |
Intel®Pentium®/ Celeron®/ 4thGeneration CoreTMi3/i5/i7 CPU, LGA1150 |
Chipset |
Intel®H81Chipset, TDP 4.1W |
Memory |
Up to 16 GB DDR3 1600/1333 MHz, 2*SO-DIMM |
Storage |
1*SATA 3.0, 2*SATA 2.0 |
Expansion Interface |
2*Mini-PCIe(1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS |
AMI UEFI BIOS |
System |
Windows 7/8/10, Linux |
I/O Interface | |
Serial Port |
2*RS232 |
USB |
2*USB 3.0, 6*USB 2.0 (4*on rear I/O, 4*header) |
Ethernet |
1*Realtek®PCI-E LAN for 1000Mbps |
Audio |
Realtek®ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifier |
PS/2 |
1*PS/2 header (Keyboard and Mouse Supported) |
Parallel Port |
Null |
GPIO |
8 programmable GPIO |
Feature Interface |
Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display |
Dual |
Mechanical & Environment | |
Dimension |
Mini-ITX, 170*170mm |
Power Input |
DC 19V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
WINDOWS
4文章
3567浏览量
89252 -
嵌入式主板
7文章
6086浏览量
35588 -
信步科技
7文章
263浏览量
7270
