Intel 4代Core i3/i5/i7处理器 (LGA1150), OPS接口, 支持VGA, HDMI, DP双屏异显, 4K超高清, DC 19V供电
- 支持Intel 4代Core i3/i5/i7处理器 (LGA1150)
- 采用Intel H81芯片组
- 提供OPS接口, 可搭配信步OPS子卡
- 支持VGA+HDMI+DP多种双屏异显, 4K超高清播放
- 支持mSATA存储, Wifi/3G/4G上网
- 采用DC 19V供电
- 采用OPS行业标准尺寸170*190mm
规格
| General | |
| CPU | Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150 |
| Chipset | Intel® H81 Chipset, TDP 4.1W |
| Memory | Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0 (22Pin), 1*mSATA |
| Expansion Interface |
2*Mini-PCIe (1*Wifi/3G/4G Supported, 1* mSATA Supported) 1*OPS Port |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux |
| I/O Interface | |
| Serial Port | 1*RS232 |
| USB | 2*USB 3.0+4*USB 2.0 (rear I/O), 1*USB 3.0+2*USB 2.0 (OPS) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | Null |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 170*190mm |
| Power Input | DC 19V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3710浏览量
94422 -
嵌入式主板
7文章
6107浏览量
37197 -
信步科技
7文章
264浏览量
7977
热点推荐
信步科技OPS-3855U规格
Skylake-U Celeron 3855U处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 4K超高清播放
支持mSATA存储, 板载Wifi上网模块
信步科技OPS-J1900规格
处理器
提供OPS接口, 可搭配信步OPS子卡
支持VGA+HDMI双屏异显, 高清播放
采用DC 12V供电
采用OPS行业标准
信步科技OPS-H270规格英文版
Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Supports OPS-C+, 4K UHD, 2
信步科技OPS-H110主板介绍英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, OPS-C+, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 12~19V Input
信步科技SV1-H8126C主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, Double-layer Rear I/O which can expand to 18*COM and 18*USB
信步科技SV1-H812C主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 10*USB, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H812C-A1主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H811A主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 10*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技OPS-H81主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, OPS, VGA, HDMI, DP, 4K UHD, 2*Mini-PCIe, DC 19V
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
信步科技SV1a-H8112P-B主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, 1*LVDS, 4K UHD, 2*Mini-PCIe, DC 19V Input
信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
信步科技OPS-H110主板规格英文版
Intel 6/7代Core i3/i5/i7处理器 (LGA1151), OPS-C+, 支持VGA, HDMI, DP双屏异显, 4K超高清, DC 12~19V供电
信步科技OPS-H81主板规格英文版
