Intel Atom N2600处理器, 6*COM, 2*LAN, 2*Mini-PCIe, DC 12V供电, 3.5英寸 (146*105mm)
规格
General | |
CPU | Intel® AtomTM N2600 CPU, Dual-core, 1.6 GHz, TDP 3.5W |
Chipset | Intel® NM10 Chipset, TDP1.5W |
Memory | Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0, 1*mSATA |
Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows XP/7, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM6 RS485 optional) |
USB | 6*USB 2.0 (2*on rear I/O, 4*header) |
Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | 3.5'', 146*105mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3553浏览量
88955 -
嵌入式主板
7文章
6086浏览量
35467 -
信步科技
7文章
263浏览量
7234
信步科技SV3-26026主板规格英文版
Intel Atom N2600 CPU, 6*COM, 2*LAN, 2*Mini-PCIe, DC 12V Input, 3.5'' (146*105mm)
信步科技SV3-26016-C主板规格英文版
Intel® Atom N2600 CPU, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V Input, 3.5'' (146*105mm)
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV1-H6116主板规格英文版
Intel 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
,支持多种双屏异显 规格 General CPU Intel Bay Trail J1900CPU, Quad-core, up to 2.42 GHz, TDP 10W Chipset Null
