Intel Atom D2550处理器, 6*COM, 2*LAN, 1*PCI, 1*Mini-PCIe, 可搭配DC 12V电源模块
规格
General | |
CPU | Intel® AtomTM D2550 CPU, Dual-core, 1.86 GHz, TDP 10W |
Chipset | Intel® NM10 Chipset, TDP 1.5W |
Memory | Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM |
Storage | 2*SATA 2.0 |
Expansion Interface | 1*PCI, 1*Mini-PCIe (Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows XP/7, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM3 TTL, COM6RS485 optional) |
USB | 7*USB 2.0 (4*on rear I/O, 3*header) |
Ethernet | 2*Realtek® PCI-E LAN for 100Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3515浏览量
88289 -
嵌入式主板
7文章
6084浏览量
35148 -
信步科技
6文章
263浏览量
7125
信步科技SV1-25526P-B主板规格英文版
Intel Atom D2550 CPU, 6*COM, 2*LAN, 1*PCI, 2*Mini-PCIe, DC 12V or 24V ATX Input (optional)
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
