Intel Atom D2550处理器, 4*COM, 1*LAN, 1*Mini-PCIe, DC 12V供电
规格
General | |
CPU | Intel® AtomTM D2550 CPU, Dual-core, up to 1.86 GHz, TDP 10W |
Chipset | Intel® NM10 Chipset, TDP 1.5W |
Memory | Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0, 1*mSATA |
Expansion Interface | 1*Mini-PCIe (mSATA Supported) |
BIOS | AMI UEFI BIOS |
System | Windows XP/7, Linux |
I/O Interface | |
Serial Port | 4*RS232 (COM3 TTL optional) |
USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifer |
PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz 1*LVDS: Single Channel 24bit, max resolution up to 1440*900@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3586浏览量
89924 -
嵌入式主板
7文章
6092浏览量
35836 -
信步科技
7文章
263浏览量
7381
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
信步科技SV1-13716P主板规格英文版
Intel Celeron 1037U CPU with NM70, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V or ATX Input (optional)
