Intel Bay Trail J1900处理器, 6*COM, 11*USB, 2*LAN, 2*Mini-PCIe, DC 12V供电
- 采用Intel Bay Trail J1900处理器
- 提供6*COM, 11*USB, 2*千兆LAN
- 提供1*VGA, 1*eDP, 支持双屏异显
- 提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
- 采用DC 12V供电
- 3.5英寸 (146*102mm)
规格
| General | |
| CPU | Intel® CeleronTM J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W |
| Chipset | Null |
| Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 2.0, 1*mSATA |
| Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux, Android |
| I/O Interface | |
| Serial Port | 6*RS232 |
| USB | 11*USB 2.0 (11*header) |
| Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
| Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifier |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 3.5'', 146*102mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6107浏览量
37191 -
安卓
5文章
2187浏览量
60608 -
信步科技
7文章
264浏览量
7976
热点推荐
华硕 P2B主板英文版说明书
华硕 P2B主板英文版说明书Before installing the memory modules, please comply with the following conditions:1.
发表于 02-23 15:58
•0次下载
信步科技SV3b-38626规格英文版
*Wifi+3G/4G)
Supports triple display of VGA, HDMI and LVDS/eDP
3.5'' (146*105mm)
规格
信步科技SV3b-62026规格英文版
Intel Skylake-U 6th Gen Core i5-6200U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3-19026主板规格英文版
Intel Bay Trail J1900 CPU, 6*COM, 2*LAN, 2*Mini-PCIe, DC 12V Input, 3.5'' (146*105mm)
信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
信步科技SV3-19026P-B主板规格英文版
Intel Bay Trail J1900 CPU, 6*COM, 11*USB, 2*LAN, 2*Mini-PCIe, DC 12V Input, 3.5'' (146*102mm)
信步科技SV1-31716P主板规格英文版
Intel® 3rd Gen Core i3-3217U CPU with HM76, 6*COM, 1*LAN, 2*Mini-PCIe, 1*Cash Drawer, DC 12V Input
信步科技SV3b-62026主板规格英文版
Intel Skylake-U Core i5-6200U处理器, 6*COM, 2*Intel千兆LAN, 2*Mini-PCIe, 背置CPU, 3.5寸 (146*105mm)
