Intel Celeron 1037U处理器, 10*COM, 2*LAN, 1*PCI-E 16X, 2*Mini-PCIe
- 采用Intel Celeron 1037U处理器
- 采用Intel NM70芯片组
- 提供10*COM, 7*USB, 2*千兆LAN
- 提供2*VGA, 1*LVDS, 支持多种双屏异显
- 提供1*PCI-E 16X, 2*Mini-PCIe
规格
| General | |
| CPU | Intel® CeleronTM 1037U CPU, Dual-core, 1.8 GHz,TDP 17W |
| Chipset | Intel® NM70 Chipset, TDP 4.1W |
| Memory | Up to 8 GB DDR3 1600/1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0, 2*SATA 2.0, 1*mSATA |
| Expansion Interface | 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7/8/10, Linux |
| I/O Interface | |
| Serial Port | 10*RS232 (COM3 RS485 optional) |
| USB | 7*USB 2.0 (4*on rear I/O, 3*header) |
| Ethernet | 2*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 2048*1536@75Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3710浏览量
94423 -
嵌入式主板
7文章
6107浏览量
37199 -
信步科技
7文章
264浏览量
7977
热点推荐
信步科技SV3b-38626规格英文版
Intel® Kaby Lake-U Celeron 3865U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel LAN
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
信步科技SV1-1372A-B主板规格英文版
