英创信息技术An Internship Summary
英创信息技术 来源:英创信息技术 作者:英创信息技术 2020-02-06 10:52 次阅读
Foreword:
This is a summary report by Zhiyuan Yang, a recent high school graduate and a soon-to-be freshman of University of Illinois at Urbana-Champaign class of 2021, electrical engineering major. The internship offers me an opportunity to learn more about programing, computer structures, and some hardware aspects of the boards Emtronix produces.
What I have done:
During the seven weeks,
I “assembled” a mini-computer Intel NUC5i7RYH. The word “assemble” here means putting RAM and an SSD hard-drive in the computer rather than building a computer from scratch. I also installed ubuntu on NUC, for two reasons. First ubuntu is free and fast. Second, it is an Linux operating system which provides a better C-language environment.
I self-studied a book called C Primer Plus in which I learned the fundamentals of the language C. Although I have not completed the whole book of 17 chapters, the first 13 chapters give me enough information to write a simple sorting program for the firm.
Usually around 5pm, I help out wrapping up products and preparing them to be picked up by SF express delivery. This working experience makes me realize how meticulous Emtronix is when it comes to the quality of the products. I recalled there was one time the screens sent out have minor display issues, but totally workable. However, Dr. Cheng still recalled all the products sent out, have them fixed to the perfect conditions, and then resent them to the customers. I also remembered that Dr. Cheng has a policy that once payment is received, products must be delivered out on that very day. After the delivery of products, Emtronix offers top-notch post-sale services and technical support. Engineers tend to the customers’ problems and questions with patience. If there are product problems, engineers would conduct experiments day and night, and work overtime willingly to solve them. Emtronix has shown me that in order to survive in a competitive market, excellent product quality is not enough; a company also needs to establish its reputation. Emtronix has already established itself as an enterprise of integrity, responsibility, and hospitality to customers. If one day I ever start my own firm, I shall also make it a reputable one as well.
Details on what I learned:
Software:
As a man with little knowledge on computer and programing, I begin my internship. The first obstacle I faced is that my computer won’t start up. I checked all kinds of sources on NUC, looked through E-guide, but failed to find the solution. I asked Canglong for help. He checked my device and had suspicions on RAM. We opened the computer and checked the RAM and it turned out the RAM was not completely plugged in. Later I knew that RAM actually stores all the data needed for the system to boot. Then I followed a link online on how to create a boot driver for ubuntu, and successfully installed ubuntu on NUC. Then I need an editor. Gedit came with the ubuntu system; it is very simple to use, like the txt documents on windows. Canglong advised me to use VIM, which is an editor that is harder to use, but once fluently used, it can be very efficient. He told me that Guangze was actually the master of Linux system and VIM in Emtronix. So I went to Guangze for guides and he later gave me some websites on Linux systems and how to use their command lines. What I found most useful is the vimtutor document in the VIM software. It introduces several key shortcuts like “R” to replace until ESC is entered or “r” to replace only one word. “v” to highlight and “dw” to delete word and “dd” to delete a whole line. VIM can also be customized. For example, at first my “tab” key will return me 8 blank spaces, which are too much, so I can change it to 4 blank spaces to look normal. Since I had all the software in place, I began to learn and practice C on my NUC.
C language learning:
The steps to learn C is pretty routine; I simply “learn and practice”. There are all kinds of syntaxes and rules of C that can be gradually understood, but to truly memorize them, one needs to apply them in real codes to be complied or what one will easily forget what he learned. Therefore, learning programing takes lots of time. I first start with different data types, like char, int, double, which are different data units the computer use to store data. I also learned operators which operate on data. Following operators, conditions and looping allow me branch my program more based on users’ input. Then I learned functions and how to call them. Then comes the arrays and file operations, pointers and data structure. And all of the knowledge I learned was used in the sorting program I wrote. I choose bubble sort, an easy way to write to conduct a complete sort. However, it is not the most efficient way to sort data, as it went through all the data and sort two by two. This would consume lots of CPU power, though it works pretty fast on PC. My program works, but there are still room for improvement.
Hardware:
In this internship, I also gain more understanding on the hardware aspects of the circuit boards Emtronix produces. Dr. Cheng gave me a set of schematics of one of the “simplest” tablets the company designs (but it still has ten pages long), and a multimeter so I could check if there are any defects in the recent shipment of this board. There are only several things to measure. First, I checked whether all the capacitors are soldered in the right place. Because some capacitors are polarized, if they are soldered reversely, the circuit may short and tiny explosion may happen. Secondly, I checked whether all the diodes are soldered correctly. I used my multimeter to check whether one-way there are certain ohms of resistance and the other-way the resistance tends to infinity. Finally, I measured the resistance of the whole circuit. It should be very large, in unit of M ohms. Then I powered it up, and checked the voltages are correct. When I was met with defects, I usually use elimination to approach the problem. As many electrical components are wired parallelly, I need to use solder to take some off and measure them individually. Soldering is a very delicate job. I watched Yating solder off some components and copied her methods, but I did a terrible job. So I went to Mrs. Dai for help, as I was told she is the leader of soldering in Emtronix. She taught me the essence of soldering “add more fusible alloy”; there are two reasons. In sum, the most important parts of soldering are temperature and contact area. I need to add more fusible alloy to the spot being soldered, because this increase in contact area improves heat conduction and better let components to come off and on. I practiced a few hours on old circuit boards , and I think I improved quite a lot when soldering the second time, to remove and put back some diodes. All the components I removed were fine, but I actually fixed one of the tablets. I guess previously the diodes were not soldered very firmly.
Acknowledgements:
I would like to express my deep gratitude toward Dr. Cheng and my mom for giving me the opportunity and support me and guide me the whole way. I would also like to give thanks to my colleagues who patiently answered all my questions!
  • WINDOWS
  • 嵌入式主板
    龙芯中科荣获2024年度信息技术应用创新工作委员会卓越贡献成员单位
    近日,中国电子工业标准化技术协会信息技术应用创新工作委员会(以下简称“信工委会”)在北京召开2024年度工作总结座谈会暨信“大比武”总结大会。中国工程院院士、信
    的头像 发表于 01-23 10:50 283次阅读
    芯盛智能荣获2024年信息技术应用创新工作委员会卓越贡献成员单位
    日前,中国电子工业标准化技术协会信息技术应用创新工作委员会(以下简称 “信工委会”)2024 年度总结座谈会于北京隆重举行。此次会议对在信工作中作出突出贡献的成员单位予以表彰。江苏
    的头像 发表于 01-20 09:56 279次阅读
    中科曙光南京研究院方案入选江苏省信息技术创新优秀解决方案
    近日,中科曙光南京研究院传来喜讯,其精心申报的《高端计算与分布式存储一体化解决方案》(以下简称“方案”)成功脱颖而出,荣耀入选“2024年江苏省信息技术应用创新优秀解决方案”名单。 这一殊荣不仅是
    的头像 发表于 01-08 15:41 331次阅读
    华砺智行亮相第十六届中国(济南)国际信息技术博览会
    近日,为期三天的的第十六届中国(济南)国际信息技术博览会在济南黄河国际会展中心圆满落幕。本次盛会汇聚行业精英,以“展览+会议+大赛+场景体验”的办会模式,全面展示了信息技术领域的最新成果与创新趋势。
    的头像 发表于 12-27 13:40 227次阅读
    飞腾助力首届教育信息技术应用创新大赛圆满落幕
    近日,由中国教育技术协会主办,教育部教育管理信息中心教育信实验室、公安部第三研究所、中国电子工业标准化技术协会信工委会支持,北京航空航天
    的头像 发表于 12-24 09:57 273次阅读
    有方科技参编的信息技术团体标准发布
    近日,有方科技参编的《信息技术产品供应链成熟度 共性指标 第1部分:企业背景评价》《信息技术产品供应链成熟度 共性指标 第2部分:技术掌控评价》《信息技术产品供应链成熟度 共性指标 第
    的头像 发表于 12-23 10:44 356次阅读
    龙芯中科助力2024首届教育信息技术应用创新大赛成功举办
    近日,2024首届教育信息技术应用创新大赛在北京航空航天大学成功举办。本次大赛由中国教育技术协会主办,教育信实验室、公安部第三研究所、中国电子工业标准化技术协会信
    的头像 发表于 12-19 17:02 335次阅读
    拓维信息参与牵头组建!长沙新一代信息技术产教联合体正式获批
    的长沙新一代信息技术产教联合体成功获批,为长沙市信息技术产业发展注入了新的活力。图/《2024年长沙市市级市域产教联合体名单》长沙新一代信息技术产教联合体将依托龙头企
    的头像 发表于 12-07 01:06 549次阅读
    拓维<b class='flag-5'>信息</b>参与牵头组建!长沙新一代<b class='flag-5'>信息技术</b>产教联合体正式获批
    中科达荣获2024年软件和信息技术服务优秀企业
    及前百家企业”名单。中科达凭借非凡的技术实力与持续的创新能力,成功入选“2024年度软件和信息技术服务竞争力百强企业”以及“2024年软件和信息技术服务优秀企业”。
    的头像 发表于 10-30 11:44 622次阅读
    国产化背景下的工控主板发展现状
    ,是信息技术应用创新产业的简称,于2016年“信工委会”(信息技术应用创新工作委员会)提出,目的就是要推动我们国内软硬件关键技术的研发
    的头像 发表于 09-21 16:15 610次阅读
    加速鲲鹏落地!拓维信息迁移工具荣获鲲鹏原生开发技术认证
    认证。图/拓维·数据库适配中间件取得鲲鹏原生开发N认证在数字化时代的大潮中,信战略作为国家推动信息技术应用创新、保障信息安全与自主可控的关键举措,其重要性日益凸显
    的头像 发表于 09-10 08:03 571次阅读
    加速鲲鹏落地!拓维<b class='flag-5'>信息</b>信<b class='flag-5'>创</b>迁移工具荣获鲲鹏原生开发<b class='flag-5'>技术</b>认证
    梯度科技入选2023年信息技术应用创新解决方案名单
    日前,工业和信息化部网络安全产业发展中心(工业和信息化部信息中心)在天津举办2024信息技术应用创新发展大会暨解决方案应用推广大会。会上正式公布了2023年
    的头像 发表于 09-09 16:29 536次阅读
    中软国际信服务助力大连信产业发展
    为进一步激发大连本地信产业生态的活力与潜力,搭建一个高效、开放的交流平台。由大连软件行业协会携手大连市信息技术应用创新综合服务中心主办,中软国际协办的,2024年大连市信息技术应用创新产业发展大会
    的头像 发表于 08-27 16:49 1037次阅读
    翼辉信息入选2023年信息技术应用创新解决方案名单
    近日,2023 年(第五届)信息技术应用创新解决方案公布遴选名单,历经资格初审、技术中评、区域评议、终评预审,翼辉以“面向工业领域嵌入式操作系统 SylixOS 解决方案”,成功在全国优秀方案中脱颖而出,入选典型解决方案名单。
    的头像 发表于 04-28 11:37 707次阅读
    翼辉<b class='flag-5'>信息</b>入选2023年<b class='flag-5'>信息技术</b>应用创新解决方案名单
    股份今日登陆科
    山东中软件商用中间件股份有限公司(以下简称“中股份”)近日在上海证券交易所科板成功上市,标志着这家国内知名的民营软件和信息技术服务企业正式进入资本市场,迎来全新的发展机遇。
    的头像 发表于 03-13 14:19 650次阅读
