如何使用MATLAB GUI从基于Arduino的IR转速表读取RPM
454398 来源:网络整理 作者:网络整理 2019-11-21 16:37 次阅读
步骤1:在MATLAB
打开您的MATLAB,然后键入命令:“ guide”
如果一切正常,将打开一个窗口供您设计布局。如果无法获取该窗口,请检查您的MATLAB安装中是否包含该模块。我的MATLAB版本是R2012b,安装了默认设置和软件包。
让我们假设您在输入“指南”后会感觉很好。放置窗口组件如下:
-1切换按钮
-2静态文本
按图片所示排列布局(实际上,布局要只要您易于使用和阅读,就可以通过修改属性检查器中的“字符串”值来更改每个对象中的文本(任何您想要的内容)(选择对象-右键单击-属性检查器,或双击)
然后,保存该GUI图形文件。
步骤2:编写代码
ARDUINO代码
arduino的代码与您在此处可以找到的代码基本相同:https://www.instructables.com/id/Infrared-Tachomete 。..但因为这里我仅想要显示rpm值(而不是rps值以及所有的“ rps”和“ rpm”文本),所以我编辑了一些行(那些具有Serial.print()的行,因为以前该程序旨在显示读数在记事本式串行监视器上,但现在我们只需要rpm值即可输入到静态文本字符串中)。好的,为了方便快捷,我将代码复制到此处,您可以自行检查以与之前的代码进行比较。请记住,arduino代码的主要目的只是将值传递给串行comm,因此该程序仅作为示例,如果您有自己的程序将任何读取到的传感器的值打印到串行,然后忽略此操作即可。
int sensorvalue;
int state1 = HIGH;
int state2;
float rps;
float rpm;
long prevMillis = 0;
long interval = 100;
long currentTime;
long prevTime = 1;
long diffTime;
int sensorthreshold = 30; // this value indicates the limit reading between dark and light,
// it has to be tested as it may change acording on the
// distance the leds are placed.
// to see what number is good, check the sensorvalue variable value
// as printed out in the serial monitor
void setup()
Serial.begin(9600);
pinMode(13,OUTPUT); // assign pin 13 led as indicator because we cannot se the IR light
void loop()
sensorvalue = analogRead(0); // read from pin 0
if(sensorvalue 《 sensorthreshold)
state1 = HIGH;
else
state1 = LOW;
digitalWrite(13,state1); // as iR light is invisible for us, the led on pin 13
// indicate the state of the circuit.
if(state2!=state1){ //counts when the state change, thats from (dark to light) or
//from (light to dark), remember that IR light is invisible for us.
if (state2》state1){
currentTime = micros(); // Get the arduino time in microseconds
diffTime = currentTime - prevTime; // calculate the time difference from the last sensors meet-up
rps = 1000000/diffTime; // calculate how many rev per second - good to know
rpm = 60000000/diffTime; // calculate how many rev per minute
unsigned long currentMillis = millis();
// print to serial at every interval - defined at the variables declaration
if(currentMillis - prevMillis 》 interval){ // see if now already an interval long
prevMillis = currentMillis;
Serial.println(rpm); // this line is edited from the code in the prev instructable
prevTime = currentTime;
state2 = state1;
/* only for testing to determine the sensorthreshold value
delay(500);
Serial.println(sensorvalue);
MATLAB代码
在MATLAB GUI布局设计窗口中,单击“查看-编辑器”(或在工具栏中找到没有手的纸和铅笔的图片)。将打开一个编辑器窗口,其中已经编写了一些代码,MATLAB为您编写了它们,没问题。只为切换按钮编写回调函数,其余代码可以保留不变。就我而言,我将切换按钮命名为OnOffToggle,因此编写代码的函数是函数OnOffToggle_Callback(hObject,eventdata,handles)。 rpmdata,所以我们只想将rpm数据打印到屏幕上即可。还有一件事,请确保在编写代码时将arduino连接到正确的COM端口。在这段代码中,我写了COM3,因为我将arduino连接到了COM3。
然后保存您的m文件。
下面是完整代码(仅编辑OnOffToggle_Callback函数):
function varargout = gui(varargin)
% GUI MATLAB code for gui.fig
% GUI, by itself, creates a new GUI or raises the existing
% singleton*.
% H = GUI returns the handle to a new GUI or the handle to
% the existing singleton*.
% GUI(‘CALLBACK’,hObject,eventData,handles,。..) calls the local
% function named CALLBACK in GUI.M with the given input arguments.
% GUI(‘Property’,‘Value’,。..) creates a new GUI or raises the
% existing singleton*. Starting from the left, property value pairs are
% applied to the GUI before gui_OpeningFcn gets called. An
% unrecognized property name or invalid value makes property application
% stop. All inputs are passed to gui_OpeningFcn via varargin.
% *See GUI Options on GUIDE‘s Tools menu. Choose “GUI allows only one
% instance to run (singleton)”。
% See also: GUIDE, GUIDATA, GUIHANDLES
% Edit the above text to modify the response to help gui
% Last Modified by GUIDE v2.5 14-Mar-2015 01:06:09
% Begin initialization code - DO NOT EDIT
gui_Singleton = 1;
gui_State = struct(’gui_Name‘, mfilename, 。..
’gui_Singleton‘, gui_Singleton, 。..
’gui_OpeningFcn‘, @gui_OpeningFcn, 。..
’gui_OutputFcn‘, @gui_OutputFcn, 。..
’gui_LayoutFcn‘, [] , 。..
’gui_Callback‘, []);
if nargin && ischar(varargin{1})
gui_State.gui_Callback = str2func(varargin{1});
end
if nargout
[varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
else
end
% End initialization code - DO NOT EDIT
% --- Executes just before gui is made visible.
function gui_OpeningFcn(hObject, eventdata, handles, varargin)
% This function has no output args, see OutputFcn.
% hObject handle to figure
% eventdata reserved - to be defined in a future version of MATLAB
% handles structure with handles and user data (see GUIDATA)
% varargin command line arguments to gui (see VARARGIN)
% Choose default command line output for gui
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes gui wait for user response (see UIRESUME)
% uiwait(handles.figure1);
% --- Outputs from this function are returned to the command line.
function varargout = gui_OutputFcn(hObject, eventdata, handles)
% varargout cell array for returning output args (see VARARGOUT);
% Get default command line output from handles structure
varargout{1} = handles.output;
function currentEdit_Callback(hObject, eventdata, handles)
function currentEdit_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
% See ISPC and COMPUTER.
if ispc && isequal(get(hObject,’BackgroundColor‘), get(0,’defaultUicontrolBackgroundColor‘))
set(hObject,’BackgroundColor‘,’white‘);
end
function OnOffToggle_Callback(hObject, eventdata, handles)
button_state = get(hObject,’Value‘);
if button_state == get(hObject,’Max‘)
set(handles.OnOffToggle,’String‘,’Stop‘);
drawnow;
i=2;
while i 》 1
rpmdata = serial(’COM3‘,’BaudRate‘,9600); % this Baud rate should be the same as that in Arduino code
fclose(instrfindall);
fopen(rpmdata);
b = fscanf(rpmdata);
set(handles.textCurrent,’String‘,b);
drawnow;
delete(rpmdata)
if get(hObject,’Value‘) == get(hObject,’Min‘)
break
end
end
set(handles.OnOffToggle,’String‘,’Start‘);
drawnow;
fclose(rpmdata);
end
步骤3:运行Rpm Reader
完成代码后,连接arduino,然后转动旋转并运行程序(编辑器或布局编辑器窗口上的绿色三角形类似游戏的按钮)。程序的一个窗口将会出现(我的如图所示),单击切换按钮,您将在那里看到车轮的当前转速。
责任编辑:wv
  • matlab
  • Arduino
  • RPM
    RPM
    用于课题的无线转速霍尔传感器,新人应该哪里开始学习
    完全没电路的基础,但是课题上导师要求设计一款无线的霍尔转速传感器,电池供电然后通过无线技术去读取传感器上的转速。想请教下各位大佬应该哪里开始学习比较好,或者是有现成的产品可以去模仿学
    发表于 01-08 10:36
    霍尔开关AH402F在转速表中的应用,替换HAL1881和SS460
    的头像 发表于 12-09 10:02 250次阅读
    霍尔开关AH402F在<b class='flag-5'>转速表</b>中的应用,替换HAL1881和SS460
    2010款起亚赛拉图车发动机转速表指针不动
    2010款起亚赛拉图车发动机转速表指针不动广西普鑫泽源汽车销售服务有限公司李康林故障现象故障诊断故障排除一辆2010款起亚赛拉图车,搭载G4ED发动机,累计行驶里程约为17.2万km。车主反映,车辆
    的头像 发表于 10-31 08:03 300次阅读
    2010款起亚赛拉图车发动机<b class='flag-5'>转速表</b>指针不动
    集成IR R600数据
    电子发烧友网站提供《集成IR R600数据.pdf》资料免费下载
    发表于 09-04 11:26 0次下载
    Arduino Nano 和 NodeMCU ESP8266 读取 DHT11 环境温湿度数据及 OLED显示
    的头像 发表于 08-13 18:04 1436次阅读
    <b class='flag-5'>Arduino</b> Nano 和 NodeMCU ESP8266 <b class='flag-5'>读取</b> DHT11 环境温湿度数据及 OLED显示
    变频器怎么外接电流转速表
    需要外接电流转速表来测量电机的电流和转速。 电流的作用 电流是一种测量电路中电流大小的仪器。在变频器系统中,电流
    的头像 发表于 07-19 11:17 2941次阅读
    简单转速表电路图 转速表的定义和应用
    转速表,顾名思义,是用来测量和显示旋转设备转速的仪表。它通常被安装在需要监测转速的设备上,如汽车发动机、电机、风扇、造纸机、塑料加工机械等。转速表通过接收并处理来自旋转设备的信号,将其
    的头像 发表于 07-10 17:33 2254次阅读
    简单<b class='flag-5'>转速表</b>电路图 <b class='flag-5'>转速表</b>的定义和应用
    来写个代码,改变你的电机转速
    一、KV值"KV值"是一个常用的参数,它表示电机的转速常数。KV值定义为电机在无负载条件下,每增加1伏特电压时,电机转速增加的转数(rpm)。换句话说,KV值是电机转速与供电电压
    的头像 发表于 07-03 08:10 1268次阅读
    来写个代码,改变你的电机<b class='flag-5'>转速</b>
    MATLAB GUI的暂停执行与继续执行问题
    MATLAB小白发问,各位大神,我想在GUI界面放一个或者两个按钮,实现程序的暂停和继续执行,比如:1到100计数,计到45,按暂停键暂停,再按或者按另一个按钮,继续计数,46开始
    发表于 06-21 12:34
    电机转速快好还是转速慢好一点
    在讨论电机转速快好还是转速慢好之前,我们需要了解电机转速的概念以及其在不同应用场景中的作用。电机转速是指电机转子每分钟旋转的圈数,通常用转每分钟(R
    的头像 发表于 06-05 11:18 3056次阅读
    电机转速快怎么可以让它转慢点
    电机是一种将电能转换为机械能的装置,广泛应用于工业、农业、交通等领域。电机的转速是指电机转子每分钟旋转的圈数,通常用转每分钟(RPM)来表示。 1.2 影响电机转速的因素 电机转速
    的头像 发表于 06-05 11:14 5933次阅读
    日本制造的110V交流无刷电机
    有哪个大佬知道这是日本哪个品牌的无刷电机,怎么接调速器,怎么接转速表,要接哪几条线,求大佬指点一下
    发表于 05-15 18:23
    Profile电机的时候转速显示NaN RPM是什么意思?
    Profile电机的时候转速显示NaN RPM,什么意思?
    发表于 04-12 07:28
    如何使用GPIO上的开关改变Sensorless BLDC转速?
    请问各位先进 可否于程序中使用连接在GPIO上的开关,透过HAL_GPIO库+MC库改变SensorlessBLDC转速 例如开关off,BLDC=5000RPM 开关on, BLDC=20000RPM 有范例代码可参考吗?谢
    发表于 04-02 07:22
    STMCK中MC_ProgramSpeedRampMotor1函数设置的最低转速是多少?
    使用电机库电机可以达到最高转速,但是如果设置小了,某个方向基本不转, 比如最高转速5000RPM,使用MC_ProgramSpeedRampMotor1(5000/6/50,0)设置后应该就是5000/50=100
    发表于 03-27 07:14
