AR1021X使用hostapd配置AP热点注意事项
通信模块 2019-10-11 23:15 次阅读
在应用AR1021X模块化集成时,一些应用需要用模块来做soft ap使用,这就牵涉到hostapd配置问题,如果配置不好,是没有SSID热点出来!模块有支持双频的,有只支持单频的,具体要认真阅读模块规格书,所以配置的时候要留意!
一般根据对应的Kernel内核版本提供的驱动包,保障物理连接正常,供电稳定,正常编译驱动后,就能加载成功,并正常使用!
以下案例现象:使用hostapd配置AP热点,ap热点出不来!
log信息如下:
ostapd -dd -e /dev/urandom /etc/hostapd.conf &
# random: Invalid entropy file /dev/urandom
random: TryinADDRCONF(NETDEV_UP): wlan0: link is not ready
g to read entropy from /dev/random
Get randomness: len=20 entropy=0
random: Updated entropy file /dev/urandom (own_pool_ready=0)
Configuration file: /etc/hostapd.conf
nl80211: interface wlan0 in phy phy0
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
nl80211: Supports Probe Response offload in AP mode
nl80211: Disable use_monitor with device_ap_sme since no monitor mode support detected
nl80211: Add own interface ifindex 4
nl80211: Set mode ifindex 4 iftype 3 (AP)
nl80211: Setup AP - device_ap_sme=1 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x102ee00 (device SME)
nl80211: Register frame type=0xd0 nl_handle=0x102ee00
nl80211: Register frame match - hexdump(len=0): [NULL]
nl80211: Enable Probe Request reporting nl_preq=0x102ed98
nl80211: Register frame type=0x40 nl_handle=0x102ed98
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Regulatory information - country=US
nl80211: 2402-2472 @ 40 MHz
nl80211: 5170-5250 @ 40 MHz
nl80211: 5250-5330 @ 40 MHz
nl80211: 5490-5730 @ 40 MHz
nl80211: 5735-5835 @ 40 MHz
nl80211: Added 802.11b mode based on 802.11g information
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=30 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=30 dBm
Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=30 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=30 dBm
Completing interface initialization
Mode: IEEE 802.11g Channel: 6 Frequency: 2437 MHz
nl80211: Set freq 2437 (ht_enabled=1 sec_channel_offset=0)
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
wlan0: Flushing old station entries
wlan0: Deauthenticate all stations
wpa_driver_nl80211_set_key: ifindex=4 alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlan0 with hwaddr 38:e2:6e:0c:04:1f and ssid 'ar1021_wifi'
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=11):
61 72 31 30 32 31 5f 77 69 66 69 ar1021_wifi
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
random: Cannot read from /dev/random: Resource tempoADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
rarily unavailable
random: Got 0/20 bytes from /dev/random
random: Only 0/20 bytes of strong random data available from /dev/random
random: Not enough entropy pool available for secure operations
WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
Get randomness: len=32 entropy=0
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
hostapd_eid_deny_mac num_deny_mac:0
hostapd_eid_accept_mac num_accept_mac:0
nl80211: Set beacon (beacon_set=0)
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
Get randomness: len=16 entropy=0
GTK - hexdump(len=32): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=4 alg=2 addr=0x6a828 key_idx=1 set_tx=1 seq_len=0 key_len=32
broadcast key
wpa_driver_nl80211_set_operstate: operstate 0->1 (UP)
netlink: Operstate: linkmode=-1, operstate=6
Failed to set TX queue parameters for queue 0.
Failed to set TX queue parameters for queue 1.
Failed to set TX queue parameters for queue 2.
Failed to set TX queue parameters for queue 3.
wlan0: Setup of interface done.
RTM_NEWLINK: operstate=1 ifi_flags=0x1002 ()
nl80211: Ignore interface down event since interface wlan0 is up
RTM_NEWLINK: operstate=1 ifi_flags=0x1043 ([UP][RUNNING])
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
nl80211: if_removed already cleared - ignore event
RTM_NEWLINK: operstate=1 ifi_flags=0x1003 ([UP])
nl80211: Event message available
nl80211: Regulatory domain change
wlan0: Event CHANNEL_LIST_CHANGED (31) received
Unknown event 31
Unknown event 31
RTM_NEWLINK: operstate=1 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
RTM_NEWLINK: operstate=1 ifi_flags=0x11003 ([UP][LOWER_UP])
hostapd.conf配置如下:
interface=wlan0
driver=nl80211
ssid=ar1021_wifi
channel=6
hw_mode=g
ignore_broadcast_ssid=0
auth_algs=1
wpa=3
wpa_passphrase=88888888
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
iwconfig:
# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
wlan0 IEEE 802.11abgn Mode:Master Frequency:2.437 GHz Tx-Power=17 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
p2p0 IEEE 802.11abgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=17 dBm
Encryption key:off
以上信息很明显,是针对只能支持ISM5.8G频段的模块,hostapd.conf配置成了ISM2.4G,只要进行重新配置就可以了!同时提醒,双频是分时双频,也就是工作时候只能支持一种,但是有两种频供选!或者理解成双频供选择,实际选用一种!
针对AR1021X系列WiFi模块(SR6225UE、SR6224UE、SR6221UE、SR6235UE、SR5223UD),编译加载的问题,可以提供Log信息,配合有效分析!
  • AR1021X
    如何为住宅配置静态IP:步骤与注意事项
    为住宅配置静态IP地址,通常涉及以下步骤和注意事项
    的头像 发表于 10-24 08:02 218次阅读
    ADS855x的驱动器电路设计注意事项
    电子发烧友网站提供《ADS855x的驱动器电路设计注意事项.pdf》资料免费下载
    发表于 10-18 11:50 0次下载
    ADS855<b class='flag-5'>x</b>的驱动器电路设计<b class='flag-5'>注意事项</b>
    TMS320DM644x注意事项
    电子发烧友网站提供《TMS320DM644x注意事项.pdf》资料免费下载
    发表于 10-16 11:35 0次下载
    TMS320DM644<b class='flag-5'>x</b>热<b class='flag-5'>注意事项</b>
    DM64xx、DM64x和C6000器件的散热注意事项
    电子发烧友网站提供《DM64xx、DM64x和C6000器件的散热注意事项.pdf》资料免费下载
    发表于 10-15 09:15 0次下载
    DM64xx、DM64<b class='flag-5'>x</b>和C6000器件的散热<b class='flag-5'>注意事项</b>
    PLC应用中的AM335x可靠性注意事项
    电子发烧友网站提供《PLC应用中的AM335x可靠性注意事项.pdf》资料免费下载
    发表于 10-12 11:33 0次下载
    PLC应用中的AM335<b class='flag-5'>x</b>可靠性<b class='flag-5'>注意事项</b>
    绕线电感定制的注意事项
    电子发烧友网站提供《绕线电感定制的注意事项.docx》资料免费下载
    发表于 09-20 11:24 0次下载
    AM574x散热注意事项
    电子发烧友网站提供《AM574x散热注意事项.pdf》资料免费下载
    发表于 09-19 11:25 0次下载
    AM574<b class='flag-5'>x</b>散热<b class='flag-5'>注意事项</b>
    调试SsitaraAM2x单片机注意事项
    电子发烧友网站提供《调试SsitaraAM2x单片机注意事项.pdf》资料免费下载
    发表于 09-11 14:13 0次下载
    调试SsitaraAM2<b class='flag-5'>x</b>单片机<b class='flag-5'>注意事项</b>
    CC13xx/CC26xx硬件配置和PCB设计注意事项
    电子发烧友网站提供《CC13xx/CC26xx硬件配置和PCB设计注意事项.pdf》资料免费下载
    发表于 09-03 11:12 0次下载
    CC13xx/CC26xx硬件<b class='flag-5'>配置</b>和PCB设计<b class='flag-5'>注意事项</b>
    采用高侧N-MOSFET的堆叠式BQ769x2设计注意事项
    电子发烧友网站提供《采用高侧N-MOSFET的堆叠式BQ769x2设计注意事项.pdf》资料免费下载
    发表于 08-27 10:10 0次下载
    采用高侧N-MOSFET的堆叠式BQ769<b class='flag-5'>x</b>2设计<b class='flag-5'>注意事项</b>
    InModbus2配置文件的注意事项
    大家好,由于最近经常有人问我InModbus2的配置文件如何编辑来达到想要的结果,所以发布一些关于InModbus2的配置文件注意事项,后期我还会发布一些示例来供大家参考让大家都掌握一些简单
    发表于 07-26 07:21
    芯海通用 MCU 应用笔记:CS32F03x设计注意事项
    本技术文档汇总了 CS32F03x (包括 RA) 在设计,开发,调试过程中经常遇到的问题和需要注意事项,旨在帮忙用户快速使用 CS32F03x系列 MCU。*附件:应用笔记:CS3
    发表于 05-16 11:02
    FMD LINK 使用注意事项
    电子发烧友网站提供《FMD LINK 使用注意事项.pdf》资料免费下载
    发表于 05-06 10:11 0次下载
    CYW43455 hostapd配置5G 80MHZ启AP失败怎么解决?
    I.M6 +CYW43455模块, 用hostapd 配置5G 11ac 80MHZ 启AP 失败,11ac 40mhz 是正常的。 确认CYW43455的规格是是支持11ac 80MHZ的带宽
    发表于 03-01 14:03
    浪涌抑制器的应用及注意事项
    浪涌抑制器的应用及注意事项?|深圳比创达电子
    的头像 发表于 01-19 09:55 719次阅读
    浪涌抑制器的应用及<b class='flag-5'>注意事项</b>?
