ATMEL ARM7TDMI 内核芯片
Device Name | Flash (Kbytes) | Pin Count | Max. Operating Frequency | CPU |
AT91M40800 | 0 | 100 | 40 | ARM7TDMI |
AT91M42800A | 0 | 144 | 33 | ARM7TDMI |
AT91M55800A | 0 | 176 | 33 | ARM7TDMI |
AT91R40008 | 0 | 100 | 75 | ARM7TDMI |
AT91SAM7L128 | 128 | 144 | 36 | ARM7TDMI |
AT91SAM7L64 | 64 | 144 | 36 | ARM7TDMI |
AT91SAM7S128 | 128 | 64 | 55 | ARM7TDMI |
AT91SAM7S16 | 16 | 48 | 55 | ARM7TDMI |
AT91SAM7S161 | 16 | 64 | 55 | ARM7TDMI |
AT91SAM7S256 | 256 | 64 | 55 | ARM7TDMI |
AT91SAM7S32 | 32 | 48 | 55 | ARM7TDMI |
AT91SAM7S321 | 32 | 64 | 55 | ARM7TDMI |
AT91SAM7S512 | 512 | 64 | 55 | ARM7TDMI |
AT91SAM7S64 | 64 | 64 | 55 | ARM7TDMI |
AT91SAM7SE256 | 256 | 144 | 48 | ARM7TDMI |
AT91SAM7SE32 | 32 | 144 | 48 | ARM7TDMI |
AT91SAM7SE512 | 512 | 144 | 48 | ARM7TDMI |
AT91SAM7X128 | 128 | 100 | 55 | ARM7TDMI |
AT91SAM7X256 | 256 | 100 | 55 | ARM7TDMI |
AT91SAM7X512 | 512 | 100 | 55 | ARM7TDMI |
AT91SAM7XC128 | 128 | 100 | 55 | ARM7TDMI |
AT91SAM7XC256 | 256 | 100 | 55 | ARM7TDMI |
AT91SAM7XC512 | 512 | 100 | 55 | ARM7TDMI |
ATMEL ARM920 内核芯片
AT91RM9200 | 0 | 256 | 180 | ARM920 |
ATMELARM926内核芯片
AT91SAM9260 | 0 | 217 | 210 | ARM926 |
AT91SAM9261 | 0 | 217 | 190 | ARM926 |
AT91SAM9263 | 0 | 324 | 240 | ARM926 |
AT91SAM9CN11 | 217 | 400 | ARM926 | |
AT91SAM9CN12 | 217 | 400 | ARM926 | |
AT91SAM9G10 | 0 | 217 | 266 | ARM926 |
AT91SAM9G15 | 0 | 217 | 400 | ARM926 |
AT91SAM9G20 | 0 | 217 | 400 | ARM926 |
AT91SAM9G25 | 0 | 217 | 400 | ARM926 |
AT91SAM9G35 | 0 | 217 | 400 | ARM926 |
AT91SAM9G45 | 0 | 324 | 400 | ARM926 |
AT91SAM9G46 | 0 | 324 | 400 | ARM926 |
AT91SAM9M10 | 0 | 324 | 400 | ARM926 |
AT91SAM9M11 | 0 | 324 | 400 | ARM926 |
AT91SAM9N12 | 217 | 400 | ARM926 | |
AT91SAM9R64 | 0 | 144 | 240 | ARM926 |
AT91SAM9RL64 | 0 | 217 | 240 | ARM926 |
AT91SAM9X25 | 0 | 217 | 400 | ARM926 |
AT91SAM9X35 | 0 | 217 | 400 | ARM926 |
AT91SAM9XE128 | 128 | 217 | 180 | ARM926 |
AT91SAM9XE256 | 256 | 217 | 180 | ARM926 |
AT91SAM9XE512 | 512 | 217 | 180 | ARM926 |
ATMELCortex-M0+内核芯片
ATSAM D20E15 | 32 | 32 | 48 | Cortex-M0+ |
ATSAMD20E14 | 16 | 32 | 48 | Cortex-M0+ |
ATSAMD20E16 | 64 | 32 | 48 | Cortex-M0+ |
ATSAMD20E17 | 128 | 32 | 48 | Cortex-M0+ |
ATSAMD20G14 | 16 | 48 | 48 | Cortex-M0+ |
ATSAMD20G15 | 32 | 48 | 48 | Cortex-M0+ |
ATSAMD20G16 | 64 | 48 | 48 | Cortex-M0+ |
ATSAMD20G17 | 128 | 48 | 48 | Cortex-M0+ |
ATSAMD20G18 | 256 | 48 | 48 | Cortex-M0+ |
ATSAMD20J14 | 16 | 64 | 48 | Cortex-M0+ |
ATSAMD20J15 | 32 | 64 | 48 | Cortex-M0+ |
ATSAMD20J16 | 64 | 64 | 48 | Cortex-M0+ |
ATSAMD20J17 | 128 | 64 | 48 | Cortex-M0+ |
ATSAMD20J18 | 256 | 64 | 48 | Cortex-M0+ |
ATMELCortex-M3内核芯片
ATSAM3A4C | 256 | 100 | 84 | Cortex-M3 |
ATSAM3A8C | 512 | 100 | 84 | Cortex-M3 |
ATSAM3N00A | 16 | 48 | 48 | Cortex-M3 |
ATSAM3N00B | 16 | 64 | 48 | Cortex-M3 |
ATSAM3N0A | 32 | 48 | 48 | Cortex-M3 |
ATSAM3N0B | 32 | 64 | 48 | Cortex-M3 |
ATSAM3N0C | 32 | 100 | 48 | Cortex-M3 |
ATSAM3N1A | 64 | 48 | 48 | Cortex-M3 |
ATSAM3N1B | 64 | 64 | 48 | Cortex-M3 |
ATSAM3N1C | 64 | 100 | 48 | Cortex-M3 |
ATSAM3N2A | 128 | 48 | 48 | Cortex-M3 |
ATSAM3N2B | 128 | 64 | 48 | Cortex-M3 |
ATSAM3N2C | 128 | 100 | 48 | Cortex-M3 |
ATSAM3N4A | 256 | 48 | 48 | Cortex-M3 |
ATSAM3N4B | 256 | 64 | 48 | Cortex-M3 |
ATSAM3N4C | 256 | 100 | 48 | Cortex-M3 |
ATSAM3S1A | 64 | 48 | 64 | Cortex-M3 |
ATSAM3S1B | 64 | 64 | 64 | Cortex-M3 |
ATSAM3S1C | 64 | 100 | 64 | Cortex-M3 |
ATSAM3S2A | 128 | 48 | 64 | Cortex-M3 |
ATSAM3S2B | 128 | 64 | 64 | Cortex-M3 |
ATSAM3S2C | 128 | 100 | 64 | Cortex-M3 |
ATSAM3S4A | 256 | 48 | 64 | Cortex-M3 |
ATSAM3S4B | 256 | 64 | 64 | Cortex-M3 |
ATSAM3S4C | 256 | 100 | 64 | Cortex-M3 |
ATSAM3S8B | 512 | 64 | 64 | Cortex-M3 |
ATSAM3S8C | 512 | 100 | 64 | Cortex-M3 |
ATSAM3SD8B | 512 | 64 | 64 | Cortex-M3 |
ATSAM3SD8C | 512 | 100 | 64 | Cortex-M3 |
ATSAM3U1C | 64 | 100 | 96 | Cortex-M3 |
ATSAM3U1E | 64 | 144 | 96 | Cortex-M3 |
ATSAM3U2C | 128 | 100 | 96 | Cortex-M3 |
ATSAM3U2E | 128 | 144 | 96 | Cortex-M3 |
ATSAM3U4C | 256 | 100 | 96 | Cortex-M3 |
ATSAM3U4E | 256 | 144 | 96 | Cortex-M3 |
ATSAM3X4C | 256 | 100 | 84 | Cortex-M3 |
ATSAM3X4E | 256 | 144 | 84 | Cortex-M3 |
ATSAM3X8C | 512 | 100 | 84 | Cortex-M3 |
ATSAM3X8E | 512 | 144 | 84 | Cortex-M3 |
ATMELCortex-M4内核芯片
ATSAM4E16C | 1024 | 100 | 120 | Cortex-M4 |
ATSAM4E16E | 1024 | 144 | 120 | Cortex-M4 |
ATSAM4E8C | 512 | 100 | 120 | Cortex-M4 |
ATSAM4E8E | 512 | 144 | 120 | Cortex-M4 |
ATSAM4LC2A | 128 | 48 | 48 | Cortex-M4 |
ATSAM4LC2B | 128 | 64 | 48 | Cortex-M4 |
ATSAM4LC2C | 128 | 100 | 48 | Cortex-M4 |
ATSAM4LC4A | 256 | 48 | 48 | Cortex-M4 |
ATSAM4LC4B | 256 | 64 | 48 | Cortex-M4 |
ATSAM4LC4C | 256 | 100 | 48 | Cortex-M4 |
ATSAM4LS2A | 128 | 48 | 48 | Cortex-M4 |
ATSAM4LS2B | 128 | 64 | 48 | Cortex-M4 |
ATSAM4LS2C | 128 | 100 | 48 | Cortex-M4 |
ATSAM4LS4A | 256 | 48 | 48 | Cortex-M4 |
ATSAM4LS4B | 256 | 64 | 48 | Cortex-M4 |
ATSAM4LS4C | 256 | 100 | 48 | Cortex-M4 |
ATSAM4N16B | 1024 | 64 | 100 | Cortex-M4 |
ATSAM4N16C | 1024 | 100 | 100 | Cortex-M4 |
ATSAM4N8A | 512 | 48 | 100 | Cortex-M4 |
ATSAM4N8B | 512 | 64 | 100 | Cortex-M4 |
ATSAM4N8C | 512 | 100 | 100 | Cortex-M4 |
ATSAM4S16B | 1024 | 64 | 120 | Cortex-M4 |
ATSAM4S16C | 1024 | 100 | 120 | Cortex-M4 |
ATSAM4S8B | 512 | 64 | 120 | Cortex-M4 |
ATSAM4S8C | 512 | 100 | 120 | Cortex-M4 |
ATSAM4SA16B | 1024 | 64 | 120 | Cortex-M4 |
ATSAM4SA16C | 1024 | 100 | 120 | Cortex-M4 |
ATSAM4SD16B | 1024 | 64 | 120 | Cortex-M4 |
ATSAM4SD16C | 1024 | 100 | 120 | Cortex-M4 |
ATSAM4SD32B | 2048 | 64 | 120 | Cortex-M4 |
ATSAM4SD32C | 2048 | 100 | 120 | Cortex-M4 |
ATMELCortex-A5 内核芯片
Device Name | Pin Count | Max. Operating Frequency | CPU |
ATSAMA5D31 | 324 | 536 | Cortex-A5 |
ATSAMA5D33 | 324 | 536 | Cortex-A5 |
ATSAMA5D34 | 324 | 536 | Cortex-A5 |
ATSAMA5D35 | 324 | 536 | Cortex-A5 |
举报投诉
嵌入式主板
7文章
6089浏览量
35711 -
米尔科技
5文章
227浏览量
21167
多内核设计的三种设计模式概述
下面是对采用当前开发工具和硬件直接实现多内核系统的三个简单模型的概述。这些多内核设计模式不是一个为了严格定义一个系统的刚性模型,而是针对思考和探讨关于系统实现宏伟
发表于 02-21 10:54
•1563次阅读
教你如何玩转米尔社区
、Cortex-A12、Cortex-A15、Cortex-A53和Cortex-A57开发板。Keil MCU开发板:基于ARM7、ARM9、Cortex-M0、M3、M4内核的NXP、ST芯片系列开发板。米尔
发表于 11-11 10:05
Cortex M3内核概述
第二讲 ARM架构一 、Cortex M3内核概述Cortex M3 Vendor-ARM介绍Cortex M3处理器整体架构Cortex M3处理器内核特性Cortex N3嵌套向量中断
发表于 07-26 08:21
STM32F103C8T6芯片的概述
寸晶圆线,发布了最新款的MM32F013X系列芯片。下面把芯片的概述发给大家看看:1.1 概述本产品使用高性能的 ARM® Cortex®-M0 为
发表于 08-20 06:41
【米尔MYS-8MMX开发板免费试用】编译内核镜像&与USBHID设备通信
问题的,但是能不能映射到设备文件,供开发者进行读写操作,那就需要检查内核编译选项了,这里刚好是比较坏的一种情况,米尔厂家出厂镜像是没有打开USBHID通信的,必须让开发者重新编译内核镜像,那么这里就涉及到
发表于 08-29 16:10
CCM601V1P5芯片概述
1、DSP:CCM601V1P5概述CCM601V1P5是一款集高性能MCU、DSP和音频CODEC于一体的高性能芯片特性u内核和存储Ø 32位RISC架构MCU内核,频率高达122.
发表于 12-09 07:31
OpenHarmony LiteOS-M内核概述
内核概述内核简介OpenHarmony LiteOS-M内核是面向IoT领域构建的轻量级物联网操作系统内核,具有小体积、低功耗、高性能的特点
发表于 05-11 19:10
三种多内核设计模式概述
使用多处理器内核要求软、硬件团队之间进行更多的系统级设计合作。基于这种理念,下面是对采用当前开发工具和硬件直接实现多内核系统的三个简单模型的概述。这些多内核设计模式不是一个为了严格定义
ARM处理器内核的详细资料概述
本文档的主要内容详细介绍的是ARM处理器内核的详细资料概述包括了:ARM7TDMI 处理器内核系列,ARM9TDMI 处理器内核系列,ARM10E处理器
发表于 10-14 17:14
•15次下载
米尔科技NXP LPC1857 LPC1850 Cortex-M3开发板概述
MYD-LPC185X系列开发板是深圳市米尔科技有限公司推出的基于NXP(恩智浦)LPC185X系列处理器(Cortex-M3内核)开发板
米尔科技内核芯片介绍
恩智浦ARM7器件的设计用于低成本、32位MCU上要求高性能和低功耗的即时嵌入式应用。这些器件在闪存和RAM上的操作速度高达72 MHz,提供512 kB片上闪存可编程的存储器和多个外设(包括以太网、USB、CAN、LCD控制器、SD/MMC、I2S、EMC等)。
鸿蒙内核开发概述
第一章 鸿蒙内核开发概述1.1 鸿蒙系统有哪些内容?鸿蒙系统,就相当于一套完整的PC软件系统。Windows里含有:简单地说,鸿蒙系统里含有① 电脑一开机,那些界面是谁显示的?是BIOS,它做什么
发表于 11-03 11:21
•20次下载
