DALI-CC-30W-48V技术手册
张工-13923882807-QQ:813267849
产品名称:DALI-CC-30W-48V
支持协议:IEC 62386-101:2018,IEC 62386-102:2018,IEC 62386-207:2018
产品型号:DALI-CC-30W-48V
调光方式:DALI模拟调光
外形结构:单面元器件
模块尺寸:125mm(长)×14.5mm(宽)×7.7mm(厚)
认证:过DALI2.0认证
| Item | Value | Remark |
Input | DC voltage input | 48V | Polarity-free |
Nominal frequency | 0Hz |
DC voltage range | 47~50V |
Nominal current | 0.65A | Full load@100% dimming level |
Efficiency | 92% | Full load@100% dimming level |
No-load power | <0.3W |
Stand-by power | <0.2W |
Output | Nominal voltage range | 10~40V |
Maximum voltage | 48Vdc |
Nominal current range | 700mA | DIP Switch (1: ON 2: ON 3: ON) |
| 650mA | DIP Switch (1: ON 2: ON 3: OFF) |
| 600mA | DIP Switch (1: ON 2: OFF 3: ON) |
| 550mA | DIP Switch (1: ON 2: OFF 3: OFF) |
| 500mA | DIP Switch (1: OFF 2: ON 3: ON) |
| 450mA | DIP Switch (1: OFF 2: ON 3: OFF) |
| 400mA | DIP Switch (1: OFF 2: OFF 3: ON) |
| 350mA | DIP Switch (1: OFF 2: OFF 3: OFF) |
Current accuracy | ± 5% |
Dimming | Dimming control | DALI 2 |
Dimming technique | Hybrid Dimming | 1~12.5%: PWM 12.5~100%: Amplitude |
Dimming range | 1~100% |
Galvanic isolation | YES | Basic insulated to Dali |
Protections | Short-circuit | YES | DALI status feedback |
Open-circuit | YES | DALI status feedback |
Overload | YES |
Overtemperature | YES |
Environment | Ambient temperature range ta | -20°C...+50°C |
Maximum tc point temperature tc | 88°C | @ta |
Storage temperature range | -40°C…+85°C |
Relative humidity | 10…95% |
Environmental rating | Indoor |
Expected lifetime | >50000h | ta 50 °C |
举报投诉
电子发烧友网站提供《具有有源箝位复位功能的48V至3.3V正激转换器.pdf》资料免费下载
发表于 12-16 09:32
•0次下载
转型,48V系统应用技术正成为这一变革的关键驱动力。 48V系统应用技术不仅在高端汽车中得到应用,而且随着成本的降低和技术的发展,其应用范围正在向中端汽车乃至卡车、公共汽车和工程机械等领域扩展。 如今已经布局的下游汽车企业也
发表于 11-22 14:13
•211次阅读
汽车电源架构不断升级趋势下,48V系统是否还有升级的必要?48V新型电气架构将给连接器带来什么改变? 在插混和纯电车型逐渐普及、800V高压平台持续升级的当下,48V技术还有市场吗?
发表于 11-21 11:07
•222次阅读
给出了逆变器电路原理图;驱动电路输入波形;逆变器输出波形。
图1 逆变器电路原理图
图2 驱动电路输入波形
图3 逆变器输出波形(蓝色的为输出(一个DC一个AC),黄色的为输入48V直流电)
发表于 11-19 10:45
Molex莫仕发布了一份报告,探讨48V电气系统技术迅速兴起,这项技术有望大幅提升汽车性能、效率、功能性和舒适性。Molex莫仕公司的《重构汽车未来:引入48V电源系统》报告探讨了48V技术
发表于 11-18 13:45
•414次阅读
早期汽车的 12V 电气系统只能满足点火和基本照明需求。随着现代汽车引入了电动转向、泵和暖通空调(HVAC)等高能耗设备,电力需求大幅增加,对 12V 系统构成了挑战。因此,汽车行业正转向 48V
发表于 11-11 17:28
•355次阅读
电子发烧友网站提供《48V三相逆变器电路图.pdf》资料免费下载
发表于 10-31 10:49
•4次下载
我们正在运行的电机电压 IG (Vs) = 24V ,希望将 VCP 上限值设置为 48V,这样的选择正确吗? VCP 48V 对应的 VSD 上限电压是多少?
发表于 09-26 06:08
电流和电池电量等原因,不能为整车提供无限大的电流。所以如同整车低压供电电压升到12V一样,它还在继续往上升,迈向48V,从而为整车提供更大的功率输出和更高的能效。故越来越多的汽车厂家开始关注48V系统执行器的
发表于 07-18 15:51
•457次阅读
随着电子技术的发展和汽车电气化程度的提高,汽车制造商开始探索更高电压平台的可能性。早期的混合动力车辆首先将电压提升到了48V,但直到特斯拉的Cybertruck推出,48V系统才得到了更广泛的应用。
发表于 04-13 11:20
•1342次阅读
特斯拉Cybertruck是一款正在意义48V纯电车型,特斯拉不仅在Cybertruck上采用48V,包括model y ,Semi等都采用48V,比较有意思的是,特拉斯为了教同行如何使用48
发表于 03-29 10:13
•1847次阅读
特斯拉全新推出的CyberTruck完全取消了传统的12V低压供电网络,转而全部采用48V配置。这可能是大多数汽车制造商的最终目标,但电源模块可以帮助立即轻松过渡到48V电源,允许汽车制造商继续
发表于 03-26 13:50
•521次阅读
根据 Green 的说法,他们不仅可以受益于线束重量和体积的减小,而且由 48V 系统供电的一些设备也可以受益。“与使用 12V 电源相比,压缩机和泵在使用 48V 电源时更加高效。”他说到,“这真的是一举两得。”
发表于 02-22 12:31
•1618次阅读
通信基站电源电压为什么是-48V直流供电? 通信基站电源电压为-48V直流供电的原因有多个方面,下面将详细介绍。 1. 安全性:直流电是相对较安全的电源供应方式。与交流电相比,直流电在传输
发表于 01-09 16:31
•2519次阅读
缩小线规并降低重量和成本的一种方法是从12V的电气架构转变为基于48V的架构。但转向48V的OEMs必须特别注意几个关键的设计考虑因素,以确保系统的安全性和可靠性。
发表于 01-04 15:33
•649次阅读
