fireflyAIO-3399JLCD使用简介
firefly 来源:firefly 作者:firefly 2019-12-24 10:35 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
LCD使用
简介
AIO-3399J开发板外置了两个LCD屏接口,一个是EDP,一个是LVDS,接口对应板子上的位置如下图:
Config配置
Android7.1为例,由于使用的是mipi转lvds,AIO-3399J默认的配置文件kernel/arch/arm64/configs/firefly_defconfig已经把LCD相关的配置设置好了,如果自己做了修改,请注意把以下配置加上:
CONFIG_LCD_MIPI=y CONFIG_MIPI_DSI=y CONFIG_RK32_MIPI_DSI=y
DTS配置
引脚配置
LVDS屏
AIO-3399J的SDK有LVDS DSI的DTS文件:kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio-lvds.dts,从该文件中我们可以看到以下语句:
/ { model = "AIO Board lvds (Android)"; compatible = "rockchip,android", "rockchip,rk3399-firefly-lvds", "rockchip,rk3399"; test-power { status = "okay"; }; ... &dsi { status = "okay"; dsi_panel: panel { compatible ="simple-panel-dsi"; reg = <0>; //ddc-i2c-bu //power-supply = <&vcc_lcd>; //pinctrl-0 = <&lcd_panel_reset &lcd_panel_enable>; backlight = <&backlight>; /* enable-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>; reset-gpios = <&gpio4 29 GPIO_ACTIVE_LOW>; */ dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST | MIPI_DSI_MODE_LPM | MIPI_DSI_MODE_EOT_PACKET)>; dsi,format = ; //bus-format = ; dsi,lanes = <4>; dsi,channel = <0>; enable-delay-ms = <35>; prepare-delay-ms = <6>; unprepare-delay-ms = <0>; disable-delay-ms = <20>; size,width = <120>; size,height = <170>; status = "okay"; ... power_ctr: power_ctr { rockchip,debug = <0>; lcd_pwr_en: lcd-pwr-en { gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&lcd_panel_pwr_en>; rockchip,delay = <10>; }; lcd_rst: lcd-rst { gpios = <&gpio2 27 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&lcd_panel_reset>; rockchip,delay = <6>; }; }; ... &pinctrl { lcd-panel { lcd_panel_reset: lcd-panel-reset { rockchip,pins = <2 27 RK_FUNC_GPIO &pcfg_pull_down>; }; lcd_panel_pwr_en: lcd-panel-pwr-en { rockchip,pins = <3 16 RK_FUNC_GPIO &pcfg_pull_down>; }; }; };
这里定义了LCD的电源控制引脚:
lcd_pwr_en:(GPIO3_C0)GPIO_ACTIVE_HIGH lcd_rst:(GPIO2_D3)GPIO_ACTIVE_HIGH
都是高电平有效,具体的引脚配置请参考《GPIO》一节。
配置背光
AIO-3399J开发板外置了一个背光接口用来控制屏幕背光,如下图所示:
在DTS文件:kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-core.dtsi中配置了背光信息,如下:
/ { compatible = "rockchip,rk3399-firefly-core", "rockchip,rk3399"; backlight: backlight { status = "disabled"; compatible = "pwm-backlight"; pwms = <&pwm0 0 25000 0>; brightness-levels = < 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255>; default-brightness-level = <200>; };
pwms属性:配置PWM,范例里面默认使用pwm0,25000ns是周期(40 KHz)。LVDS需要加背光电源控制脚,在kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio-lvds.dts中可以看到以下语句:
&backlight { status = "okay"; enable-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; brightness-levels = < 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255>; };
因此使用时需修改DTS文件。
brightness-levels属性:配置背光亮度数组,最大值为255,配置暗区和亮区,并把亮区数组做255的比例调节。比如范例中暗区是255-221,亮区是220-0。 default-brightness-level属性:开机时默认背光亮度,范围为0-255。 具体请参考kernel中的说明文档:kernel/Documentation/devicetree/bindings/leds/backlight/pwm-backlight.txt
配置显示时序
LVDS屏
与EDP屏不同,LVDS屏的 Timing 写在DTS文件中,在kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio-lvds.dts中可以看到以下语句:
disp_timings: display-timings { native-mode = <&timing0>; timing0: timing0 { clock-frequency = <80000000>; hactive = <768>; vactive = <1024>; hsync-len = <20>; //20, 50 hback-porch = <130>; //50, 56 hfront-porch = <150>;//50, 30 vsync-len = <40>; vback-porch = <130>; vfront-porch = <136>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <0>; }; } }
时序属性参考下图:
Init Code
LVDS屏
lvds屏上完电后需要发送初始化指令才能使之工作。
dts 可以在kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio-lvds.dts中可以看到lvds的初始化指令列表:
&dsi { status = "okay"; ... panel-init-sequence = [ 29 00 06 3C 01 09 00 07 00 29 00 06 14 01 06 00 00 00 29 00 06 64 01 0B 00 00 00 29 00 06 68 01 0B 00 00 00 29 00 06 6C 01 0B 00 00 00 29 00 06 70 01 0B 00 00 00 29 00 06 34 01 1F 00 00 00 29 00 06 10 02 1F 00 00 00 29 00 06 04 01 01 00 00 00 29 00 06 04 02 01 00 00 00 29 00 06 50 04 20 01 F0 03 29 00 06 54 04 32 00 B4 00 29 00 06 58 04 80 07 48 00 29 00 06 5C 04 0A 00 19 00 29 00 06 60 04 38 04 0A 00 29 00 06 64 04 01 00 00 00 29 01 06 A0 04 06 80 44 00 29 00 06 A0 04 06 80 04 00 29 00 06 04 05 04 00 00 00 29 00 06 80 04 00 01 02 03 29 00 06 84 04 04 07 05 08 29 00 06 88 04 09 0A 0E 0F 29 00 06 8C 04 0B 0C 0D 10 29 00 06 90 04 16 17 11 12 29 00 06 94 04 13 14 15 1B 29 00 06 98 04 18 19 1A 06 29 02 06 9C 04 33 04 00 00 ]; panel-exit-sequence = [ 05 05 01 28 05 78 01 10 ]; ... };
命令格式以及说明可参考以下附件: Rockchip DRM Panel Porting Guide.pdf
kernel 发送指令可以看到在kernel/drivers/gpu/drm/panel/panel-simple.c文件中的操作:
static int panel_simple_enable(struct drm_panel *panel) { struct panel_simple *p = to_panel_simple(panel); int err; if (p->enabled) return 0; DBG("enter\n"); if (p->on_cmds) { err = panel_simple_dsi_send_cmds(p, p->on_cmds); if (err) dev_err(p->dev, "failed to send on cmds\n"); } if (p->desc && p->desc->delay.enable) { DBG("p->desc->delay.enable=%d\n", p->desc->delay.enable); msleep(p->desc->delay.enable); } if (p->backlight) { DBG("open backlight\n"); p->backlight->props.power = FB_BLANK_UNBLANK; backlight_update_status(p->backlight); } p->enabled = true; return 0; }
u-boot 发送指令可以看到在u-boot/drivers/video/rockchip-dw-mipi-dsi.c文件中的操作:
static int rockchip_dw_mipi_dsi_enable(struct display_state *state) { struct connector_state *conn_state = &state->conn_state; struct crtc_state *crtc_state = &state->crtc_state; const struct rockchip_connector *connector = conn_state->connector; const struct dw_mipi_dsi_plat_data *pdata = connector->data; struct dw_mipi_dsi *dsi = conn_state->private; u32 val; DBG("enter\n"); dw_mipi_dsi_set_mode(dsi, DW_MIPI_DSI_VID_MODE); dsi_write(dsi, DSI_MODE_CFG, ENABLE_CMD_MODE); dw_mipi_dsi_set_mode(dsi, DW_MIPI_DSI_VID_MODE); if (!pdata->has_vop_sel) return 0; if (pdata->grf_switch_reg) { if (crtc_state->crtc_id) val = pdata->dsi0_en_bit | (pdata->dsi0_en_bit << 16); else val = pdata->dsi0_en_bit << 16; writel(val, RKIO_GRF_PHYS + pdata->grf_switch_reg); } debug("vop %s output to dsi0\n", (crtc_state->crtc_id) ? "LIT" : "BIG"); //rockchip_dw_mipi_dsi_read_allregs(dsi); return 0; }
  • 嵌入式主板
  • 安卓
  • Firefly
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    fireflyAIO-3399J主板简介
    AIO-3399J 的标准套装包含以下配件
    的头像 发表于 11-05 15:52 2597次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板<b class='flag-5'>简介</b>
    fireflyAIO-3399C主板红外遥控器简介
    红外遥控器 产品参数 产品:12键红外遥控器 版本:Firefly定制版 电源:两节7号电池 适配:AIO-3399C 描述:支持AIO-3399C开发板的遥控开机功能
    的头像 发表于 12-09 15:59 2358次阅读
    fireflyAIO-3399C主板PWM介绍
    AIO-3399C开发板上引出有 3 路 PWM 输出,
    的头像 发表于 12-09 16:20 2402次阅读
    fireflyAIO-3399C主板LED介绍
    LED 使用 AIO-3399C 开发板上有 2 个 LED 灯
    的头像 发表于 12-09 16:25 2680次阅读
    <b class='flag-5'>fireflyAIO-3399</b>C主板LED介绍
    fireflyAIO-3399C主板LCD简介
    AIO-3399C开发板默认外置支持了两个LCD屏接口,一个是LVDS,一个是EDP,接口对应板子上的位置
    的头像 发表于 12-13 10:09 4493次阅读
    <b class='flag-5'>fireflyAIO-3399</b>C主板LCD<b class='flag-5'>简介</b>
    fireflyAIO-3399C主板IR简介
    AIO-3399C 开发板上使用红外收发传感器 IR (耳机接口和recovery之间)实现遥控功能,在IR接口处接上红外接收器。本文主要描述在开发板上如何配置红外遥控器。
    的头像 发表于 12-13 10:12 2468次阅读
    <b class='flag-5'>fireflyAIO-3399</b>C主板IR<b class='flag-5'>简介</b>
    fireflyAIO-3399C编译Industry固件简介
    Android7.1 的SDK分为 tvbox版本以及industry版本(主要维护),用户可根据需求,自行下载所需的SDK来进行编译和开发,两版SDK均兼容AIO-3399C与AIO-3399C(AI)板型。
    的头像 发表于 12-13 10:36 2579次阅读
    fireflyAIO-3399J主板散热套件简介
    散热套件 铝制散热片 产品参数 适配:AIO-3399J 尺寸:43mm (L)* 39.5mm(W)*11mm(H)
    的头像 发表于 12-24 10:01 1991次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板散热套件<b class='flag-5'>简介</b>
    fireflyAIO-3399J主板红外遥控器简介
    红外遥控器 产品参数 产品:12键红外遥控器 版本:Firefly定制版 电源:两节7号电池 适配:AIO-3399J 描述:支持AIO-3399J开发板的遥控开机功能
    的头像 发表于 12-24 10:07 2431次阅读
    fireflyAIO-3399J主板TIMER使用简介
    RK3399有12 个Timers (timer0-timer11),有12 个Secure Timers(stimer0~stimer11) 和 2 个Timers(pmutimer0
    的头像 发表于 12-24 10:25 2534次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板TIMER使用<b class='flag-5'>简介</b>
    fireflyAIO-3399J主板RTC使用简介
    AIO-3399J开发板上有 一个集成于RK808上的RTC(Real Time Clock),主要功能有时钟,日历,闹钟,周期性中断,双通道32KHz时钟输出。
    的头像 发表于 12-24 10:20 3096次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板RTC使用<b class='flag-5'>简介</b>
    fireflyAIO-3399J主板MIPI CSI使用简介
    AIO-3399J 开发板分别带有两个MIPI,一个DVP摄像头接口,MIPI最高支持支持4K拍照,并支持1080P 30FPS以上视频录制。
    的头像 发表于 12-24 10:22 6548次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板MIPI CSI使用<b class='flag-5'>简介</b>
    fireflyAIO-3399J主板LED使用介绍
    AIO-3399J 开发板上有 2 个 LED 灯
    的头像 发表于 12-24 10:31 4010次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板LED使用介绍
    fireflyAIO-3399J主板IR使用简介
    AIO-3399J 开发板上使用红外收发传感器 IR (在 mic 接口和喇叭接口之间)实现遥控功能,在IR接口处接上红外接收器。
    的头像 发表于 12-24 10:32 3282次阅读
    <b class='flag-5'>fireflyAIO-3399</b>J主板IR使用<b class='flag-5'>简介</b>
    fireflyAIO-3399J编译Buildroot固件简介
    /FireflyTeam/manifests.git -b linux-sdk -m rk3399/rk3399_linux_release.xml # 同步源码 ../repo/repo sync
    的头像 发表于 12-24 11:11 3282次阅读
