CPU Model: Allwinner H5
Number of Cores: 64-bit Quad-Core
Frequency:4* Cortex-A53 1.5GHz Memory RAM: 512MB/1GB DDR3 Storage eMMC: 8GB
MicroSD Slot: MicroSD*1 for external storage up to 128GB Connectivity Ethernet: Gbps Ethernet, RTL8211E-VB-CG chip
WiFi: 802.11b/g/n
Bluetooth: 4.0 dual mode
Antenna: IPX Connector*1 Audio Input/Output: 2.54mm pitch 5 pin-header USB USB 2.0*1: USB 2.0 Host Type A
USB pin header*2
MicroUSB*1: Power input(5V/2A) Pin-header
GPIO 1:
24Pin, 2.54mm pitch double-row pin-header containing UART, SPI, I2C and IO
GPIO 2:
12Pin, 2.54mm pitch pin-header containing USB, IR receiver,I2S and IO
Serial Debug Port: 2.54mm pitch 4pin-header LED Power LED(Red)*1
STAT LED(Green)*1 Others Working Temperature: -20℃ to 70℃ Power DC 5V/2A
OS Support FriendlyCore(based on UbuntuCore-16.04)
Third party: Armbian, DietPi, Lakka, Kali, OpenWrt etc Kernel version Linux-4.14-LTS
U-boot-2017.11 FriendlyCore 64-bit OS
supports FriendlyElec’s BakeBit Kit
supports FriendlyElec’s NanoHAT OLED
pre-installed FriendlyElec’s NanoHAT Motor Python Library
pre-installed WiringPi for GPIO access
pre-installed RPi.GPIO for GPIO access
npi-config: system configuration utility for setting passwords, language, timezone, hostname,
SSH and auto-login
networkmanager: a network tility to manage networking
auto-login with user account “pi” with access to npi-config
supports Gbps Ethernet
supports WiFi and Bluetooth
supports FriendlyElec‘s FA-CAM202 USB camera
supports audio recording and playing Debian for NAS Dock supports FriendlyElec’s NAS Dock
pre-installed OpenMediaVault
PCB Six Layer Dimension 40*52mm Weight 22.20g
Linux
87文章
11310浏览量
209652 -
嵌入式主板
7文章
6085浏览量
35376 -
友善之臂
36浏览量
3498
