- 产品型号SinoV-PD-RT9400
产品描述
The RT9400 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard.
产品介绍
Description:
The RT9400 signature and control circuit provides the PoE compatibility signature and
power classification required by the Power Sourcing Equipment (PSE) before applying up
to 15W power to the port. The RT9400 provides a Class 0 signature.
The DC/DC converter operates over a wide input voltage range and provides a regulated
output. The DC/DC converter also has built-in short-circuit output protection.
Features:
·IEEE802.3af compliant
·Input voltage range 36V to 57V
·Integral high efficiency DC/DC converter.
·Low output ripple and noise
·High performance with low price
·Short-circuit protection
·Adjustable Output
·Optional multi-voltage output 3.3V 5V 12V 24V
·Transformer isolation ,1500V isolation (input to output)
·Easy to use, with a minimum number of external components.
Applications:
·IP Cameras
·Wireless access point
·Security and alarm systems
·VOIP telephone
·Point of sale network terminal equipment
RT9400 Product Selector
Part Number | NominalOutput Voltage | Maximum Output Power* | Marking | Package |
RT9400-3.3V | 3.3V | 6.6W | 3.3V | SIL |
RT9400 -5V | 5V | 10W | 5V | SIL |
RT9400 -12V | 12V | 12W | 12V | SIL |
RT9400 -24V | 24V | 12W | 24V | SIL |
*At 25°C with VIN = 48V
Reducing the output voltage, connect R2 between ADJ and +VDC
R2 Value
output voltage
R2 Value
output voltage
RT9400-3.3V
open
3.3V
0R
2.8V
RT9400-5V
open
5V
0R
4.4V
RT9400-12V
open
12V
0R
9.9V
RT9400-24V
open
24V
30K
18.2V
Increasing the output voltage, connect R1 between ADJ and -VDC
R1 Value
output voltage
R1 Value
output voltage
RT9400-3.3V
open
3.3V
0R
3.7V
RT9400-5V
open
5V
0R
5.7V
RT9400-12V
open
12V
0R
12.8V
RT9400-24V
open
24V
0R
25.5V
举报投诉
嵌入式主板
7文章
6085浏览量
35314 -
源创通信
85浏览量
1959
源创通信SinoV-D100 CDMA学生卡介绍
SinoV-D100 是源创通信最新开发的平安校园终端设备,集成了RFID, GPS,GPRS,亲情电话,SOS紧急呼叫功能。卡片功能齐全,小巧。支持CDMA网络,支持电信平安校园2.0协议。
