嵌入式主板
君正集成电路
应用领域
• 图像识别类:二维码识别,车牌识别,人脸识别和指纹识别;
• 智能家电类:智能空调,智能冰箱和日用小家电;
• 智能家居类:智能网关,智能灯,智能机器人等。
芯片规格
CPU
XBurst CPU 1.0GHz, MIPS-based
Hardware FPU, SIMD
16KB L1 I-cache and 16KB L1 D-cache, 128KB L2 unified cache.
Memory
32/64 MBytes LPDDR in package
Display
Support 8-bit, 9-bit, 16-bit parallel interface SLCD
Camera
Support 8-bit parallel interface, up to 2.0MPixels
Hardware JPEG encoder, 1280x720@30fps
Support CCIR656 input
Audio
Embedded high-quality audio CODEC with stereo ADC and DAC
Low power DMIC controller with voice trigger engine
Support I2S/ SPDIF interface for external audio codec.
Support PCM interface, both master and slave mode.
On-chip Peripherals
I2C x3
SPI x1
USB 2.0HS OTG x1
Full-duplex UARTx3
Serial flash interface x1
Smart card interface x1
I2S x1
PCM x1
Ethernet MAC x1
Security
1Kbits OTP memory
Support hardware RSA(1024bits) and AES(128bits)
Support security boot
Package
13x13x1.2mm, BGA-190, 0.8pitch
OS
Linux 3.0 and later
Linux
87文章
11296浏览量
209366 -
嵌入式主板
7文章
6085浏览量
35304 -
君正集成电路
26浏览量
5573
