飞凌嵌入式FETMX8MM-C核心板介绍
飞凌嵌入式 来源:飞凌嵌入式 作者:飞凌嵌入式 2019-12-03 16:38 次阅读
CPUNXP i.MX8M Mini
架构:四核Cortex-A53+M4
主频:1.8GHz
内存:2GB DDR4
ROM:8GB eMMC
系统:Linux4.14.78+QT5.10.1、Android9.0
FETMX8MM-C核心板
FETMX8MM-C 核心板基于NXP 公司的i.MX8M Mini 四核64位处理器设计,主频最高1.8GHz,ARM Cortex-A53架构;2GB DDR4 RAM,支持一个通用型Cortex®-M4 400 MHz内核处理器。可提供多种音频接口,包括I2S、AC97、TDM、PDM和SPDIF。提供多种外设接口,如MIPI-CSI、MIPI-DSIUSB、PCIe、UART、eCSPI、IIC和千兆以太网
目标应用:
·IP摄像头视频监控 ·双向视频会议
·可视门铃·图像分析
·音频处理·音频广播系统
规格参数
CPU
  • Cortex A53 Core:
    • 4x Cortex-A53 processors
  • • Target frequency of 1.8GHz
  • • Support of 64-bit Armv8-A architecture
  • • Floating Point Unit (FPU) with support of the VFPv4-D16 architecture
  • • 32 KB L1 Instruction Cache
  • • 32 KB L1 Data Cache
  • • 512 KB unified L2 cache
  • Cortex M4 Core:
    • 1x Cortex-M4 processor
  • frequency of 400MHz
  • • 256 KB tightly coupled memory (TCM,128 KB TCMU, 128 KB TCML)
RAM
  • • 2GB
  • • DDR4
ROM
  • • 8GB
  • • eMMC Flash
Multimedia Interface
  • LCDIF Display Controller:
  • • Support up to 2 layers of overlay
  • • Support up to 1080p60 display through MIPI DSI
  • MIPI Interface:
  • • 4-lane MIPI CSI interface,operating up to a maximum bit rate of 1.5 Gbps.
  • • 4-lane MIPI DSI interface,operating up to a maximum bit rate of 1.5 Gbps.
  • Audio:
  • • SPDIF input and output, including a new Raw Capture input mode
  • Five synchronous audio interface (SAI) modules supporting I2S,AC97, TDM,codec/DSP,and DSD interfaces, including one SAI with 8 Tx and 8 Rx lanes, one SAI with 4 Tx and 4 Rx lanes,two SAI with 2 Tx and 2 Rx lanes,and one SAI with 1 Tx and 1Rx lane. Support over 20 channels of audio subject to I/O limitations.
  • • 8-Channel Pulse Density Modulation (PDM) input
GPU
  • 3D GPU Core:
  • • GCNanoUltra
  • • Support OpenGL ES 1.1, 2.0
  • • Support OpenVG 1.1
  • • TrustZone support using a local MMU to manage secure regions
  • 2D GPU Core:
  • • GC320
  • • Support multi-source composition
  • • Support one-pass filter
VPU
  • Decoder:
  • • 1080p60 VP9 Profile 0, 2 (10-bit)
  • • 1080p60 HEVC/H.265 Decoder
  • • 1080p60 AVC/H.264 Baseline, Main, High decoder
  • • 1080p60 VP8
  • Encoder:
  • • 1080p60 AVC/H.264 Encoder
  • • 1080p60 VP8
PCle
  • One PCI Express (PCIe)
  • • Single lane supporting PCIe Gen2
  • • Dual mode operation to function as root complex or endpoint
  • • Integrated PHY interface
  • • Support L1 low power sub-state
USB
  • Two USB 2.0 OTG controllers with integrated PHY interfaces
SD/SDIO
  • Two Ultra Secure Digital Host Controller (uSDHC) interfaces:
  • • SD/SDIO 3.0 compliance with 200 MHz SDR signaling to support up to 100MB/sec
  • • Support for SDXC (extended capacity)
  • • 1.8 V and 3.3 V operation, but do not support 1.2V operation.
Ethernet
  • One Gigabit Ethernet controller:
  • • support for Energy Efficient Ethernet (EEE)
  • • Ethernet AVB,
  • • IEEE 1588
UART
  • Four Universal Asynchronous Receiver/Transmitter (UART) modules:
  • • 7- or 8-bit data words, 1 or 2 stop bits, programmable parity (even,odd, or none)
  • • Programmable baud rates up to 4 Mbps.
  • • 32-byte FIFO on Tx and 32half-word FIFO on Rx supporting auto-baud
I2C
  • Four I2C modules:
  • I2C provides serial interface for external devices. Data rates of up to 320 kbps are supported.
eCSPI
  • Three eCSPI modules:
  • Full-duplex enhanced Synchronous Serial Interface, with data rate up to 52 Mbit/s. Configurable to support Master/Slave modes, four chip selects to support multiple peripherals.
FlexSPI
  • The FlexSPI module acts s an interface to external serial flash devices. This module contains the following features:
  • • Flexible sequence engine to support various flash vendor devices
  • • Single pad/Dual pad/Quad pad mode of operation
  • • Single Data Rate/Double Data Rate mode of operation
  • • Parallel Flash mode
  • DMA support
  • • Memory mapped read access to connected flash devices
  • • Multi master access with priority and flexible and configurable buffer for each master
  • Linux
  • 嵌入式主板
  • 安卓
    嵌入式i.MX8M Mini核心板已支持Linux6.1
    嵌入式FETMX8MM-C核心板现已支持Linux6.1系统,此次升级不仅使系统功能更加丰富,还通过全新BSP实现了内存性能的显著提升。
    的头像 发表于 01-10 09:56 2119次阅读
    <b class='flag-5'>飞</b><b class='flag-5'>凌</b><b class='flag-5'>嵌入式</b>i.MX<b class='flag-5'>8</b>M Mini<b class='flag-5'>核心板</b>已支持Linux6.1
    低调的奢华-嵌入式FETMX6Q-C是怎么练成的
    ,产品品质稳如磐石,为超长客户产品使用寿命保驾护航。NXP i.MX6系列CPU的非凡实力,加上对于嵌入式核心板卡的精益求精,这种强强联合的产物,绝对是业内首选,带给开发工程师们前
    发表于 10-07 15:09
    FETMX8MM-C核心板之管道巡检机器人控制平板方案分享
    机器人提供Cortex-M4平台方案—FETMX8MM-C核心板,i.MX8MMini四核64位处理器设计,可提供多种音频接口和多种外设接口。五、FETMX8MM-C
    发表于 10-13 16:34
    iMX8MM核心板在麻醉系统中的应用
    FETMX8MM-C核心板可作为麻醉系统中的主控平台,该款核心板采用NXP i.MX 8M Mini四核Cortex-A53架构处理器,每个核心
    发表于 10-23 15:07
    FETMX8MM-C核心板在麻醉系统中的应用
    的i.MX8M Mini处理器列入NXP产品长期供货计划,包含在该计划内的产品在推出后至少保证10年以上的供货周期,以确保对长生命周期产品的供货稳定性;② 嵌入式iMX
    发表于 10-26 13:09
    测评|iMX8MP核心板多媒体功能测评
    嵌入式另外两款基于NXP iMX8M系列处理器设计的的FETMX8MM-C核心板
    发表于 11-05 15:20
    FETMX6Q-C核心板有哪些优势呢
    医疗领域深耕研究,推出多款符合医疗产品的嵌入式核心板卡。本文针对多参监护仪,推荐一款功能强大、性能优异、稳定性强、超长供货周期的核心板FETMX6Q-C
    发表于 12-20 06:35
    动态讲解-一起了解这款尺寸仅29x40mm的小尺寸FETMX6ULL-C核心板
    。下面是iMX6ULL处理器的内部功能框图:4月初,嵌入式发布了一款新品FETMX6ULL-C核心板,可能有些工程师用户对这款平台还不太
    发表于 05-05 11:52
    ARM核心板,为医疗设备不断赋能
    嵌入式广泛应用于医疗行业的部分核心板产品,带您更全面、更立体地了解嵌入式在助力医疗设备智能化发展方面所做的努力。产品
    发表于 06-30 14:53
    FETMX8MP-C核心板多媒体功能测评
    距离FETMX8MP-C核心板推出已经有一段时间了,因其强大的性能且具有多领域的通用性,此款核心板受到了很多工程师用户的青睐。
    的头像 发表于 11-05 18:15 1140次阅读
    <b class='flag-5'>飞</b><b class='flag-5'>凌</b><b class='flag-5'>FETMX8MP-C</b><b class='flag-5'>核心板</b>多媒体功能测评
    基于飞嵌入式FETMX8MM-C核心板的血细胞分析仪
    某医疗器械制造商最终选择了嵌入式FETMX8MM-C核心板作为血细胞分析仪的主控。作为一款兼具高性能、丰富功能接口以及10年+超长生命周
    的头像 发表于 02-02 15:33 668次阅读
    基于飞<b class='flag-5'>凌</b><b class='flag-5'>嵌入式</b><b class='flag-5'>FETMX8MM-C</b><b class='flag-5'>核心板</b>的血细胞分析仪
    稳定运行矿山鸿蒙系统——嵌入式的这2款核心板获得「矿鸿资质证书」
    嵌入式FETMX6ULL-S核心板和FETA40i-C
    的头像 发表于 02-23 15:24 902次阅读
    稳定运行矿山鸿蒙系统——<b class='flag-5'>飞</b><b class='flag-5'>凌</b><b class='flag-5'>嵌入式</b>的这2款<b class='flag-5'>核心板</b>获得「矿鸿资质证书」
    首发!嵌入式FETMX6ULL-S核心板已适配OpenHarmony 4.1
    近日,嵌入式FETMX6ULL-S核心板上率先适配了OpenHarmony 4.1,这也是业内的首个应用案例,
    的头像 发表于 05-20 09:04 990次阅读
    首发!<b class='flag-5'>飞</b><b class='flag-5'>凌</b><b class='flag-5'>嵌入式</b><b class='flag-5'>FETMX</b>6ULL-S<b class='flag-5'>核心板</b>已适配OpenHarmony 4.1
    嵌入式FET3576-C核心板四大优势详解
    为了充分满足AIoT市场对高性能、高算力和低功耗主控日益增长的需求 ,嵌入式近期推出了基于Rockchip RK3576处理器开发设计的FET3576-C
    的头像 发表于 06-28 09:17 711次阅读
    <b class='flag-5'>飞</b><b class='flag-5'>凌</b><b class='flag-5'>嵌入式</b>FET3576-<b class='flag-5'>C</b><b class='flag-5'>核心板</b>四大优势详解
    低成本与高性能兼备,FETMX8MPL-C核心板上新
    为了切实满足更多客户的基础应用及项目降本需求,嵌入式现推出FETMX8MPL-C核心板。相较于先前已成功推向市场的
    的头像 发表于 12-10 10:34 572次阅读
    低成本与高性能兼备,<b class='flag-5'>FETMX8MPL-C</b><b class='flag-5'>核心板</b>上新
