10个经典C语言面试基础算法及代码
黄工的嵌入式技术圈 来源:黄工的嵌入式技术圈 作者:黄工的嵌入式技术 2020-01-16 11:09 次阅读
链接:http://www.codeceo.com/article/10-c-interview-algorithm.html
算法是一个程序和软件的灵魂,作为一名优秀的程序员,只有对一些基础的算法有着全面的掌握,才会在设计程序和编写代码的过程中显得得心应手。
一、计算Fibonacci数列
Fibonacci数列又称斐波那契数列,又称黄金分割数列,指的是这样一个数列:1、1、2、3、5、8、13、21。
C语言实现的代码如下:
/* Displaying Fibonacci sequence up to nth term where n is entered by user. */#include int main(){ int count, n, t1=0, t2=1, display=0; printf("Enter number of terms: "); scanf("%d",&n); printf("Fibonacci Series: %d+%d+", t1, t2); /* Displaying first two terms */ count=2; /* count=2 because first two terms are already displayed. */ while (count { display=t1+t2; t1=t2; t2=display; ++count; printf("%d+",display); } return 0;}
结果输出:
Enter number of terms: 10Fibonacci Series: 0+1+1+2+3+5+8+13+21+34+
二、回文检查
源代码:
/* C program to check whether a number is palindrome or not */#include int main(){ int n, reverse=0, rem,temp; printf("Enter an integer: "); scanf("%d", &n); temp=n; while(temp!=0) { rem=temp%10; reverse=reverse*10+rem; temp/=10; } /* Checking if number entered by user and it's reverse number is equal. */ if(reverse==n) printf("%d is a palindrome.",n); else printf("%d is not a palindrome.",n); return 0;} 结果输出: Enter an integer: 1232112321 is a palindrome.
三、质数检查
注:1既不是质数也不是合数。
源代码:
/*Cprogramtocheckwhetheranumberisprimeornot.*/#include int main(){ int n, i, flag=0; printf("Enter a positive integer: "); scanf("%d",&n); for(i=2;i<=n/2;++i) { if(n%i==0) { flag=1; break; } } if (flag==0) printf("%d is a prime number.",n); else printf("%d is not a prime number.",n); return 0;}
结果输出:
Enter a positive integer: 2929 is a prime number.
四、打印金字塔和三角形
使用 * 建立三角形
** ** * ** * * ** * * * * 源代码: #include int main(){ int i,j,rows; printf("Enter the number of rows: "); scanf("%d",&rows); for(i=1;i<=rows;++i) { for(j=1;j<=i;++j) { printf("* "); } printf(" "); } return 0;}  如下图所示使用数字打印半金字塔。 11 21 2 31 2 3 41 2 3 4 5
源代码:
#include int main(){ int i,j,rows; printf("Enter the number of rows: "); scanf("%d",&rows); for(i=1;i<=rows;++i) { for(j=1;j<=i;++j) { printf("%d ",j); } printf(" "); } return 0;}
用 * 打印半金字塔:
源代码:
#include int main(){ int i,j,rows; printf("Enter the number of rows: "); scanf("%d",&rows); for(i=rows;i>=1;--i) { for(j=1;j<=i;++j) { printf("* "); } printf(" "); } return 0;}
用 * 打印金字塔
源代码:
#include int main(){ int i,space,rows,k=0; printf("Enter the number of rows: "); scanf("%d",&rows); for(i=1;i<=rows;++i) { for(space=1;space<=rows-i;++space) { printf(" "); } while(k!=2*i-1) { printf("* "); ++k; } k=0; printf(" "); } return 0;}
五、简单的加减乘除计算器
源代码:
/*Sourcecodetocreateasimplecalculatorforaddition,subtraction,multiplicationanddivisionusingswitch...casestatementinCprogramming.*/# include int main(){ char o; float num1,num2; printf("Enter operator either + or - or * or divide : "); scanf("%c",&o); printf("Enter two operands: "); scanf("%f%f",&num1,&num2); switch(o) { case '+': printf("%.1f + %.1f = %.1f",num1, num2, num1+num2); break; case '-': printf("%.1f - %.1f = %.1f",num1, num2, num1-num2); break; case '*': printf("%.1f * %.1f = %.1f",num1, num2, num1*num2); break; case '/': printf("%.1f / %.1f = %.1f",num1, num2, num1/num2); break; default: /* If operator is other than +, -, * or /, error message is shown */ printf("Error! operator is not correct"); break; } return 0;}
结果输出:
Enter operator either + or - or * or divide : -Enter two operands: 3.48.43.4 - 8.4 = -5.0
六、检查一个数能不能表示成两个质数之和
源代码:
#include int prime(int n);int main(){ int n, i, flag=0; printf("Enter a positive integer: "); scanf("%d",&n); for(i=2; i<=n/2; ++i) { if (prime(i)!=0) { if ( prime(n-i)!=0) { printf("%d = %d + %d ", n, i, n-i); flag=1; } } } if (flag==0) printf("%d can't be expressed as sum of two prime numbers.",n); return 0;} /* Function to check prime number */int prime(int n){ int i, flag=1; for(i=2; i<=n/2; ++i) if(n%i==0) flag=0; return flag;}
结果输出:
Enter a positive integer: 3434 = 3 + 3134 = 5 + 2934 = 11 + 2334 = 17 + 17
七、用递归的方式颠倒字符串
源代码:
/* Example to reverse a sentence entered by user without using strings. */#include void Reverse();int main(){ printf("Enter a sentence: "); Reverse(); return 0;} void Reverse(){ char c; scanf("%c",&c); if( c != ' ') { Reverse(); printf("%c",c); }}
结果输出:
Enter a sentence: margorp emosewaawesome program
八、实现二进制与十进制之间的相互转换
源代码:
/* C programming source code to convert either binary to decimal or decimal to binary according to data entered by user. */#include #include int binary_decimal(int n);int decimal_binary(int n);int main(){ int n; char c; printf("Instructions: "); printf("1. Enter alphabet 'd' to convert binary to decimal. "); printf("2. Enter alphabet 'b' to convert decimal to binary. "); scanf("%c",&c); if (c =='d' || c == 'D') { printf("Enter a binary number: "); scanf("%d", &n); printf("%d in binary = %d in decimal", n, binary_decimal(n)); } if (c =='b' || c == 'B') { printf("Enter a decimal number: "); scanf("%d", &n); printf("%d in decimal = %d in binary", n, decimal_binary(n)); } return 0;} /* Function to convert decimal to binary.*/int decimal_binary(int n){ int rem, i=1, binary=0; while (n!=0) { rem=n%2; n/=2; binary+=rem*i; i*=10; } return binary;} /* Function to convert binary to decimal.*/int binary_decimal(int n){ int decimal=0, i=0, rem; while (n!=0) { rem = n%10; n/=10; decimal += rem*pow(2,i); ++i; } return decimal;}
结果输出:
九、使用多维数组实现两个矩阵的相加
源代码:
#include int main(){ int r,c,a[100][100],b[100][100],sum[100][100],i,j; printf("Enter number of rows (between 1 and 100): "); scanf("%d",&r); printf("Enter number of columns (between 1 and 100): "); scanf("%d",&c); printf(" Enter elements of 1st matrix: "); /* Storing elements of first matrix entered by user. */ for(i=0;i for(j=0;j { printf("Enter element a%d%d: ",i+1,j+1); scanf("%d",&a[i][j]); } /* Storing elements of second matrix entered by user. */ printf("Enter elements of 2nd matrix: "); for(i=0;i for(j=0;j { printf("Enter element a%d%d: ",i+1,j+1); scanf("%d",&b[i][j]); } /*Adding Two matrices */ for(i=0;i for(j=0;j sum[i][j]=a[i][j]+b[i][j]; /* Displaying the resultant sum matrix. */ printf(" Sum of two matrix is: "); for(i=0;i for(j=0;j { printf("%d ",sum[i][j]); if(j==c-1) printf(" "); } return 0;}
结果输出:
十、矩阵转置
源代码:
#include int main(){ int a[10][10], trans[10][10], r, c, i, j; printf("Enter rows and column of matrix: "); scanf("%d %d", &r, &c); /* Storing element of matrix entered by user in array a[][]. */ printf(" Enter elements of matrix: "); for(i=0; i for(j=0; j { printf("Enter elements a%d%d: ",i+1,j+1); scanf("%d",&a[i][j]); } /* Displaying the matrix a[][] */ printf(" Entered Matrix: "); for(i=0; i for(j=0; j { printf("%d ",a[i][j]); if(j==c-1) printf(" "); } /* Finding transpose of matrix a[][] and storing it in array trans[][]. */ for(i=0; i for(j=0; j { trans[j][i]=a[i][j]; } /* Displaying the transpose,i.e, Displaying array trans[][]. */ printf(" Transpose of Matrix: "); for(i=0; i for(j=0; j { printf("%d ",trans[i][j]); if(j==r-1) printf(" "); } return 0;}
结果输出:
  • 算法
  • 基础知识
  • C语言编程
  • 代码
    hex文件如何查看原c语言代码
    直接将 .hex 文件转换回原始的 C 语言代码是不可能的,因为 .hex 文件是二进制文件,它包含了单片机程序编译后的机器码,这些机器码与原始的 C
    的头像 发表于 09-02 10:37 1349次阅读
    十大排序算法总结
    排序算法是最经典算法知识。因为其实现代码短,应该广,在面试中经常会问到排序算法及其相关的问题。
    的头像 发表于 12-20 10:39 1076次阅读
    C语言代码的常用技巧
    #和##对于大部分C语言玩得还算比较溜的朋友并不是很陌生,不过能把这两知识点游刃有余的应用到所在代码中的每个角落,似乎并没有几个人能够做到,学的时候朗朗上口,而编码的时候却抛之脑后。
    的头像 发表于 12-05 09:25 519次阅读
    <b class='flag-5'>C</b><b class='flag-5'>语言</b><b class='flag-5'>代码</b>的常用技巧
    c语言hello world程序编写
    C语言是一种非常经典和常用的编程语言,而"Hello world"程序是每一编程入门者的必修课。它是用来熟悉编程
    的头像 发表于 11-26 09:23 2230次阅读
    c语言源程序main函数的位置
    C语言源程序中的main函数是程序的入口点,它被认为是C语言程序的起点。在执行程序时,操作系统将首先定位到main函数,并从该函数开始执行程序的代码
    的头像 发表于 11-24 10:23 2289次阅读
    c语言代码错误怎么找
    当我们编写C语言代码时,常常会遇到一些错误。这些错误可能是语法错误,逻辑错误或者是运行时错误。无论是什么类型的错误,我们都需要学会如何找到并解决这些问题。 一、语法错误: 语法错误是最常见的错误类型
    的头像 发表于 11-24 10:05 3563次阅读
    c语言怎么把代码全部注释掉
    要将C语言代码全部注释掉,即不让代码被编译和执行,可以使用注释语句来实现。C语言提供两种注释方式
    的头像 发表于 11-22 10:21 6598次阅读
    c语言中顺序结构的基本流程
    的语句组成,这些语句用于完成特定的任务或操作。在C语言中,每个语句都以分号结束,多个语句可以用大括号括起来形成一语句块。在顺序结构中,每个语句都依次执行,按照代码的顺序执行,然后才会
    的头像 发表于 11-22 10:20 924次阅读
    C语言中如何实现注释
    C语言中,注释是用来增加代码可读性和注释过程和功能的文本。C语言中支持两种类型的注释:单行注释和多行注释。 单行注释以双斜杠(//)开始,
    的头像 发表于 11-22 10:17 1212次阅读
    200经典C程序【源码】
    电子发烧友网站提供《200经典C程序【源码】.zip》资料免费下载
    发表于 11-21 10:34 2次下载
    200<b class='flag-5'>个</b><b class='flag-5'>经典</b><b class='flag-5'>C</b>程序【源码】
    178经典c语言代码+算法大全
    电子发烧友网站提供《178经典c语言代码+算法大全.rar》资料免费下载
    发表于 11-21 10:19 6次下载
    178<b class='flag-5'>个</b><b class='flag-5'>经典</b><b class='flag-5'>c</b><b class='flag-5'>语言</b>源<b class='flag-5'>代码</b>+<b class='flag-5'>算法</b>大全
    178C语言算法源码下载
    电子发烧友网站提供《178C语言算法源码下载.zip》资料免费下载
    发表于 11-21 09:35 3次下载
    178<b class='flag-5'>个</b><b class='flag-5'>C</b><b class='flag-5'>语言</b><b class='flag-5'>算法</b>源码下载
    硬件工程师经典面试题详解
    硬件工程师经典面试题详解
    的头像 发表于 11-20 15:08 1354次阅读
    硬件工程师<b class='flag-5'>经典</b><b class='flag-5'>面试</b>题详解
    c语言经典教程
    电子发烧友网站提供《c语言经典教程.rar》资料免费下载
    发表于 11-20 11:45 6次下载
    <b class='flag-5'>c</b><b class='flag-5'>语言</b><b class='flag-5'>经典</b>教程
    C语言经典编程900例
    电子发烧友网站提供《C语言经典编程900例.rar》资料免费下载
    发表于 11-20 11:40 6次下载
    <b class='flag-5'>C</b><b class='flag-5'>语言</b><b class='flag-5'>经典</b>编程900例
