* x25045的读写程序 用c51写的 */
#define CS P2.7 /*单片机p2.7为片选 可以改为你的实际引脚 */
#define SO P2.6 /*数据输出 */
#define SK P2.5 /* 时钟 */
#define SI P2.4 /* 数据输入*/
/* here is the instrution of x25045*/
#define WREN 0x06
#define WRDI 0x04
#define RDSR 0x05
#define WRSR 0x01
#define READ0 0x03
#define READ1 0x0b
#define WRITE0 0x02
#define WRITE1 0x0a
unsigned char Read8()
bit bData;
unsigned char cLoop;
unsigned char cData;
for(cLoop=0;cLoop《8;cLoop++)
SK=1;
SK=0;
bData=SO;
cData《《=1;
if(bData)
cData|=0x01;
return cData;
void Write8(unsigned char cData)
if((cData&0x80)==0)
SI=0;
else
SI=1;
SK=0;
SK=1;
cData《《=1;
unsigned char ReadSR()
CS=0;
Write8(RDSR);
cData=Read8();
CS=1;
return cData;
unsigned char WriteSR(unsigned char cData)
unsigned char cTemp;
cTemp=ReadSR();
if((cTemp&0x01)==1)
return 0;
CS=0;
Write8(WREN);
CS=1;
CS=0;
Write8(WRSR);
Write8(cData);
CS=1;
return 1;
void Write1B(unsigned char cData,unsigned char cAddress,bit bRegion)
/* 写入一个字节,cData为写入的数,cAddress为写入地址,bRegion为页 */
while((ReadSR()&0x01)==1)
CS=0;
Write8(WREN);
CS=1;
CS=0;
if(bRegion==0)
Write8(WRITE0);
else
Write8(WRITE1);
Write8(cAddress);
Write8(cData);
SK=0;
CS=1;
unsigned char Read1B(unsigned char cAddress,bit bRegion)
/* 读入一个字节,cAddress为读入地址,bRegion为页 */
CS=0;
if(bRegion==0)
Write8(READ0);
else
Write8(READ1);
Write8(cAddress);
cData=Read8();
CS=1;
return cData;
单片机
6078文章
45602浏览量
674225 -
程序
117文章
3849浏览量
85513 -
x25045
9浏览量
14160
一个X25045的C51读写程序
