关于同步降压转换器主要特性,框图,基本应用电路及其元件表
电子工程师 来源:中电网 作者:中电网 2021-04-03 12:17 次阅读
ST公司的l6983是静态电流仅为17 μA的 38 V 3 A同步降压转换器.输入电压VIN为3.5V到38V,输出电压为0.85V到VIM,具有固定输出3.3V和5V版本.3A DC输出电流,内部补偿网络. L6983是基于峰值电流模式架构,采用QFN16 3x3封装.可采用低消耗模式(LCM)和低噪音模式(LNM)版本.LCM模式在轻负载时可控制输出电压波纹,最大化效率. LNM模式开关频率固定,因此轻负载时最小化输出电压波纹.L6983的开关频率可在200 Hz - 2.2 MHz间选择,同时具有扩频技术以改善EMC.关断电流2 μA.器件具有热软起动,具有过压保护和热保护以及输出电压加序.设计用于24V总线工业电源系统,24V电池供电设备,分散智能节点,传感器和常开应用以及低噪音应用.本文介绍了L6983主要特性,框图,基本应用电路(可调整版本)及其元件表,以及评估板STEVAL-ISA208V1主要特性,电路图,材料清单和PCB设计图.
The L6983 is an easy to use synchronous monolithic step-down regulator capable of delivering up to 3 A DC to the load. The wide input voltage range makes the device suitable for a broad range of applications. The L6983 is based on a peak current mode architecture and is packaged in a QFN16 3x3 with internal compensation thus minimizing design complexity and size.
The L6983 is available both in low consumption mode (LCM) and low noise mode (LNM) versions. LCM maximizes the efficiency at light-load with controlled output voltage ripple so the device is suitable for battery-powered applications. LNM makes the switching frequency constant and minimizes the output voltage ripple for light load operations, meeting the specification for low noise sensitive applications. The L6983 allows the switching frequency to be selected in the 200 Hz - 2.2 MHz range
with optional spread spectrum for improved EMC.
The EN pin provides enable/disable function. The typical shutdown current is 2 μA when disabled. As soon as the EN pin is pulled up, the device is enabled and the internal 1.3 ms soft-start takes place. The L6983 features Power Good open collector that monitors the FB voltage. Pulse-by-pulse current sensing on both power elements implements an effective constant current protection and thermal shutdown prevents thermal run-away.
L6983主要特性:
• 3.5 V to 38 V operating input voltage
• Output voltage from 0.85 V to VIN
• 3.3 V and 5 V fixed output voltage versions
• 3 A DC output current
• 17 μA operating quiescent current
• Internal compensation network
• Two different versions: LCM for high efficiency at light loads and LNM for noise sensitive applications
• 2 μA shutdown current
• Internal soft-start
• Enable
• Overvoltage protection
• Output voltage sequencing
• Thermal protection
• 200 kHz to 2.2 MHz programmable switching frequency. Stable with low ESR capacitor
• Optional spread spectrum for improved EMC
• Power Good
• Synchronization to external clock for LNM devices
• QFN16 package
L6983应用:
• Designed for 24 V buses industrial power systems
• 24 V battery powered equipment
• Decentralized intelligent nodes
• Sensors and always-on applications
• Low noise applications
图1. L6983框图
图2. L6983基本应用电路(可调整版本)
图2应用电路的元件表:
评估板STEVAL-ISA208V1
38 V, 3 A synchronous step-down switching regulator evaluation board based on the L6983CQTR
The L6983 is an easy-to-use synchronous monolithic step-down regulator capable of delivering up to 3 ADC to the load. Its wide input voltage range makes the device suitable for a broad range of applications. The device implements peak current mode architecture in a QFN16 3x3 package with internal compensation to minimize design complexity and size.
The L6983 is available both in low consumption mode (LCM) and low noise mode (LNM) versions. LCM maximizes efficiency at light-load with controlled output voltage ripple, which is ideal for battery-powered applications. LNM makes the switching frequency constant and minimizes the output voltage ripple overload current range,meeting the specification for noise sensitive applications.
The L6983 allows switching frequency selection between 200 Hz and 2.2 MHz with optional spread spectrum for improved EMC. The EN pin provides enable/disable function. The typical shutdown current is 2 μA when disabled. When the EN pin is pulled up, the device is enabled and the internal 1.3 ms soft-start takes place. The device features power good open collector that monitors the FB voltage. Pulse-bypulse
current sensing on both power elements implements effective constant current protection and thermal shutdown prevents thermal runaway.
评估板STEVAL-ISA208V1主要特性:
– LCM for high efficiency at light loads
– LNM for noise sensitive applications
• Enable
• QFN16 package
• 200 kHz to 2.2 MHz programmable switching frequency; stable with low ESR capacitor
• Power good
图3. 评估板STEVAL-ISA208V1外形图
图4. 评估板STEVAL-ISA208V1电路图
评估板STEVAL-ISA208V1材料清单:
图5. 评估板STEVAL-ISA208V1 PCB设计图(顶层)
图6. 评估板STEVAL-ISA208V1 PCB设计图(底层)
编辑:lyn
  • 传感器
  • 应用电路
  • 同步降压转换器
    同步降压转换器的输出电容对效率有什么影响
    同步降压转换器的输出电容对效率有着显著的影响,主要体现在输出电压纹波、热效应、系统稳定性以及动态响应等方面。
    的头像 发表于 08-14 10:27 393次阅读
    同步降压转换器有哪些优缺点
    同步降压转换器(Synchronous Buck Converter)作为一种高效的直流电压转换装置,在电子设备中得到了广泛应用。其通过控制开关管的导通和断开,实现输入电压到稳定输出电
    的头像 发表于 08-14 10:23 359次阅读
    简述同步降压转换器的输出电容
    同步降压转换器(Synchronous Buck Converter)的输出电容在电路中扮演着至关重要的角色,它不仅影响着输出电压的稳定性,还关系到
    的头像 发表于 08-14 10:09 311次阅读
    同步降压转换器的工作频率是什么
    同步降压转换器(Synchronous Buck Converter)的工作频率是指其内部开关元件(如MOSFET)的通断频率,也就是控制
    的头像 发表于 08-14 10:08 298次阅读
    同步降压转换器的工作原理和作用
    同步降压转换器(Synchronous Buck Converter),作为一种重要的电源管理电路,其工作原理和作用在电子技术和电力电子领域中占据着重要地位。以下是对
    的头像 发表于 08-14 09:51 1030次阅读
    降压转换器 MicroSiP模块TPS82140数据
    TPS82140 是一款 17V 输入、2A 降压转换器 MicroSiP™电源模块,经优化兼具小型解决方案尺寸和高效率优势。该模块集成了同步降压
    发表于 04-24 14:48 0次下载
    <b class='flag-5'>降压</b><b class='flag-5'>转换器</b> MicroSiP模块TPS82140数据<b class='flag-5'>表</b>
    同步降压DC/DC转换器LM2650数据
    电子发烧友网站提供《同步降压DC/DC转换器LM2650数据.pdf》资料免费下载
    发表于 04-19 10:01 0次下载
    <b class='flag-5'>同步</b><b class='flag-5'>降压</b>DC/DC<b class='flag-5'>转换器</b>LM2650数据<b class='flag-5'>表</b>
    800毫安同步降压转换器TPS6205x数据
    电子发烧友网站提供《800毫安同步降压转换器TPS6205x数据.pdf》资料免费下载
    发表于 04-09 14:55 0次下载
    800毫安<b class='flag-5'>同步</b><b class='flag-5'>降压</b><b class='flag-5'>转换器</b>TPS6205x数据<b class='flag-5'>表</b>
    低噪声同步反相降压转换器TPS63710数据
    电子发烧友网站提供《低噪声同步反相降压转换器TPS63710数据.pdf》资料免费下载
    发表于 04-03 09:41 0次下载
    低噪声<b class='flag-5'>同步</b>反相<b class='flag-5'>降压</b><b class='flag-5'>转换器</b>TPS63710数据<b class='flag-5'>表</b>
    简单易用的宽VIN同步降压转换器LMR516xx数据
    电子发烧友网站提供《简单易用的宽VIN同步降压转换器LMR516xx数据.pdf》资料免费下载
    发表于 03-22 14:04 0次下载
    简单易用的宽VIN<b class='flag-5'>同步</b><b class='flag-5'>降压</b><b class='flag-5'>转换器</b>LMR516xx数据<b class='flag-5'>表</b>
    发表于 03-11 11:20 0次下载
    低噪声同步反相降压转换器TPS63710 数据
    电子发烧友网站提供《低噪声同步反相降压转换器TPS63710 数据.pdf》资料免费下载
    发表于 03-07 10:12 0次下载
    低噪声<b class='flag-5'>同步</b>反相<b class='flag-5'>降压</b><b class='flag-5'>转换器</b>TPS63710 数据<b class='flag-5'>表</b>
    高电流、同步双通道降压转换器TPS65253数据
    电子发烧友网站提供《高电流、同步双通道降压转换器TPS65253数据.pdf》资料免费下载
    发表于 03-06 11:43 0次下载
    高电流、<b class='flag-5'>同步</b>双通道<b class='flag-5'>降压</b>型<b class='flag-5'>转换器</b>TPS65253数据<b class='flag-5'>表</b>
    dcdc降压转换器工作原理
    降压DC/DC电压转换器,又称为降压转换器、低压降转换器或简称为降压
    的头像 发表于 02-16 09:37 1494次阅读
    dcdc<b class='flag-5'>降压</b><b class='flag-5'>转换器</b>工作原理
    为什么电容器是降压转换器和升压转换器的重要元件
    的头像 发表于 11-27 17:00 548次阅读
