Infineon FS45MR12W1M1-B11 7.5kW马达驱动方案
电子工程师 来源:中电网 作者:中电网 2021-03-24 18:02 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
infineon公司的评估板Eval-M5-E1B1245N-SiC是7.5 kWCoolSiC™ MOSFET马达驱动器,包括有三相SiC功率模块,和装备了M5 32引脚接口连接器如XMC DriveCard 4400的控制板,具有CoolSiC™ MOSFET马达驱动的特性.评估板Eval-M5-E1B1245N-SiC包括有六块电源模块
FS45MR12W1M1_B11和EiceDRIVER™ 1200 V绝缘栅驱动器1EDI20H12AH.模块额定耐压指标为1200V,开态电阻为 45 mOhm.输入电压为340~480 VAC,集成了NTC温度传感器,最大马达输出功率7.5kW,板上集成了EMI滤波器,在电源信号部分间绝缘,隔离的Δ∑-ADC电流检测,热敏电阻输出,过流和短路硬件保护,超温硬件保护,保护时所有六个开关开断.主要用在马达控制和驱动,太阳能系统解决方案和不间断电源(UPS).本文介绍了评估板Eval-M5-E1B1245N-SiC主要特性和优势,框图和主要指标,电路图,材料清单和PCB装配图.
Eval-M5-E1B1245N-SiC CoolSiC™ MOSFET motor drives evaluation board for 7.5 kW
This complete evaluation board including a 3-phase SiC power module for motor drive applications. In combination with control boards equipped with the M5 32-pin interface connector such as the XMC DriveCard 4400, it features and demonstrates our CoolSiC™ MOSFETs in motor drives.
The evaluation board was developed to support customers during their first steps designing applications with the sixpack power module FS45MR12W1M1_B11 and EiceDRIVER™ 1200 V isolated gate driver 1EDI20H12AH. The module has a rated blocking voltage of 1200 V at a typical on-state resistance of 45 mOhm. It is optimized for motor drive applications with a very high-frequency switching operation.
评估板Eval-M5-E1B1245N-SiC主要特性:
EasyPACK™ 1B 1200 V / 45 mΩ sixpack module with CoolSiC™ MOSFET
Lead-free terminal plating; RoHS compliant
Low inductive design
Integrated NTC temperature sensor
The evaluation board characteristics are:
Input voltage 340~480 VAC
Maximum 7.5 kW motor power output
On-board EMI filter
Basic insulation between power and signal part
Isolated current sensing with Δ∑-ADC
Isolated sensing of dc-link voltage by Δ∑-ADC
Thermistor output
Overload and short-circuit hardware protection
Overtemperature hardware protection
All six switches turn off during protection
Rugged gate driver technology with stability against transient and negative voltage
Auxiliary power supply with 5 V
Measurement test points compatible with standard oscilloscope probes
PCB is 259 mm x 204 mm and has four layers of 35 μm copper each
评估板Eval-M5-E1B1245N-SiC主要优势:
MADK is optimized to GPD / Servo drives with very high fsw
Including the Easy 1B with CoolSiC™ MOSFET in sixpack configuration
Equipped with all assembly groups for sensorless field oriented control (FOC)
Overtemperature and overcurrent protection as well as short circuit protection
Diagrams
图1.评估板Eval-M5-E1B1245N-SiC框图
评估板Eval-M5-E1B1245N-SiC主要指标:
This application note provides an overview of the evaluation board Eval-M5-E1B1245N-SiC including its main features, key data, pin assignments and mechanical dimensions.
Eval-M5-E1B1245N-SiC is a complete evaluation board including a 3-phase SiC power module for motor drive applications. In combination with control boards equipped with the M5 32-pin interface connector such as the XMC DriveCard 4400, it features and demonstrates Infineon’s CoolSiC™ MOSFETs in motor drives.
The evaluation board Eval-M5-E1B1245N-SiC was developed to support customers during their first steps designing applications with the sixpack power module FS45MR12W1M1_B11. The module has a rated blocking voltage of 1200 V at a typical on-state resistance of 45 mOhm. It is optimized for motor drive applications with a very high-frequency switching operation.
The Eval-M5-E1B1245N-SiC evaluation board is part of the iMOTION™ Modular Application Design Kit for motor drives (iMOTION™ MADK).
The MADK platform is intended for use at various power stages with different control boards. These boards can easily be interfaced via the iMOTION™ MADK-M5 32-pin interface connector to control boards such as the XMC DriveCard 4400 or XMC DriveCard 1300.
This evaluation board is designed as an easy-to-use power stage based on Infineon’s 3-phase power modules. The board is equipped with shunts in the phase output enabling the implementation of sensorless control. It provides a three-phase AC connector, EMI filter, rectifier and a 3-phase output for connecting the motor. The power stage also contains isolated current, voltage and temperature sensing circuits.
The Eval-M5-E1B1245N-SiC evaluation board is available via regular Infineon distribution partners as well as on Infineon’s website. The features of this board are described in the design feature chapter of this document. The remaining paragraphs provide information enabling customers to copy, modify and qualify the design for production according to their own specific requirements.
Environmental conditions were considered in the design of the Eval-M5-E1B1245N-SiC. The design was tested as described in this document, but not qualified in terms of safety requirements, manufacturing and operation over the entire operating temperature range or lifetime. The boards provided by Infineon are subject to functional testing only.
Evaluation boards are not subject to the same procedures as regular products regarding Returned Material Analysis (RMA), Process Change Notification (PCN) and Product Discontinuation (PD). Evaluation boards are intended to be used under laboratory conditions and by trained specialists only.
潜在应用:
Motor control and drives
Solutions for solar energy systems
Uninterruptible power supply
图2.评估板Eval-M5-E1B1245N-SiC外形图
图3.评估板Eval-M5-E1B1245N-SiC正面概述图
图4.评估板Eval-M5-E1B1245N-SiC侧面图
图3和图4中数字功能表:
图5.驱动器板连接器电路图
图6.主输入和预充电电路
图7.EMI滤波器电路
图8.辅助电源电路
图9.功率级
图10.单相腿驱动器电路
图11.驱动器电源电路
图12.驱动器电路整流器电路
图13.评估板NTC测量电路
图14.相位电流测量电路
图15.DC总线电压测量电路
图16.数模转换测量电路
图17.保护电路和温度测量电路
图18.短路保护电路
图19.评估板Eval-M5-E1B1245N-SiC顶层装配图
图20.评估板Eval-M5-E1B1245N-SiC底层装配图
评估板Eval-M5-E1B1245N-SiC材料清单:
编辑:jq
  • 电源
  • 驱动
  • 马达
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    EVAL-M1-6ED2230-B1评估板:电机驱动设计的得力助手
    EVAL-M1-6ED2230-B1评估板:电机驱动设计的得力助手 在电机驱动应用的设计领域,评估板的作用至关重要。今天我们就来详细了解一下英飞凌(Infineon)的EVAL -
    的头像 发表于 05-18 12:40 146次阅读
    CoolSiC™ MOSFET电机驱动评估板Eval - M5 - E1B1245N - SiC深度解析
    了解一下Infineon的CoolSiC™ MOSFET电机驱动评估板Eval - M5 - E1B1245N - SiC,它专为7.5
    的头像 发表于 05-18 12:10 218次阅读
    Infineon EVAL-M1-IM323评估板:电机驱动设计的理想之选
    Infineon EVAL-M1-IM323评估板:电机驱动设计的理想之选 在电机驱动应用设计领域,Infineon的EVAL-
    的头像 发表于 05-18 11:45 249次阅读
    尝试运行KW45B41Z-EVK开发板的BLE示例
    我正在尝试运行KW45B41Z-EVK开发板的BLE示例。我已经使用SDK版本25.06.00 (890 2025-06-27)尝试了以下示例: kw45b
    发表于 05-15 07:00
    FS01MR12A8MA2BHPSA1具体参数 Infineon品牌 产品种类: MOSFET模块
    (英飞凌)打造系统级解决方案,应该能满足车身上所有的基本需求,像车身、动力总成等。 FS01MR12A8MA2BHPSA1 制造商:Infineon 产品种类:MOSFET模块 RoHS: 技术
    发表于 03-31 11:35
    新品 | CoolSiC™ 碳化硅MOSFET M1H EasyDUAL™ 1200V
    温度传感器,具有1200V耐压和4mΩ导通电阻,专为电动汽车电驱动系统与电动航空生态系统中的功率转换应用而设计。产品型号:■FF4MR12W2M1HP_B11_A
    的头像 发表于 01-22 17:05 1530次阅读
    新品 | CoolSiC™ 碳化硅MOSFET <b class='flag-5'>M1</b>H EasyDUAL™ 1200V
    EVAL-M1-36-45A评估板:电机驱动设计的得力助手
    EVAL-M1-36-45A评估板:电机驱动设计的得力助手 一、引言 在电机驱动应用的设计领域,拥有一款性能优良且易于评估的开发板至关重要。EVAL-M1-36-45A评估板作为iMO
    的头像 发表于 12-21 09:40 1030次阅读
    DF4-19MR20W3M1HF_B11 EasyPACK™模块:高效能与可靠性的完美结合
    的DF4-19MR20W3M1HF_B11 EasyPACK™模块,就是这样一款集多种优势于一身的产品,它在太阳能等应用中展现出了卓越的性能。 文件下载: Infineon Technologies
    的头像 发表于 12-20 15:40 1737次阅读
    FS75R17W2E4P_B11 EasyPACK™模块:特性、应用与参数解析
    EasyPACK™模块,凭借其出色的电气和机械特性,在众多应用场景中展现出了强大的竞争力。 文件下载: Infineon Technologies FS75R17W2E4P_B11 EasyPACK
    的头像 发表于 12-20 15:40 1438次阅读
    EVAL-6ED2231S12TM1评估板:开启电机驱动新世界
    EVAL-6ED2231S12TM1是一款用于评估1200V SOI三相栅极驱动器6ED2231S12T以及EasyPACK™ 1B 1200V CoolSiC™ MOSFET模块
    的头像 发表于 12-20 11:35 2684次阅读
    EVAL-1ED3330MC12M-SiC评估板:助力SiC栅极驱动器评估与设计
    EVAL-1ED3330MC12M-SiC评估板:助力SiC栅极驱动器评估与设计 在电力电子领域,对于栅极驱动器的评估和设计是至关重要的环节。今天,我们就来详细探讨一下Infineon
    的头像 发表于 12-18 14:20 919次阅读
    大联大品佳集团推出基于Infineon产品的1.4kW压缩机电机方案
    大联大控股宣布,其旗下品佳推出基于英飞凌(Infineon)EVAL-M3-IM564评估板的1.4kW压缩机电机方案。 图示1-大联大品佳
    的头像 发表于 10-17 11:06 971次阅读
    大联大品佳集团推出基于<b class='flag-5'>Infineon</b>产品的1.4<b class='flag-5'>kW</b>压缩机电机<b class='flag-5'>方案</b>
    ‌STMicroelectronics M2P45M12W2-1LA SiC功率模块技术解析
    STMicroelectronics M2P45M12W2-1LA汽车电源模块提供带有集成NTC的六块 拓扑结构,专门用于混合动力和电动汽车中板载充电器 (OBC) 的DC/DC 转换器 级。该
    的头像 发表于 10-15 09:44 1027次阅读
    ‌STMicroelectronics <b class='flag-5'>M2P45M12W2-1</b>LA SiC功率模块技术解析
    新品 | 面向电动汽车充电应用的Easy模块产品扩展
    NTC温度传感器并配备PressFIT针脚。产品型号:■F4-6MR20W3M1H_B11■F4-10MR20W3M1H_B11■F4-11MR12W3M1H_B1
    的头像 发表于 07-15 17:08 852次阅读
    新品 | 用于CoolSiC™ MOSFET FF6MR20W2M1H_B70的双脉冲测试评估板
    新品用于CoolSiCMOSFETFF6MR20W2M1H_B70的双脉冲测试评估板评估板是用于评估采用1ED3890MC12M栅极驱动
    的头像 发表于 06-12 17:33 1516次阅读
    新品 | 用于CoolSiC™ MOSFET FF6<b class='flag-5'>MR20W2M1H_B</b>70的双脉冲测试评估板
