ARM Linux中一些重要的宏及地址定义
如意 来源:CSDN 作者:CaspianSea 2020-06-22 17:02 次阅读
1)TEXT_OFFSET 内核在RAM中的起始位置相对于RAM起始地址偏移。值为0x00008000
。/arch/arm/Makefile
111 textofs-y := 0x00008000
112 textofs-$(CONFIG_ARCH_CLPS711X) := 0x00028000
113 # We don‘t want the htc bootloader to corrupt kernel during resume
114 textofs-$(CONFIG_PM_H1940) := 0x00108000
115 # SA1111 DMA bug: we don’t want the kernel to live in precious DMA-able memory
116 ifeq ($(CONFIG_ARCH_SA1100),y)
117 textofs-$(CONFIG_SA1111) := 0x00208000
118 endif
212 # The byte offset of the kernel image in RAM from the start of RAM.
213 TEXT_OFFSET := $(textofs-y)
2)PAGE_OFFSE 内核镜像起始虚拟地址。值为0xC0000000
arch/arm/Kconfig
1165 config PAGE_OFFSET ----这个就是CONFIG_PAGE_OFFSET宏,默认值为0xC0000000
1166 hex
1167 default 0x40000000 if VMSPLIT_1G
1168 default 0x80000000 if VMSPLIT_2G
1169 default 0xC0000000
。/arch/arm/include/asm/memory.h
34 #define PAGE_OFFSET UL(CONFIG_PAGE_OFFSET)
3)PHYS_OFFSET RAM启始物理地址,对应于DDR的物理地址。需要在mach-xxxx/include/mach/memory.h文件中定义这个宏。
对于2410来说值为0x30000000,RAM接在片选6上
arch/arm/mach-s3c2410/include/mach/memory.h
#define PHYS_OFFSET UL(0x30000000)
4)KERNEL_RAM_VADDR 内核在RAM中的虚拟地址。值为0xC0008000
5)KERNEL_RAM_PADDR 内核在RAM中的物理地址。值为0x30008000
arch/arm/kernel/head.S
29 #define KERNEL_RAM_VADDR (PAGE_OFFSET + TEXT_OFFSET)
30 #define KERNEL_RAM_PADDR (PHYS_OFFSET + TEXT_OFFSET)
6)swapper_pg_dir 初始页表虚拟地址,值为0xC0004000,
一般分配KERNEL_RAM_VADDR地址下16K作为页表,因此,我们必须确保正确设置KERNEL_RAM_VADDR。
44 .globl swapper_pg_dir
45 .equ swapper_pg_dir, KERNEL_RAM_VADDR - 0x4000
7)VMALLOC_START 0xc4800000
8)VMALLOC_END 0xe0000000
9)MODULES_VADDR 0xbf000000
10)MODULES_END 0xc0000000
47 #ifndef CONFIG_THUMB2_KERNEL
48 #define MODULES_VADDR (PAGE_OFFSET - 16*1024*1024)
49 #else
50 /* smaller range for Thumb-2 symbols relocation (2^24)*/
51 #define MODULES_VADDR (PAGE_OFFSET - 8*1024*1024)
52 #endif
53
54 #if TASK_SIZE 》 MODULES_VADDR
55 #error Top of user space clashes with start of module space
56 #endif
57
58 /*
59 * The highmem pkmap virtual space shares the end of the module area.
60 */
61 #ifdef CONFIG_HIGHMEM
62 #define MODULES_END (PAGE_OFFSET - PMD_SIZE)
63 #else
64 #define MODULES_END (PAGE_OFFSET)
65 #endif
11)PKMAP_BASE
arch/arm/include/asm/highmem.h:
6:#define PKMAP_BASE (PAGE_OFFSET - PMD_SIZE)
12)TASK_SIZE
35 #define TASK_SIZE (UL(CONFIG_PAGE_OFFSET) - UL(0x01000000))
36 #define TASK_UNMAPPED_BASE (UL(CONFIG_PAGE_OFFSET) / 3)
13)一些不同地址之间转换的宏
135 /*
136 * Physical vs virtual RAM address space conversion. These are
137 * private definitions which should NOT be used outside memory.h
138 * files. Use virt_to_phys/phys_to_virt/__pa/__va instead.
139 */
140 #ifndef __virt_to_phys
141 #define __virt_to_phys(x) ((x) - PAGE_OFFSET + PHYS_OFFSET)//物理地址和虚拟地址
142 #define __phys_to_virt(x) ((x) - PHYS_OFFSET + PAGE_OFFSET)//之间转换的宏
143 #endif
144
145 /*
146 * Convert a physical address to a Page Frame Number and back
147 */
148 #define __phys_to_pfn(paddr) ((paddr) 》》 PAGE_SHIFT) //物理地址和页帧号之间
149 #define __pfn_to_phys(pfn) ((pfn) 《《 PAGE_SHIFT) //转换的宏
150
151 /*
152 * Convert a page to/from a physical address
153 */
154 #define page_to_phys(page) (__pfn_to_phys(page_to_pfn(page)))//页地址和物理地址
155 #define phys_to_page(phys) (pfn_to_page(__phys_to_pfn(phys)))//之间的转换宏依赖于内存模型。
201 /*
202 * Drivers should NOT use these either.
203 */
204 #define __pa(x) __virt_to_phys((unsigned long)(x))
205 #define __va(x) ((void *)__phys_to_virt((unsigned long)(x)))
206 #define pfn_to_kaddr(pfn) __va((pfn) 《《 PAGE_SHIFT)
207
208 /*
209 * Virtual 《-》 DMA view memory address translations
210 * Again, these are *only* valid on the kernel direct mapped RAM
211 * memory. Use of these is *deprecated* (and that doesn‘t mean
212 * use the __ prefixed forms instead.) See dma-mapping.h.
213 */
214 #ifndef __virt_to_bus
215 #define __virt_to_bus __virt_to_phys
216 #define __bus_to_virt __phys_to_virt
217 #define __pfn_to_bus(x) __pfn_to_phys(x)
218 #define __bus_to_pfn(x) __phys_to_pfn(x)
219 #endif
  • ARM
    ARM
  • Linux
    为什么你的串口总是丢一些特殊字符?
    导读在嵌入式开发和物联网应用中,Linux系统的串口通信至关重要。本文将简单介绍Linux下串口设备的命名规则和termios结构体,并解析终端的三种工作模式,帮助开发者更好地掌握Linux
    的头像 发表于 02-06 13:26 94次阅读
    为什么你的串口总是丢<b class='flag-5'>一些</b>特殊字符?
    迅为RK3588开发板实时系统编译-Preemption系统/ Xenomai系统编译-设置屏幕配置
    定义是#define LCD_TYPE_LVDS_10_1_1280x800_GT9271, 需要将kernel/arch/arm64/configs/rockchip_linux
    发表于 01-14 16:19
    定义后面能不能加分号
    用define定义,最后需不需要加分号?
    的头像 发表于 01-06 16:35 203次阅读
    如何在Linux系统上设置站群服务器IP地址
    Linux系统上设置站群服务器的IP地址,可以通过以下步骤进行,主机推荐小编为您整理发布如何在Linux系统上设置站群服务器IP地址
    的头像 发表于 12-11 10:05 253次阅读
    这些ipv6公网地址查询方法,定要知道!
    路由器管理界面查看,联系互联网服务提供商获取信息,以及使用网络诊断和扫描工具如ping、traceroute和Nmap,以下是UU云小编整理的一些常见方法: IPv6公网地址查询是网络管理和故障排除中的重要环节。
    的头像 发表于 12-10 13:37 1549次阅读
    一些常见的动态电路
    无论是模电还是数电,理论知识相对来说还是比较枯燥,各种电路原理理解清楚不算容易,换种生动形象的方式或许会增加一些趣味性,也更容易理解这些知识。下面整理了一些常见的电路,以动态图形的方式展示。 整流
    的头像 发表于 11-16 09:26 552次阅读
    <b class='flag-5'>一些</b>常见的动态电路
    分享一些常见的电路
    理解模电和数电的电路原理对于初学者来说可能比较困难,但通过一些生动的教学方法和资源,可以有效地提高学习兴趣和理解能力。 下面整理了一些常见的电路,以动态图形的方式展示。 整流电路 单相桥式整流
    的头像 发表于 11-13 09:28 451次阅读
    分享<b class='flag-5'>一些</b>常见的电路
    C语言中最常见的定义写法
    如果让你用C语言写个定义,我相信大部分同学顺手就能写出define。
    的头像 发表于 10-28 11:12 415次阅读
    Linux应用编程的基本概念
    Linux应用编程涉及到在Linux环境下开发和运行应用程序的系列概念。以下是一些涵盖Linux应用编程的基本概念。
    的头像 发表于 10-24 17:19 314次阅读
    SV中define定义的用法
    SV中使用预处理指令`define来定义可以用来创建文本替换。根据场景不同,`define主要用来定义常量、简化复杂的表达式或代码段以及提高代码的可移植性。其基本语法为:
    的头像 发表于 10-21 14:22 888次阅读
    LED驱动器应用的一些指南和技巧
    电子发烧友网站提供《LED驱动器应用的一些指南和技巧.pdf》资料免费下载
    发表于 09-25 11:35 0次下载
    LED驱动器应用的<b class='flag-5'>一些</b>指南和技巧
    FPGA电路设计的一些技巧
    FPGA设计有别于DSP和ARM系统,相比之下较为灵活和自由。主要是设计构思好专用管脚的电路,通用I/O的连接可以自身定义。因而,FPGA电路设计中会有一些独特的方法能够参照。 FPGA管脚兼容性
    发表于 07-21 20:20
    Linux 6.8版本– Arm、RISC-V和MIPS体系结构的显著变化
    Linus Torvalds刚刚在Linux内核邮件列表上宣布了Linux 6.8的发布: 因此,本次发布的提交数量下降的时间比我倾向于的要长一些,但其中很多似乎是关于各种自检更新(尤其是网络),而
    的头像 发表于 03-13 15:58 4688次阅读
    <b class='flag-5'>Linux</b> 6.8版本– <b class='flag-5'>Arm</b>、RISC-V和MIPS体系结构的显著变化
    一些有关通信电路的资料?
    有关嵌入式之间DSP、ARM、FPGA三者之间和这三款芯片和外部电路之间通信的一些资料,比如说芯片之间的并行通信和芯片和外部电路之间的串行通信,MODBUS、DP、CAN等,一些一些
    发表于 03-03 18:53
    嵌入式Linux C语言编程程序调试与定义
    Linux使用gcc编译程序的时候,对于调试的语句还具有一些特殊的语法。gcc编译的过程中,会生成一些,可以使用这些分别打印当前源文件
    发表于 03-01 11:41 1155次阅读
