1.IP地址:192.168.1.241
下载这次部署需要的更新包,并上传到/usr/local/src目录:[root@binds src]# ll
total 17576
-rw-r--r-- 1 root root 730589 Jul 14 13:29 nginx-1.2.8.tar.gz
-rw-r--r-- 1 root root 1790055 Jul 29 10:39 pcre-8.32.tar.gz
-rw-r--r-- 1 root root 14902187 Jul 28 18:00 php-5.3.22.tar.gz
-rw-r--r-- 1 root root 560351 Jul 29 10:41 zlib-1.2.7.tar.gz
安装nginx必须安装pcre-8.32.tar.gz
[root@binds pcre-8.32]# tar zxvf pcre-8.32.tar.gz
[root@binds pcre-8.32]# cd pcre-8.32
[root@binds pcre-8.32]# 。/configure
[root@binds pcre-8.32]# make && make install
make[3]: Leaving directory `/usr/local/src/pcre-8.32‘
make[2]: Leaving directory `/usr/local/src/pcre-8.32’
make[1]: Leaving directory `/usr/local/src/pcre-8.32‘
安装结束
接下来安装
[root@binds src]# tar zxvf zlib-1.2.7.tar.gz
[root@binds src]# cd zlib-1.2.7
[root@binds zlib-1.2.7]# 。/configure
出现错误Looking for a four-byte integer type.。。 Found. 无关紧要
[root@localhost zlib-1.2.7]# make && make install
chmod 644 /usr/local/lib/libz.a
cp libz.so.1.2.7 /usr/local/lib
chmod 755 /usr/local/lib/libz.so.1.2.7
cp zlib.3 /usr/local/share/man/man3
chmod 644 /usr/local/share/man/man3/zlib.3
cp zlib.pc /usr/local/lib/pkgconfig
chmod 644 /usr/local/lib/pkgconfig/zlib.pc
cp zlib.h zconf.h /usr/local/include
chmod 644 /usr/local/include/zlib.h /usr/local/include/zconf.h
安装完成后,安装nginx
[root@binds src]# tar zxvf nginx-1.2.8.tar.gz
[root@binds src]# cd nginx-1.2.8
。/configure --prefix=/usr/local/nginx-1.2.8 --with-http_sub_module --with-http_stub_status_module --with-http_ssl_module --with-http_gzip_static_module
Configuration summary
+ using system PCRE library
+ using system OpenSSL library
+ md5: using OpenSSL library
+ sha1: using OpenSSL library
+ using system zlib library
nginx path prefix: “/usr/local/nginx-1.2.8”
nginx binary file: “/usr/local/nginx-1.2.8/sbin/nginx”
nginx configuration prefix: “/usr/local/nginx-1.2.8/conf”
nginx configuration file: “/usr/local/nginx-1.2.8/conf/nginx.conf”
nginx pid file: “/usr/local/nginx-1.2.8/logs/nginx.pid”
nginx error log file: “/usr/local/nginx-1.2.8/logs/error.log”
nginx http access log file: “/usr/local/nginx-1.2.8/logs/access.log”
nginx http client request body temporary files: “client_body_temp”
nginx http proxy temporary files: “proxy_temp”
nginx http fastcgi temporary files: “fastcgi_temp”
nginx http uwsgi temporary files: “uwsgi_temp”
nginx http scgi temporary files: “scgi_temp”
[root@binds nginx-1.2.8]# make && make install
cp conf/nginx.conf ’/usr/local/nginx-1.2.8/conf/nginx.conf.default‘
test -d ’/usr/local/nginx-1.2.8/logs‘ || mkdir -p ’/usr/local/nginx-1.2.8/logs‘
test -d ’/usr/local/nginx-1.2.8/html‘ || cp -R html ’/usr/local/nginx-1.2.8‘
make[1]: Leaving directory `/usr/local/src/nginx-1.2.8’
安装完成
打补丁:后面会补全
root@binds nginx-1.2.8]# service iptables stop
iptables: Setting chains to policy ACCEPT: filter [ OK ]
iptables: Flushing firewall rules: [ OK ]
iptables: Unloading modules: [ OK ]
[root@localhost nginx-1.2.8]# /usr/local/nginx-1.2.8/sbin/nginx
/usr/local/nginx-1.2.8/sbin/nginx: error while loading shared libraries: libpcre.so.1: cannot open shared object file: No such file or directory
报错解决方法:
创建软连接:[root@binds share]#测试下:ln -s /usr/local/lib/libpcre.so.1 /lib64/
接下来继续安装php
mkdir -p /usr/local/php/lib/php/extensions/no-debug-non-zts-20090626
[root@binds share]# cd /usr/local/src/
total 17592
drwxr-xr-x 9 1001 1001 4096 Aug 10 10:58 nginx-1.2.8
drwxr-xr-x 9 1169 1169 12288 Aug 10 10:34 pcre-8.32
drwxr-xr-x 14 501 games 4096 Aug 10 10:52 zlib-1.2.7
[root@binds src]# tar zxvf php-5.3.22.tar.gz
[root@binds php-5.3.22]# yum -y install libjpeg libjpeg-devel libpng libpng-devel freetype freetype-devel libxml2 libxml2-devel zlib zlib-devel glibc glibc-devel glib2 glib2-devel bzip2 bzip2-devel ncurses ncurses-devel curl curl-devel e2fsprogs e2fsprogs-devel krb5 krb5-devel libidn libidn-devel openssl openssl-devel openldap openldap-devel nss_ldap openldap-clients openldap-servers gd curl curl-devel mysql mysql-devel mhash libiconv mcrypt
。/configure “--prefix=/usr/local/php” “--enable-fpm” “--with-config-file-path=/home/server_config/php” “--with-mysql=/usr/local/mysql” “--with-mysqli=/usr/local/mysql/bin/mysql_config” “--with-pdo-mysql=/usr/local/mysql” “--with-iconv-dir” “--with-freetype-dir” “--with-jpeg-dir” “--with-png-dir” “--with-gd” “--with-zlib” “--with-libxml-dir” “--with-curl” “--with-curlwrappers” “--with-openssl” “--with-mhash” “--with-xmlrpc” “--with-mcrypt” “--with-ldap” “--with-ldap-sasl” “--enable-xml” “--enable-safe-mode” “--enable-bcmath” “--enable-shmop” “--enable-sysvsem” “--enable-inline-optimization” “--enable-mbregex” “--enable-mbstring” “--enable-gd-native-ttf” “--enable-ftp” “--enable-pcntl” “--enable-sockets” “--enable-fastcgi”
低版本:。/configure --prefix=/usr/local/php \
--with-config-file-path=/home/server_config/php\
--with-mysql=/usr/local/mysql/ \
--with-mysqli=/usr/local/mysql/bin/mysql_config --with-iconv-dir=/usr/local/ \
--with-freetype-dir --with-jpeg-dir --with-png-dir --with-zlib --with-libxml-dir=/usr/ \
--enable-xml --disable-rpath --enable-discard-path --enable-bcmath \
--enable-shmop --enable-sysvsem --enable-inline-optimization --with-curl --with-curlwrappers \
--enable-mbregex --enable-fastcgi --enable-fpm --enable-force-cgi-redirect --enable-mbstring \
--with-mcrypt --with-gd --enable-gd-native-ttf --with-openssl --with-mhash --enable-pcntl \
--enable-sockets --with-ldap --with-ldap-sasl --with-xmlrpc --enable-zip --enable-soap
--enable-safe-mode
可能报错:
checking for LDAP Cyrus SASL support.。。 yes
configure: error: Cannot find ldap libraries in /usr/lib.
执行:cp -frp /usr/lib64/libldap* /usr/lib
checking for mcrypt support.。。 yes
configure: error: mcrypt.h not found. Please reinstall libmcrypt.
上传libmcrypt-2.5.8.tar.gz
# tar zxvf libmcrypt-2.5.8.tar.gz
# cd libmcrypt-2.5.8
# 。/configure
# make
# make install
checking for specified location of the MySQL UNIX socket.。。 no configure: error: Cannot find libmysq
执行:
cp -rp /usr/lib64/mysql/libmysqlclient.so.16.0.0 /usr/lib/libmysqlclient.so
[root@localhost php-5.3.22]# make && make install
/usr/bin/ld: cannot find -lltdl
collect2: ld returned 1 exit status
make: *** [libphp5.la] Error 1
如果需要mcrypt,那么需要安装libltdl
libltdl在libmcrypt软件包中就有,具体过程:
#cd /software/libmcrypt-2.5.8/libltdl
#./configure –enable-ltdl-install
[root@localhost php-5.3.22]# cp php.
php.gif php.ini-development php.ini-production
[root@localhost php-5.3.22]# cp php.ini-development /usr/local/php-5.3.22/lib/
[root@localhost php-5.3.22]# cp php.ini-production /usr/local/php-5.3.22/lib/
[root@localhost php-5.3.22]# cd /usr/local/php-5.3.22/
[root@localhost php-5.3.22]# ll
total 32
drwxr-xr-x 2 root root 4096 Aug 11 18:16 bin
drwxr-xr-x 2 root root 4096 Aug 11 18:16 etc
drwxr-xr-x 3 root root 4096 Aug 11 18:16 include
drwxr-xr-x 3 root root 4096 Aug 11 18:18 lib
drwxr-xr-x 4 root root 4096 Aug 11 18:15 man
drwxr-xr-x 2 root root 4096 Aug 11 18:15 sbin
drwxr-xr-x 3 root root 4096 Aug 11 18:15 share
drwxr-xr-x 4 root root 4096 Aug 11 18:15 var
[root@localhost php-5.3.22]# cd etc/
[root@localhost etc]# ll
total 28
-rw-r--r-- 1 root root 1222 Aug 11 18:16 pear.conf
-rw-r--r-- 1 root root 21680 Aug 11 18:15 php-fpm.conf.default
[root@localhost etc]# mv php-fpm.conf.default php-fpm.conf
[root@localhost etc]# /usr/local/php-5.3.22/sbin/php-fpm
第三方php apc apcu的安装
上传APC-3.1.9.tgz apcu-4.0.6.tgz到服务器
tar zxvf APC-3.1.9.tgz
[root@localhost APC-3.1.9]# /usr/local/php/bin/phpize
[root@localhost src]# tar zxvf apcu-4.0.6.tgz
[root@localhost apcu-4.0.6]# /usr/local/php/bin/phpize
。/configure --enable-apcu --with-php-config=/usr/local/php/bin/php-config
。/configure --prefix=/usr/local/unixODBC-2.3.0 --includedir=/usr/local/include --libdir=/usr/lib -bindir=/usr/bin --sysconfdir=/etc
安装imagick-3.1.0RC2 先yum -y install ImageMagick-devel
PHP
454浏览量
26774 -
nginx
154浏览量
12227 -
CentOS
79浏览量
13801
