CMSIS-RTOS API是ARM公司为RTOS内核制定的一套通用接口协议,它提供了一套「标准的API接口」,可以移植到各种各样的RTOS上,使得上层的软件、中间件、库以及其他组件在不同的RTOS之上都可以正常工作。
这套API表现为两个文件:cmsis-os.h和cmsis-os.c,也就是说,不同的RTOS内核分别用自己的一套东西去适配.c文件中的接口,而用户只需要调用.h文件中给出的API编写应用。
本文会列举性的给出CMSIS-RTOS有哪些API和宏定义,并给出每类API的使用demo,学习者只需要了解这些东西,能看懂用CMSIS-RTOS API编写的应用程序即可~
基于TencentOS-tiny的CMSIS-RTOS API v1.02版本实现:
cmsis_os.h
cmsis_os.c
基于TencentOS-tiny的CMSIS-RTOS API v2.1.3版本实现:
cmsis_os2.h
cmsis_os2.c
CMSIS-RTOS API的整体架构如下图:
2. CMSIS-RTOS API列表
下面列出了 CMSIS-RTOS API v1.02 版本提供的所有API。
CMSIS-RTOS 所有API使用的错误码(cmsis-os.h):
typedefenum{
osOK=0,///< function completed; no error or event occurred. osEventSignal = 0x08, ///< function completed; signal event occurred. osEventMessage = 0x10, ///< function completed; message event occurred. osEventMail = 0x20, ///< function completed; mail event occurred. osEventTimeout = 0x40, ///< function completed; timeout occurred. osErrorParameter = 0x80, ///< parameter error: a mandatory parameter was missing or specified an incorrect object. osErrorResource = 0x81, ///< resource not available: a specified resource was not available. osErrorTimeoutResource = 0xC1, ///< resource not available within given time: a specified resource was not available within the timeout period. osErrorISR = 0x82, ///< not allowed in ISR context: the function cannot be called from interrupt service routines. osErrorISRRecursive = 0x83, ///< function called multiple times from ISR with same object. osErrorPriority = 0x84, ///< system cannot determine priority or thread has illegal priority. osErrorNoMemory = 0x85, ///< system is out of memory: it was impossible to allocate or reserve memory for the operation. osErrorValue = 0x86, ///< value of a parameter is out of range. osErrorOS = 0xFF, ///< unspecified RTOS error: run-time error but no other error message fits. os_status_reserved = 0x7FFFFFFF ///< prevent from enum down-size compiler optimization. } osStatus;
CMSIS-RTOS API一些可选项控制是否开启(cmsis-os.h):
#defineosFeature_MainThread1///< main thread 1=main can be thread, 0=not available
#defineosFeature_Pool1///< Memory Pools: 1=available, 0=not available #define osFeature_MailQ 1 ///< Mail Queues: 1=available, 0=not available #define osFeature_MessageQ 1 ///< Message Queues: 1=available, 0=not available #define osFeature_Signals 0 ///< maximum number of Signal Flags available per thread #define osFeature_Semaphore 30 ///< maximum count for ef osSemaphoreCreate function #define osFeature_Wait 0 ///< osWait function: 1=available, 0=not available #define osFeature_SysTick 1 ///< osKernelSysTick functions: 1=available, 0=not available
2.1. 内核信息和控制
API | 描述 |
osKernelInitialize | 初始化RTOS内核 |
osKernelStart | 启动RTOS内核 |
osKernelRunning | Query if the RTOS kernel is running |
osKernelSysTick (可选) | Get RTOS kernel system timer counter |
osKernelSysTickFrequency (可选) | RTOS kernel system timer frequency in Hz |
osKernelSysTickMicroSec (可选) | Convert microseconds value to RTOS kernel system timer value |
osKernelInitialize
osStatusosKernelInitialize(void);
返回值:status code
osKernelStart
osStatusosKernelStart(void);
返回值:status code
osKernelRunning
int32_tosKernelRunning(void);
返回值:0表示RTOS未启动,1表示RTOS已经启动
osKernelSysTick
uint32_tosKernelSysTick(void);
返回值:RTOS内核系统当前的时间
2.2. 线程管理
##连接符的作用是连接两个字符串,合为一个字符串。
CMSIS-RTOS API 存放线程参数管理的结构体如下:typedefstructos_thread_def{
char*name;///< Thread name os_pthread pthread; ///< start address of thread function osPriority tpriority; ///< initial thread priority uint32_t instances; ///< maximum number of instances of that thread function k_stack_t *stackbase; ///< base address of task uint32_t stacksize; ///< stack size requirements in bytes; 0 is default stack size k_timeslice_t timeslice; ///< timeslice k_task_t *task; } osThreadDef_t;
CMSIS-RTOS API 定义线程的宏如下:
#defineosThreadDef(name,priority,instances,stacksz)
k_task_ttask_handler_##name; k_stack_ttask_stack_##name[(stacksz)]; constosThreadDef_tos_thread_def_##name= {#name,(os_pthread)(name),(osPriority)(priority),(instances), (&((task_stack_##name)[0])),(stacksz),((k_timeslice_t)0u),(&(task_handler_##name))}
宏定义中的 instances 表示基于此任务参数,创建出几个任务实例,比如instances为2,则会创建出两个任务。
CMSIS-RTOS API定义的获取线程参数结构体的宏如下:
#defineosThread(name)
&os_thread_def_##name
管理线程参数的API如下:
API | 描述 |
osThreadCreate | 创建线程并开始执行 |
osThreadTerminate | 停止线程执行 |
osThreadYield | 线程主动让出 |
osThreadGetID | 获取当前正在运行线程的ID |
osThreadSetPriority | 改变线程优先级 |
osThreadGetPriority | 获取线程优先级 |
osThreadCreate
osThreadIdosThreadCreate(constosThreadDef_t*thread_def,void*argument);
其中osThreadId被定义为k_task_t指针类型:typedefk_task_t*osThreadId;
返回值:TencentOS-tiny中的任务控制块类型指针。
osThreadTerminate
osStatusosThreadTerminate(osThreadIdthread_id);
返回值:osStatus
osThreadYield
osStatusosThreadYield(void);
返回值:osStatus
osThreadGetID
osThreadIdosThreadGetId(void);
osThreadSetPriority
osStatusosThreadSetPriority(osThreadIdthread_id,osPrioritypriority);
osThreadGetPriority
osPriorityosThreadGetPriority(osThreadIdthread_id);
使用时需要特别注意,在TencentOS-tiny中,调用CMSIS-RTOS API提供的优先级选项设置之后,实际设置的任务值是不同的。
CMSIS-RTOS API提供的线程优先级宏定义如下:
typedefenum{
osPriorityIdle=-3,///< priority: idle (lowest) osPriorityLow = -2, ///< priority: low osPriorityBelowNormal = -1, ///< priority: below normal osPriorityNormal = 0, ///< priority: normal (default) osPriorityAboveNormal = +1, ///< priority: above normal osPriorityHigh = +2, ///< priority: high osPriorityRealtime = +3, ///< priority: realtime (highest) osPriorityError = 0x84 ///< system cannot determine priority or thread has illegal priority } osPriority;在TecentOS-tiny中实现的时候进行了转化:
statick_prio_tpriority_cmsis2knl(osPriorityprio)
{ if(prio==osPriorityError){ returnK_TASK_PRIO_INVALID; } return(k_prio_t)(3-prio); } staticosPrioritypriority_knl2cmsis(k_prio_tprio) { return(osPriority)(3-prio); }
比如创建线程时设置为 osPriorityNormal=0,则「实际设置的任务优先级为3」。
2.3. 通用等待函数
CMSIS-RTOS提供的等待函数API如下:
API | 描述 |
osDelay | 等待指定的时间 |
osWait(可选) | 等待信号、消息、邮箱的某个事件 |
osDelay
osStatusosDelay(uint32_tmillisec);
返回值:osStatus。
2.4. 软件定时器管理
CMSIS-RTOS API提供的存储定时器参数的结构体如下:typedefstructos_timer_def{
os_ptimercb;///< start address of a timer function k_timer_t *timer; } osTimerDef_t;
CMSIS-RTOS API提供的定义一个软件定时器的宏定义如下:
#defineosTimerDef(name,function)
k_timer_ttimer_handler_##name; constosTimerDef_tos_timer_def_##name= {(os_ptimer)(function),(&(timer_handler_##name))}
CMSIS-RTOS API定义的获取软件定时器参数结构体的宏如下:
#defineosTimer(name)
&os_timer_def_##name
CMSIS-RTOS API提供的软件定时器管理API如下:
API | 描述 |
osTimerCreate | 创建一个软件定时器 |
osTimerStart | 启动软件定时器 |
osTimerStop | 停止软件定时器 |
osTimerDelete | 删除软件定时器 |
osTimerCreate
osTimerIdosTimerCreate(constosTimerDef_t*timer_def,os_timer_typetype,void*argument);
其中osTimerId被定义为k_timer_t指针类型:
typedefk_timer_t*osTimerId;
type参数为 os_timer_type 类型,表示软件定时器的类型为单次触发或者周期触发:
typedefenum{
osTimerOnce=0,///< one-shot timer osTimerPeriodic = 1 ///< repeating timer } os_timer_type;
osTimerStart
osStatusosTimerStart(osTimerIdtimer_id,uint32_tmillisec);
返回值:osStatus。
osTimerStop
osStatusosTimerStop(osTimerIdtimer_id)
返回值:osStatus。
osTimerDelete
osStatusosTimerDelete(osTimerIdtimer_id);
返回值:osStatus。
2.5. 信号量管理
CMSIS-RTOS API提供的存储信号量参数的结构体如下:
typedefstructos_semaphore_def{
uint32_tdummy;///< dummy value. k_sem_t *sem; } osSemaphoreDef_t;
CMSIS-RTOS API提供的定义一个信号量的宏定义如下:
#defineosSemaphoreDef(name)
k_sem_tsem_handler_##name; constosSemaphoreDef_tos_semaphore_def_##name={0,(&(sem_handler_##name))}
CMSIS-RTOS API定义的获取信号量参数结构体的宏如下:
#defineosSemaphore(name)
&os_semaphore_def_##name
CMSIS-RTOS API提供的信号量管理API如下:
API | 描述 |
osSemaphoreCreate | 创建一个信号量 |
osSemaphoreWait | 等待信号量 |
osSemaphoreRelease | 释放信号量 |
osSemaphoreDelete | 删除信号量 |
osSemaphoreCreate
osSemaphoreIdosSemaphoreCreate(constosSemaphoreDef_t*semaphore_def,int32_tcount);
其中 osSemaphoreId 被定义为k_sem_t指针类型:
typedefk_sem_t*osSemaphoreId;
osSemaphoreWait
int32_tosSemaphoreWait(osSemaphoreIdsemaphore_id,uint32_tmillisec);
返回值:int32_t ,正常返回当前count数,失败返回-1。
如果需要阻塞延时,参数应该设置为CMSIS-RTOS API提供的宏定义 osWaitForever :
#defineosWaitForever0xFFFFFFFF///< wait forever timeout value
osSemaphoreRelease
osStatusosSemaphoreRelease(osSemaphoreIdsemaphore_id);
返回值:osStatus。
osSemaphoreDelete
osStatusosSemaphoreDelete(osSemaphoreIdsemaphore_id);
返回值:osStatus。
2.6. 互斥锁管理
CMSIS-RTOS API提供的存储互斥锁参数的结构体如下:
typedefstructos_mutex_def{
uint32_tdummy;///< dummy value. k_mutex_t *mutex; } osMutexDef_t;
CMSIS-RTOS API提供的定义一个互斥锁的宏定义如下:
#defineosMutexDef(name)
k_mutex_tmutex_handler_##name; constosMutexDef_tos_mutex_def_##name={0,(&(mutex_handler_##name))}
CMSIS-RTOS API定义的获取互斥锁参数结构体的宏如下:
#defineosMutex(name)
&os_mutex_def_##name
CMSIS-RTOS API提供的互斥锁管理API如下:
API | 描述 |
osMutexCreate | 创建一个互斥锁 |
osMutexWait | 等待获取互斥锁 |
osMutexRelease | 释放互斥锁 |
osMutexDelete | 删除互斥锁 |
osMutexCreate
osMutexIdosMutexCreate(constosMutexDef_t*mutex_def);
其中 osMutexId 被定义为k_mutex_t指针类型:
typedefk_mutex_t*osMutexId;
osMutexWait
osStatusosMutexWait(osMutexIdmutex_id,uint32_tmillisec);
返回值:osStatus 。
osMutexRelease
osStatusosMutexRelease(osMutexIdmutex_id);
返回值:osStatus。
osMutexDelete
osStatusosMutexDelete(osMutexIdmutex_id);
返回值:osStatus。
2.7. 静态内存池管理
CMSIS-RTOS API提供的存储静态内存池参数的结构体如下:
typedefstructos_pool_def{
uint32_tpool_sz;///< number of items (elements) in the pool uint32_t item_sz; ///< size of an item void *pool; ///< pointer to memory for pool k_mmblk_pool_t *mmblk_pool; ///< memory blk pool handler } osPoolDef_t;
#defineosPoolDef(name,no,type)
k_mmblk_pool_tmmblk_pool_handler_##name; uint8_tmmblk_pool_buf_##name[(no)*sizeof(type)]; constosPoolDef_tos_pool_def_##name= {(no),sizeof(type),(&((mmblk_pool_buf_##name)[0])),(&(mmblk_pool_handler_##name))}
#defineosPool(name)
&os_pool_def_##name
API | 描述 |
osPoolCreate | 创建一块固定大小的静态内存池 |
osPoolAlloc | 申请分配内存 |
osPoolCAlloc | 申请分配一块内存并全部初始化为0 |
osPoolFree | 申请回收内存 |
osPoolCreate
osPoolIdosPoolCreate(constosPoolDef_t*pool_def);
其中 osPoolId 被定义为 k_mmblk_pool_t 指针类型:
typedefk_mmblk_pool_t*osPoolId;
osPoolAlloc
void*osPoolAlloc(osPoolIdpool_id);
osPoolCAlloc
void*osPoolCAlloc(osPoolIdpool_id);
osPoolFree
osStatusosPoolFree(osPoolIdpool_id,void*block);
返回值:osStatus。
2.8. 消息队列管理
CMSIS-RTOS API提供的存储消息队列参数的结构体如下:
typedefstructos_messageQ_def{
uint32_tqueue_sz;///< number of elements in the queue uint32_t item_sz; ///< size of an item void *pool; ///< memory array for messages k_msg_q_t *queue; ///< queue handler } osMessageQDef_t;
CMSIS-RTOS API提供的定义一个消息队列的宏定义如下:
#defineosMessageQDef(name,queue_sz,type)
k_msg_q_tmsg_q_handler_##name; constosMessageQDef_tos_messageQ_def_##name= {(queue_sz),sizeof(type),NULL,(&(msg_q_handler_##name))}
CMSIS-RTOS API定义的获取消息队列参数结构体的宏如下:
#defineosMessageQ(name)
&os_messageQ_def_##name
CMSIS-RTOS API提供的消息队列管理API如下:
API | 描述 |
osMessageCreate | 初始化一个消息队列 |
osMessagePut | 向消息队列中加入数据 |
osMessageGet | 从消息队列中取出数据 |
osMessageCreate
osMessageQIdosMessageCreate(constosMessageQDef_t*queue_def,osThreadIdthread_id);
其中 osMessageQId 被定义为 k_msg_q_t 指针类型:
typedefk_msg_q_t*osMessageQId;
osMessagePut
osStatusosMessagePut(osMessageQIdqueue_id,uint32_tinfo,uint32_tmillisec);
返回值:osStatus 。
因为TencentOS-tiny中消息队列实现机制的不同,此API中的 millisec 参数未用到。
osMessageGet
osEventosMessageGet(osMessageQIdqueue_id,uint32_tmillisec);
返回值:osEvent ,其中包含了事件信息和错误码,以及消息队列收到的值。
3. 使用示例
3.1. 任务创建示例
#include
voidtask1_entry(void*arg) { while(1) { printf("task1isrunning... "); osDelay(1000); } } osThreadDef(task1_entry,osPriorityNormal,1,512); voidtask2_entry(void*arg) { while(1) { printf("task2isrunning... "); osDelay(1000); } } osThreadDef(task2_entry,osPriorityNormal,1,512); voidapplication_entry(void*arg) { osThreadCreate(osThread(task1_entry),NULL); osThreadCreate(osThread(task2_entry),NULL); return; }
任务运行结果如下:
task1isrunning... task2isrunning... task1isrunning... task2isrunning... task1isrunning... task2isrunning...
3.2. 软件定时器使用示例
#includevoidtimer1_cb(void*arg) { printf("timer1istimeout! "); } voidtimer2_cb(void*arg) { printf("timer2istimeout! "); } osTimerDef(timer1,timer1_cb); osTimerDef(timer2,timer2_cb); voidapplication_entry(void*arg) { osTimerIdtimer1; osTimerIdtimer2; timer1=osTimerCreate(osTimer(timer1),osTimerOnce,NULL); timer2=osTimerCreate(osTimer(timer2),osTimerPeriodic,NULL); osTimerStart(timer1,5000); osTimerStart(timer2,1000); return; }
运行结果如下:
timer2istimeout! timer2istimeout! timer2istimeout! timer2istimeout! timer1istimeout! timer2istimeout! timer2istimeout! timer2istimeout! timer2istimeout!
3.3. 信号量使用示例
#includeosSemaphoreIdsync_sem_id; osSemaphoreDef(sync_sem); voidtask1_entry(void*arg) { while(1) { printf("task1iswaitingsemforever... "); osSemaphoreWait(sync_sem_id,osWaitForever); printf("task1getsem! "); } } osThreadDef(task1_entry,osPriorityNormal,1,512); voidtask2_entry(void*arg) { while(1) { printf("task2willreleaseasem... "); osSemaphoreRelease(sync_sem_id); osDelay(1000); } } osThreadDef(task2_entry,osPriorityNormal,1,512); voidapplication_entry(void*arg) { sync_sem_id=osSemaphoreCreate(osSemaphore(sync_sem),0); osThreadCreate(osThread(task1_entry),NULL); osThreadCreate(osThread(task2_entry),NULL); return; }
运行结果为:
task1iswaitingsemforever... task1getsem! task1iswaitingsemforever... task2willreleaseasem... task1getsem! task1iswaitingsemforever... task2willreleaseasem... task1getsem! task1iswaitingsemforever... task2willreleaseasem... task1getsem! task1iswaitingsemforever... task2willreleaseasem... task1getsem! task1iswaitingsemforever...
3.4. 互斥锁使用示例
#include
osMutexIdsync_mutex_id; osMutexDef(sync_mutex); voidtask1_entry(void*arg) { while(1) { osMutexWait(sync_mutex_id,osWaitForever); printf("task1getmutex,doingsth... "); HAL_Delay(1000);//死循环占用CPU printf("task1finishdosth! "); osMutexRelease(sync_mutex_id); osDelay(1000); } } osThreadDef(task1_entry,osPriorityHigh,1,512); voidtask2_entry(void*arg) { while(1) { osMutexWait(sync_mutex_id,osWaitForever); printf("task2getmutex,doingsth... "); HAL_Delay(2000);//死循环占用CPU printf("task2finishdosth! "); osMutexRelease(sync_mutex_id); osDelay(1000); } } osThreadDef(task2_entry,osPriorityNormal,1,512); voidapplication_entry(void*arg) { sync_mutex_id=osMutexCreate(osMutex(sync_mutex)); osThreadCreate(osThread(task1_entry),NULL); osThreadCreate(osThread(task2_entry),NULL); return; }
运行结果为:
task1getmutex,doingsth... task1finishdosth! task2getmutex,doingsth... task2finishdosth! task1getmutex,doingsth... task1finishdosth! task1getmutex,doingsth... task1finishdosth! task2getmutex,doingsth...
3.5. 动态内存使用示例
#includetypedefstructblk_st{ intid; char*payload; }blk_t; #defineMMBLK_BLK_NUM10 osPoolDef(MemPool,MMBLK_BLK_NUM,blk_t); osPoolIdmem_pool_id; voidtask1_entry(void*arg) { blk_t*ptr=NULL; osStatuserr; /*打印出一个块的大小*/ printf("blocksizeis%dbytes ",sizeof(blk_t)); /*申请一个块*/ ptr=osPoolAlloc(mem_pool_id); if(ptr==NULL){ printf("ammblkallocfail "); return; } else{ printf("ammblkallocsuccess "); } /*使用该块*/ ptr->id=1; ptr->payload="hello"; printf("mmblkid:%dpayload:%s ",ptr->id,ptr->payload); /*使用完毕之后释放*/ err=osPoolFree(mem_pool_id,ptr); if(err!=osOK){ printf("ammblkfreefail,err=%d ",err); return; } else{ printf("ammblkfreesuccess "); } while(1){ tos_task_delay(1000); } } #defineSTK_SIZE_TASK11024 osThreadDef(task1_entry,osPriorityNormal,1,STK_SIZE_TASK1); voidapplication_entry(void*arg) { //初始化静态内存池 mem_pool_id=osPoolCreate(osPool(MemPool)); if(mem_pool_id==NULL){ printf("mmblkpoolcreatefail "); return; } else{ printf("mmblkpoolcreatesuccess "); } //创建任务 osThreadCreate(osThread(task1_entry),NULL); return; }
运行结果为:
mmblkpoolcreatesuccess blocksizeis8bytes ammblkallocsuccess mmblkid:1payload:hello ammblkfreesuccess
3.6. 消息队列使用示例
#include#defineSTK_SIZE_TASK_RECEIVER512 #defineSTK_SIZE_TASK_SENDER512 #defineMESSAGE_MAX10 osMessageQIdmsg_q_id; osMessageQDef(msg_q,MESSAGE_MAX,uint32_t); voidtask_receiver_entry(void*arg) { osEventevent; osStatusret; uint32_tvalue; while(1) { event=osMessageGet(msg_q_id,osWaitForever); ret=event.status; if(ret==osOK) { value=event.value.v; printf("receiver:msgincoming[%s] ",(char*)value); } } } osThreadDef(task_receiver_entry,osPriorityNormal,1,STK_SIZE_TASK_RECEIVER); voidtask_sender_entry(void*arg) { char*msg_prio_0="msg0"; char*msg_prio_1="msg1"; char*msg_prio_2="msg2"; printf("sender:postamessgae:[%s] ",msg_prio_2); osMessagePut(msg_q_id,(uint32_t)msg_prio_2,0); printf("sender:postamessgae:[%s] ",msg_prio_1); osMessagePut(msg_q_id,(uint32_t)msg_prio_1,0); printf("sender:postamessgae:[%s] ",msg_prio_0); osMessagePut(msg_q_id,(uint32_t)msg_prio_0,0); } osThreadDef(task_sender_entry,osPriorityNormal,1,STK_SIZE_TASK_SENDER); voidapplication_entry(void*arg) { msg_q_id=osMessageCreate(osMessageQ(msg_q),NULL); osThreadCreate(osThread(task_receiver_entry),NULL); osThreadCreate(osThread(task_sender_entry),NULL); return; }
运行结果为:
sender:postamessgae:[msg2] sender:postamessgae:[msg1] sender:postamessgae:[msg0] receiver:msgincoming[msg2] receiver:msgincoming[msg1] receiver:msgincoming[msg0]
内核
3文章
1372浏览量
40289 -
API
2文章
1500浏览量
62011 -
CMSIS
40浏览量
11902
原文标题:CMSIS RTOS API,内核通用API接口
文章出处:【微信号:strongerHuang,微信公众号:strongerHuang】欢迎添加关注!文章转载请注明出处。
