1、前言
本文结合多年工作经验,以及贴片电阻的一些特性的了解,通过查阅资料总结而成。旨在为硬件工程师提供比较全面的贴片电阻学习资料,方便查漏补缺,同时也能作为一个手册在工作中需要的时候能够快速查询。
2、电阻阻值
2.1常用电阻阻值表
电阻阻值是离散的,并不是所有阻值的电阻都有生厂,要根据需求进行选择,
常用电阻阻值表如下:
5%精度-E24 | |||||||||
1.0 | 5.6 | 33 | 160 | 820 | 3.9K | 20K | 100K | 510K | 2.7M |
1.1 | 6.2 | 36 | 180 | 910 | 4.3K | 22K | 110K | 560K | 3M |
1.2 | 6.8 | 39 | 200 | 1K | 4.7K | 24K | 120K | 620K | 3.3M |
1.3 | 7.5 | 43 | 220 | 1.1K | 5.1K | 27K | 130K | 680K | 3.6M |
1.5 | 8.2 | 47 | 240 | 1.2K | 5.6K | 30K | 150K | 750K | 3.9M |
1.6 | 9.1 | 51 | 270 | 1.3K | 6.2K | 33K | 160K | 820K | 4.3M |
1.8 | 10 | 56 | 300 | 1.5K | 6.6K | 36K | 180K | 910K | 4.7M |
2.0 | 11 | 62 | 330 | 1.6K | 7.5K | 39K | 200K | 1M | 5.1M |
2.2 | 12 | 68 | 360 | 1.8K | 8.2K | 43K | 220K | 1.1M | 5.6M |
2.4 | 13 | 75 | 390 | 2K | 9.1K | 47K | 240K | 1.2M | 6.2M |
2.7 | 15 | 82 | 430 | 2.2K | 10K | 51K | 270K | 1.3M | 6.8M |
3.0 | 16 | 91 | 470 | 2.4K | 11K | 56K | 300K | 1.5M | 7.5M |
3.3 | 18 | 100 | 510 | 2.7K | 12K | 62K | 330K | 1.6M | 8.2M |
3.6 | 20 | 110 | 560 | 3K | 13K | 68K | 360K | 1.8M | 9.1M |
3.9 | 22 | 120 | 620 | 3.2K | 15K | 75K | 390K | 2M | 10M |
4.3 | 24 | 130 | 680 | 3.3K | 16K | 82K | 430K | 2.2M | 15M |
4.7 | 27 | 150 | 750 | 3.6K | 18K | 91K | 470K | 2.4M | 22M |
5.1 | 30 |
1%精度-E96 | |||||||||
10 | 33 | 100 | 332 | 1K | 3.32K | 10.5K | 34K | 107K | 357K |
10.2 | 33.2 | 102 | 340 | 1.02K | 3.4K | 10.7K | 34.8K | 110K | 360K |
10.5 | 34 | 105 | 348 | 1.05K | 3.48K | 11K | 35.7K | 113K | 365K |
10.7 | 34.8 | 107 | 350 | 1.07K | 3.57K | 11.3K | 36K | 115K | 374K |
11 | 35.7 | 110 | 357 | 1.1K | 3.6K | 11.5K | 36.5K | 118K | 383K |
11.3 | 36 | 113 | 360 | 1.13K | 3.65K | 11.8K | 37.4K | 120K | 390K |
11.5 | 36.5 | 115 | 365 | 1.15K | 3.74K | 12K | 38.3K | 121K | 392K |
11.8 | 37.4 | 118 | 374 | 1.18K | 3.83K | 12.1K | 39K | 124K | 402K |
12 | 38.3 | 120 | 383 | 1.2K | 3.9K | 12.4K | 39.2K | 127K | 412K |
12.1 | 39 | 121 | 390 | 1.21K | 3.92K | 12.7K | 40.2K | 130K | 422K |
12.4 | 39.2 | 124 | 392 | 1.24K | 4.02K | 13K | 41.2K | 133K | 430K |
12.7 | 40.2 | 127 | 402 | 1.27K | 4.12K | 13.3K | 42.2K | 137K | 432K |
13 | 41.2 | 130 | 412 | 1.3K | 4.22K | 13.7K | 43K | 140K | 442K |
13.3 | 42.2 | 133 | 422 | 1.33K | 4.32K | 14K | 43.2K | 143K | 453K |
13.7 | 43 | 137 | 430 | 1.37K | 4.42K | 14.3K | 44.2K | 147K | 464K |
14 | 43.2 | 140 | 432 | 1.4K | 4.53K | 14.7K | 45.3K | 150K | 470K |
14.3 | 44.2 | 143 | 442 | 1.43K | 4.64K | 15K | 46.4K | 154K | 475K |
14.7 | 45.3 | 147 | 453 | 1.47K | 4.7K | 15.4K | 47K | 158K | 487K |
15 | 46.4 | 150 | 464 | 1.5K | 4.75K | 15.8K | 47.5K | 160K | 499K |
15.4 | 47 | 154 | 470 | 1.54K | 4.87K | 16K | 48.7K | 162K | 511K |
15.8 | 47.5 | 158 | 475 | 1.58K | 4.99K | 16.2K | 49.9K | 165K | 523K |
16 | 48.7 | 160 | 487 | 1.6K | 5.1K | 16.5K | 51K | 169K | 536K |
19.1 | 57.6 | 191 | 565 | 1.91K | 6.04K | 20K | 60.4K | 205K | 634K |
19.6 | 59 | 196 | 578 | 1.96K | 6.19K | 20.5K | 61.9K | 210K | 649K |
20 | 60.4 | 200 | 590 | 2K | 6.2K | 21K | 62K | 215K | 665K |
20.5 | 61.9 | 205 | 604 | 2.05K | 6.34K | 21.5K | 63.4K | 220K | 680K |
21 | 62 | 210 | 619 | 2.1K | 6.49K | 22K | 64.9K | 221K | 681K |
21.5 | 63.4 | 215 | 620 | 2.15K | 6.65K | 22.1K | 66.5K | 226K | 698K |
22 | 64.9 | 220 | 634 | 2.2K | 6.8K | 22.6K | 68K | 232K | 715K |
22.1 | 66.5 | 221 | 649 | 2.21K | 6.81K | 23.2K | 68.1K | 237K | 732K |
22.6 | 68 | 226 | 665 | 2.26K | 6.98K | 23.7K | 69.8K | 240K | 750K |
23.2 | 68.1 | 232 | 680 | 2.32K | 7.15K | 24K | 71.5K | 243K | 768K |
23.7 | 69.8 | 237 | 681 | 2.37 | 7.32K | 24.3K | 73.2K | 249K | 787K |
24 | 71.5 | 240 | 698 | 2.4K | 7.5K | 24.9K | 75K | 255K | 806K |
24.3 | 73.2 | 243 | 715 | 2.43K | 7.68K | 25.5K | 76.8K | 261K | 820K |
24.7 | 75 | 249 | 732 | 2.49K | 7.87K | 26.1K | 78.7K | 267K | 825K |
24.9 | 75.5 | 255 | 750 | 2.55K | 8.06K | 26.7K | 80.6K | 270K | 845K |
25.5 | 76.8 | 261 | 768 | 2.61K | 8.2K | 27K | 82K | 274K | 866K |
26.1 | 78.7 | 267 | 787 | 2.67K | 8.25K | 27.4K | 82.5K | 280K | 887K |
26.7 | 80.6 | 270 | 806 | 2.7K | 8.45K | 28K | 84.5K | 287K | 909K |
27 | 82 | 274 | 820 | 2.74K | 8.66K | 28.7K | 86.6K | 294K | 910K |
27.4 | 82.5 | 280 | 825 | 2.8K | 8.8K | 29.4K | 88.7K | 300K | 931K |
28 | 84.5 | 287 | 845 | 2.87K | 8.87K | 30K | 90.9K | 301K | 953K |
28.7 | 86.6 | 294 | 866 | 2.94K | 9.09K | 30.1K | 91K | 309K | 976K |
29.4 | 88.7 | 300 | 887 | 3.0K | 9.1K | 30.9K | 93.1K | 316K | 1.0M |
30 | 90.9 | 301 | 909 | 3.01K | 9.31K | 31.6K | 95.3K | 324K | 1.5M |
30.1 | 91 | 309 | 910 | 3.09K | 9.53K | 32.4K | 97.6K | 330K | 2.2M |
30.9 | 93.1 | 316 | 931 | 3.16K | 9.76K | 33K | 100K | 332K | |
31.6 | 95.3 | 324 | 953 | 3.24K | 10K | 33.2K | 102K | 340K | |
32.4 | 97.6 | 330 | 976 | 3.3K | 10.2K | 33.6K | 105K | 348K |
2.2阻值表来源
电阻标准由IEC(国际电工委员会)制定,标准文件为IEC60063和EN60115-2。
电子元器件厂商为了便于元件规格的管理和选用,同时也为了使电阻的规格不至太多,采用了统一的标准组成的元件的数值。
电阻的标称阻值分为E6、E12、E24、E48、E96、E192六大系列,分别使用于允许偏差为±20、±10%、±5%、±2%、±1%、±0.5%的电阻器。其中以E24和E96两个系列为最常用。
“E”表示“指数间距”(Exponential Spacing),它表明了电阻阻值是由公式计算出来的。
字母n指的是E24,E96等标准中的数值24和96,m的取值范围为0~n-1;这样,E24有24个基准值,E96有96个基准值,这些基准值再乘以10的x次方,就可以得到各种各样的电阻值了。
例:E96电阻值分布 | ||||||||
x | x | x | x | x | x | x | x | |
1.00 | 1Ω | 10Ω | 100Ω | 1kΩ | 10kΩ | 100kΩ | 1MΩ | 10MΩ |
=1.02 | 1.02Ω | 10.2Ω | 102Ω | 1.02kΩ | 10.2kΩ | 102kΩ | 1.02MΩ | |
=1.05 | 1.05Ω | 10.5Ω | 105Ω | 1.05kΩ | 10.5kΩ | 105kΩ | 1.05MΩ | |
=9.76 | 9.76Ω | 97.6Ω | 976Ω | 9.76kΩ | 97.6kΩ | 976kΩ | 9.76MΩ |
3、电阻丝印
封装0603以上的电阻(包含0603)在表面都印有丝印。
丝印展示出了2层意义:阻值大小和精度。
常用电阻丝印一般有这几种情况:
1)带有三位或者四位数字的丝印
2)带有字母“R”的丝印
3)带有数字和R之外字母的丝印
3.1带有三位或者四位数字的丝印
三位数字表示5%精度的,四位数字表示1%精度的,前面几位表示数值,最后一位表示10的x次方。
例1:丝印为“103”,则:,5%精度
例2:丝印为“1003”,则:,1%精度
3.2 带有字母“R”的丝印
带字母”R”的电阻一般阻值较小,精度多为1%,不过也不绝对,可以把R看作是小数点,前边的数字为有效值。
例:丝印为“22R0”,将R看作小数点,前面的22表示有效值,读数为22.0Ω,即精度为22Ω的1%精度电阻。
3.3带有数字和R之外字母的丝印
这种电阻丝印在0603封装中比较常见,精度为1%,与之对应的标准为E-96。
E-96规定:用两位数字加一个字母作为丝印,实际阻值可以通过查表来获取,两位数字表明了电阻数值,字母表明了10的x次方,也需要查表。
例:丝印为“88A”,从下表知,“88”代表8.06,A代表,即阻值:。
两位数字查表 | ||||||||||
个位 十位 |
0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
0 | 1.00 | 1.02 | 1.05 | 1.07 | 1.10 | 1.13 | 1.15 | 1.18 | 1.21 | |
1 | 1.24 | 1.27 | 1.30 | 1.33 | 1.37 | 1.40 | 1.43 | 1.47 | 1.50 | 1.54 |
2 | 1.58 | 1.62 | 1.65 | 1.69 | 1.74 | 1.78 | 1.82 | 1.87 | 1.91 | 1.96 |
3 | 2.00 | 2.05 | 2.10 | 2.15 | 2.21 | 2.26 | 2.32 | 2.37 | 2.43 | 2.49 |
4 | 2.55 | 2.61 | 2.67 | 2.74 | 2.80 | 2.87 | 2.94 | 3.01 | 3.09 | 3.16 |
5 | 3.24 | 3.32 | 3.40 | 3.48 | 3.57 | 3.65 | 3.74 | 3.83 | 3.92 | 4.02 |
6 | 4.12 | 4.22 | 4.32 | 4.42 | 4.53 | 4.64 | 4.75 | 4.87 | 4.99 | 5.11 |
7 | 5.23 | 5.36 | 5.49 | 5.62 | 5.76 | 5.90 | 6.04 | 6.19 | 6.34 | 6.49 |
8 | 6.65 | 6.81 | 6.98 | 7.15 | 7.32 | 7.50 | 7.68 | 7.87 | 8.06 | 8.25 |
9 | 8.45 | 8.66 | 8.87 | 9.09 | 9.31 | 9.53 | 9.76 |
阻值倍数代码 | |||||||||||
代码 | A | B | C | D | E | F | G | H | X | Y | Z |
倍数 |
4、电阻精度
电阻的精度一般用字母表示:
T:±0.01%
A:±0.05%
B:±0.1%
D:±0.5%
F:±1%
J:±5%
K:±10%
最常用的精度是1%和5%
一般场合使用5%精度,有精度要求的使用1%电阻,比如DCDC,电流采样,特殊要求的根据实际情况选择更高精度的。
5、电阻的封装
封装的命名是根据电阻的实际尺寸来的—英寸单位
例子:
0402实际尺寸:1mm*0.5mm 0.04英寸*0.02英寸 0402
常用的电阻封装有:
01005、0201、0402、0603、0805、1206、1210、1218、2010、2512
目前一般电子产品主要用0402,0603封装的,要求功率高点的用1206的,手机或者穿戴设备会用到更小封装,比如01005,0201等。
6、电阻的功率
6.1电阻额定功率与封装
电阻的额定功率主要由封装决定,但也不是绝对的,还跟电阻的工艺(薄膜还是厚膜),品牌,阻值大小等有一定关系。
如果上网查功率与封装的关系的话,会有一些网友给出功率与封装表格,那并不一定总是正确的,使用时需要谨慎。
下面列一些厂家的电阻与额定功率的关系表格。
各品牌电阻功率与封装的关系 | ||||||
封装 | 国巨YAGEO | 罗姆ROHM | 风华FH | 光颉Viking | 网上查询 | 参考建议 |
R01005 | 1/32W | 1/32W | 1/32W | 1/32W | 1/32W | 1/32W |
R0201 | 1/20W | 1/20W | 1/20W | 1/20W | 1/20W | 1/20W |
R0402 |
1/16W 1/8W |
1/16W | 1/16W | 1/16W | 1/16W | 1/16W |
R0603 |
1/10W 1/5W |
1/10W |
1/16W 1/10W |
1/10W | 1/10W | 1/16W |
R0805 |
1/8W 1/4W |
1/8W 1/10W(0.5%) |
1/8W 1/10W |
1/8W | 1/8W | 1/10W |
R1206 |
1/4W 1/2W |
1/4W 1/8W(0.5%) |
1/4W 1/8W |
1/4W | 1/4W | 1/8W |
R1210 | 1/2W |
1/4W(1~9.76Ω) 1/3W(10K~3.3MΩ 1/2W(10K~9.76Ω) |
1/4W 1/3W |
1/3W | 1/3W | 1/4W |
R2512 |
1W 2W |
1W | 1W | 1W | 1W | 1W |
同一封装,不同品牌的电阻功率可能不同。
同一封装,不同精度的电阻功率可能不同。
同一封装,不同阻值的电阻功率可能不同。
6.2电阻额定功率与温度的关系
需要注意的是,上一小节提供的额定功率是在70℃条件一下的,如果温度超过70℃,其额定功率是会下降的。
并且,R01005和R0201比其它封装电阻的额定功率,随温度升高有下降得更快的趋势。
R01005和R0201电阻的工作温度范围是-55℃~125℃,R0402及其以上工作温度范围为:-55℃~155℃。
如下图是贴片电阻的负荷(额定功率)下降曲线。
注1:曲线①使用于01005,0201产品,曲线②使用于0402、0603、0805、1206、1210、2010、2512产品。
注2:当电阻使用的环境温度超过70℃时,其额定负荷(额定功率)按照上述曲线下降。
7、电阻的额定电压
电阻是有额定耐压值的,不能超过额定耐压值使用。
1、材质相同(厚膜)的额定电压,各品牌相差不大。
2、材质不同,额定电压有差别,薄膜要比厚膜要低。
3、封装越大,额定电压升高。
各品牌电阻的额定电压 | ||||||
封装 | 国巨(厚膜) | 罗姆(厚膜) | 风华(厚膜) | 光颉(厚膜) | 光颉(薄膜) | 参考建议 |
R0201 | 25V | 25V | 25V | 15V | 15V | |
R0402 | 50V | 50V | 50V | 50V | 25V | 25V |
R0603 | 75V | 50V | 50V | 75V | 50V | 50V |
R0805 | 150V | 150V | 100V | 150V | 100V | 100V |
R1206 | 200V | 200V | 200V | 200V | 150V | 150V |
R1210 | 200V | 200V | 200V | 200V | 150V | 150V |
R2512 | 200V | 200V | 200V | 250V | 150V | 150V |
8、电阻的温漂
8.1电阻温度系数TCR
电阻温度系数(temperature coefficient of resistance 简称TCR)表示电阻当温度改变1摄氏度时,电阻值的相对变化,单位为ppm/℃,ppm(part per million)百万分之几。
温度系数= (R-Ra)/Ra ÷ (T-Ta) × 1000000
Ra: 基准温度条件下的阻值
Ta: 基准温度20℃
R: 任意温度条件下的阻值
T: 任意温度
一般常用电阻温度系数的范围为:-200~500ppm/℃
8.2电阻温漂影响
例:100ppm/°C电阻温度系数的贴片电阻器,从基准温度20°C到100°C时的阻値变化率是?
阻值变化率=温差*温度系数/100万=(100-20)*100/1000000=0.8%
9、0Ω电阻
9.1-0Ω电阻的作用
1、方便测试电流
2、兼容设计,跳线
3、模拟地,数字地分开,单点接地
4、占个位置(可换成其它阻值的电阻,也可换成磁珠)
5、做电路保护,充当低成本熔丝
9.2-0Ω电阻阻值多大
根据电阻标准文件EN60115-2,0Ω电阻实际最大阻值10mΩ,20mΩ,50mΩ可选,实际查询各个厂家,普通0Ω电阻的阻值最大可达50mΩ
9.3-0Ω电阻过流能力
需要注意的是,不同厂家的0Ω电阻过流能力并不相同,可从下表看出:
各品牌0Ω电阻阻值和额定电流 | ||||||||
厂家 | 罗姆ROHM | 国巨YAGEO | 光颉Viking | 参考建议 | ||||
封装 | 最大阻值 | 额定电流 | 最大阻值 | 额定电流 | 最大阻值 | 额定电流 | 最大阻值 | 额定电流 |
R0201 | 50mΩ | 0.5A | 50mΩ | 0.5A | 50mΩ | 1A | 50mΩ | 0.5A |
R0402 | 50mΩ | 1A | 50mΩ | 1A | 50mΩ | 1A | 50mΩ | 1A |
R0603 | 50mΩ | 1A | 50mΩ | 1A | 50mΩ | 1A | 50mΩ | 1A |
R0805 | 50mΩ | 2A | 50mΩ | 2A | 50mΩ | 2A | 50mΩ | 2A |
R1206 | 50mΩ | 2A | 50mΩ | 2A | 50mΩ | 2A | 50mΩ | 2A |
R1210 | 50mΩ | 2A | 50mΩ | 2A | 50mΩ | 2.5A | 50mΩ | 2A |
R2512 | 50mΩ | 4A | 50mΩ | 2A | 50mΩ | 4A | 50mΩ | 2A |
如果需要能过超大电流的0Ω电阻,也是有的,只不过这种电阻就不常规,如下图罗姆的超大过流能力的0Ω电阻,单个可达到20A-60A,阻值最大只有0.5mΩ,不过价格也非常贵。
责任编辑|:PSY
原文标题:贴片电阻详解
文章出处:【微信公众号:汽车电子硬件设计】欢迎添加关注!文章转载请注明出处。
电阻
86文章
5561浏览量
172596 -
贴片电阻
10文章
1707浏览量
26163 -
丝印
2文章
99浏览量
17332 -
电阻阻值
17浏览量
8309
原文标题:贴片电阻详解
文章出处:【微信号:QCDZYJ,微信公众号:汽车电子工程知识体系】欢迎添加关注!文章转载请注明出处。
