CrowdSupply刚上线一个众筹项目 - 称之为Precursor的便携式、开源RISC-V SoC开发套件,使用了分别来自Xilinx和Lattice的两颗流行的FPGA。
从外观上看,它像极了一个智能手机,它号称,通过编程,你确实可以把它当成一个智能手机或平板电脑使用,且你可以对它有完全的控制,因为你可以编程它的每一个bit,沉到硬件的最底层!
套件的正面照片
背面照片
拆开了由以下一些部分组成:
一块电路板
一个单色的LCD屏
一个键盘
看看键盘的电路板:
内部的结构:
高度安全、完全可信任
从下面的对比图中可以看到其主要的功能:
再跟其它的FPGA开发板比较一下:
价格高是有原因的。
下面是其结构框图:
功能特性:
Made for developers
No adhesives holding the bezels in place – just one screw driver is all it takes
Want to add hardware? Maybe a cellular modem? No problem!
Battery compartment is a blank check for your peripherals
Install a smaller battery for more space
Flex PCB breakout for 8x FPGA GPIO into the battery compartment
Bezel is made out of FR-4, and can be user-customized to hold additional components
Inspect, modify and compile your SoC and embedded controller from source
All source fileshosted on GitHubfor convenient fork, pull request, and issue tracking
Open source PCB and case design
Easy-access developer's cable (included)
Low-level debugging (GDB + Chipscope) and firmware flashing via developer's cable plugged into a custom Raspberry Pi HAT (included)
Middleware debugging via USB cable via wishbone tunnel
Open source to the core
Extendable and modifiable
Slim and light mobile form factor
6063 alloy aluminum case -– 3D files provided, so you can mill your own case!
FR-4 front bezel -– PCB source provided
ABS + PC polymer antenna radome -– 3D printable
69 mm x 138 mm x 7.2 mm
96 grams reference weight
Compare to iPhone X at 70.9 mm x 143.6 mm x 7.7 mm and 174 grams
Accessible mechanical design
User-customizable CPUs
Manages power, standby, and charging functions
Tested with 18 MHz VexRISC-V, RV32I, no cache
-L1 speed grade for longer battery life
Tested with 100 MHz VexRISC-V, RV32IMAC + MMU, 4k L1 I/D cache
Xilinx XC7S50 primary System on Chip (SoC) FPGA
iCE40UP5K secondary Embedded Controller (EC) FPGA
16 MB external SRAM
128 MB Flash
100 MHz DDR 8-bit wide bus for fast XIP code performance
Dual hardware TRNG
External discrete noise generator
In-SoC ring oscillator based TRNG
Inspectable I/O
Physical keyboard with changeable layout overlays
200 ppi black and white LCD (336 x 536 resolution), 100% inspectable with standard optical microscope
Both keyboard and LCD are backlit for night-time use
Modular keyboard PCB -- customize layouts, add sensors, or swap in a touch surface
Audio with safe defaults
Integrated 0.7 W speaker for notifications
Vibration motor
3.5 mm headset jack
No integrated microphone -- audio surveillance is not possible when headset is unplugged
Integrated Wi-Fi
Sandboxed in a hardware-delineated untrusted domain
Silicon Labs WF200C chipset
USB Type-C port
Supports charging at 5 V; over-voltage protection tolerant to 20 V
Power negotiation to 5 V @ 1.5 A (source and sink)
Supports legacy USB 2.0 full-speed PHY
Basic DRP negotiation hardware support
1100 mAh Li-Ion battery
Approx. 100 hours standby with Wi-Fi + embedded controller + static display enabled
Approx. 700 mW "on-state" (most features enabled and active, backlight off) power draw, or 5.5 hours continuous use
Integrated gas gauge for more accurate battery life estimate
Full charge in about three hours
Runtime depends on user application
Anti-tamper features
User-sealable metal can for trusted components
Dedicated real-time clock (RTC) with basic clock integrity monitoring
Power monitors trip reset in case of power glitches
Always-on accelerometer/gyro to detect movement in standby
Support for instant secure erase via battery-backed AES key and self-destruct circuit
责任编辑:xj
原文标题:便携、安全、开源RISC-V SoC开发套件
文章出处:【微信公众号:FPGA入门到精通】欢迎添加关注!文章转载请注明出处。
FPGA
1630文章
21761浏览量
604386 -
soc
38文章
4182浏览量
218521 -
Xilinx
71文章
2168浏览量
121709 -
RISC-V
45文章
2300浏览量
46261
文章出处:【微信号:xiaojiaoyafpga,微信公众号:电子森林】欢迎添加关注!文章转载请注明出处。
