随着现代图像处理和人工智能技术的快速发展,不少学者尝试讲CV应用到教学领域,能够代替老师去阅卷,将老师从繁杂劳累的阅卷中解放出来,从而进一步有效的推动教学质量上一个台阶。
传统的人工阅卷,工作繁琐,效率低下,进度难以控制且容易出现试卷遗漏未改、登分失误等现象。
现代的“机器阅卷”,工作便捷、效率高、易操作,只需要一个相机(手机),拍照即可获取成绩,可以导入Excel表格便于存档管理。
下面我们从代码实现的角度来解释一下我们这个简易答题卡识别系统的工作原理。
第一步,导入工具包及一系列的预处理
import numpy as np
import argparse
import imutils
import cv2
# 设置参数
ap = argparse.ArgumentParser()
ap.add_argument("-i", "--image", defaul)
args = vars(ap.parse_args())
# 正确答案
ANSWER_KEY = {0: 1, 1: 4, 2: 0, 3: 3, 4: 1} #
def order_points(pts):
# 一共4个坐标点
rect = np.zeros((4, 2), dtype = "float32")
# 按顺序找到对应坐标0,1,2,3分别是 左上,右上,右下,左下
# 计算左上,右下
s = pts.sum(axis = 1)
rect[0] = pts[np.argmin(s)]
rect[2] = pts[np.argmax(s)]
# 计算右上和左下
diff = np.diff(pts, axis = 1)
rect[1] = pts[np.argmin(diff)]
rect[3] = pts[np.argmax(diff)]
return rect
def four_point_transform(image, pts):
# 获取输入坐标点
rect = order_points(pts)
(tl, tr, br, bl) = rect
# 计算输入的w和h值
widthA = np.sqrt(((br[0]-bl[0])** 2) + ((br[1]-bl[1])**2))
widthB = np.sqrt(((tr[0] -tl[0]) ** 2) + ((tr[1] - tl[1]) ** 2))
maxWidth = max(int(widthA), int(widthB))
heightA = np.sqrt(((tr[0]-br[0])**2)+((tr[1]-br[1])**2))
heightB = np.sqrt(((tl[0]-bl[0])**2)+((tl[1]-bl[1])**2))
maxHeight = max(int(heightA), int(heightB))
# 变换后对应坐标位置
dst = np.array([
[0, 0],
[maxWidth - 1, 0],
[maxWidth - 1, maxHeight - 1],
[0, maxHeight - 1]], dtype = "float32")
# 计算变换矩阵
M = cv2.getPerspectiveTransform(rect, dst)
warped = cv2.warpPerspective(image, M, (maxWidth, maxHeight))
return warped # 返回变换后结果
def sort_contours(cnts, metho):
reverse = False
i = 0
if method == "right-to-left" or method == "bottom-to-top":
reverse = True
if method == "top-to-bottom" or method == "bottom-to-top":
i = 1
boundingBoxes = [cv2.boundingRect(c) for c in cnts]
(cnts, boundingBoxes) = zip(*sorted(zip(cnts, boundingBoxes),
key=lambda b: b[1][i], reverse=reverse))
return cnts, boundingBoxes
def cv_show(name,img):
cv2.imshow(name, img)
cv2.waitKey(0)
cv2.destroyAllWindows()
image = cv2.imread(args["image"])
contours_img = image.copy()
gray = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
blurred = cv2.GaussianBlur(gray, (5, 5), 0)
edged = cv2.Canny(blurred, 75, 200)
# 轮廓检测
cnts = cv2.findContours(edged.copy(), cv2.RETR_EXTERNAL,
cv2.CHAIN_APPROX_SIMPLE)[1]
cv2.drawContours(contours_img,cnts,-1,(0,0,255),3)
docCnt = None
# 确保检测到了
if len(cnts) > 0:
# 根据轮廓大小进行排序
cnts = sorted(cnts, key=cv2.contourArea, reverse=True)
for c in cnts: # 遍历每一个轮廓
# 近似
peri = cv2.arcLength(c, True)
approx = cv2.approxPolyDP(c, 0.02 * peri, True)
# 准备做透视变换
if len(approx) == 4:
docCnt = approx
break
# 执行透视变换
warped = four_point_transform(gray, docCnt.reshape(4, 2))
thresh = cv2.threshold(warped, 0, 255,
cv2.THRESH_BINARY_INV | cv2.THRESH_OTSU)[1]
thresh_Contours = thresh.copy()
# 找到每一个圆圈轮廓
cnts = cv2.findContours(thresh.copy(), cv2.RETR_EXTERNAL,
cv2.drawContours(thresh_Contours,cnts,-1,(0,0,255),3)
questionCnts = []
for c in cnts:# 遍历
# 计算比例和大小
(x, y, w, h) = cv2.boundingRect(c)
ar = w / float(h)
# 根据实际情况指定标准
if w >= 20 and h >= 20 and ar >= 0.9 and ar <= 1.1:
questionCnts.append(c)
# 按照从上到下进行排序
questionCnts = sort_contours(questionCnts,
metho)[0]
correct = 0
# 每排有5个选项
for (q, i) in enumerate(np.arange(0, len(questionCnts), 5)):
cnts = sort_contours(questionCnts[i:i + 5])[0]
bubbled = None
for (j, c) in enumerate(cnts): # 遍历每一个结果
# 使用mask来判断结果
mask = np.zeros(thresh.shape, dtyp)
cv2.drawContours(mask, [c], -1, 255, -1) #-1表示填充
# 通过计算非零点数量来算是否选择这个答案
mask = cv2.bitwise_and(thresh, thresh, mask=mask)
total = cv2.countNonZero(mask)
# 通过阈值判断
if bubbled is None or total > bubbled[0]:
bubbled = (total, j)
# 第二步,与正确答案进行对比
color = (0, 0, 255)
k = ANSWER_KEY[q]
# 判断正确
if k == bubbled[1]:
color = (0, 255, 0)
correct += 1
cv2.drawContours(warped, [cnts[k]], -1, color, 3) #绘图
#正确率的文本显示
score = (correct / 5.0) * 100
print("[INFO] score: {:.2f}%".format(score))
cv2.putText(warped, "{:.2f}%".format(score), (10, 30),
cv2.FONT_HERSHEY_SIMPLEX, 0.9, (0, 0, 255), 2)
cv2.imshow("Input", image)
cv2.imshow("Output", warped)
cv2.waitKey(0)
本文由博客一文多发平台 OpenWrite 发布!
审核编辑 黄昊宇
举报投诉
图像处理
26文章
1247浏览量
56123 -
人工智能
1781文章
45190浏览量
232499 -
python
53文章
4709浏览量
83711
[转载]最适合人工智能开发的5种编程语言
,并不是每种编程语言都能够为开发人员节省时间及精力。所以我们整理了5种比较适用于人工智能开发的编程语言,希望能够对你有所帮助。1.PythonPython由于简单易用,是人工智能领域中使用最广泛的编程语言
发表于 06-19 12:04
Python助力百度无人车 人工智能时代到来
今年7月份,在“百度AI开发者大会”上,百度CEO李彦宏亲自乘坐百度无人车,在真实路况下演示了百度无人驾驶技术,预示着人工智能时代的到来。百度无人车的研发成功是智能机器人领域的又一突破,Pyt
发表于 12-13 14:48
3种适用于人工智能开发的编程语言
人工智能是一个很广阔的领域,很多编程语言都可以用于人工智能开发,所以很难说人工智能必须用哪一种语言来开发。选择多也意味着会有优劣之分,并不是每种编程语言都能够为
发表于 09-12 10:45
适合人工智能开发的5种最佳编程语言优缺点对比
成为开发人员最喜欢的人工智能开发编程语言。Python最打动人心的地方之一就是便携性,它可以在Linux、Windows、Mac OS和UNIX等平台上使用。允许用户创建交互式的、解释的、模块化的、动态
发表于 09-29 10:27
解读人工智能的未来
被称为狭义人工智能,因为它只能做一件特定的事情。狭义AI是构建AGI的第一步吗?许多对AGI感到困惑的人认为目前研发人员应该正在用同样的技术把这些分散的狭义AI拼凑起来。有趣的是,关于自动化
发表于 11-14 10:43
【专辑精选】人工智能之Python教程与资料
电子发烧友总结了以“Python”为主题的精选干货,今后每天一个主题为一期,希望对各位有所帮助!(点击标题即可进入页面下载相关资料)Python人工智能学习工具包+入门与实践资料集锦pytho
发表于 05-06 17:57
什么是基于云计算的人工智能服务?
如今,采用人工智能的企业遇到了一个主要障碍,那就是在内部开发人工智能产品成本高昂,因此有了外包人工智能产品的需求。而对于从中小企业到预算受限的大型企业来说,通过云计算来采用人工智能的成
发表于 09-11 11:51
树莓派Python与自美人工智能系统实现人脸识别
`今天和大家来聊聊树莓派、python和自美人工智能系统。可能有很多人对此不是很了解,我来逐一为大家介绍一下。一、树莓派:英文名为Raspberry Pi(中文名为“树莓派”,简写为RPi,(或者
发表于 12-26 11:24
人工智能芯片是人工智能发展的
人工智能芯片是人工智能发展的 | 特伦斯谢诺夫斯基责编 | 屠敏本文内容经授权摘自《深度学习 智能时代的核心驱动力量》从AlphaGo的人机对战,到无人驾驶汽车的上路,再到AI合成主播上岗
发表于 07-27 07:02
物联网人工智能是什么?
一、人工智能介绍工作以后想要拿高薪的话,人工智能是你的不二之选,那么问题来了,究竟什么是人工智能呢?又需要了解哪些才能去开发人工智能产品呢?接下来小编带领大家进入
发表于 09-09 14:12
人工智能参与高考阅卷解析
如今,人工智能和大数据越来越多运用于生活中,高考阅卷近年来也有人工智能参与,虽然不直接阅卷,却可以通过辅助阅卷质量检测来保障
发表于 07-21 10:23
•1840次阅读
python和人工智能的关系
python和人工智能的关系 Python语言是人工智能领域最为流行和广泛应用的编程语言之一,因为它有很多优点: 1. 简洁易学:Python
