其实不想用这个题目的,只因为TCP相关的东西比较吸引人的眼球,这篇文章的主题还是eBPF,而不是TCP。
用eBPF写TCP拥塞控制算法只是本文所讲内容的一个再平凡不过的例子。
先看两个问题,或者说是两个痛点:
内核越来越策略化。
内核接口不稳定。
分别简单说一下。
所谓内核策略化就是说越来越多的灵巧的算法,小tricks等灵活多变的代码进入内核,举例来讲,包括但不限于以下这些:
TCP拥塞控制算法。
TC排队规则,数据包调度算法。
各种查找的哈希算法。
这部分策略化的代码几乎都是用“回调函数”实现的,这在另一方面烘托了Linux内核也是模块化设计的,且机制和策略分离,当需要一种新的算法时,只需要register一组新的回调函数即可。
然而,…
然而不够完美,因为上述第2点,“内核接口不稳定”!即每一个内核版本的数据结构以及API都是不兼容的。
这意味着什么?
这意味着,即便是高度封装好的算法模块代码,也需要为不同版本的Linux内核维护一套代码,当涉及内核模块由于版本问题不得不升级时,数据结构和api的适配工作往往是耗时且出力不讨好的。
但其实,很多算法根本就是与内核数据结构,内核api这些无关的。
两个内核版本,数据结构只是字段变化了位置,新增了字段,更新了字段名字,即便如此,不得不对算法模块进行重新编译…
如果能在模块载入内核的时候,对函数和数据结构字段进行重定位就好了!
我们的目标是,一次编写,多次运行。
又是Facebook走在了前面,来自Facebook的BPF CO-RE(Compile Once – Run Everywhere):
http://vger.kernel.org/bpfconf2019_talks/bpf-core.pdf
没错,eBPF,就是它!
我们看下其描述:
BPF CO-RE talk discussed issues that developers currently run into when developing, testing, deploying, and running BPF applications at scale, taking Facebook’s experience as an example. Today, most types of BPF programs access internal kernel structures, which necessitates the need to compile BPF program’s C code “on the fly” on every single production machine due to changing struct/union layouts and definitions inside kernel. This causes many problems and inconveniences, starting from the need to have kernel sources available everywhere and in sync with running kernel, which is a hassle to set up and maintain. Reliance on embedded LLVM/Clang for compilation means big application binary size, increased memory usage, and some rare, but impactful production issues due to increased resource usage due to compilation. With current approach testing BPF programs against multitude of production kernels is a stressful, time-consuming, and error-prone process. The goal of BPF CO-RE is to solve all of those issues and move BPF app development flow closer to typical experience, one would expect when developing applications: compile BPF code once and distribute it as a binary. Having a good way to validate that BPF application will run without issues on all active kernels is also a must.
The complexity hides in the need to adjust compiled BPF assembly code to every specific kernel in production, as memory layout of kernel data structures changes between kernel versions and even different kernel build configurations. BPF CO-RE solution relies on self-describing kernel providing BTF type information and layout (ability to produce it was recently committed upstream). With the help from Clang compiler emitting special relocations during BPF compilation and with libbpf as a dynamic loader, it’s possible to reconciliate correct field offsets just before loading BPF program into kernel. As BPF programs are often required to work without modification (i.e., re-compilation) on multiple kernel versions/configurations with incompatible internal changes, there is a way to specify conditional BPF logic based on actual kernel version and configuration, also using relocations emitted from Clang. Not having to rely on kernel headers significantly improves the testing story and makes it possible to have a good tooling support to do pre-validation before deploying to production.
There are still issues which will have to be worked around for now. There is currently no good way to extract #define macro from kernel, so this has to be dealt with by copy/pasting the necessary definitions manually. Code directly relying on size of structs/unions has to be avoided as well, as it isn’t relocatable in general case. While there are some raw ideas how to solve issues like that in the future, BPF CO-RE developers prioritize providing basic mechanisms to allow “Compile Once - Run Everywhere” approach and significantly improve testing and pre-validation experience through better tooling, enabled by BPF CO-RE. As existing applications are adapted to BPF CO-RE, there will be new learning and better understanding of additional facilities that need to be provided to provide best developer experience possible.
该机制可以:
用eBPF的一组字节码实现内核模块的一组回调函数。
对使用到的内核数据结构字段进行重定位,适配当前内核的对应偏移。
后果就是:
很多内核算法模块可以用eBPF来编写了。
Linux 5.6用TCP拥塞控制算法举了一例,我们看一下:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=09903869f69f
可以看到,这个eBPF程序是与内核版本无关的,你可以看到它的tcp_sock结构体的定义:
struct tcp_sock { struct inet_connection_sock inet_conn; __u32 rcv_nxt; __u32 snd_nxt; __u32 snd_una; __u8 ecn_flags; __u32 delivered; __u32 delivered_ce; __u32 snd_cwnd; __u32 snd_cwnd_cnt; __u32 snd_cwnd_clamp; __u32 snd_ssthresh; __u8 syn_data:1, /* SYN includes data */ syn_fastopen:1, /* SYN includes Fast Open option */ syn_fastopen_exp:1,/* SYN includes Fast Open exp. option */ syn_fastopen_ch:1, /* Active TFO re-enabling probe */ syn_data_acked:1,/* data in SYN is acked by SYN-ACK */ save_syn:1, /* Save headers of SYN packet */ is_cwnd_limited:1,/* forward progress limited by snd_cwnd? */ syn_smc:1; /* SYN includes SMC */ __u32 max_packets_out; __u32 lsndtime; __u32 prior_cwnd;} __attribute__((preserve_access_index));
这里注意到两点:
该结构体并非内核头文件里的对应结构体,它只包含了内核对应结构体里TCP CC算法用到的字段,它是内核对应同名结构体的子集。
preserve_access_index属性表示eBPF字节码在载入的时候,会对这个结构体里的字段进行重定向,满足当前内核版本的同名结构体字段的偏移。
我们在看下eBPF实现的TCP CC回调函数是个什么样子:
BPF_TCP_OPS_3(tcp_reno_cong_avoid, void, struct sock *, sk, __u32, ack, __u32, acked){ struct tcp_sock *tp = tcp_sk(sk); if (!tcp_is_cwnd_limited(sk)) return; /* In "safe" area, increase. */ if (tcp_in_slow_start(tp)) { acked = tcp_slow_start(tp, acked); if (!acked) return; } /* In dangerous area, increase slowly. */ tcp_cong_avoid_ai(tp, tp->snd_cwnd, acked);}... SEC(".struct_ops")struct tcp_congestion_ops dctcp = { .init = (void *)dctcp_init, .in_ack_event = (void *)dctcp_update_alpha, .cwnd_event = (void *)dctcp_cwnd_event, .ssthresh = (void *)dctcp_ssthresh, .cong_avoid = (void *)tcp_reno_cong_avoid, .undo_cwnd = (void *)dctcp_cwnd_undo, .set_state = (void *)dctcp_state, .flags = TCP_CONG_NEEDS_ECN, .name = "bpf_dctcp",};
没啥特殊的,几乎和内核模块的写法一样,唯一不同的是:
它和内核版本无关了。你用llvm/clang编译出来.o字节码将可以被载入到所有的内核。
它让人感觉这是在用户态编程。
是的,这就是在用户态写的TCP CC算法,eBPF字节码的对应verifier会对你的代码进行校验,它不允许可以crash内核的eBPF代码载入,你的危险代码几乎无法通过verify。
如果你想搞明白这一切背后是怎么做到的,看两个文件就够了:
net/ipv4/bpf_tcp_ca.c
kernel/bpf/bpf_struct_ops.c
当然,经理不会知道这意味着什么。
浙江温州皮鞋湿,下雨进水不会胖。
原文标题:用eBPF写TCP拥塞控制算法
文章出处:【微信公众号:Linuxer】欢迎添加关注!文章转载请注明出处。
责任编辑:haq
内核
4文章
1476浏览量
43092 -
TCP
8文章
1433浏览量
83777
文章出处:【微信号:LinuxDev,微信公众号:Linux阅码场】欢迎添加关注!文章转载请注明出处。
TCP/IP(Socket)协议深度剖析
PID控制的算法
看透微突发:利用 INT 技术实现交换机队列级的实时拥塞告警
如何用FPGA控制ADV7513实现HDMI画面显示和音频播放
ECN如何在HPC和数据中心中应对网络拥塞
解析DCQCN:RDMA在数据中心网络的关键拥塞控制协议
Modbus TCP 转 Modbus RTU电脑端 TCP 与西门子 V20 变频器的通信案例
基于eBPF的Kubernetes网络异常检测系统
什么是Modbus TCP协议
如何用AI负载为SONiC交换机调整ECN水线
当CCLinkIE撞上Modbus TCP:照明控制系统的“方言战争”终结术
CAN转Modbus TCP网关!CT机伺服控制精准扫描的“幕后功臣”
如何用eBPF写TCP拥塞控制算法?
