最近整理了下AAAI2021 NLP论文各个细方向的接收列表!应该还有几篇漏网之鱼,之后发现了补上~ AAAI2021接收论文PDF查看地址如下: https://aaai.org/Conferences/AAAI-21/wp-content/uploads/2020/12/AAAI-21_Accepted-Paper-List.Main_.Technical.Track_.pdf
NLP细方向论文列表
情感分析
Learning Modality-Specific Representations with Self-Supervised Multi-Task Learning for Multimodal Sentiment Analysis
An Adaptive Hybrid Framework for Cross-Domain Aspect-Based Sentiment Analysis
Bridging Towers of Multi-Task Learning with a Gating Mechanism for Aspect-Based Sentiment Analysis and Sequential Metaphor Identification
Human-Level Interpretable Learning for Aspect-Based Sentiment Analysis
A Joint Training Dual-MRC Framework for Aspect Based Sentiment Analysis
Quantum Cognitively Motivated Decision Fusion for Video Sentiment Analysis
Context-Guided BERT for Targeted Aspect-Based Sentiment Analysis
Segmentation of Tweets with URLs and its Applications to Sentiment Analysis
A Neural Group-Wise Sentiment Analysis Model with Data Sparsity Awareness
句法分析
Encoder-Decoder Based Unified Semantic Role Labeling with Label-Aware Syntax
Code Completion by Modeling Flattened Abstract Syntax Trees as Graphs
Story Ending Generation with Multi-Level Graph Convolutional Networks over Dependency Trees
命名实体识别
Multi-Modal Graph Fusion for Named Entity Recognition with Targeted Visual Guidance
CrossNER: Evaluating Cross-Domain Named Entity Recognition
A Supervised Multi-Head Self-Attention Network for Nested Named Entity Recognition
Nested Named Entity Recognition with Partially-Observed TreeCRFs
Continual Learning for Named Entity Recognition
Knowledge-Aware Named Entity Recognition with Alleviating Heterogeneity
Denoising Distantly Supervised Named Entity Recognition via a Hypergeometric Probabilistic Model
MTAAL: Multi-Task Adversarial Active Learning for Medical Named Entity Recognition and Normalization
人机对话/问答
Reinforced History Backtracking for Conversational Question Answering
Quantum-Inspired Neural Network for Conversational Emotion Recognition
DialogXL: All-in-One XLNet for Multi-Party Conversation Emotion Recognition
Learning from My Friends: Few-Shot Personalized Conversation Systems via Social Networks
NaturalConv: A Chinese Dialogue Dataset Towards Multi-Turn Topic-Driven Conversation
Conversational Neuro-Symbolic Commonsense Reasoning
Keyword-Guided Neural Conversational Model
Infusing Multi-Source Knowledge with Heterogeneous Graph Neural Network for Emotional Conversation Generation
MultiTalk: A Highly-Branching Dialog Testbed for Diverse Conversations
Knowledge-Driven Data Construction for Zero-Shot Evaluation in Commonsense Question Answering
What the Role Is vs. What Plays the Role: Semi-Supervised Event Argument Extraction via Dual Question Answering
Regularizing Attention Networks for Anomaly Detection in Visual Question Answering50
TSQA: Tabular Scenario Based Question Answering
Unanswerable Question Correction in Question Answering over Personal Knowledge Base
Benchmarking Knowledge-Enhanced Commonsense Question Answering via Knowledge-to Text Transformation
Dynamic Neuro-Symbolic Knowledge Graph Construction for Zero-Shot Commonsense Question Answering
Asking the Right Questions: Learning Interpretable Action Models through Query Answering
HopRetriever: Retrieve Hops over Wikipedia to Answer Complex Questions
关系抽取
FL-MSRE: A Few-Shot Learning Based Approach to Multimodal Social Relation Extraction
Multi-View Inference for Relation Extraction with Uncertain Knowledge
GDPNet: Refining Latent Multi-View Graph for Relation Extraction
Progressive Multi-Task Learning with Controlled information Flow for Joint Entity and Relation Extraction
Curriculum-Meta Learning for Order-Robust Continual Relation Extraction
Document-Level Relation Extraction with Reconstruction
Document-Level Relation Extraction with Adaptive Thresholding and Localized Context Pooling
Entity Structure Within and Throughout: Modeling Mention Dependencies for Document Level Relation Extraction
Empower Distantly Supervised Relation Extraction with Collaborative Adversarial Training
Clinical Temporal Relation Extraction with Probabilistic Soft Logic Regularization and Global Inference
A Unified Multi-Task Learning Framework for Joint Extraction of Entities and Relations
事件抽取
GATE: Graph Attention Transformer Encoder for Cross-Lingual Relation and Event Extraction
Span-Based Event Coreference Resolution
机器翻译
Self-Supervised Bilingual Syntactic Alignment for Neural Machine Translation
Empirical Regularization for Synthetic Sentence Pairs in Unsupervised Neural Machine Translation8
Efficient Object-Level Visual Context Modeling for Multimodal Machine Translation: Masking Irrelevant Objects Helps Grounding
Lexically Constrained Neural Machine Translation with Explicit Alignment Guidance
Finding Sparse Structure for Domain Specific Neural Machine Translation
Meta-Curriculum Learning for Domain Adaptation in Neural Machine Translation
Guiding Non-Autoregressive Neural Machine Translation Decoding with Reordering Information
Synchronous Interactive Decoding for Multilingual Neural Machine Translation
Accelerating Neural Machine Translation with Partial Word Embedding Compression
DirectQE: Direct Pretraining for Machine Translation Quality Estimation
We Don't Speak the Same Language: Interpreting Polarization through Machine Translation
知识图谱
Dual Quaternion Knowledge Graph Embeddings
Type-Augmented Relation Prediction in Knowledge Graphs
ChronoR: Rotation Based Temporal Knowledge Graph Embedding
PASSLEAF: A Pool-Based Semi-Supervised Learning Framework for Uncertain Knowledge Graph Embedding
KG-BART: Knowledge Graph-Augmented Bart for Generative Commonsense Reasoning
Answering Complex Queries in Knowledge Graphs with Bidirectional Sequence Encoders
GaussianPath: A Bayesian Multi-Hop Reasoning Framework for Knowledge Graph Reasoning
Topology-Aware Correlations between Relations for Inductive Link Prediction in Knowledge Graphs
Learning from History: Modeling Temporal Knowledge Graphs with Sequential Copy Generation Networks
Neural Latent Space Model for Dynamic Networks and Temporal Knowledge Graphs
Knowledge Graph Embeddings with Projective Transformations
(Comet-) Atomic 2020: On Symbolic and Neural Commonsense Knowledge Graphs
Randomized Generation of Adversary-Aware Fake Knowledge Graphs to Combat Intellectual Property Theft
Dynamic Knowledge Graph Alignment
阅读理解
Semantics Altering Modifications for Evaluating Comprehension in Machine Reading
Retrospective Reader for Machine Reading Comprehension
Reasoning in Dialog: Improving Response Generation by Context Reading Comprehension
VisualMRC: Machine Reading Comprehension on Document Images
A Bidirectional Multi-Paragraph Reading Model for Zero-Shot Entity Linking
Bidirectional Machine Reading Comprehension for Aspect Sentiment Triplet Extraction
Audio-Oriented Multimodal Machine Comprehension via Dynamic Inter- and Intra-Modality Attention
文本生成
A Theoretical Analysis of the Repetition Problem in Text Generation
TextGAIL: Generative Adversarial Imitation Learning for Text Generation
Towards Faithfulness in Open Domain Table-to-Text Generation from an Entity-Centric View
Perception Score: A Learned Metric for Open-Ended Text Generation Evaluation
Generate Your Counterfactuals: Towards Controlled Counterfactual Generation for Text
Write-a-Speaker: Text-Based Emotional and Rhythmic Talking-Head Generation
Stylized Dialogue Response Generation Using Stylized Unpaired Texts
知识蒸馏
PSSM-Distil: Protein Secondary Structure Prediction (PSSP) on Low-Quality PSSM by Knowledge Distillation with Contrastive Learning
LRC-BERT: Latent-Representation Contrastive Knowledge Distillation for Natural Language Understanding
Peer Collaborative Learning for Online Knowledge Distillation
Few-Shot Class-Incremental Learning via Relation Knowledge Distillation
Harmonized Dense Knowledge Distillation Training for Multi-Exit Architectures
Diverse Knowledge Distillation for End-to-End Person Search
Learning to Augment for Data-Scarce Domain BERT Knowledge Distillation
Data-Free Knowledge Distillation with Soft Targeted Transfer Set Synthesis
ALP-KD: Attention-Based Layer Projection for Knowledge Distillation
Progressive Network Grafting for Few-Shot Knowledge Distillation
Show, Attend and Distill: Knowledge Distillation via Attention-Based Feature Matching
Stochastic Precision Ensemble: Self-Knowledge Distillation for Quantized Deep Neural Networks
Reinforced Multi-Teacher Selection for Knowledge Distillation
少量或者零样本学习
Tailoring Embedding Function to Heterogeneous Few-Shot Tasks by Global and Local Feature Adaptors
Learning Intact Features by Erasing-Inpainting for Few-Shot Classification
PTN: A Poisson Transfer Network for Semi-Supervised Few-Shot Learning
Few-Shot Lifelong Learning
Partial Is Better Than All: Revisiting Fine-Tuning Strategy for Few-Shot Learning
Few-Shot Font Generation with Localized Style Representations and Factorization
Few-Shot One-Class Classification via Meta-Learning
Relative and Absolute Location Embedding for Few-Shot Node Classification on Graph
Learning a Few-Shot Embedding Model with Contrastive Learning
Looking Wider for Better Adaptive Representation in Few-Shot Learning
Attributes-Guided and Pure-Visual Attention Alignment for Few-Shot Recognition
Task Cooperation for Semi-Supervised Few-Shot Learning
SALNet: Semi-Supervised Few-Shot Text Classification with Attention-Based Lexicon Construction
StarNet: Towards Weakly Supervised Few-Shot Object Detection
Few-Shot Learning for Multi-Label Intent Detection
Incremental Embedding Learning via Zero-Shot Translation
Task Aligned Generative Meta-Learning for Zero-Shot Learning
Generalized Zero-Shot Learning via Disentangled Representation
DASZL: Dynamic Action Signatures for Zero-Shot Learning
Semantic-Guided Reinforced Region Embedding for Generalized Zero-Shot Learning
Extracting Zero-Shot Structured Information from Form-like Documents: Pretraining with Keys and Triggers
Leveraging Table Content for Zero-Shot Text-to-SQL with Meta-Learning
Meta-Learning Framework with Applications to Zero-Shot Time-Series Forecasting
跨领域
Error-Aware Density Isomorphism Reconstruction for Unsupervised Cross-Domain Crowd Counting
SD-Pose: Semantic Decomposition for Cross-Domain 6D Object Pose Estimation17
Dynamic Hybrid Relation Exploration Network for Cross-Domain Context-Dependent Semantic Parsing
Learning Cycle-Consistent Cooperative Networks via Alternating MCMC Teaching for Unsupervised Cross-Domain Translation
Cross-Domain Grouping and Alignment for Domain Adaptive Semantic Segmentation
Embracing Domain Differences in Fake News: Cross-Domain Fake News Detection Using Multi-Modal Data
跨语言
FILTER: An Enhanced Fusion Method for Cross-Lingual Language Understanding
On the Importance of Word Order Information in Cross-Lingual Sequence Labeling
XL-WSD: An Extra-Large and Cross-Lingual Evaluation Framework for Word Sense Disambiguation
多语言
How Linguistically Fair Are Multilingual Pre-Trained Language Models?
Adversarial Meta Sampling for Multilingual Low-Resource Speech Recognition
Analogy Training Multilingual Encoders
Multilingual Transfer Learning for QA Using Translation as Data Augmentation
新bert改进模型
RpBERT: A Text-Image Relation Propagation-Based BERT Model for Multimodal NER
U-BERT: Pre-Training User Representations for Improved Recommendation
ActionBert: Leveraging User Actions for Semantic Understanding of User Interfaces
RareBERT: Transformer Architecture for Rare Disease Patient Identification Using Administrative Claims
DialogBERT: Discourse-Aware Response Generation via Learning to Recover and Rank Utterances
Degree Planning with PLAN-BERT: Multi-Semester Recommendation Using Future Courses of Interest
多模态
SMIL: Multimodal Learning with Severely Missing Modality
Confidence-Aware Non-Repetitive Multimodal Transformers for TextCaps
Multi-Modal Multi-Label Emotion Recognition with Heterogeneous Hierarchical Message Passing
Robust Multi-Modality Person Re-Identification
Deep Probabilistic Imaging: Uncertainty Quantification and Multi-Modal Solution Characterization for Computational Imaging
VMLoc: Variational Fusion for Learning-Based Multimodal Camera Localization
MUFASA: Multimodal Fusion Architecture Search for Electronic Health Records
Multimodal Fusion via Teacher-Student Network for Indoor Action Recognition
Dynamic Graph Representation Learning for Video Dialog via Multi-Modal Shuffled Transformers
Learning Intuitive Physics with Multimodal Generative Models
MERL: Multimodal Event Representation Learning in Heterogeneous Embedding Spaces
Theoretical Analyses of Multi-Objective Evolutionary Algorithms on Multi-Modal Objectives
Noise Estimation Using Density Estimation for Self-Supervised Multimodal Learning
Humor Knowledge Enriched Transformer for Understanding Multimodal Humor
MELINDA: A Multimodal Dataset for Biomedical Experiment Method Classification
责任编辑:xj
原文标题:【AAAI2021】NLP所有方向论文列表(情感分析、句法、NER、对话/问答、关系抽取、KD等)
文章出处:【微信公众号:深度学习自然语言处理】欢迎添加关注!文章转载请注明出处。
机器学习
66文章
8461浏览量
133437 -
情感分析
14浏览量
5263 -
nlp
1文章
489浏览量
22239
文章出处:【微信号:zenRRan,微信公众号:深度学习自然语言处理】欢迎添加关注!文章转载请注明出处。
OpenHarmony程序分析框架论文入选ICSE 2025
