作为小米科技的创始人、董事长和首席执行官,雷军的名字如雷贯耳。网上出现一篇“刘强东的代码水平如何”的文章,有网友在下面回复“代码只服雷军”。雷军的代码水平真的很牛吗?
原来雷军年轻的时候,也是一名程序员,而且一干就是10年。雷军在22年前的作文中写道:我会当一辈子程序员,由此可以看出雷军对编程有着狂热的爱好。
还有网友分享了一篇雷军22年前写的代码,废话不多说,直接贴代码。
雷军写的这篇代码,是不是看起来很牛逼?简直就是亮瞎眼!
前方高能……
; ; RI.ASM Revision 2.12 [ July 12, 1994 ] Revision equ 'V2.12 ' ; ; ; ; RAMinit Release 2.0 ; Copyright (c) 1989-1994 by Yellow Rose Software Co. ; Written by Mr. Leijun ; ; Function: ; Press HotKey to remove all TSR program after this program ; ; ; .......................................................................... ; Removed Softwares by RI: ; SPDOS v6.0F, WPS v3.0F ; Game Busters III, IV ; NETX ( Novell 3.11 ) ; PC-CACHE ; Norton Cache ; Microsoft SmartDrv ; SideKick 1.56A ; MOUSE Driver ; Crazy (Monochrome simulate CGA program) ; RAMBIOS v2.0 ; 386MAX Version 6.01 ; .......................................................................... ; No cancel softwares: ; Windows 3.1 MSD ; ; No removed TSR softwares: ; MS-DOS fastopen ; Buffers, Files ... (QEMM 6.0) ; QCache (386MAX 6.01) ; .......................................................................... ; COMMENT V2.04 Use mouse driver software reset function to initiation mouse 2/17/1993 by Mr. Lei and Mr. Feng V2.05 RI cannot work in Windows DOS prompt 3/9/1993 by Mr. Lei V2.06 1. When XMS cannot allocate 1K memory, RI halts. 2. RI repeat deallocates EMS memory. V2.07 HotKey Setup Error 4/25/1993 by Mr. Lei V2.08 KB Buffer V2.10 1. Release high memory blocks (EMM386 QEMM386 S-ICE 386MAX) 2. RI copies flag V2.12 1. Exists a critical error in Init 8259 procedure 2. Save [40:F0--FF] user data area dosseg .model tiny .code locals @@ org 100h Start: jmp Main org 103h True equ 1 False equ 0 MaxHandles equ 100h INT3 macro out 0ffh,al endm ; ; HotKey Status Test Var ; --------------- --------------- ; ; 7 6 5 4 3 2 1 0 417 418 496 ; . . x . x . . . Left Alt is pressed 8 2 ; x . . . x . . . Right Alt is pressed 8 8 ; . . . x . x . . Left Ctrl is pressed 4 1 ; . x . . . x . . Right Ctrl is pressed 4 4 ; . . . . . . x . Left Shift is pressed 2 ; . . . . . . . x Right Shift is pressed 1 ; LeftAlt equ 00101000b RightAlt equ 10001000b LeftCtrl equ 00010100b RightCtrl equ 01000100b LeftShift equ 00000010b RightShift equ 00000001b HotKey db LeftCtrl or RightCtrl DataBegin dw 0 NextDataSeg dw 0ffffh oldInt2F_addr dw 0, 0 XMS_control dw 0, 0 Handle_begin dw 0 cvtOfs dw 0 ; DOS 3.0 equ 0 and above DOS 4.0 is 1 org 104h db 0dh db Revision db ??date db 26 org 114h tsrLength dw 0 MachineID db 0FCh ; IBM PC/AT AuxHotKey db 0 ; 2Dh ; 'X' Scan Code AuxHotKeyName db 'X$ ' Power db True Flag db '!' Kbd102 db 0 NoFlag db 0 StopFlag db 1 DosEnv dw 0 WorkSeg dw 0 PrevDataSeg dw 0 Copies db '1' old_8259 db 0 ; 21h port db 0 ; a1h port Status dw 0 XMSbit equ 00000001b EMSbit equ 00000010b SKbit equ 10000000b GoINT1C: db 0eah oldInt1C_addr dw 0, 0 newINT1C: test cs:Status, SKbit jnz GoINT1C cmp cs:StopFlag, 0 jz @@0 ; ; Mr. Lei 2/8/1993 ; Problem: if WPS quit and reenter, old RI cann't control keyboard. ; push ds push ax xor ax, ax mov ds, ax mov ax, ds:[94] cmp ax, offset NewInt9 pop ax pop ds jnz GoINT1C mov cs:StopFlag, 0 @@0: push ax push ds push es xor ax, ax mov ds, ax mov es, ds:[94+2] cmp word ptr es:[101h], 'IE' ; 'LEI' jz @@1 cli mov cs:StopFlag, 1 mov ax, ds:[94] mov cs:oldINT9_addr2, ax mov ax, ds:[94+2] mov cs:oldINT9_addr2[2], ax mov ds:[94], offset newINT9_2 mov ds:[94+2], cs sti @@1: pop es pop ds pop ax jmp GoINT1C ; ---------------------------------------------------------------------- ; INT2F Func ; ; AX = C0D7h Return RI segment in AX ; AX = C0D8h Removes all TSR programs after RI ; AX = C0D9h Removes all TSR programs include RI ; AX = C0DAh Removes all RI copies ; ---------------------------------------------------------------------- newINT2F: cmp ax, 0c0d7h ; LEI Hanzi GB Code jnz @@1 push cs pop ax iret @@1: cmp ax, 0c0d7h+1 jnz @@2 jmp KeepSelf @@2: cmp ax, 0c0d7h+2 jnz @@3 jmp NoKeepSelf @@3: cmp ax, 0c0d7h+3 jnz @@9 mov cs:NextDataSeg, -1 mov cs:Copies, '1' jmp NoKeepSelf @@9: jmp dword ptr cs:oldInt2F_addr CallInt9: ret newINT9_2: mov cs:NoFlag, 1 pushf db 9ah ; call far ptr oldint9_addr oldInt9_Addr2 dw 0, 0 jmp newINT9_proc newINT9: pushf db 9ah ; call far ptr oldint9_addr oldInt9_Addr dw 0, 0 cmp cs:NoFlag, 0 jz newINT9_proc mov cs:NoFlag, 0 iret newINT9_proc: cmp cs:Flag, '!' ; busy ? jnz @@0 iret @@0: mov cs:Flag, '!' ; set busy flag push ax ; cmp hot key push bx push es mov ax,40h mov es,ax cmp cs:AuxHotKey, 0 jz @@_1 mov bx, es:[1ah] cmp bx, es:[1ch] jz @@10 push bx mov bl, es:[bx+1] cmp bl, cs:AuxHotKey pop bx jnz @@10 @@_1: mov ah,es:[17h] ; test CTRL SHIFT ALT mov al,cs:HotKey push ax and ax,0f0fh cmp al,ah pop ax jnz @@10 cmp cs:Kbd102, True jnz @@1 shr al, 1 shr al, 1 shr al, 1 shr al, 1 push ax mov ah, es:[18h] and ax, 303h cmp al, ah pop ax jnz @@10 mov ah, es:[96h] shr ax, 1 shr ax, 1 and ax, 303h cmp al, ah jnz @@10 cmp cs:AuxHotKey, 0 jz @@_3 inc bx inc bx cmp bx, 3eh jb @@_2 mov bx, 1eh @@_2: mov es:[1ah], bx @@_3: call IsWinDos or ax, ax jz @@1 call Beep @@10: sti pop es pop bx pop ax mov cs:Flag, ' ' ; no busy iret @@1: ; OK pop es pop bx pop ax KeepSelf: call RemoveTSR push es mov es,cs:WorkSeg mov dx,es:tsrLength mov di,dx mov al,0h ; Aug 24, 1993 mov cx,100h rep stosb pop es int 27h NoKeepSelf: mov ax,0e07h int 10h mov cs:clsStr, 47h ; Color (White in Red) call RemoveTSR dec cs:Copies call RestoreSelfIntVec push es cmp cs:PrevDataSeg, 0 jz @@1 mov es, cs:PrevDataSeg mov es:NextDataSeg, -1 @@1: pop es mov ax, 4c00h int 21h ; --------------------------------------------------------------------------- IsWinDOS: mov ax, 1600h int 2fh cmp al, 01h jz @@9 cmp al, 0ffh jz @@9 ; Windows/386 Version 2.X cmp al, 00h jz @@1 cmp al, 80h jnz @@9 ; Windows 3 in enhanced mode ; Version number in AL/AH @@1: mov ax, 4680h int 2fh cmp al, 80h jnz @@9 xor ax, ax jmp @@10 @@9: mov ax, 1 @@10: ret ; ----------------------------------------------------------------------- RestoreSelfIntVec: cmp Copies, '0' jz @@0 ret @@0: cli push cs pop ds xor ax, ax mov es, ax mov si, offset oldInt9_Addr mov di, 94 movsw movsw mov si, offset oldInt2F_Addr mov di, 2Fh4 movsw movsw mov si, offset oldInt1C_Addr mov di, 1Ch4 movsw movsw sti ret ; ------------- KERNEL PROGRAM ---------------------------------------------- RemoveTSR: pop ax cli ; Set stack mov sp, cs mov ss, sp mov sp, 100h sti push ax cmp cs:Power, True jnz @@1 call Init8259 @@1: push cs pop ds @@_0: mov ax,ds:NextDataSeg cmp ax, -1 jz @@_1 mov cs:PrevDataSeg, ds mov ds, ax jmp @@_0 @@_1: mov si,ds:DataBegin mov cs:WorkSeg, ds lodsw cmp ax, 'XX' jz @@_2 call Beep ret @@_2: call RestoreEnvStr call RestoreMCB ; restore current mcb call CloseFiles call RestorePort call RestoreLEDs call RestoreVecList ; Restore vectors list call RestoreFloppyParam cmp cs:Power, True jnz @@2 call RestoreCVTchain ; Restore cvt chain call RestoreMemoryManager @@2: call RestoreBiosData call Enable8259 mov ah, 1 int 16h call RestoreClockSpeed call CloseSpeaker call ResetDisk call UpdateTime call ClosePRN mov bx,cs:WorkSeg mov ah,50h int 21h ; Set PSP segment mov ax,3 int 10h ; Set display mode call InitPRN call InitMouse mov al, cs:Copies cmp al, '1' ja @@_sh1 mov cs:ShowCopies, '' jmp @@_sh2 @@_sh1: mov cs:ShowCopies, al @@_sh2: mov si, offset clsStr call ColorPrintStr mov cs:Flag, ' ' ; no busy cmp Copies, '1' jnz @@_end mov cs:StopFlag, 0 @@_end: call ClearKB_buffer ret Beep: mov ax,0e07h int 10h ret ; ######################################################################### ClearKB_Buffer: push es push bx mov bx, 0040h mov es, bx cli mov bx, es:[1ah] mov es:[1ch], bx sti pop bx pop es ret Init8259: ; cmp cs:Copies, '1' ; jz @@1 ; ret @@1: cmp cs:MachineID, 0fch ja @@pc_xt @@AT: mov bx,870h ; mov al,0 ; out 0F1h,al ; jcxz $+2 jcxz $+2 mov al,11h ; ICW1 out 0A0h,al jcxz $+2 jcxz $+2 out 20h,al jcxz $+2 jcxz $+2 mov al,bl ; ICW2 out 0A1h,al jcxz $+2 jcxz $+2 mov al,bh out 21h,al jcxz $+2 jcxz $+2 mov al,2 ; ICW3 out 0A1h,al jcxz $+2 jcxz $+2 mov al,4 out 21h,al jcxz $+2 jcxz $+2 mov al,1 ; ICW4 out 0A1h,al jcxz $+2 jcxz $+2 out 21h,al jcxz $+2 jcxz $+2 mov al,0FFh ; OCW1 out 0A1h,al jcxz $+2 jcxz $+2 out 21h,al ret @@PC_XT: mov al,13h ; ICW1 out 20h,al jcxz $+2 jcxz $+2 mov al,8 ; ICW2 out 21h,al jcxz $+2 jcxz $+2 mov al,9 ; ICW4 out 21h,al jcxz $+2 jcxz $+2 mov al,0FFh ; OCW1 out 21h,al ret Enable8259: mov ax, word ptr cs:old_8259 out 021h,al jcxz $+2 jcxz $+2 mov al,ah out 0a1h,al ; DEC PC Bus Mouse ret ; July 1994 by Mr. Lei ; ------------------------------------------------------------------------- RestoreBiosData: lodsw cmp ax, '--' jz @@1 call Beep ret @@1: push es push di mov di, 40h mov es, di mov di, 10h movsw mov di, 0a8h ; [40h:a8h] movsw movsw mov di, 49h mov cx, 1dh rep movsb mov di, 0f0h ; User data mov cx, 8 rep movsw pop di pop es ret ; ------------------------------------------------------------------------- RestoreMCB: push ds push es lodsw ; 'MZ' @@0: lodsw cmp ax, 'MM' jz @@1 mov es,ax xor di,di movsb movsw movsw inc ax mov bx, ds cmp ax, bx jz @@10 mov byte ptr es:[8], 0 ; Aug 24, 1993 @@10: cmp byte ptr es:[0], 'Z' jnz @@0 mov byte ptr es:[10h], 0 jmp @@0 @@1: pop es pop ds ret ; ------------------------------------------------------------------------- CloseFiles: mov ax, 5 ; Begin handle push ds push si mov cx, 15 ; Max handle sub cx, ax inc cx mov bx, ax @@1: push bx push cx mov ah, 3eh int 21h pop cx pop bx inc bx loop @@1 pop si pop ds ret ; ------------------------------------------------------------------------- RestorePort: mov di, 40h ; restore port mov es, di xor di, di mov cx, 8 rep movsw ret ; ------------------------------------------------------------------------- RestoreLEDs: lodsb and al, 11110000b ; LED status mov ah, es:[17h] and ah, 00001111b or ah, al and ah, 0f0h ; Clear CTRL ALT SHIFT mov es:[17h], ah ret ; ------------------------------------------------------------------------- RestoreEnvStr: lodsw push si push di push ds push es mov es, cs:DosEnv mov ds, ax xor si, si mov di, si @@0: lodsb or al, al jnz @@1 cmp byte ptr ds:[si], 0 jz @@2 @@1: stosb jmp @@0 @@2: stosb stosb pop es pop ds pop di pop si ret ; ----------------------------------------------------------------------- RestoreVecList: xor ax,ax mov di,ax mov es,ax mov cx,100h @@0: lodsw xchg dx, ax lodsw cmp dx, 'EL' jnz @@1 cmp al, 'I' jnz @@1 sub cl, ah push cx mov cl, ah mov ax, es:[di-4] mov dx, es:[di-2] @@a: stosw xchg ax, dx stosw xchg ax, dx loop @@a pop cx or cx, cx jz @@9 jmp @@0 @@1: xchg ax, dx stosw xchg ax, dx stosw loop @@0 @@9: ret ;---------------------------------------------------------------------------- RestoreFloppyParam: ; Mr. Lei 2/10/1992 push es push ax xor ax, ax mov es, ax mov byte ptr es:[525h], 2 pop ax pop es ret ;--------------------------------------------------------------------------- RestoreCVTchain: lodsw cmp ax, 'VC' jz @@_0 call Beep ret @@_0: push ax push cx push es ; ----------------------------------------------------------------- lodsw ; DPB mov di, ax lodsw mov es, ax @@1: lodsb inc di stosb add di, cs:cvtOfs add di, 10h movsw movsw les di, es:[di+2] cmp di, -1 jnz @@1 ; ----------------------------------------------------------------- lodsw ; DCB mov di, ax lodsw mov es, ax xor ax, ax dec ax stosw ; ----------------------------------------------------------------- lodsw ; Device Driver Chain mov di, ax lodsw mov es, ax xor cx, cx @@9: push di mov cl, 5 rep movsw pop di les di, es:[di] mov ax, di inc ax jnz @@9 pop es pop cx pop ax ret ; ---------------------------------------------------------------------------- RestoreMemoryManager: test cs:Status, XMSbit jz @@1 call LoadXMSstatus @@1: test cs:Status, EMSbit jz @@2 call LoadEMSstatus @@2: ret LoadEMSstatus: lodsw cmp ax, 'ME' jz @@_0 call Beep ret @@_0: lodsw mov cx, ax xor dx, dx @@_1: push ds push si push dx push cx @@0: cmp dx, ds:[si] jz @@1 add si, 4 loop @@0 push cx mov cx, 5 @@0: mov ah, 45h ; Deallocate Handle and Memory int 67h or ah, ah jz @@1 loop @@0 @@1: pop cx @@1: pop cx pop dx pop si pop ds inc dx cmp dx, 100h jb @@_1 shl cx, 1 shl cx, 1 add si, cx ret LoadXMSstatus: lodsw cmp ax, 'MX' jz @@_0 call Beep ret @@_0: lodsw mov cx, ax jcxz @@5 @@1: lodsw mov dx, ax @@2: push dx mov ah, 0ah ; free call dword ptr cs:xms_control or ax, ax pop dx jnz @@4 cmp bl, 0abh jnz @@4 push dx mov ah, 0dh ; unlock call dword ptr cs:xms_control or ax, ax pop dx jmp @@2 @@4: loop @@1 @@5: ret endp ; ----------------------------------------------------------------------- CloseSpeaker: in al, 61h and al, 0fch out 61h, al ret ; ----------------------------------------------------------------------- RestoreClockSpeed: mov al, 00110110b out 43h, al xor ax, ax out 40h, al out 40h, al ret ; ----------------------------------------------------------------------- ResetDisk: xor ax, ax xor dx, dx int 13h ; Restore A inc dx int 13h ; Restore B mov dl, 80h int 13h ; Restore C ret ; -------------------------------------------------------------------------- ClosePRN: mov ah, 51h ; Get PSP seg int 21h mov es, bx mov ax, es:[16h] ; Prev PSP seg cmp ax, bx jnz @@9 mov ax, 3e00h ; COMMAND mov bx, 4 int 21h @@9: ret InitPRN: mov ax, 3e00h mov bx, 4 ; PRN int 21h mov ax, 3d01h mov dx, offset PRNname push cs pop ds int 21h ret PRNname db 'PRN',0 InitMouse: ; 2/16/1993 by Mr. Lei push es xor ax, ax mov es, ax cmp word ptr es:[33h4+2], 0 jz @@0 cmp word ptr es:[33h4], 0 jz @@0 mov ax, 21h int 33h ; Hook Mouse Interrupt @@0: pop es ret ; ------------- CMOS CLOCK set to System ----------------------------------- UpdateTime: call GetRealTime mov ah, 2dh int 21h ret GetRealTime: mov ah,2 int 1Ah mov al,ch call bcdxchg mov ch,al mov al,cl call bcdxchg mov cl,al mov al,dh call bcdxchg mov dh,al mov dl,0 ret BCDxchg: push ax push cx mov cl,4 shr al,cl pop cx mov bl,0Ah mul bl pop bx and bl,0Fh add al,bl ret ; ----------------------------------------------------------------------- ; Display string ColorPrintStr: lodsb mov bh, al ; color xor cx, cx mov dx, 014fh mov ax, 0600h int 10h mov ah, 02 ; GotoXY (0, 0) xor dx, dx mov bh, 0 int 10h PrintStr: push cs pop ds xor bx, bx @@1: lodsb cmp al, '$' jz @@2 or al, al jz @@2 mov ah, 0eh int 10h jmp short @@1 @@2: mov al, cs:clsStrcolor mov cs:clsStr, al ret ; ----------------------------------------------------------------------- Self dw 0 clsStrcolor db 17h clsStr db 17h ; Color (White in Blue) db ' RAMinit Version 2.12 (c) 1989-1994 by KingSoft Ltd. Mr. Leijun' db 0dh,0ah db ' [' ShowCopies db '' db '] Activate...',0ah,0dh,'$' endTSR equ $ mcbList equ offset endTSR + 2 + 2 vecList equ mcbList + 710 + 2 + 10h + 1 + 400h devLink equ vecList + 4 + 5 26 + 4 + 10 30h + 4 xmsList equ devLink + 2 + MaxHandles 2 emsList equ xmsList + 4 + 1024 crtMode equ emsList + 2 + 1Dh + 4 + 10h tsrLen equ crtMode + 1 ; ; DOS Environment Reserved by RI ; -------------------------------------------------- ; Flag 'XX' 2 bytes ; Environment Segment 1 word ; Free MCBs <=710 bytes ; MCB segment 1 word ; MCB 5 bytes ; End flag 'MM' 1 word ; COM LPT ports 10h bytes ; LEDs status 1 bytes ; Packed vectors list <=400h bytes ; Flag 'CV' 2 bytes ; CVT First DPB pointer 4 bytes ; DPBs data <=526 bytes ; First DCB pointer 4 bytes ; Pointer to NUL 4 bytes ; All device driver datas <=30h10 bytes ; Flag 'XM' 2 bytes ; XMS free handle counter 2 bytes ; EMS free handle list <=100h4 bytes ; Flag 'EM' 2 bytes ; EMS free handle counter 2 bytes ; EMS free handle list <=1024 bytes ; EMS handle 1 word ; Number of pages 1 word ; Flag '--' 1 word ; Equipment List 1 word ; CRT 40:49h-66h 1dh bytes ; 40:A8h 1 dword ; BIOS User Data Area 40:F0--FF 10h bytes ; ** ; main: jmp main0 Print Macro Str Lea dx, Str call DisplayStr endm InstMsg db 'RAMinit Version 2.12 ' db 'Copyright (c) 1989-1994 by KingSoft Ltd. ',0dh,0ah,'$' Msg0 db 'Already installed !',0dh,0ah,0ah db 'For Help, type "RI /?". ',0dh,0ah,'$' Msg_0 db 0ah,'Residents a new RAMinit copy [y/n] ? $' Msg_2 db 'OK, RI No.' Msg_RI db '2' db ' residents successful !', 0dh,0ah,'$' Msg1 db 'Activate with: $' KeyMsg db 'Right_Shift$' db 'Left_Shift$ ' KMsg1 db 'Left_Ctrl$ ' db 'Left_Alt$ ' db 'Right_Ctrl$ ' db 'Right_Alt$ ' KMsg2 db 'Ctrl$ ' db 'Alt$ ' db 'Ctrl$ ' db 'Alt$ ' PlusMsg db ' + $' crlf db 0dh,0ah,'$' HelpMsg db 'Programmed by Mr. Leijun Dec 1992', 0dh,0ah,0ah db 'Usage: RI [options]',0dh,0ah,0ah db '/H,/? Display this screen',0dh,0ah db '/CLS Removes all TSR programs after current RI',0dh,0ah db '/RET Removes TSR programs include current RI',0dh,0ah db '/NEW Residents a new data copy of current environment',0dh,0ah db '/ALL Removes all RI copies and all other tsr programs',0dh,0ah db '/Sxyy.. Define Hotkey x=AuxHotkey yy..=shift status',0dh,0ah db ' x=auxiliary hotkey (default is "X") ',0dh,0ah db ' x equ "1" means need AuxHotkey',0dh,0ah db ' yy..=shift status [CAScas]',0dh,0ah db ' C: Left Ctrl A: Left Alt S: Left Shift',0dh,0ah db ' c: Right Ctrl a: Right Alt s: Right Shift',0dh,0ah,0ah db 'Example: "RI /S1c" means Hotkey is Right_Ctrl+X',0dh,0ah db ' "RI /S0Cc" means HotKey is Left_Ctrl+Right_Ctrl',0dh,0ah db ' "RI /CLS" equals simply press hotkey',0dh,0ah db ' "RI /RET" Removes all TSRs after current RI and this RI',0dh,0ah db 0ah db 'Contact me for RAMinit problems: (01)2561155 Call 1997',0dh,0ah db '$' ErrMsg db 'ERROR: Invalid options !',0dh,0ah,0ah,'$' WinErr db 7, 'Sorry, I cannot work in Windows DOS environment.',0dh,0ah,'$' SetMsg db 7, 'Defines new Hotkey successful !',0dh,0ah,0ah,'$' tsrOK db False Main0: cld Print instMsg call IsWinDos or ax, ax jz @@1 Print WinErr mov ax, 4c00h int 21h @@1: call HotKeyValid mov cs:Status, 0 call EMS_test call CmpDosVer call CmpSideKick call GetMachineID call ModifyHotKeyPrompt mov ax, 0c0d7h int 2fh mov es, ax cmp word ptr es:[101h], 'IE' ; 'LEI' jnz @@0 mov cs:Self, ax @@0: call CmdLine call PrintHotKeyPrompt cmp cs:tsrOK, true jz @@2 call tsrReplyOK @@2: cmp cs:tsrOK, true jnz @@_2 call PrintCopies @@_2: mov word ptr cs:[100h], 'EL' mov byte ptr cs:[102h], 'I' push cs pop es push cs pop ds std mov si, offset eof mov cx, eof - offset Here mov di, tsrLen add di, cx inc cx rep movsb cld mov bx, tsrLen jmp bx Here: mov ax,cs mov es,ax mov di,offset endTSR mov cs:DataBegin, di mov cs:NextDataSeg, -1 mov ax, 'XX' stosw in al, 0a1h mov ah, al in al, 21h push ax mov word ptr cs:old_8259, ax xor ax, ax out 21h,al ; CLI call SaveOthers call SetSelfInt call BackupVecList cmp cs:Power, true jnz @@20 call BackupCVTchain call BackupMemoryManager @@20: call BackupBiosData sti mov cs:Flag, ' ' ; no busy mov cs:StopFlag, 0 ; mov cs:tsrLength, di call SetDosEnvSeg cmp cs:Self, 0 jz @@29 push cs pop ds push cs pop es cld mov cx, cs:tsrLength mov si, cs:DataBegin sub cx, si mov di, 120h mov cs:DataBegin, di rep movsb mov cs:tsrLength, di @@29: pop ax out 21h, al ; STI mov al, ah out 0a1h, al mov dx, cs:tsrLength inc dx int 27h ; ---------------------------------------------------------------------------- SetDosEnvSeg: push ds push es mov ax, cs @@10: mov es, ax mov ax, es:[16h] ; Get father process psp segment or ax, ax jz @@11 mov bx, es cmp ax, bx jnz @@10 @@11: mov es, word ptr es:[2ch] ; Get father process env segment mov cs:DosEnv, es pop es pop ds ret ; ---------------------------------------------------------------------------- SaveOthers: mov ax, cs:[2ch] ; Env Seg stosw call backupMCB ; Current MCB mov ax, 40h ; COM LPT Port mov ds, ax mov si, 0h mov cx, 8 rep movsw mov si, 17h ; LED status lodsb stosb ; call OpenLEDs ret ; -------------------------------------------------------------------------- backupMCB: mov ax, 'ZM' stosw push ds push es mov ah, 52h int 21h ; Get MCB chain head mov ax, es:[bx-2] pop es @@0: mov ds, ax cmp byte ptr ds:[0], 'Z' ; End ? jz @@20 cmp byte ptr ds:[0], 'M' ; Memory control block jnz @@30 cmp word ptr ds:[3], 0 ; Nul mcb jz @@10 cmp word ptr ds:[1], 0 ; Free MCB jnz @@10 call SaveFreeMCB @@10: inc ax add ax, ds:[3] jmp @@0 @@20: call SaveFreeMCB cmp ax, 0a000h inc ax jnb @@30 mov ax, 9fffh ; MS-DOS UMB jmp @@0 @@30: cmp ax, 0c000h ; 386MAX ja @@90 mov ax, 0c020h jmp @@0 @@90: ; Error ? pop ds mov ax, 'MM' ; Set MCB flag stosw ret SaveFreeMCB: stosw xor si,si movsb movsw movsw ret ; ; push ax ; stosw ; xor si,si ; movsb ; movsw ; movsw ; pop ax ; cmp ax, 09fffh ; jnb @@3 ; push ax ; push ds ; mov ds,ax ; cmp byte ptr ds:[0], 'M' ; pop ds ; pop ax ; jnz @@4 ; mov ax, 09fffh ; MS-DOS UMB ; jmp @@0 ; @@4: cmp ax, 0c000h ; ja @@3 ; mov ax, 0c020h ; 386MAX ; jmp @@0 ; ; -------------------------------------------------------------------------- OpenLEDs: push ax ; Open all LEDs or al, 070h mov ds:[17h], al mov ah, 1 int 16h mov cx, 4 ; Delay @@20: push cx xor cx, cx @@21: loop @@21 pop cx loop @@20 pop ax mov ds:[17h], al mov ah, 1 int 16h ret ; -------------------------------------------------------------------------- SetSelfInt: push es push di cmp cs:self, 0 jnz @@1 push cs pop ds mov ax,3509h int 21h mov word ptr cs:oldInt9_addr,bx mov word ptr cs:oldInt9_addr[2],es mov dx,offset NewInt9 mov ax,2509h int 21h mov ax,352Fh int 21h mov word ptr cs:oldInt2F_addr,bx mov word ptr cs:oldInt2F_addr[2],es mov dx,offset newInt2F mov ax,252Fh int 21h mov ax,351Ch int 21h mov word ptr cs:oldInt1C_addr,bx mov word ptr cs:oldInt1C_addr[2],es mov dx,offset newInt1C mov ax,251ch int 21h cli jmp @@2 @@1: mov es, cs:Self inc es:Copies @@_0: cmp es:NextDataSeg, -1 jz @@_1 mov es, es:NextDataSeg jmp @@_0 @@_1: mov es:NextDataSeg, cs @@2: pop di pop es ret ; ----------------------------------------------------------------------- SaveCounter: mov word ptr es:[di], 'EL' mov byte ptr es:[di+2], 'I' mov byte ptr es:[di+3], bl xor bx, bx add di, 4 ret ; ----------------------------------------------------------------------- DisplayStr: push cs pop ds mov ah, 9 int 21h ret ; ----------------------------------------------------------------------- CmdLine: push cs pop ds xor ax, ax mov si, 80h lodsb or al, al jnz @@1 ret @@1: mov cx, ax dec ax push ax push si @@0: lodsb cmp al, ' ' jz @@0 cmp al, '/' jnz @@2 lodsb cmp al, 'S' jz @@_2 cmp al, 's' jnz @@2 @@_2: call SetHotKey Print SetMsg mov ax, 4c00h int 21h @@2: pop si pop ax push ax push si @@_3: lodsb cmp al, 'A' jb @@3 cmp al, 'Z' ja @@3 add byte ptr ds:[si-1],20h ; DownCase @@3: loop @@_3 pop si pop cx add si, cx lodsb cmp al, 's' ; CLS jnz @@5 cmp word ptr ds:[si-3], 'lc' jnz @@5 cmp cs:Self, 0 jz @Err mov ax, 0c0d7h+1 int 2fh @@5: cmp al, 'h' ; HELP jz @help cmp al, '?' jz @help cmp al, 't' ; RET jnz @@6 cmp word ptr ds:[si-3], 'er' jnz @@6 @@7: cmp cs:Self, 0 jz @Err mov ax, 0c0d7h+2 int 2fh @@6: cmp al, 'w' ; NEW jnz @@8 cmp word ptr ds:[si-3], 'en' jnz @@8 mov cs:tsrOK, true ret @@8: cmp al, 'l' ; ALL jnz @@9 cmp word ptr ds:[si-3], 'la' jnz @@9 mov ax, 0c0d7h+3 int 2fh @@9: cmp al, ' ' jnz @Err ret @Err: Print ErrMsg @help: Print HelpMsg mov ax, 4c00h int 21h ;--------------------------------------------------------------------------- tsrReplyOK: cmp cs:Self, 0 jz @@1 Print Msg0 push es mov ax, cs:Self @@_10: mov es, ax mov ax, es:NextDataSeg cmp ax, -1 jnz @@_10 mov ax, es @@_0: push ax dec ax mov es, ax mov bx, es:[3] pop ax add ax, bx inc ax mov es, ax cmp word ptr es:[0], 'OC' jz @@_0 mov bx, cs cmp ax, bx pop es jz @@2 Print Msg_0 mov ah, 1 int 21h push ax Print crlf pop ax cmp al, 'y' jz @@3 cmp al, 'Y' jz @@3 @@2: ; Print Msg_1 mov ax, 4c01h int 21h @@3: @@1: mov cs:tsrOK, true ret PrintCopies: cmp cs:Self, 0 jz @@1 push es ; Added -by- Mr. Lei mov es, cs:Self ; Aug 24, 1993 mov al, es:Copies inc al ; Total RI copies push ax ; Set es = current mcb mov ax, cs dec ax mov es, ax pop ax mov cx, 5 ; Search end of file name mov bx, 8 @@10: inc bx cmp byte ptr es:[bx], 20h jz @@20 cmp byte ptr es:[bx], 0ffh jz @@20 cmp byte ptr es:[bx], 00h jz @@20 loop @@10 @@20: ; Set current RI no mov byte ptr es:[bx], ':' ; "RI:2" mov byte ptr es:[bx+1], al cmp bx, 8+7 jnb @@30 mov byte ptr es:[bx+2], 0 @@30: pop es mov cs:Msg_RI, al Print Msg_2 @@1: ret ;--------------------------------------------------------------------------- ; Backup Interrupt Vector List ; BackupVecList: push ds push cs pop es xor si,si ; Vectors mov ds,si movsw movsw xor bx, bx mov cx,00ffh @@0: lodsw xchg dx, ax lodsw cmp ax, es:[di-2] jnz @@1 cmp dx, es:[di-4] jz @@2 @@1: or bx, bx jz @@3 call SaveCounter @@3: xchg dx, ax stosw xchg dx, ax stosw loop @@0 jmp @@4 @@2: inc bx loop @@0 call SaveCounter @@4: pop ds ret ; ;----------------------------------------------------------------------------- BackupCVTchain: mov ax, 'VC' stosw push ax push bx push cx push ds push es mov ah, 52h int 21h ; ES:BX -- DOS table as described below ; -------------------------------------------------------------------- push es ; DPB chains push bx lds si, es:[bx] push cs pop es mov ax, si stosw mov ax, ds stosw mov bx, cs:cvtOfs xor cx, cx @@1: mov al, ds:[si+1] stosb mov ax, ds:[si+bx+12h] stosw mov ax, ds:[si+bx+14h] stosw inc cx lds si, ds:[si+bx+18h] cmp si, -1 jnz @@1 ; mov ax, 5 ; mul cl ; add ax, 4 ; add cs:tsrLength, ax pop bx pop es ; -------------------------------------------------------------------- push es ; DCB file control blocks push bx les bx, es:[bx+4] @@11: cmp word ptr es:[bx], -1 jz @@10 les bx, es:[bx] jmp @@11 @@10: mov ax, es xchg ax, bx push cs pop es stosw xchg ax, bx stosw pop bx pop es ; add cs:tsrLength, 4 ; --------------------------------------------------------------------- push es ; Device Driver Chains pop ds add bx, 22h mov si, bx ; NUL pop es mov ax, si stosw mov ax, ds stosw xor cx, cx xor bx, bx @@9: push si mov cl, 5 rep movsw inc bx pop si lds si, ds:[si] mov ax, si inc ax jnz @@9 pop ds pop cx pop bx pop ax ret ; ---------------------------------------------------------------------------- BackupBiosData: mov ax, '--' stosw push ds push si mov si, 40h mov ds, si mov si, 10h movsw mov si, 0a8h movsw movsw mov si, 49h mov cx, 1dh rep movsb mov si, 0f0h mov cx, 8 rep movsw pop si pop ds ret ; --------------------------------------------------------------------------- BackupMemoryManager: push cs pop es push ds push es call SaveXMSstatus call SaveEMSstatus pop es pop ds ret ;--------------------------------------------------------------------- SaveEMSstatus: test cs:status, EMSbit jnz @@1 ret @@1: mov ax, 'ME' stosw inc di inc di push di mov ah, 4dh int 67h pop di mov es:[di-2], bx shl bx, 1 shl bx, 1 add di, bx ret ; ------------------------------------------------------------------- SaveXMSstatus: call XMS_test test cs:status, XMSbit jnz @@1 ret @@1: mov ax, 'MX' stosw mov dx, 1 call XMS_alloc jnz @@_1 xor cx, cx ; XMS alloc failure stosw ret @@_1: push dx sub dx, MaxHandles 10 @@2: push dx call XMS_Lock pop dx jnz @@3 cmp bl, 0a2h jnz @@4 add dx, 10 jmp @@2 @@3: push dx call XMS_unlock pop dx @@4: mov cs:handle_begin, dx pop dx push dx call XMS_bstat xor cx, cx mov cl, bl inc cx pop dx call XMS_Free mov dx, cs:Handle_begin push cx push cs pop es mov ax, cx stosw @@5: push dx call XMS_Lock pop dx jnz @@6 cmp bl, 0a2h ; Handle invalid jz @@7 @@6: call XMS_unlock add dx, 10 jmp @@5 @@7: mov ax, dx stosw add dx, 10 loop @@5 pop cx ret ; ------------------------------------------------------------------ XMS_test: push es mov ax, 4300h int 2fh cmp al, 80h jnz @@9 mov ax, 4310h int 2fh mov cs:XMS_control, bx mov cs:XMS_control[2], es or cs:Status, XMSbit @@9: pop es ret XMS_stat: mov ah, 0 call dword ptr cs:xms_control mov hma_exist, dl ret hma_exist db 0 XMS_alloc: mov ah, 9 call dword ptr cs:xms_control or ax, ax ret XMS_lock: mov ah, 0ch call dword ptr cs:xms_control or ax, ax ret XMS_unlock: mov ah, 0dh call dword ptr cs:xms_control or ax, ax ret XMS_bstat: mov ah, 0eh call dword ptr cs:xms_control or ax, ax ret XMS_free: mov ah, 0ah call dword ptr cs:xms_control or ax, ax ret ; ---------------------------------------------------------------------------- EMS_test: push cs pop ds mov dx, offset EMMname mov ax, 3d00h int 21h jc @@2 mov bx, ax mov ah, 3eh int 21h or cs:Status, EMSbit @@2: ret EMMname db 'EMMXXXX0',0 ; ----------------------------------------------------------------------------- SetHotKey: xor bx, bx lodsb push ax @@1: lodsb cmp al, 0dh jz @@9 cmp al, 'C' jnz @@2 or bl, LeftCtrl jmp @@1 @@2: cmp al, 'c' jnz @@3 or bl, RightCtrl jmp @@1 @@3: cmp al, 'A' jnz @@4 or bl, LeftAlt jmp @@1 @@4: cmp al, 'a' jnz @@5 or bl, RightAlt jmp @@1 @@5: cmp al, 'S' jnz @@6 or bl, LeftShift jmp @@1 @@6: cmp al, 's' jnz @@7 or bl, RightShift jmp @@1 @@7: pop ax jmp @Err @@9: mov cs:HotKey, bl pop ax mov cs:AuxHotKey, 2dh ; 'X' scan key cmp al, '1' jz @@29 mov cs:AuxHotKey, 0 @@29: cmp cs:Self, 0 jz @@30 push es mov es, cs:Self mov es:HotKey, bl mov bl, cs:AuxHotKey mov es:AuxHotKey, bl pop es @@30: call GetRunFileName mov ax, 3d02h int 21h jc @@10 push cs pop ds mov bx, ax mov cx, 4 mov dx, 100h mov ah, 40h int 21h jc @@10 mov ax, 4200h xor cx, cx mov dx, 17h int 21h jc @@10 mov cx, 1 mov dx, offset AuxHotKey mov ah, 40h int 21h jc @@10 mov ah, 3eh int 21h @@10: ret ; ----------------------------------------------------------------------- GetRunFileName: ; Return: ; DS:DX Pointer of this run file name ASCIIZ string push ax push bx push cx push si push di push es push cs pop es mov ax, es:[2ch] mov es, ax xor di, di mov cx, 1000h xor al, al @@1: repnz scasb cmp es:[di], al loopnz @@1 mov dx, di add dx, 3 push es pop ds pop es pop di pop si pop cx pop bx pop ax ret ; --------------------------------------------------------------------------- GetMachineID: push es mov KBD102,True mov ax,40h mov es,ax test byte ptr es:[96h], 00010000b jnz @@1 mov Kbd102,False @@1: xor ax,ax dec ax mov es,ax mov al,es:[0eh] mov cs:MachineID, al pop es ret ; --------------------------------------------------------------------------- ModifyHotKeyPrompt: cmp cs:Kbd102, True jz @@9 push cs pop es push cs pop ds mov cx, 124 mov si, offset KMsg2 mov di, offset KMsg1 rep movsb @@9: cmp cs:MachineID, 0fch jna @@10 mov cs:clsStrcolor, 70h ; Mono mov cs:clsStr, 70h @@10: ret ; --------------------------------------------------------------------------- PrintHotKeyPrompt: Print Msg1 mov al, cs:HotKey mov ah, al shr al, 1 shr al, 1 and ax, 33ch or al, ah mov dx, offset KeyMsg @@40: or ax, ax ; Mr. Lei 4/25/1993 jz @@_42 shr al, 1 push ax jnc @@41 push ax call ColorDisplayStr ; mov ah, 9 ; int 21h pop ax or al, al jz @@42 push dx mov dx, offset PlusMsg call ColorDisplayStr ; Print PlusMsg pop dx @@41: add dx, 12 pop ax jmp @@40 @@42: pop ax @@_42: cmp cs:AuxHotKey, 0 jz @@43 cmp cs:HotKey, 0 ; Mr. Lei jz @@_43 mov dx, offset PlusMsg call ColorDisplayStr ; Print PlusMsg @@_43: mov dx, offset AuxHotKeyName call ColorDisplayStr ; Print AuxHotKeyName @@43: Print crlf ret ColorDisplayStr: push bx push cx push dx push si mov bl, 0fh mov si, dx xor bh, bh mov cx, 1 @@1: lodsb cmp al, '$' jz @@2 or al, al jz @@2 push cx mov ah, 09h int 10h mov ah, 3 int 10h inc dl mov ah, 2 int 10h pop cx jmp short @@1 @@2: pop si pop dx pop cx pop bx ret ; --------------------------------------------------------------------------- CmpSideKick: xor ax, ax mov es, ax les bx, es:[20h] cmp word ptr es:[bx-4], 4b53h jnz @@1 cmp word ptr es:[bx-2], 4942h jz @@2 @@1: mov es, ax les bx, es:[94h] cmp word ptr es:[bx-2], 4b53h jz @@2 ret @@2: or cs:Status, SKbit ret ; --------------------------------------------------------------------------- CmpDosVer: mov ah, 30h int 21h cmp al, 3 jb @@1 cmp al, 3 jna @@2 mov cs:cvtOfs, 1 ret @@2: mov cs:cvtOfs, 0 ret @@1: Print DosVerErr mov ax, 4cffh int 21h DosVerErr db 'Sorry, DOS version too lower !',0dh,0ah,'$' HotKeyValid: cmp cs:HotKey, 0 jnz @@_1 cmp cs:AuxHotKey, 0 jnz @@_1 Print HotKeyErr mov ax, 4cfeh int 21h @@_1: ret HotKeyErr db 'Sorry, please setup hotkey again. ',0dh,0ah,'$' eof: ends end Start ; ------------- The End ! ---------------------------------------------------
电脑是雷军人生中的最爱,电脑的世界对于雷军而言实在太美妙。雷军觉得,电脑的世界没有人那么复杂。只要你程序写得好,就可以和电脑处好关系,也可以指挥电脑,做一些你想做的事情。
雷军认为,电脑的世界很大,程序员都是活在自己的王国里。在这里,程序员可以主宰一切。正是因为热爱,所以雷军一干就是10年。
雷军心爱的代码被新程序员格式化
对于雷军来说,虽然现在他更加 专注在产品开发以及管理方面,但是曾经他对心爱的代码视为珍宝。之前来了一位技术支持人员,而这位技术人员进公司的第一份工作,就是帮雷军整理他的硬盘。
一位理解错误,原本只要覆盖式的安装系统就可以的事情,这位程序员却把雷军的硬盘格式化了。这些代码是雷军多年来积累下来,而且也是他的最爱,就这样成为 炮灰,相信雷军非常难过。
编程是技术,也是一种艺术
雷军认为,编程的工作同石匠的工作相类似,即是技术活,也是体力活,而编写优秀的软件,算是一件比较难得事。
编程是一门技术活,因此才有可能大规模的进行,进而才会有软件工程。此外,因为编程是一种艺术,因此有很多好的产品。
雷军关爱下属 亲自指导女程序员
因为自己是程序员出身,雷军在技术方面的水平不用质疑。雷军对于下面的程序员,也是很关照的。
早前,雷军亲自指导美女程序员的一张图片爆红。从曝光的图片来看,这名由雷总亲自指导的女程序员,竟是位前端开发工程师。雷总下基层,还亲自指导码农,小米不强大都说不过去。
当然,上面的只是雷军生活中的一个小插曲。曾经,雷军认为自己会干一辈子的编程。但是现在,雷军作为小米董事长,身价已经不能用数字来衡量了。他接触程序的机会,相信是少之又少,因为下面有很多程序员帮他干活。
程序员数学之美
程序员数学学习
锻炼数学逻辑思维
原文标题:雷军 1994 年写的代码,你见过吗?厉害了!
文章出处:【微信公众号:人工智能与大数据技术】欢迎添加关注!文章转载请注明出处。
责任编辑:haq
编程
88文章
3659浏览量
94465 -
代码
30文章
4862浏览量
69726
文章出处:【微信号:TheBigData1024,微信公众号:人工智能与大数据技术】欢迎添加关注!文章转载请注明出处。
2024年前视摄像头市场分析
