C代码常用校验方法函数介绍
FPGA之家 来源:FPGA之家 作者:FPGA之家 2021-03-29 11:50 次阅读
01
前言
在项目开发中,通常会用到一些通用或者经常使用的工具函数或者计算函数,一般我都会把这些函数放在一个.C文件下,使用的时候直接调用。下面整理出来分享给大家。
02
常用校验方法函数
查表法计算 CRC校验(CRC模型:CRC-16MODBUS):
const unsigned int CrcTbl[256]= { 0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241, 0xC601, 0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440, 0xCC01, 0x0CC0, 0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40, 0x0A00, 0xCAC1, 0xCB81, 0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841, 0xD801, 0x18C0, 0x1980, 0xD941, 0x1B00, 0xDBC1, 0xDA81, 0x1A40, 0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01, 0x1DC0, 0x1C80, 0xDC41, 0x1400, 0xD4C1, 0xD581,
0x1540, 0xD701, 0x17C0, 0x1680, 0xD641, 0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081, 0x1040, 0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240, 0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441, 0x3C00, 0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41, 0xFA01, 0x3AC0, 0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840, 0x2800, 0xE8C1, 0xE981, 0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41, 0xEE01, 0x2EC0,
0x2F80, 0xEF41, 0x2D00, 0xEDC1, 0xEC81, 0x2C40, 0xE401, 0x24C0, 0x2580, 0xE541, 0x2700, 0xE7C1, 0xE681, 0x2640, 0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0, 0x2080, 0xE041, 0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281, 0x6240, 0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441, 0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41, 0xAA01, 0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840, 0x7800, 0xB8C1, 0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41, 0xBE01, 0x7EC0, 0x7F80,
0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40, 0xB401, 0x74C0, 0x7580, 0xB541, 0x7700, 0xB7C1, 0xB681, 0x7640, 0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101, 0x71C0, 0x7080, 0xB041, 0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0, 0x5280, 0x9241, 0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481, 0x5440, 0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40,
0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841, 0x8801, 0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40, 0x4E00, 0x8EC1, 0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41, 0x4400, 0x84C1, 0x8581, 0x4540, 0x8701, 0x47C0, 0x4680, 0x8641, 0x8201, 0x42C0, 0x4380, 0x8341, 0x4100, 0x81C1, 0x8081, 0x4040 };/**----------------------------------------------------------------- *
@函数名 pf_crcCheck * @功能 计算Crc校验 * * @参数 * unsigned char *pcMess 需计算数据的首地址 * unsigned int wLen 需计算数据的长度 * @返回值 unsigned int Crc校验结果***----------------------------------------------------------------*/unsigned int pf_crcCheck(unsigned char *pcMess,unsigned int wLen) { unsigned int Index; unsigned int nCRCData; nCRCData=0xffff; while(wLen--) { Index=nCRCData》》8; Index=Index^(*pcMess++&0x00ff); nCRCData=(nCRCData^CrcTbl[Index])&0x00ff; nCRCData=(nCRCData《《8)|(CrcTbl[Index]》》8); } return (nCRCData》》8|nCRCData《《8); }
累加和校验:
/**----------------------------------------------------------------- * @函数名 CheckSum * @功能 累加和校验 * * @参数 * u8 *buf 需转换的数据的首地址 * u8 len 需转换的数据的长度 * @返回值 无***----------------------------------------------------------------*/U8 CheckSum(U8 *buf, U8 len){ U8 i, ret = 0;
for(i=0; i《len; i++) { ret += buf[i]; } return ret;//数据相加后的模255的值}
03
无符号型整数转换成字符串
unsigned char 类型转换成没有空格的字符:
/**----------------------------------------------------------------- * @函数名 U8ToStrNoSpace * @功能 u8类型转换成没有空格的字符 * * @参数 * u8 d 需转换的数据 * u8 *str 计算完成的字符存储位置 * @返回值 无***----------------------------------------------------------------*/void U8ToStrNoSpace(u8 d, u8 * str){ if(d 》= 100) { str[3] = ‘’; str[2] = d%10+‘0’; d /= 10; str[1] = d%10+‘0’; d /= 10; str[0] = d%10+‘0’; } else if(d 》= 10) { str[2] = ‘’; str[1] = d%10+‘0’; d /= 10; str[0] = d%10+‘0’; } else { str[1] = ‘’; str[0] = d%10+‘0’; }}
unsigned short 类型转换成字符:
/**----------------------------------------------------------------- * @函数名 U16ToStr * @功能 u16类型转换成字符 * * @参数 * u16 d 需转换的数据 * u8 *str 计算完成的字符存储位置 * u8 len 转换字符的长度位 * @返回值 无***----------------------------------------------------------------*/void U16ToStr(u16 d, u8 * str, u8 len){ u8 i;
str[len-1] = ‘0’; str[len] = ‘’; i = len; while(d 》 0) { str[i-1] = (d%10) + ‘0’; i --; if (i == 0) { break; } d /= 10; }
if (i == len) { i --; }
while (i 》 0) { str[i-1] = ‘ ’; i--; }}
/**----------------------------------------------------------------- * @函数名 U8ToStr * @功能 u8类型转换成3位字符 * * @参数 * u8 d 需转换的数据 * u8 *str 计算完成的字符存储位置 * @返回值 无***----------------------------------------------------------------*/void U8ToStr(u8 d, u8 * str){ U16ToStr((u16)d, str, 3);}
unsigned char变成16进制字符串:
u8 const HEX_CODE[16] = {‘0’,‘1’,‘2’,‘3’,‘4’,‘5’,‘6’,‘7’,‘8’,‘9’,‘A’,‘B’,‘C’,‘D’,‘E’,‘F’};
/**----------------------------------------------------------------- * @函数名 U8ToHexstr * @功能 u8类型转换成16进制字符串 * * @参数 * u8 d 需转换的数据 * u8 *str 计算完成的字符存储位置 * @返回值 无***----------------------------------------------------------------*/void U8ToHexstr(u8 d, u8 * str){ str[0] = HEX_CODE[d/16]; str[1] = HEX_CODE[d%16]; str[2] = ‘’;}
/ The End /
原文标题:C代码常用函数整理
文章出处:【微信公众号:FPGA之家】欢迎添加关注!文章转载请注明出处。
责任编辑:haq
  • C语言
  • 代码
原文标题:C代码常用函数整理
文章出处:【微信号:zhuyandz,微信公众号:FPGA之家】欢迎添加关注!文章转载请注明出处。
    C语言如何处理函数的返回值
    的那样,直接把 1234 赋值给了变量 ret? 搞懂这个问题不难,只要看下汇编代码就行。 把代码编译一下,只编译不链接,得到的就是C对应的汇编代码。 这块是 test
    的头像 发表于 01-16 09:21 108次阅读
    Python常用函数大全
    在 Python 世界里,有一些宝藏函数和模块,它们可以让你编程更轻松、代码更高效。这篇文章将带你一一认识这些神器,让你的开发生活瞬间轻松不少!
    的头像 发表于 10-27 17:20 377次阅读
    嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-串口通讯编程示例之串口完整代码
    ->02_elf1_cmd_serialportserial.c本节代码提供了串口通信的函数库,主要分三部分:(一)设置串口参数'func_set_opt&
    发表于 10-26 09:52
    ;02_elf1_cmd_serialport serial.c 本节代码提供了串口通信的函数库,主要分三部分: (一)设置串口参数\'func_set_opt\' 首先通过
    发表于 10-25 10:41
    labview常用的基本函数
    电子发烧友网站提供《labview常用的基本函数.pdf》资料免费下载
    发表于 10-15 17:29 7次下载
    如何通过I2C加载TPS2388x SRAM和奇偶校验代码
    电子发烧友网站提供《如何通过I2C加载TPS2388x SRAM和奇偶校验代码.pdf》资料免费下载
    发表于 09-06 11:16 0次下载
    如何通过I2<b class='flag-5'>C</b>加载TPS2388x SRAM和奇偶<b class='flag-5'>校验</b><b class='flag-5'>代码</b>
    LP886-Q1在大屏汽车导航的应用及其EEPROM烧录校验方法
    电子发烧友网站提供《LP886-Q1在大屏汽车导航的应用及其EEPROM烧录校验方法.pdf》资料免费下载
    发表于 09-05 11:14 0次下载
    LP886-Q1在大屏汽车导航的应用及其EEPROM烧录<b class='flag-5'>校验方法</b>
    简述socket编程中的常用函数
    Socket编程是一种基于TCP/IP协议的网络编程技术,它允许应用程序通过网络进行通信。在Socket编程中,有许多常用函数,它们用于创建、配置、连接、发送和接收数据等操作。以下是对这些常用
    的头像 发表于 08-16 10:49 499次阅读
    凯迪正大分享电缆交流电压检测的试验方法及其重要性
    电缆交流电压检测作为评估电缆工作状态、预防故障发生的重要方式之一,其试验方法的选择与执行至关重要。本文讲结合凯迪正大的实操经验探讨电缆交流电压检测的基本原理、常用验方法、操作步骤及其在实际应用中的重要性。
    的头像 发表于 08-12 15:41 496次阅读
    便携式互感器校验装置的使用方法——每日了解电力知识
    今天武汉摩恩智能电气有限公司带大家了解一下MOEORW-8050/35 便携式互感器校验装置 MOEORW-8050/35 便携式互感器校验装置使用方法: 1.校验仪面板与背板
    的头像 发表于 07-19 10:41 396次阅读
    便携式互感器<b class='flag-5'>校验</b>装置的使用<b class='flag-5'>方法</b>——每日了解电力知识
    互感器校验仪检定装置的试验方法——每日了解电力知识
    今天武汉摩恩智能电气有限公司带大家了解一下MEHGJ-1006 互感器校验仪检定装置。 1、检定互感器校验仪接线方法: MEHGJ-1006 互感器校验仪检定装置使用指南: 1、测试功
    的头像 发表于 07-12 09:11 570次阅读
    互感器<b class='flag-5'>校验</b>仪检定装置的试<b class='flag-5'>验方法</b>——每日了解电力知识
    详解TSMaster CAN 与 CANFD 的 CRC E2E 校验方法
    面对切换工具链的用户来说,在TSMaster上完成总线通讯中的CRC/E2E校验处理不是特别熟悉,该文章可以协助客户快速使用TSMaster完成CAN/CANFD总线通讯的CRC/E2E校验。本文
    的头像 发表于 05-25 08:21 2736次阅读
    详解TSMaster CAN 与 CANFD 的 CRC E2E <b class='flag-5'>校验方法</b>
    MATLAB信号处理常用函数详解
    MATLAB是一款功能强大的数学软件,尤其在信号处理领域,它提供了众多的函数和工具箱,使得信号的分析、处理、仿真变得简单而高效。本文将详细介绍MATLAB在信号处理中常用函数,并通过
    的头像 发表于 05-17 14:31 2663次阅读
    怎么使用hal accumulate函数完成crc分块校验与整体校验crc值相等?
    发表于 03-27 07:46
    浅析MCU通信、存储常用的简单校验算法
    UART有一个奇偶校验,CAN通信有CRC校验。Modbus、MAVlink、USB等通信协议也有校验信息。
    的头像 发表于 03-07 10:56 589次阅读
    浅析MCU通信、存储<b class='flag-5'>常用</b>的简单<b class='flag-5'>校验</b>算法
