220V发光灯电路--220 Volts Flashing
灯光控制电路 来源:www.elecfans.com 作者:电子发烧友 2010-01-15 08:52 次阅读
220V发光灯电路--220 Volts Flashing Lamps
Especially designed for Christmas tree lamps
Replaces old thermally-activated switches
Parts:
R1___________100K 1/4W Resistor
R2,R5__________1K 1/4W Resistors
R3,R6________470R 1/4W Resistors
R4____________12K 1/4W Resistor
C1__________1000΅F 25V Electrolytic Capacitor
D1-D4_______1N4007 1000V 1A Diodes
D5__________P0102D 400V 800mA SCR
Q1___________BC327 45V 800mA PNP Transistor
Q2___________BC337 45V 800mA NPN Transistor
PL1__________Male Mains plug
SK1__________Female Mains socket
Device purpose:
This circuit is intended as a reliable replacement to thermally-activated switches used for Christmas tree lamp-flashing. The device formed by Q1, Q2 and related resistors triggers the SCR. Timing is provided by R1,R2 & C1. To change flashing frequency don't modify R1 and R2 values: set C1 value from 100 to 2200΅F instead.
Best performances are obtained with C1=470 or 1000΅F and R4=12K or 10K. Due to low consumption of normal 10 or 20 lamp series-loops intended for Christmas trees (60mA @ 220V typical for a 20 lamp series-loop), very small and cheap SCR devices can be used, e.g. C106D1 (400V 3.2A) or TICP106D (400V 2A), this last and the suggested P0102D devices having TO92 case.
Important Note:
For proper operation it's absolutely necessary to employ high Gate-sensitive SCRs.
If you are unable to find these devices you can use Triacs instead. In this case the circuit operates also with relatively powerful devices. A recommended Triac type is the ubiquitous TIC206M (600V 4A) but many others can work.
Note that in spite of the Triac, diode bridge D1-D4 is in any case necessary.
This circuit was awarded with publication in ELECTRONICS WORLD "Circuit Ideas", June 2000 issue, page 458.
  • 220V
    220V输入的LED电源电路
    220V电源输
    发表于 10-17 15:57 1.7w次阅读
    <b class='flag-5'>220V</b>输入的LED<b class='flag-5'>灯</b>电源<b class='flag-5'>电路</b>
    直流12V交流220V逆变器电路
    直流12V交流220V逆变器电路
    发表于 10-23 21:40 3269次阅读
    直流12<b class='flag-5'>V</b>交流<b class='flag-5'>220V</b>逆变器<b class='flag-5'>电路</b>
    12v220v电路
    12v220v电路
    发表于 05-20 17:00 6612次阅读
    12<b class='flag-5'>v</b>变<b class='flag-5'>220v</b><b class='flag-5'>电路</b>图
    直流12V220V交流逆变器电路图 (500W)
    直流12V220V交流逆变器电路图 (500W) 直流12V220V交流逆变器电路图可以转
    发表于 03-05 16:10 4.1w次阅读
    直流12<b class='flag-5'>V</b>转<b class='flag-5'>220V</b>交流逆变器<b class='flag-5'>电路</b>图 (500W)
    220v转24v电路
    220v转24v电路
    发表于 03-05 17:21 4.4w次阅读
    <b class='flag-5'>220v</b>转24<b class='flag-5'>v</b><b class='flag-5'>电路</b>图
    220v led电路图(三款超简单led电源电路
    220v led使用220V电源供电,led电路图如下所示,220V交流电经C1降压电容降
    发表于 10-07 22:01 15.3w次阅读
    <b class='flag-5'>220v</b> led<b class='flag-5'>灯</b><b class='flag-5'>电路</b>图(三款超简单led电源<b class='flag-5'>电路</b>)
    20W的日光电路图(220V电子镇流器电路图),Ballast circuit
    20W的日光电路图(220V电子镇流器电路图),Ballast circuit 关键字:20W的日光
    的头像 发表于 09-20 18:45 3497次阅读
    220V降5V芯片,220V降12V电源芯片模块
    220V降5V芯片,220V降12V电源芯片模块220V降5V芯片,
    发表于 11-07 12:06 121次下载
    <b class='flag-5'>220V</b>降5<b class='flag-5'>V</b>芯片,<b class='flag-5'>220V</b>降12<b class='flag-5'>V</b>电源芯片模块
    分享一个直接连接到220V电​​源的闪光电路
    这是直接连接到220V电​​源的220V800W闪光电路。可以使用一个或多个具有高消耗/功率的。它是标志警告或危险的理想选择,该
    的头像 发表于 05-10 17:19 3792次阅读
    分享一个直接连接到<b class='flag-5'>220V</b>电​​源的闪光<b class='flag-5'>灯</b><b class='flag-5'>电路</b>
    220V交流触摸调光电路解析
    这里是220V交流触摸调光电路。只需触摸此触摸调光器,您就可以分三个阶段增加白炽的光强度。触摸调光器围绕8针CMOSICTT8486A/TT6061A设计,专为触摸调光器应用而生产
    的头像 发表于 06-08 16:19 6765次阅读
    <b class='flag-5'>220V</b>交流<b class='flag-5'>灯</b>触摸调光<b class='flag-5'>电路</b>解析
    220V AC电源LED指示电路
    这是 220V AC 电源 LED 指示的示意图,可用于指示电缆线已连接到 220v 电气装置。
    的头像 发表于 06-21 16:50 1.3w次阅读
    <b class='flag-5'>220V</b> AC电源LED指示<b class='flag-5'>灯</b><b class='flag-5'>电路</b>图
    220V指示电路图分享
      图1这种电路成本最低,但是设计不合理,发光二极管反向截止时要承受220V电压,峰值反向电压达到220V*1.414 = 311V,有反向
    的头像 发表于 11-11 16:12 1.5w次阅读
    <b class='flag-5'>220V</b>指示<b class='flag-5'>灯</b><b class='flag-5'>电路</b>图分享
    220V LED里面电路阻容降压的原理是什么?
    这次我们说一个家里用的220V LED电路原理,总体上来说是通过阻容降压来降低输入的电压,再经过整流桥、滤波电容、稳压管等元件来驱动多个LED
    的头像 发表于 12-06 13:57 1.1w次阅读
    220V转12V220V降5V电源芯片方案
    220V转12V芯片,220V降5V芯片,交流220V转直流12V芯片,
    的头像 发表于 08-17 15:48 4025次阅读
    <b class='flag-5'>220V</b>转12<b class='flag-5'>V</b>:<b class='flag-5'>220V</b>降5<b class='flag-5'>V</b>电源芯片方案
    220V指示电路哪个更好一些?
    图1这种电路成本最低,但是设计不合理,发光二极管反向截止时要承受220V电压,峰值反向电压达到220V*1.414 = 311V,有反向击穿
    的头像 发表于 09-11 16:48 1378次阅读
    <b class='flag-5'>220V</b>指示<b class='flag-5'>灯</b><b class='flag-5'>电路</b>哪个更好一些?
