LED灯和脉冲发生器电路--LED or Lamp Puls
灯光控制电路 来源:www.elecfans.com 作者:电子发烧友 2010-01-15 09:02 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
LED或灯脉冲发生器电路--LED or Lamp Pulser
Astonishing effect
4.5V supply
Parts:
R1,R2___________4K7 1/4W Resistors
R3_____________22K 1/4W Resistor
R4______________2M2 1/4W Resistor (See Notes)
R5_____________10K 1/4W Resistor
R6_____________47R 1/4W Resistor (See Notes)
C1______________1΅F 63V Polyester Capacitor
D1_____________5mm. Red LED (See Notes)
IC1__________LM358 Low Power Dual Op-amp
Q1___________BC337 45V 800mA NPN Transistor
Circuit operation:
This circuit operates a LED in pulsing mode, i.e. the LED goes from off state, lights up gradually, then dims gradually, etc.
This operation mode is obtained by a triangular wave generator formed by two op-amps contained in a very cheap 8 pin DIL case IC. Q1 ensures current buffering, in order to obtain a better load drive.
R4 & C1 are the timing components: using the values shown in the parts list, the total period is about 4 seconds.
Notes:
The most satisfying results are obtained adopting for R4 a value ranging from 220K to 4M7.
Adopting for R4 a value below 220K, the pulsing effect will be indistinguishable from a normal blinking effect.
The LED can be any type and color.
You can use a filament lamp instead, provided its features are comprised in the range 3.2 to 6V, 200mA max.
Using a lamp as a load, R6 must be omitted.
Voltage supply range can be 4 to 6V: 4.5V is the best compromise.
Don't supply the circuit with voltages exceeding 6V: it will work less good and Q1 could be damaged when a lamp was used as the load.
At 6V supply, increase R6 value to 100 Ohm.
  • 脉冲发生器
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    5个LED闪光驱动电路,5 Lamp/LED Fla
    发表于 02-27 09:20 5448次阅读
    5个<b class='flag-5'>灯</b>的<b class='flag-5'>LED</b>闪光<b class='flag-5'>灯</b>驱动<b class='flag-5'>器</b><b class='flag-5'>电路</b>,5 <b class='flag-5'>Lamp</b>/<b class='flag-5'>LED</b> Fla
    怎么在Multisim中点亮LED或者LAMP
    今天在Multisim10中,随便搭了一个简单的电路,点亮LED或者LAMP,但是发现没有变化,请问一下,是我的版本有问题吗?为什么接通
    发表于 12-08 16:50
    几种60HZ脉冲发生器电路
    60HZ脉冲发生器电路几种60H脉冲发生器电路 附图1
    发表于 05-23 12:58 3113次阅读
    几种60HZ<b class='flag-5'>脉冲</b><b class='flag-5'>发生器</b><b class='flag-5'>电路</b>
    led控制线路图
    led控制线路图由电源电路脉冲发生器、控制电路
    发表于 11-08 13:37 1.8w次阅读
    <b class='flag-5'>led</b><b class='flag-5'>灯</b>控制<b class='flag-5'>器</b>线路图
    高压脉冲发生器电路
    高压脉冲发生器电路
    发表于 12-19 01:29 3248次阅读
    高压<b class='flag-5'>脉冲</b><b class='flag-5'>发生器</b><b class='flag-5'>电路</b>
    脉冲发生器
    脉冲发生器
    发表于 03-21 09:29 533次阅读
    钟<b class='flag-5'>脉冲</b><b class='flag-5'>发生器</b>
    脉冲发生器
    脉冲发生器
    发表于 03-23 10:09 715次阅读
    脉冲发生器
    脉冲发生器
    发表于 03-23 10:24 608次阅读
    脉冲发生器电路
    脉冲发生器电路
    发表于 05-18 15:57 2057次阅读
    <b class='flag-5'>脉冲</b><b class='flag-5'>发生器</b><b class='flag-5'>电路</b>图
    LED动态显示序列发生器电路
    LED动态显示序列发生器电路
    发表于 05-23 13:20 834次阅读
    <b class='flag-5'>LED</b>动态显示序列<b class='flag-5'>发生器</b><b class='flag-5'>电路</b>图
    LED或闪光电路--LED or Lamp Flasher
    LED或闪光电路--LED or Lamp Flasher Minimum parts counting Designed for 3
    发表于 01-15 08:50 1601次阅读
    <b class='flag-5'>LED</b>或闪光<b class='flag-5'>灯</b><b class='flag-5'>电路</b>--<b class='flag-5'>LED</b> or <b class='flag-5'>Lamp</b> Flasher
    高压脉冲发生器电路图大全(六款等效电路/电子灭虫/脉冲发生器产生)
    本为介绍了六款高压脉冲发生器电路图,其中包括了高压脉冲发生器等效电路、高压
    发表于 05-10 11:29 4.2w次阅读
    高压<b class='flag-5'>脉冲</b><b class='flag-5'>发生器</b><b class='flag-5'>电路</b>图大全(六款等效<b class='flag-5'>电路</b>/电子灭虫<b class='flag-5'>灯</b>/<b class='flag-5'>脉冲</b><b class='flag-5'>发生器</b>产生)
    脉冲发生器输出是1吗?信号发生器怎么只发一个脉冲
    和说明。 一、脉冲发生器的输出 脉冲发生器是一种能够产生特定类型脉冲的电子设备,通常用于测试电路
    的头像 发表于 08-24 15:18 3730次阅读
    脉冲发生器是什么意思?脉冲发生器怎么使用?
    脉冲发生器是什么意思?脉冲发生器怎么使用? 脉冲发生器是一种电子设备,可以生成不同类型的
    的头像 发表于 08-24 15:18 6111次阅读
    如何使用IC4017构建追逐LED光波效应发生器电路
    这篇文章解释了如何使用 IC 4017 设计和构建追逐 LED光波效应发生器电路。基本上,该电路LED 追逐
    的头像 发表于 02-25 14:14 2020次阅读
    如何使用IC4017构建追逐<b class='flag-5'>LED</b>光波效应<b class='flag-5'>发生器</b><b class='flag-5'>电路</b>
