衰落发光二极管电路--Fading LEDs
灯光控制电路 来源:www.elecfans.com 作者:电子发烧友 2010-01-17 09:20 次阅读
Two strips of LEDs fading in a complementary manner
9V Battery-operated portable unit
Parts:
R1,R2_______________4K7 1/4W Resistors
R3_________________22K 1/4W Resistor
R4__________________1M 1/4W Resistor (See Notes)
R5__________________2M2 1/4W Carbon Trimmer (See Notes)
R6,R10,R11,R14,R15_10K 1/4W Resistors
R7,R8______________47K 1/4W Carbon Trimmers (See Notes)
R9,R13_____________27K 1/4W Resistors
R12,R16____________56R 1/4W Resistors
C1__________________1΅F 63V Polyester Capacitor
C2________________100΅F 25V Electrolytic Capacitor
D1-D4 etc._________5 or 3mm. LEDs (any type and color) (See Notes)
IC1_______________LM358 Low Power Dual Op-amp
Q1,Q2,Q4__________BC327 45V 800mA PNP Transistors
Q3,Q5,Q6__________BC337 45V 800mA NPN Transistors
SW1________________SPST miniature Slider Switch
B1___________________9V PP3 Battery
Clip for PP3 Battery
Device purpose:
This circuit operates two LED strips in pulsing mode, i.e. one LED strip goes from off state, lights up gradually, then dims gradually, etc. while the other LED strip do the contrary.
Each strip can be made up from 2 to 5 LEDs at 9V supply.
Circuit operation:
The two Op-Amps contained into IC1 form a triangular wave generator. The rising and falling voltage obtained at pin #7 of IC1 drives two complementary circuits formed by a 10mA constant current source (Q1, Q2 and Q5, Q6) and driver transistor (Q3 and Q6).
R4, R5 & C1 are the timing components: the total period can be varied changing their values. R7 & R8 vary the LEDs brightness.
Notes:
For those whishing to avoid the use of trimmers, suggested values for a 9V supply are:
R4=3M9, R9 & R13=47K and trimmers replaced by a short.
Whishing to use a wall-plug transformer-supply instead of a 9V battery, you can supply the circuit at 12V, allowing the use of up to 6 LEDs per strip, or at 15V, allowing the use of up to 7 LEDs per strip.
In this case, the value of the trimmers R7 & R8 should be changed to 100K.
  • 发光二极管
    发光二极管型号有哪些_发光二极管型号大全
    辐射出往的发光器件,重要应用于各种光控及远控发射电路中。  红外发光二极管的结构、道理与通俗发光二极管邻近,只是应用的半导体材料不同。红外发光二极管
    发表于 04-03 11:33
    发表于 09-07 11:29
    发光二极管原理
    发光二极管不宜在高温环境中使用。  发光二极管的反向耐压(即反向击穿电压)值比普通二极管的小,所以使用时,为了防止击穿造成发光二极管发光
    发表于 06-13 02:40
    发光二极管电路的设计原理是什么
    发光二极管电路的设计原理是什么?发光二极管电路的特性有哪些?发光二极管与其它发光灯对比有何优势?
    发表于 10-09 08:07
    发光二极管
    发光二极管 发光二极管(LED)通常用元素
    发表于 09-17 09:25 969次阅读
    发光二极管的基本电路
    发光二极管的基本电路 发光二极管属于电流控制型器件,使用时必须加限流电阻才能保证其正常工作。发光二极管的基本电路如图10-5 所示。
    发表于 09-19 17:28 5767次阅读
    二极管-发光二极管
    二极管-发光二极管   发光二极管简称为
    发表于 11-07 09:06 1817次阅读
    什么是发光二极管
    什么是发光二极管              发光二极管功耗小,噪
    发表于 12-29 11:22 936次阅读
    舞蹈发光二极管电路--Dancing LEDs
    的头像 发表于 01-17 09:18 2642次阅读
    舞蹈<b class='flag-5'>发光二极管</b><b class='flag-5'>电路</b>--Dancing <b class='flag-5'>LEDs</b>
    发光二极管(LED),发光二极管(LED)是什么意思
    发光二极管(LED),发光二极管(LED)是什么意思 发光二极管(LED)的发光原理可以用PN结的能带结构来解释:当导带中的电子与价带中的空穴
    发表于 02-27 16:14 4265次阅读
    发光二极管的原理是什么?
    发光二极管的原理是什么? 发光二极管是一种特殊的二极管。和普通的二极管一样,发光二极管由半导体芯片组成,这些半导体材料会
    发表于 02-27 16:17 6002次阅读
    有机发光二极管_什么是有机发光二极管
    本内容介绍了什么是有机发光二极管,有机发光二极管的概念,有机发光二极管的结构及优势,详细的全面的介绍有机发光二极管
    发表于 05-15 14:55 7936次阅读
    有机<b class='flag-5'>发光二极管</b>_什么是有机<b class='flag-5'>发光二极管</b>
    发光二极管特点_发光二极管要加电阻吗_发光二极管电阻怎么接
    发光二极管简称为LED。由含镓(Ga)、砷(As)、磷(P)、氮(N)等的化合物制成。当电子与空穴复合时能辐射出可见光,因而可以用来制成发光二极管。在电路及仪器中作为指示灯,或者组成文字或数字显示
    发表于 12-11 19:42 1.1w次阅读
    发光二极管封装是什么,关于发光二极管封装的详解
    一看什么是发光二极管封装?以及发光二极管封装详解。 一. 什么是发光二极管封装? 发光二极管封装即LED封装,是指发光芯片的封装,相比集成
    发表于 12-26 11:04 6206次阅读
    什么是红外二极管发光二极管?红外二极管发光二极管的区别
    什么是红外二极管发光二极管又是什么呢?红外二极管发光二极管的区别  红外二极管发光二极管
    的头像 发表于 01-26 15:42 2154次阅读
