发光二极管驱逐舰(霹雳游侠灯)电路-LED Chaser (
灯光控制电路 来源:www.elecfans.com 作者:本站 2010-01-18 10:38 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
发光二极管驱逐舰(霹雳游侠灯)电路-LED Chaser (Knight Rider lights)
I don't know why, but people like blinking lights. You see LED chasers everywhere, in TV shows (Knight Rider), movies, and store windows. This schematic is my version of a simple 10 LED chaser. There is no 555 timer used because at my local electronics store they are over $4 Cdn. Instead, an oscillator made up of two sections of a 4011 NAND gate is employed. This chip is very inexpensive and extremely common.
Schematic
Parts:
Part
Total Qty.
Description
Substitutions
R1
1
1 Meg 1/4W Resistor
R2
1
100K Pot
R3
1
1K 1/4W Resistor
220Ohm if using blue LEDs
C1
1
0.1uF 16V Ceramic Disk Capacitor
U1
1
4011 CMOS NAND Gate
U2
1
4017 CMOS Counter
LED1-10
10
LEDs Of Any Colour
MISC
1
Board, Sockets For ICs, Knob For R2
Notes:
1. Use R2 to adjust the "chase rate".
2. You may need to use a lower value resistor if you wish to use blue LEDs. Try 220 Ohm.
3. You can also use incandescent lamps instead of LEDs. Use transistors to drive them by connecting the base of the transistors to each of the outputs of the 4017 through a 1K resistor. Connect one end of the lamp to the positive supply. Then connect the other end to the collector of the transistor. The emitter then goes to ground. Depending on the lamps, you may need power transistors that are heat sinked.
4. C1 may be replaced with a larger value for a slower "chase rate".
5. If you have problems with weird circuit behavior, try replacing R1 with a 33K resistor, and increasing C1 to 1uF.
6. If you plan to use this circuit in your car, be warned that in some areas it is illegal to have red, blue or yellow flashing lights unless you are an emergency vehicle.
  • 发光二极管
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    紫外发光二极管发光原理 紫外发光二极管的结构
    紫外发光二极管是指可发出波长约400nm的近紫外光的发光二极管led)。
    的头像 发表于 02-26 16:03 3.4w次阅读
    紫外<b class='flag-5'>发光二极管</b>的<b class='flag-5'>发光</b>原理 紫外<b class='flag-5'>发光二极管</b>的结构
    霹雳游侠制作
    霹雳游侠制作PCB打样找华强 http://www.hqpcb.com 样板2天出货
    发表于 12-18 19:53
    发光二极管型号有哪些_发光二极管型号大全
    等场合。在我们的日常生活中被广泛的使用,下面就和小编一起来认识一下发光二极管型号。英文单词的缩写,主要含义:LED = Light EmitTIng Diode,发光二极管,是一种能够将电能转化
    发表于 04-03 11:33
    发表于 09-07 11:29
    贴片LED发光二极管的应用范围
    的指示。从贴片LED发光二极管发展和应用历程上看,这一时期为LED的指示应用阶段。下面高品级发光二极管品牌科特翎科技为大家介绍贴片
    发表于 06-20 02:01
    发光二极管电路的设计原理是什么
    发光二极管电路的设计原理是什么?发光二极管电路的特性有哪些?发光二极管与其它发光
    发表于 10-09 08:07
    发光二极管闪光电路原理图
    发光二极管闪光电路原理图 发光二极管闪光电路原理图
    发表于 01-17 14:01 4441次阅读
    <b class='flag-5'>发光二极管</b>闪光<b class='flag-5'>灯</b><b class='flag-5'>电路</b>原理图
    发光二极管
    发光二极管 发光二极管LED)通常用元素
    发表于 09-17 09:25 1180次阅读
    3V供电的LED驱逐舰电路 (3V LED Chaser)
    3V供电的LED驱逐舰电路 (3V LED Chaser) General There are many 9V
    发表于 12-30 09:19 2454次阅读
    发光二极管(LED),发光二极管(LED)是什么意思
    发光二极管(LED),发光二极管(LED)是什么意思 发光二极管(LED)的
    发表于 02-27 16:14 4694次阅读
    led/发光二极管参数有哪些?
    led/发光二极管参数有哪些? 简介:  LED发光二极管( Light Emitting Diode, LED)的简称,也被称作
    发表于 02-27 17:24 1.3w次阅读
    发光二极管(LED),发光二极管(LED)的原理和作用是什么
    发光二极管(LED),发光二极管(LED)的原理和作用是什么? 发光二极管(LED)的
    发表于 03-26 17:33 4918次阅读
    发光二极管特点_发光二极管要加电阻吗_发光二极管电阻怎么接
    发光二极管简称为LED。由含镓(Ga)、砷(As)、磷(P)、氮(N)等的化合物制成。当电子与空穴复合时能辐射出可见光,因而可以用来制成发光二极管。在电路及仪器中作为指示
    发表于 12-11 19:42 1.2w次阅读
    发光二极管的优点,发光二极管二极管有区别吗
    当电子与空穴复合时能辐射出可见光,因而可以用来制成发光二极管。在电路及仪器中作为指示,或者组成文字或数字显示。砷化镓二极管发红光,磷化镓二极管
    发表于 01-25 13:47 2.5w次阅读
    发光二极管封装是什么,关于发光二极管封装的详解
    一看什么是发光二极管封装?以及发光二极管封装详解。 一. 什么是发光二极管封装? 发光二极管封装即LED封装,是指
    发表于 12-26 11:04 7575次阅读
