固体中经典车削表面—理论计算和诠释
ExMh_zhishexues 来源:知社学术圈 作者:知社学术圈 2021-05-29 16:52 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
基于Kohn-Sham方程的密度泛函理论为描述各类材料系统的物理和化学性质提供了一个强大的工具。原子和离子的最高占据轨道能量下的经典车削表面对化学键的研究具有重要意义。比如,共价键的车削面为椭圆形,离子键的车削面存在接缝,而范德华二聚体的车削面则存在分叉。但上述性质仅针对有限系统成立,对于实际固体来说,其密度并不会在远离原子核的地方衰减为零。那么利用现有的计算手段表征实际存在的固体的经典车削面的性质就变得尤为重要。
来自美国费城坦普尔大学物理系和化学系的John P. Perdew教授和加州大学化学和物理系的Kieron Burke教授以及杜伦大学材料物理中心的Stewart J. Clark教授利用局域自旋密度近似和广义梯度近似计算并分析了多种固体车削面的性质和物理规律。
他们发现,在平衡态下,经典禁止区域不存在于金属中,在共价半导体中也较为少见,但在离子晶体和分子晶体中很常见。此外,他们还证明,在所有材料中,经典禁止区域会随着核间距的均匀扩展而产生和增长。
同时,经典禁止区域也可以出现在金属的单空位中。经典允许区在金属中是连接着的,在宽能隙绝缘体中是断开的。令人惊奇的是,许多半导体在平衡状态时不存在经典禁止区域。缺陷的存在可以诱导产生经典禁止区域,对未来固体中车削面性质的研究具有重要意义。
该文近期发表于npj Computational Materials 7: 25 (2021),英文标题与摘要如下。
Calculation and interpretation of classical turning surfaces in solids
Aaron D. Kaplan, Stewart J. Clark, Kieron Burke & John P. Perdew
Classical turning surfaces of Kohn–Sham potentials separate classically allowed regions (CARs) from classically forbidden regions (CFRs)。 They are useful for understanding many chemical properties of molecules but need not exist in solids, where the density never decays to zero.
At equilibrium geometries, we find that CFRs are absent in perfect metals, rare in covalent semiconductors at equilibrium, but common in ionic and molecular crystals.
In all materials, CFRs appear or grow as the internuclear distances are uniformly expanded. They can also appear at a monovacancy in a metal. Calculations with several approximate density functionals and codes confirm these behaviors.
A classical picture of conduction suggests that CARs should be connected in metals, and disconnected in wide-gap insulators, and is confirmed in the limits of extreme compression and expansion. Surprisingly, many semiconductors have no CFR at equilibrium, a key finding for density functional construction.
Nonetheless, a strong correlation with insulating behavior can still be inferred. Moreover, equilibrium bond lengths for all cases can be estimated from the bond type and the sum of the classical turning radii of the free atoms or ions.
  • 晶体
  • 能量
  • 原子
  • 离子
原文标题:npj: 固体中经典车削表面—理论计算和诠释
文章出处:【微信号:zhishexueshuquan,微信公众号:知社学术圈】欢迎添加关注!文章转载请注明出处。
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    数控车削加工工艺分析要点
    数控车削加工工艺分析要点加工工艺分析是数控车削的核心环节,直接影响加工效率、精度及成本。以下是关键分析步骤:零件图纸分析 确认图纸尺寸、公差、表面粗糙度等技术要求。 识别关键特征(如内外圆、螺纹、槽
    发表于 04-11 09:35
    磁环电感计算:从理论公式到应用的关键跨越
    随着电子设备向小型化、高功率密度方向发展,磁环电感的设计理念已从单纯的理论计算转向应用适配。谷景通过优化磁芯材料配方与绕线工艺,在缩小体积的同时保持优异的电气性能,满足智能家居、工业控制、汽车电子等
    的头像 发表于 03-09 10:22 342次阅读
    光耦的进化诠释了“分离与连接”的工程辩证
    在电子工程领域,光电耦合器(简称光耦)的百年进化史,生动诠释了“分离与连接”这一工程辩证法则。作为电气隔离与信号传输的核心器件,光耦通过光介质的巧妙运用,在电气分离与信号连接之间构建起精妙的平衡
    的头像 发表于 01-19 11:02 315次阅读
    光耦的进化<b class='flag-5'>诠释</b>了“分离与连接”的工程辩证
    ‌Vishay TX3系列固体钽电容技术解析与应用指南
    Vishay/Sprague TX3固体表面贴装片式电容器设计用于电子烟火系统,采用模制外壳,尺寸为3528-21和6032-28。这些TANTAMOUNT™电容器为电子雷管提供增强的性能,为电池
    的头像 发表于 11-12 15:36 780次阅读
    ‌Vishay TX3系列<b class='flag-5'>固体</b>钽电容技术解析与应用指南
    红外热像仪在航空固体燃料燃烧实验中的应用
    固体燃料是航空航天领域的关键动力源。对航空固体燃料进行燃烧实验,有助于研究和优化其配方,从而提升能量密度、燃烧效率和安全稳定性,最终增强火箭的推力性能。这些实验能深入探究固体燃料在不同压力、温度及气流速度等条件下的燃烧过程与燃烧
    的头像 发表于 11-12 14:58 697次阅读
    今日看点:谷歌芯片实现量子计算经典超算快13000倍;NFC 技术突破:读取距离从 5 毫米提升至 20 毫米
    谷歌芯片实现量子计算经典超算快13000倍 近日,谷歌在《自然》杂志披露与Willow芯片相关的量子计算突破性研究成果。该公司称这是历史上首次证明量子计算机可以在硬件上成功运行一项可
    发表于 10-23 10:20 1711次阅读
    锂离子电池集流体—铜箔的表面粗糙度表征研究
    固体电解质相间膜,减少锂枝晶的生长,并延长电池的循环寿命。美能光子湾3D共聚焦显微镜,能够快速高效完成亚微米级形貌和表面粗糙度的精准测量任务,协助研究人员观察集流
    的头像 发表于 08-05 17:56 1112次阅读
    锂离子电池集流体—铜箔的<b class='flag-5'>表面</b>粗糙度表征研究
    超声辅助车削工艺下的表面质量研究:C45碳钢与201不锈钢的对比分析
    在现代机械加工领域,超声波辅助车削技术(CUAT)作为一种创新的加工方法,正逐渐成为提高加工效率、降低刀具磨损以及改善表面质量的重要手段。通过将超声波振动引入传统车削工艺,CUAT不仅能够实现间歇
    的头像 发表于 08-05 17:51 1526次阅读
    超声辅助<b class='flag-5'>车削</b>工艺下的<b class='flag-5'>表面</b>质量研究:C45碳钢与201不锈钢的对比分析
    Quantum Machines推动量子计算新边界
    量子计算正在为经典计算无法企及的难题打开大门,例如药物开发中新材料的发现,优化和模拟。然而,量子研发领域存在诸多难题。
    的头像 发表于 07-23 16:04 993次阅读
    【电磁兼容技术案例分享】磁环电感量的理论计算与仿真验证分析
    的头像 发表于 07-15 16:25 979次阅读
    【电磁兼容技术案例分享】磁环电感量的<b class='flag-5'>理论</b><b class='flag-5'>计算</b>与仿真验证分析
    CST+FDTD超表面逆向设计及前沿应用
    滤波器、以及能够动态调控光场的超表面器件。耦合模理论(CoupledMode Theory, CMT)在超表面设计中的应用非常广泛,它主要用于分析和设计超表面的电磁行为,尤其是在处理光
    的头像 发表于 06-05 09:29 929次阅读
    CST+FDTD超<b class='flag-5'>表面</b>逆向设计及前沿应用
    量子计算最新突破!“量子+AI”开启颠覆未来的指数级革命
    电子发烧友网报道(文/李弯弯)量子计算是一种基于量子力学原理的新型计算模式,其核心在于利用量子比特的叠加态和纠缠态特性,实现远超经典计算机的并行计算
    的头像 发表于 05-28 00:40 1.3w次阅读
    量子<b class='flag-5'>计算</b>最新突破!“量子+AI”开启颠覆未来的指数级革命
    VirtualLab Fusion:平面透镜|从光滑表面到菲涅尔、衍射和超透镜的演变
    透镜的性能。 收集并导出透镜数据以满足制造需求。 工作流程 #2: 用平面透镜替换“厚”透镜表面。 评估包含平面透镜的系统的功能。 促进系统优化。 将平面透镜集成到透镜设计工作流程中,需要在理论
    发表于 05-15 10:36
    EastWave应用:垂直腔表面激光器
    。 参考文献:Appl.Physics.B 91, 475-478(2008) 1. 计算模式及参数 2. 模型说明 □ 采用周期阵列,创建光子晶体。将部分元胞删除,形成表面腔。 □ 采用周期阵列
    发表于 05-12 08:57
    《FDTD Solutions仿真全面教程:超构表面与光束操控的前沿探索》
    表面频域功率监视器设置为例) Ø材料库与材料浏览器(以多晶硅与二氧化钛的数据导入为例) Ø模拟计算与分析:资源管理、运行模拟 Ø结果分析:视觉化器使用Visualize、使用脚本进行高级分析
    发表于 04-22 11:59
