stm325个串口的配置函数 STM32串口如何发送数据
ss 来源:CSDNSumjess、可以吃的鱼 作者:CSDNSumjess、可以吃 2021-07-22 15:02 次阅读
5个串口的配置函数和收发数据函数代码:
#include “stm32f10x.h”
#include “misc.h”
#include “stm32f10x_gpio.h”
#include “stm32f10x_usart.h”
void USART1_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure); //端口A;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入;
USART_InitStructure.USART_BaudRate = 9600; //波特率;
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位;
USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位;
USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
//无硬件流控;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
//收发模式;
USART_Init(USART1, &USART_InitStructure);//配置串口参数
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级;
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //中断号;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_Cmd(USART1, ENABLE); //使能串口;
void USART1_Send_Byte(u8 Data) //发送一个字节;
USART_SendData(USART1,Data);
while( USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET );
void USART1_Send_String(u8 *Data) //发送字符串;
while(*Data)
USART1_Send_Byte(*Data++);
void USART1_IRQHandler(void) //中断处理函数;
u8 res;
if(USART_GetITStatus(USART1, USART_IT_RXNE) == SET) //判断是否发生中断;
USART_ClearFlag(USART1, USART_IT_RXNE); //清除标志位;
res=USART_ReceiveData(USART1); //接收数据;
USART1_Send_Byte(res); //用户自定义;
void USART2_Configuration(void)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //USART2 TX;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //USART2 RX;
//无硬件流控;
//收发模式;
USART_Init(USART2, &USART_InitStructure);//配置串口参数;
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //中断号;
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
USART_Cmd(USART2, ENABLE); //使能串口;
void USART2_Send_Byte(u8 Data) //发送一个字节;
USART_SendData(USART2,Data);
while( USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET );
void USART2_Send_String(u8 *Data) //发送字符串;
while(*Data)
USART2_Send_Byte(*Data++);
void USART2_IRQHandler(void) //中断处理函数;
u8 res;
if(USART_GetITStatus(USART2, USART_IT_RXNE) == SET) //判断是否发生中断;
USART_ClearFlag(USART2, USART_IT_RXNE); //清除标志位;
res=USART_ReceiveData(USART2); //接收数据;
USART2_Send_Byte(res); //用户自定义;
void USART3_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE );
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART3 TX;
GPIO_Init(GPIOB, &GPIO_InitStructure); //端口B;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //USART3 RX;
//无硬件流控;
//收发模式;
USART_Init(USART3, &USART_InitStructure);//配置串口参数;
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; //中断号;
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
USART_Cmd(USART3, ENABLE); //使能串口;
void USART3_Send_Byte(u8 Data) //发送一个字节;
USART_SendData(USART3,Data);
while( USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET );
void USART3_Send_String(u8 *Data) //发送字符串;
while(*Data)
USART3_Send_Byte(*Data++);
void USART3_IRQHandler(void) //中断处理函数;
u8 res;
if(USART_GetITStatus(USART3, USART_IT_RXNE) == SET) //判断是否发生中断;
USART_ClearFlag(USART3, USART_IT_RXNE); //清除标志位;
res=USART_ReceiveData(USART3); //接收数据;
USART3_Send_Byte(res); //用户自定义;
void UART4_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE );
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //UART4 TX;
GPIO_Init(GPIOC, &GPIO_InitStructure); //端口C;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //UART4 RX;
//无硬件流控;
//收发模式;
USART_Init(UART4, &USART_InitStructure);//配置串口参数;
NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn; //中断号;
USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);
USART_Cmd(UART4, ENABLE); //使能串口;
void UART4_Send_Byte(u8 Data) //发送一个字节;
USART_SendData(UART4,Data);
while( USART_GetFlagStatus(UART4, USART_FLAG_TC) == RESET );
void UART4_Send_String(u8 *Data) //发送字符串;
while(*Data)
UART4_Send_Byte(*Data++);
void UART4_IRQHandler(void) //中断处理函数;
u8 res;
if(USART_GetITStatus(UART4, USART_IT_RXNE) == SET) //判断是否发生中断;
USART_ClearFlag(UART4, USART_IT_RXNE); //清除标志位;
res=USART_ReceiveData(UART4); //接收数据;
UART4_Send_Byte(res); //用户自定义;
void UART5_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE );
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART5, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //UART5 TX;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //UART5 RX;
GPIO_Init(GPIOD, &GPIO_InitStructure); //端口D;
//无硬件流控;
//收发模式;
USART_Init(UART5, &USART_InitStructure);//配置串口参数;
NVIC_InitStructure.NVIC_IRQChannel = UART5_IRQn; //中断号;
USART_ITConfig(UART5, USART_IT_RXNE, ENABLE);
USART_Cmd(UART5, ENABLE); //使能串口;
void UART5_Send_Byte(u8 Data) //发送一个字节;
USART_SendData(UART5,Data);
while( USART_GetFlagStatus(UART5, USART_FLAG_TC) == RESET );
void UART5_Send_String(u8 *Data) //发送字符串;
while(*Data)
UART5_Send_Byte(*Data++);
void UART5_IRQHandler(void) //中断处理函数;
u8 res;
if(USART_GetITStatus(UART5, USART_IT_RXNE) == SET) //判断是否发生中断;
USART_ClearFlag(UART5, USART_IT_RXNE); //清除标志位;
res=USART_ReceiveData(UART5); //接收数据;
UART5_Send_Byte(res); //用户自定义;
STM32串口发送数据
1. 串口发送数据最直接的方式就是标准调用库函数 。
void Send_data(u8 *s)
while(*s!=‘\0’)
while(USART_GetFlagStatus(USART1,USART_FLAG_TC )==RESET);
USART_SendData(USART1,*s);
s++;
2. 直接使用printf函数。
可以吃的鱼
整合自:CSDNSumjess、可以吃的鱼
编辑:jq
  • STM32
    LS10串口数据库模块外扩SD卡功能
    LS10串口数据库模块外扩SD卡功能
    的头像 发表于 11-23 09:42 276次阅读
    LS10<b class='flag-5'>串口</b><b class='flag-5'>数据</b>库模块外扩SD卡功能
    快速实现C2000串口程序升级
    电子发烧友网站提供《快速实现C2000串口程序升级.pdf》资料免费下载
    发表于 08-29 10:50 1次下载
    快速实现C2000<b class='flag-5'>串口</b>程序升级
    stm32串口烧录怎么设置
    准备工作 确保您拥有STM32开发板和相应的硬件设备,如USB转串口模块。 安装STM32CubeMX和STM32CubeProgrammer软件,这些是ST官方提供的工具,用于
    的头像 发表于 08-22 09:33 1952次阅读
    用esp32的串口Stm32F407串口通讯,通过TJA转CAN,结果esp32串口读到的一直是自己发的数据,为什么?
    我用esp32的串口Stm32F407串口通讯,通过TJA转CAN。结果esp32串口读到的一直是自己发的数据,各位大神给我看看哪里有问题
    发表于 06-19 07:00
    485串口可以用can协议吗
    一、引言 随着工业自动化和智能控制技术的发展,通信协议在设备间数据传输和控制中扮演着越来越重要的角色。485串口和CAN协议是两种常见的通信协议,它们在不同的应用场景中发挥着重要作用。本文将对这两种
    的头像 发表于 06-16 09:21 1533次阅读
    STM32做以太网转4串口单核能做吗?
    目前要做一以太网转4串口透传模块,一STM32能搞定吗?是不是需要什么内核、?求解~~对内核了解不多,裸机100年
    发表于 05-13 07:27
    Nucleo F303k8串口调试能发送,但是不能接收,为什么?
    。 问题描述: (1)字符发送正常,用串口助手都能收到,会进入中断函数USARTx_IRQHandler; (2)通过串口助手
    发表于 05-10 07:40
    STM32 hal库无法接收串口数据是怎么回事?
    型号:STM32L432KC官方开发板 串口使用的是板载的USB下载以及串口 用法: 在串口初始化后,while(1)之前调用 接收中断
    发表于 04-29 06:11
    HAL库STM32串口2发送数组给串口1异常的原因?
    刚结束STM32,所以想请教一下。就是我想用串口2接收数据然后发送串口1,串口1接收后再
    发表于 04-25 06:01
    Python怎么读取STM32串口数据
    =ser.readlines()print(s) 可是什么都读取不了。如果用买的STM32开发板送的串口助手,能接收到数据。板子上烧录的printf输出程序。 请问各位大神,Python程序要怎么写才能读取
    发表于 04-24 07:30
    STM32串口发送字符,发送和接收的数据不同是怎么回事?
    stm32f407系列的,使用串口3.USB转串口使用的市CP2102芯片。发送数据和接收的数据
    发表于 04-10 06:32
    STM32F407VET6串口5的三引脚TX RX GND跟STM32F103VET6串口5的RX TX GND三引脚相连后烧毁的原因?
    我把STM32F407VET6芯片的串口5的三引脚TX RX GND分别跟STM32F103VET6串口5的RX TX GND 三
    发表于 03-26 08:03
    STM32串口发送起始数据丢失的原因?怎么处理?
    今天遇到有意思的情况,就是采用串口发送的时候,最开始开机第一次发送的时候,第一个数据会丢失,比如我要
    发表于 03-20 06:48
    使用CubeMX配置STM32010C6T6的LPUART1外设,调用串口发送和接收函数均不能收发数据怎么解决?
    如题,STM32010C6T6串口1配置完成后,Cube界面接收引脚模式默认为推挽输出,并且没有其它选项可以更改,(其它系列MCU默认是输入模式)生成的工程调用串口
    发表于 03-19 07:48
    STM32G031k8t6串口发送为什么会进入硬件中断?
    STM32G031k8t6串口发送进入硬件中断
    发表于 03-13 07:59
