中间件是什么?Go 项目中引入中间件的目的和效果如何?本文详细介绍了Golang 中间件。
中间件是一种计算机 软件,可为 操作系统 提供的 软件应用程序 提供服务,以便于各个软件之间的沟通,特别是系统软件和应用软件。广泛用于 web 应用和面向服务的体系结构等。
纵观 GO 语言,中间件应用比较普遍,主要应用:
记录对服务器发送的请求(request)
处理服务器响应(response )
请求和处理之间做一个权限认证工作
远程调用
安全
等等
中间件处理程序是简单的http.Handler,它包装另一个http.Handler做请求的一些预处理和/或后处理。它被称为“中间件”,因为它位于 Go Web 服务器和实际处理程序之间的中间位置。
下面是一些中间件例子
记录日志中间件
package main
import (
“fmt”
“log”
“net/http”
func logging(f http.HandlerFunc) http.HandlerFunc {
return func(w http.ResponseWriter, r *http.Request) {
log.Println(r.URL.Path)
f(w, r)
func foo(w http.ResponseWriter, r *http.Request) {
fmt.Fprintln(w, “foo”)
func bar(w http.ResponseWriter, r *http.Request) {
fmt.Fprintln(w, “bar”)
func main() {
http.HandleFunc(“/foo”, logging(foo))
http.HandleFunc(“/bar”, logging(bar))
http.ListenAndServe(“:8080”, nil)
访问 http://localhost:8080/foo
返回结果
foo
将上面示例修改下,也可以实现相同的功能。
package main
import (
“fmt”
“log”
“net/http”
func loggingMiddleware(next http.Handler) http.Handler {
return http.HandlerFunc(func(w http.ResponseWriter, r *http.Request) {
next.ServeHTTP(w, r)
func main() {
http.Handle(“/foo”, loggingMiddleware(http.HandlerFunc(foo)))
http.Handle(“/bar”, loggingMiddleware(http.HandlerFunc(bar)))
返回结果
foo
多中间件例子
package main
import (
“fmt”
“log”
“net/http”
“time”
type Middleware func(http.HandlerFunc) http.HandlerFunc// Logging logs all requests with its path and the time it took to processfunc Logging() Middleware {
// Create a new Middleware
return func(f http.HandlerFunc) http.HandlerFunc {
// Define the http.HandlerFunc
// Do middleware things
start := time.Now()
defer func() { log.Println(r.URL.Path, time.Since(start)) }()
// Call the next middleware/handler in chain
f(w, r)
// Method ensures that url can only be requested with a specific method, else returns a 400 Bad Requestfunc Method(m string) Middleware {
if r.Method != m {
http.Error(w, http.StatusText(http.StatusBadRequest), http.StatusBadRequest)
return
f(w, r)
// Chain applies middlewares to a http.HandlerFuncfunc Chain(f http.HandlerFunc, middlewares 。。.Middleware) http.HandlerFunc {
for _, m := range middlewares {
f = m(f)
return f
func Hello(w http.ResponseWriter, r *http.Request) {
fmt.Fprintln(w, “hello world”)
func main() {
http.HandleFunc(“/”, Chain(Hello, Method(“GET”), Logging()))
中间件本身只是将其http.HandlerFunc作为其参数之一,包装它并返回一个新http.HandlerFunc的服务器来调用。在这里,我们定义了一种新类型Middleware,最终可以更容易地将多个中间件链接在一起。
当然我们也可以改成如下形式
package main
import (
“fmt”
“log”
“net/http”
“time”
type Middleware func(http.Handler) http.Handlerfunc Hello(w http.ResponseWriter, r *http.Request) {
func Chain(f http.Handler, mmap 。。.Middleware) http.Handler {
for _, m := range mmap {
f = m(f)
return f
return func(f http.Handler) http.Handler {
if r.Method != m {
return
f.ServeHTTP(w, r)
//log.Println(r.URL.Path)
start := time.Now()
f.ServeHTTP(w, r)
func main() {
http.Handle(“/”, Chain(http.HandlerFunc(Hello), Method(“GET”), Logging()))
在 gin 框架下实现中间件
r := gin.Default() 创建带有默认中间件的路由,默认是包含 logger 和 recovery 中间件的
r :=gin.new() 创建带有没有中间件的路由
示例
package main
import (
“github.com/gin-gonic/gin”
“log”
“time”
func Logger() gin.HandlerFunc {
return func(c *gin.Context) {
t := time.Now()
// Set example variable
c.Set(“example”, “12345”)
// before request
c.Next()
// after request
latency := time.Since(t)
log.Print(latency) //时间 0s
// access the status we are sending
status := c.Writer.Status()
log.Println(status) //状态 200
func main() {
r := gin.New()
r.Use(Logger())
r.GET(“/test”, func(c *gin.Context) {
example := c.MustGet(“example”)。(string)
// it would print: “12345”
log.Println(example)
// Listen and serve on 0.0.0.0:8080
r.Run(“:8080”)
以上示例也可改为
package main
import (
“log”
“time”
t := time.Now()
// before request
c.Next()
// after request
func main() {
r := gin.New()
r.GET(“/test”, Logger(), func(c *gin.Context) {
r.Run(“:8080”)
即不用 r.use 添加中间件,直接将 Logger() 写到 r.GET 方法的参数里(“/test”之后)。
更多 gin 中间件示例可参考 https://github.com/gin-gonic/gin
转自:guyan0319
segmentfault.com/a/1190000018819804
编辑:jq
Web
2文章
1309浏览量
74940 -
计算机
19文章
7835浏览量
93444 -
服务器
14文章
10341浏览量
91737
原文标题:GO 中间件 Middleware
文章出处:【微信号:aming_linux,微信公众号:阿铭linux】欢迎添加关注!文章转载请注明出处。
MIMX9302xxxxD不支持多核中间件吗?
京东缓存中间件架构与缓存内核优化
谷景DLCHX工字电感在智能插座项目中的应用
以“网关中间件”实现充电桩OCPP 1.6安全配置文件无缝升级
博泰车联网携手产业伙伴共建天元OS开源生态
黑芝麻智能携手产业伙伴共建天元OS开源生态
Neway电机方案在实际应用中效果如何?
房产数据平台安家go获取地区列表数据的API接口
如何选择适合自己项目的通信协议评估工具?
STM32U575VGT6在cubeMX中没有FATFS中间件,是不支持吗?
中科创达与ETAS推出预集成多域中间件解决方案
树莓派项目中10款最佳的DIN导轨外壳!
Go项目中引入中间件的目的和效果如何
