基于宏高效实现环形缓冲区教程
strongerHuang 来源:小麦大叔 作者:菜刀和小麦 2021-09-02 09:24 次阅读
来源 | 小麦大叔
循环缓冲区是嵌入式软件工程师在日常开发过程中的关键组件。
多年来,互联网上出现了许多不同的循环缓冲区实现和示例。我非常喜欢这个模块,可以GitHub上找到这个开源的 CBUF.h 模块。
地址:https://github.com/barraq/BRBrain/blob/master/firmware/CBUF.h
CBUF.h 模块使用宏实现循环缓冲区,具体源码如下所示;
#if !defined( CBUF_H )#define CBUF_H /**《 Include Guard *//* ---- Include Files ---------------------------------------------------- *//* ---- Constants and Types ---------------------------------------------- *//**
* Initializes the circular buffer for use.
#define CBUF_Init( cbuf ) cbuf.m_getIdx = cbuf.m_putIdx = 0/**
* Returns the number of elements which are currently contained in the
* circular buffer.
*/#define CBUF_Len( cbuf ) ((typeof( cbuf.m_putIdx ))(( cbuf.m_putIdx ) - ( cbuf.m_getIdx )))/**
* Appends an element to the end of the circular buffer
*/#define CBUF_Push( cbuf, elem ) (cbuf.m_entry)[ cbuf.m_putIdx++ & (( cbuf##_SIZE ) - 1 )] = (elem)/**
* Retrieves an element from the beginning of the circular buffer
*/#define CBUF_Pop( cbuf ) (cbuf.m_entry)[ cbuf.m_getIdx++ & (( cbuf##_SIZE ) - 1 )]/**
* Retrieves the i‘th element from the beginning of the circular buffer
*/#define CBUF_Get( cbuf, idx ) (cbuf.m_entry)[( cbuf.m_getIdx + idx ) & (( cbuf##_SIZE ) - 1 )]/**
* Retrieves the i’th element from the end of the circular buffer
*/#define CBUF_GetEnd( cbuf, idx ) (cbuf.m_entry)[( cbuf.m_putIdx - idx - 1 ) & (( cbuf##_SIZE ) - 1 )]/**
* Determines if the circular buffer is empty
*/#define CBUF_IsEmpty( cbuf ) ( CBUF_Len( cbuf ) == 0 )/**
* Determines if the circular buffer is full.
*/#define CBUF_IsFull( cbuf ) ( CBUF_Len( cbuf ) == ( cbuf##_SIZE ))/**
* Determines if the circular buffer is currenly overflowed or underflowed.
*/#define CBUF_Error( cbuf ) ( CBUF_Len( cbuf ) 》 cbuf##_SIZE )#if defined( __cplusplus )template 《 class IndexType, unsigned Size, class EntryType 》
class CBUF
{public
CBUF()
m_getIdx = m_putIdx = 0;
IndexType Len() const { return m_putIdx - m_getIdx; }
bool IsEmpty() const { return Len() == 0; }
bool IsFull() const { return Len() == Size; }
bool Error() const { return Len() 》 Size; }
void Push( EntryType val )
m_entry[ m_putIdx++ & ( Size - 1 )] = val;
EntryType Pop()
return m_entry[ m_getIdx++ & ( Size - 1 )];
private:
volatile IndexType m_getIdx;
volatile IndexType m_putIdx;
EntryType m_entry[ Size ];
#endif // __cplusplus/* ---- Variable Externs ------------------------------------------------- *//* ---- Function Prototypes ---------------------------------------------- *//** @} */#endif // CBUF_H
现在一般我不喜欢以这种方式使用宏,但实现已被证明是快速、高效且工作相对良好的,这是很难争论的。
循环缓冲区的设置非常简单。首先,需要定义循环缓冲区的大小。这是通过定义宏 myQ_SIZE 来完成的,同时记住缓冲区大小需要是 2 的幂。
然后通过创建一个 myQ 类型的变量来声明循环缓冲区。例如,如果 myQ_SIZE 定义为 64 字节,则可以定义 UART 的发送和接收缓冲区,如下面的图 1 所示。
图 1 – 定义循环缓冲区
在此示例中,myQ 被定义为静态以限制缓冲区的范围并声明为易失性,因为它们在中断内被修改。定义循环缓冲区只是第一步。为了分配缓冲区,必须将这些变量传递给 CBUF_INIT 宏,如下图 2 所示。
图 2 – 缓冲区初始化
除了这个初始设置之外,缓冲区相当简单且易于使用。例如,可以使用 CBUF_PUSH 将通过串行接口接收 UART接收的字符推送到循环缓冲区,如图 3 所示。
图 3 – 推入缓冲区
开发人员不仅希望将数据推送到循环缓冲区上,还希望从缓冲区弹出或获取数据。看到这一点的一个简单示例是需要获取字符并通过 UART 传输的串行发送器。图 4 中可以看到一个示例传输函数。
图 4 – 从缓冲区弹出数据
在健壮的应用程序中,还应检查循环缓冲区长度和溢出状态。CBUF 模块确实提供了能够检查这些重要指标的宏。
要记住的一个重要问题是,如果需要对 CBUF 本身进行任何调试,这是不可能的。无法为宏设置断点,因此如果出现问题,则需要对模块进行功能化以逐步执行和调试。
多年来使用这个模块虽然我没有发现任何问题。循环缓冲区是在嵌入式系统中与串行设备通信的一个重要方面。
循环缓冲区也很好理解,应该创建它们以便它们可以模块化并从一个应用程序到下一个应用程序重复使用。
到目前为止,CBUF 模块已被证明是这样一个模块,所以在这里,我强烈推荐一下这个模块。
免责声明:本文来源网络,版权归原作者所有。如涉及作品版权问题,请与我联系删除。
编辑:jq
  • 缓冲
  • uart
  • 嵌入式软件
  • GitHub
原文标题:用宏高效实现环形缓冲区
文章出处:【微信号:strongerHuang,微信公众号:strongerHuang】欢迎添加关注!文章转载请注明出处。
    基于C语言实现环形缓冲区/循环队列
    这里分享一个自己用纯C实现环形缓冲区
    的头像 发表于 04-11 10:39 3449次阅读
    基于C语言<b class='flag-5'>实现</b><b class='flag-5'>环形</b><b class='flag-5'>缓冲区</b>/循环队列
    STM32进阶之串口环形缓冲区实现
    完了数据,‘0’地址空间的数据进行释放掉,列队头指向下一个可以处理数据的地址‘1’。从而实现整个环形缓冲区的数据读写。看图,队列头就是指向已经存储的数据,并且这个数据是待处理的。下一个CPU处理的数据
    发表于 06-08 14:03
    MCU进阶之串口环形缓冲区实现
    是列队头的数据,处理完了数据,‘0’地址空间的数据进行释放掉,列队头指向下一个可以处理数据的地址‘1’。从而实现整个环形缓冲区的数据读写。看图,队列头就是指向已经存储的数据,并且这个数据是待处理的。下一个
    发表于 08-17 13:11
    环形缓冲区的设计分享!
    去访问该缓冲区的最后一个内存位置的的后一位置时回到环形缓冲区的起点。类似一个环一样。这样形容就很好理解了,当然有办法实现了。我在这里采用了2种方式
    发表于 10-28 23:29
    环形缓冲区简介
    STM32串口数据接收 --环形缓冲区环形缓冲区简介  在单片机中串口通信是我们使用最频繁的,使用串口通信就会用到串口的数据接收与发送,环形
    发表于 08-17 06:56
    怎么实现串口环形缓冲区
    怎么实现串口环形缓冲区
    发表于 12-06 06:01
    请问串口的DMA接收缓冲区是不是环形缓冲区
    大家好!请问串口的DMA接收缓冲区是不是环形缓冲区?通过阅读串口部分的代码,我了解到这样几点:1、串口的DMA接收时循环接收,当缓冲区满了会重新从头开始覆盖掉之前的数据,和
    发表于 08-30 14:27
    环形缓冲区读写操作的分析与实现
    环形缓冲区是嵌入式系统中一种重要的常用数据结构。在多任务环境下实现时,如果有多个读写任务,一般需要用信号量来保护多个任务共享的环形缓冲区。但
    发表于 04-15 11:35 40次下载
    环形缓冲区实现原理
    在通信程序中,经常使用环形缓冲区作为数据结构来存放通信中发送和接收的数据。环形缓冲区是一个先进先出的循环缓冲区,可以向通信程序提供对
    的头像 发表于 03-22 10:03 7618次阅读
    <b class='flag-5'>环形</b><b class='flag-5'>缓冲区</b>的<b class='flag-5'>实现</b>原理
    缓冲区是啥意思 STM32串口数据接收之环形缓冲区
    缓冲区顾名思义是缓冲数据用的。实现缓冲区最简单的办法时,定义多个数组,接收一包数据到数组A,就把接收数据的地址换成数组B,每个数据有个标记字节用于表示这个数组是否收到数据,收到数据是否
    的头像 发表于 07-22 15:33 1.1w次阅读
    STM32串口数据接收 --环形缓冲区
    发表于 12-28 19:24 31次下载
    STM32串口数据接收 --<b class='flag-5'>环形</b><b class='flag-5'>缓冲区</b>
    环形缓冲区实现思路
    单片机程序开发一般都会用到UART串口通信,通过通信来实现上位机和单片机程序的数据交互。通信中为了实现正常的收发,一般都会有对应的发送和接收缓存来暂存通信数据。这里使用环形缓冲区的方式
    的头像 发表于 01-17 15:07 1724次阅读
    STM32进阶之串口环形缓冲区实现
    STM32进阶之串口环形缓冲区实现
    的头像 发表于 09-19 09:20 2539次阅读
    STM32进阶之串口<b class='flag-5'>环形</b><b class='flag-5'>缓冲区</b><b class='flag-5'>实现</b>
    C++环形缓冲区设计与实现
    的存储空间。环形缓冲区的特点是其终点和起点是相连的,形成一个环状结构。这种数据结构在处理流数据和实现数据缓存等场景中具有广泛的应用。 环形缓冲区
    的头像 发表于 11-09 11:21 2320次阅读
    C++<b class='flag-5'>环形</b><b class='flag-5'>缓冲区</b>设计与<b class='flag-5'>实现</b>
    单片机中的几种环形缓冲区的分析和实现
    单片机中的几种环形缓冲区的分析和实现一、简介环形缓冲区(RingBuffer)是一种高效的使用内
    的头像 发表于 08-14 08:39 1153次阅读
    单片机中的几种<b class='flag-5'>环形</b><b class='flag-5'>缓冲区</b>的分析和<b class='flag-5'>实现</b>
