PO VO DTO转换神器的思路
Linux爱好者 来源:今日头条 作者:bettermann 2021-10-12 11:13 次阅读
当然有的人喜欢写get set,或者用BeanUtils 进行复制,代码只是工具,本文只是提供一种思路。
pom 配置:
<properties>
<project.build.sourceEncoding>UTF-8project.build.sourceEncoding>
<maven.compiler.source>1.8maven.compiler.source>
<maven.compiler.target>1.8maven.compiler.target>
<org.mapstruct.version>1.4.1.Finalorg.mapstruct.version>
<org.projectlombok.version>1.18.12org.projectlombok.version>
properties>
<dependencies>
<dependency>
<groupId>org.mapstructgroupId>
<artifactId>mapstructartifactId>
<version>${org.mapstruct.version}version>
dependency>
<dependency>
<groupId>org.projectlombokgroupId>
<artifactId>lombokartifactId>
<version>${org.projectlombok.version}version>
<scope>providedscope>
dependency>
<dependency>
<artifactId>mapstruct-processorartifactId>
dependency>
dependencies>
<build>
<plugins>
<plugin>
<groupId>org.apache.maven.pluginsgroupId>
<artifactId>maven-compiler-pluginartifactId>
<version>3.8.1version>
<configuration>
<source>1.8source>
<target>1.8target>
<annotationProcessorPaths>
<path>
path>
<path>
path>
configuration>
plugin>
plugins>
build>
关于lombok和mapstruct的版本兼容问题多说几句,maven插件要使用3.6.0版本以上、lombok使用1.16.16版本以上,另外编译的lombok mapstruct的插件不要忘了加上。否则会出现下面的错误:No property named "aaa" exists in source parameter(s). Did you mean "null"?
这种异常就是lombok编译异常导致缺少get setter方法造成的。还有就是缺少构造函数也会抛异常。
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
publicclassStudent{
privateStringname;
privateintage;
privateGenderEnumgender;
privateDoubleheight;
privateDatebirthday;
publicenumGenderEnum{
Male("1","男"),
Female("0","女");
privateStringcode;
privateStringname;
publicStringgetCode(){
returnthis.code;
publicStringgetName(){
returnthis.name;
GenderEnum(Stringcode,Stringname){
this.code=code;
this.name=name;
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
publicclassStudentVO{
privateStringname;
privateintage;
privateStringgender;
privateStringbirthday;
@Mapper
publicinterfaceStudentMapper{
StudentMapperINSTANCE=Mappers.getMapper(StudentMapper.class);
@Mapping(source="gender.name",target="gender")
@Mapping(source="birthday",target="birthday",dateFormat="yyyy-MM-ddHHss")
StudentVOstudent2StudentVO(Studentstudent);
实体类是开发过程少不了的,就算是用工具生成肯定也是要有的,需要手写的部分就是这个Mapper的接口,编译完成后会自动生成相应的实现类
然后就可以直接用mapper进行实体的转换了
publicclassTest{
publicstaticvoidmain(String[]args){
Studentstudent=Student.builder().name("小明").age(6).gender(GenderEnum.Male).height(121.1).birthday(newDate()).build();
System.out.println(student);
//这行代码便是实际要用的代码
StudentVOstudentVO=StudentMapper.INSTANCE.student2StudentVO(student);
System.out.println(studentVO);
mapper可以进行字段映射,改变字段类型,指定格式化的方式,包括一些日期的默认处理。
可以手动指定格式化的方法:
@Mapper
@Mapping(source="gender",target="gender")
defaultStringgetGenderName(GenderEnumgender){
returngender.getName();
上面只是最简单的实体映射处理,下面介绍一些高级用法
1.List 转换
属性映射基于上面的mapping配置
@Mapper
Liststudents2StudentVOs(ListstudentList);
Listlist=newArrayList<>();
list.add(student);
Listresult=StudentMapper.INSTANCE.students2StudentVOs(list);
System.out.println(result);
2.多对象转换到一个对象
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
publicclassStudent{
privateStringname;
privateintage;
@Data
@AllArgsConstructor
@Builder
@NoArgsConstructor
publicclassCourse{
privateStringcourseName;
privateintsortNo;
privatelongid;
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
privateStringname;
privateintage;
privateStringcourse;
@Mapper
@Mapping(source="student.gender.name",target="gender")
@Mapping(source="student.birthday",target="birthday",dateFormat="yyyy-MM-ddHHss")
@Mapping(source="course.courseName",target="course")
StudentVOstudentAndCourse2StudentVO(Studentstudent,Coursecourse);
publicclassTest{
Coursecourse=Course.builder().id(1L).courseName("语文").build();
StudentVOstudentVO=StudentMapper.INSTANCE.studentAndCourse2StudentVO(student,course);
3.默认值
@Mapper
@Mapping(target="name",source="student.name",defaultValue="张三")
转自:toutiao.com/i6891531055631696395
责任编辑:haq
  • 转换器
  • 代码
    用TPA2005D1搭了一个音频放大电路,在测输出端Vo+和Vo-的波形时,发现有杂波,怎么去除?
    最近用TPA2005D1搭了一个音频放大电路,试了一下,功能可以了,但是在测输出端Vo+和Vo-的波形时,发现有杂波,电路图和波形图在下面,请知道的大神帮忙分析一下,怎么去杂波??
    发表于 10-21 08:11
    监控平台设计思路
    电子发烧友网站提供《监控平台设计思路.pptx》资料免费下载
    发表于 10-09 11:18 0次下载
    用OPA27做同相加法器Vo=Vi1+Vi2时遇到的疑问求解
    用OPA27做同相加法器Vo=Vi1+Vi2的时候,函数发生器给Vi1输入频率为1kHZ,Vpp=1V的正弦波,而Vi2接地时,没有输出。然后稍作改动,成了Vo=-(Vi1+Vi2),如下图所示
    发表于 09-12 06:31
    PGA204的1管脚和9管脚没有用到(Vo1,Vo2),布线时应该如何布线?
    PGA204的1管脚和9管脚没有用到(Vo1,Vo2),布线时应该如何布线,是直接悬空还还是接AGND或者是VCC呢?
    发表于 08-28 08:20
    为什么LM324在测试失调电压和失调电流时要Vo=1.4V,有什么依据吗?
    发表于 08-02 09:32
    THS4509运放给+5V单电源供电,请问输出电压Vo+ - Vo-最大能输出多少V?
    你好,请问这款运放给+5V单电源供电,请问输出电压Vo+ - Vo-最大能输出多少V?
    发表于 08-01 08:16
    RK3588 在使用rockit接口设置vo时,UI消失,大家遇到过吗?
    使用RK3588,先通过vo显示出来了UI,然后希望通过vo输出解码的视频,在设置vo时,在调用RK_MPI_VO_GetPubAttr接口,UI直接消失,所在进程依然运行
    发表于 06-11 17:59
    基于VO2忆阻器的无线物联网混合系统
    针对此问题,北京大学集成电路学院/集成电路高精尖创新中心的杨玉超教授团队首次提出以VO2 忆阻器为主体的高一致性、可校准的频率振荡器,在此基础上构建了8×8的VO2 忆阻器阵列,通过紧凑设计的外围电路实现了频率现场生成和可编程频率混合系统。
    的头像 发表于 02-22 09:30 591次阅读
    VO2750 蓄电池放电测试仪使用说明书
    电子发烧友网站提供《VO2750 蓄电池放电测试仪使用说明书.pdf》资料免费下载
    发表于 02-01 10:09 0次下载
    工业自动化协议转换网关BL121PO PLC To OPC UA 网关产品介绍
    电子发烧友网站提供《工业自动化协议转换网关BL121PO PLC To OPC UA 网关产品介绍.pdf》资料免费下载
    发表于 01-26 14:36 0次下载
    介绍一款基于java的渗透测试神器-CobaltStrike
    Cobalt Strike是一款基于java的渗透测试神器,常被业界人称为CS神器
    的头像 发表于 01-16 09:16 844次阅读
    介绍一款基于java的渗透测试<b class='flag-5'>神器</b>-CobaltStrike
    共模电容:又一款EMC滤波神器
    共模电容:又一款EMC滤波神器?|深圳比创达电子(上)
    的头像 发表于 12-25 10:54 651次阅读
    共模电容:又一款EMC滤波<b class='flag-5'>神器</b>?
    准谐振变换器的基本思路
    准谐振变换器是一种特殊类型的电源转换器,其工作原理与常规的电源转换器有所不同。它采用谐振原理,将交流电压转换为直流电压,或者将直流电压转换为交流电压。本文将详细介绍准谐振变换器的基本
    的头像 发表于 12-14 17:12 1316次阅读
    OP191在VO为+-5V输出电流比datasheet给出的值大很多的原因?
    我在测试VO=+-5V时,VS接的+-5V,测试出来其 SUPPLY Current在VO=0条件下,比datasheet给出的值大很多。请问是什么原因造成的。
    发表于 11-20 06:29
    网络型地铁门禁设计思路
    电子发烧友网站提供《网络型地铁门禁设计思路.doc》资料免费下载
    发表于 11-10 16:04 0次下载
    网络型地铁门禁设计<b class='flag-5'>思路</b>
