今天有点空,我们移植一下LVGL~
先看效果图:
在这之前,我们得调试好屏幕及触摸~
我们以之前的LCD那个程序为模板,开始添加LVGL文件。
先下载LVGL源文件包(点击“阅读原文”查看原贴即可下载)解压下来,将GUI添加进工程:
其中由于LVGL的特性,需要添加C99支持,并屏蔽一些类型的警告:
勾选C99,并在Misc Controls 中填入 --diag_suppress=68 --diag_supp
ress=111 --diag_suppress=550:
添加LVGL的心跳,这了由于已经用了SYStiCK作为延时定时器。
我们这了新开一个定时器1,并设定为1ms中断,为LVGL提供心跳节拍~
//1秒产生一次中断 int_time = CLK / ((prescaler+1) * (period+1))
void TIM1_Int_Init(u16 arr,u16 psc)
timer_parameter_struct timer_parameter;
rcu_periph_clock_enable(RCU_TIMER1);
//预分频
timer_parameter.prescaler = psc,
//对齐模式
timer_parameter.alignedmode = TIMER_COUNTER_EDGE,
//定时器增长方向
timer_parameter.counterdirection = TIMER_COUNTER_UP,
//定时器自动加载值
timer_parameter.period = arr,
//时钟分频值
timer_parameter.clockdivision = TIMER_CKDIV_DIV4,
timer_init(TIMER1, &timer_parameter);
timer_interrupt_enable(TIMER1, TIMER_INT_UP);
nvic_irq_enable(TIMER1_IRQn, 0, 2);
timer_enable(TIMER1);
void TIMER1_IRQHandler()
IF (timer_interrupt_flag_get(TIMER1, TIMER_INT_UP) != RESET)
lv_tick_inc(1);//lvgl的1ms心跳
timer_interrupt_flag_clear(TIMER1, TIMER_INT_UP);
在main初始化里面设定:
TIM1_Int_Init(999,119);//定时器初始化(1ms 中断),用于给 lvgl 提供 1ms 的心跳节拍
其余就是一些常见的config的配置:
对lv_conf.h进行如下修改:
* [url=home.php?mod=space&uid=1455510]@file[/url] lv_conf.h
* COPY THIS FILE AS `lv_conf.h` NEXT TO the `lvgl` FOLDER
/* clang-format off */
Graphical settings
/* Maximal horizontal and vertical resolution to support by the library.*/
/* Color depth:
* - 1: 1 byte per pixel
* - 8: RGB233
* - 16: RGB565
* - 32: ARGB8888
/* Swap the 2 bytes of RGB565 color.
* Useful if the display has a 8 bit inteRFace (e.g. SPI)*/
/* 1: Enable screen transparency.
* Useful for OSD or other overlapping GUIs.
* Requires `LV_COLOR_DEPTH = 32` colors and the screen's style should be modified: `style.body.opa = ...`*/
/*Images pixels with this color will not be drawn (with chroma keying)*/
/* Enable anti-aliasing (lines, and radiuses will be smoothed) */
/* Default display refresh period.
* Can be changed in the display driver (`lv_disp_drv_t`).*/
/* Dot Per Inch: used to initialize default sizes.
* E.g. a button with width = LV_DPI / 2 -> half inch wide
* (Not so important, you can adjust it to modify default sizes and spaces)*/
/* Type of coordinates. Should be `int16_t` (or `int32_t` for extreme cases) */
typedef int16_t lv_coord_t;
Memory manager settings
/* LittelvGL's internal memory manager's settings.
* The graphical objects and other related data are stored here. */
/* 1: use custom malloc/free, 0: use the built-in `lv_mem_alloc` and `lv_mem_free` */
/* Size of the memory used by `lv_mem_alloc` in bytes (>= 2kB)*/
/* Complier prefix for a big array declaration */
/* Set an address for the memory pool instead of allocating it as an array.
* Can be in external SRAM too. */
/* Automatically defrag. on free. Defrag. means joining the adjacent free cells. */
/* Garbage Collector settings
* Used if lvgl is binded to higher level language and the memory is managed by that language */
Input device settings
/* Input device default settings.
* Can be changed in the Input device driver (`lv_indev_drv_t`)*/
/* Input device read period in milliseconds */
/* Drag threshold in pixels */
/* Drag throw slow-down in [%]. Greater value -> faster slow-down */
/* Long press time in milliseconds.
* Time to send `LV_EVENT_LONG_PRESSSED`) */
/* repeated trigger period in long press [ms]
* Time between `LV_EVENT_LONG_PRESSED_REPEAT */
* Feature usage
/*1: Enable the Animations */
/*Declare the type of the user data of animations (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_anim_user_data_t;
/* 1: Enable shadow drawing*/
/* 1: Enable object groups (for keyboard/encoder navigation) */
typedef void * lv_group_user_data_t;
/* 1: Enable GPU interface*/
/* 1: Enable file system (might be required for images */
/*Declare the type of the user data of file system drivers (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_fs_drv_user_data_t;
/*1: Add a `user_data` to drivers and objects*/
* Image decoder and cache
/* 1: Enable indexed (palette) images */
/* 1: Enable alpha indexed images */
/* Default image cache size. Image caching keeps the images opened.
* If only the built-in image formats are used there is no real advantage of caching.
* (I.e. no new image decoder is added)
* With complex image decoders (e.g. PNG or JPG) caching can save the continuous open/decode of images.
* However the opened images might consume additional RAM.
* LV_IMG_CACHE_DEF_SIZE must be >= 1 */
/*Declare the type of the user data of image decoder (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_img_decoder_user_data_t;
* Compiler settings
/* Define a custom attribute to `lv_tick_inc` function */
/* Define a custom attribute to `lv_task_handler` function */
/* With size optimization (-Os) the compiler might not align data to
* 4 or 8 byte boundary. This alignment will be explicitly applied where needed.
* E.g. __attribute__((aligned(4))) */
/* Attribute to mark large constant arrays for example
* font's bitmaps */
* HAL settings
/* 1: use a custom tick source.
* It removes the need to manually update the tick with `lv_tick_inc`) */
typedef void * lv_disp_drv_user_data_t; /*Type of user data in the display driver*/
typedef void * lv_indev_drv_user_data_t; /*Type of user data in the input device driver*/
* Log settings
/*1: Enable the log module*/
/* How important log should be added:
* LV_LOG_LEVEL_TRACE A lot of logs to give detaiLED information
* LV_LOG_LEVEL_INFO Log important events
* LV_LOG_LEVEL_WARN Log if something unwanted happened but didn't cause a problem
* LV_LOG_LEVEL_ERROR Only critical issue, when the system may fail
* LV_LOG_LEVEL_NONE Do not log anything
/* 1: Print the log with 'printf';
* 0: user need to register a callback with `lv_log_register_print`*/
* THEME USAGE
* FONT USAGE
/* The built-in fonts contains the ASCII range and some Symbols with 4 bit-per-pixel.
* The symbols are available via `LV_SYMBOL_...` defines
* More info about fonts: https://docs.littlevgl.com/#Fonts
* To create a new font go to: https://littlevgl.com/ttf-font-to-c-array
/* Robot fonts with bpp = 4
* https://fonts.google.com/specimen/Roboto */
/*Pixel perfect monospace font
* http://pelulamu.net/unscii/ */
/* Optionally declare your custom fonts here.
* You can use these fonts as default font too
* and they will be available globally. E.g.
* #define LV_FONT_CUSTOM_DECLARE LV_FONT_DECLARE(my_font_1)
* LV_FONT_DECLARE(my_font_2)
/*Always set a default font from the built-in fonts*/
/* Enable it if you have fonts with a lot of characters.
* The limit depends on the font size, font face and bpp
* but with > 10,000 characters if you see issues probably you need to enable it.*/
/*Declare the type of the user data of fonts (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_font_user_data_t;
* Text settings
/* Select a character encoding for strings.
* Your IDE or editor should have the same character encoding
* - LV_TXT_ENC_UTF8
* - LV_TXT_ENC_ASCII
/*Can break (wrap) texts on these chars*/
* LV_OBJ SETTINGS
/*Declare the type of the user data of object (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_obj_user_data_t;
/*1: enable `lv_obj_realaign()` based on `lv_obj_align()` parameters*/
/* Enable to make the object clickable on a larger area.
* LV_EXT_CLICK_AREA_OFF or 0: Disable this feature
* LV_EXT_CLICK_AREA_TINY: The extra area can be adjusted horizontally and vertically (0..255 px)
* LV_EXT_CLICK_AREA_FULL: The extra area can be adjusted in all 4 directions (-32k..+32k px)
* LV OBJ X USAGE
* Documentation of the object types: https://docs.littlevgl.com/#Object-types
/*Arc (dependencies: -)*/
/*Bar (dependencies: -)*/
/*Button (dependencies: lv_cont*/
/*Enable button-state animations - draw a circle on click (dependencies: LV_USE_ANIMATION)*/
/*Button matrix (dependencies: -)*/
/*Calendar (dependencies: -)*/
/*Canvas (dependencies: lv_img)*/
/*Check box (dependencies: lv_btn, lv_label)*/
/*Chart (dependencies: -)*/
/*Container (dependencies: -*/
/*Drop down list (dependencies: lv_page, lv_label, lv_symbol_def.h)*/
/*Open and close default animation time [ms] (0: no animation)*/
/*Gauge (dependencies:lv_bar, lv_lmeter)*/
/*Image (dependencies: lv_label*/
/*Image Button (dependencies: lv_btn*/
/*1: The imgbtn requires left, mid and right parts and the width can be set freely*/
/*Keyboard (dependencies: lv_btnm)*/
/*Label (dependencies: -*/
/*Hor, or ver. scroll speed [px/sec] in 'LV_LABEL_LONG_ROLL/ROLL_CIRC' mode*/
/* Waiting period at beginning/end of animation cycle */
/*Enable selecting text of the label */
/*Store extra some info in labels (12 bytes) to speed up drawing of very long texts*/
/*LED (dependencies: -)*/
/*Line (dependencies: -*/
/*List (dependencies: lv_page, lv_btn, lv_label, (lv_img optionally for icons ))*/
/*Default animation time of focusing to a list element [ms] (0: no animation) */
/*Line meter (dependencies: *;)*/
/*Message box (dependencies: lv_rect, lv_btnm, lv_label)*/
/*Page (dependencies: lv_cont)*/
/*Focus default animation time [ms] (0: no animation)*/
/*Preload (dependencies: lv_arc, lv_anim)*/
/*Roller (dependencies: lv_ddlist)*/
/*Focus animation time [ms] (0: no animation)*/
/*Number of extra "pages" when the roller is infinite*/
/*Slider (dependencies: lv_bar)*/
/*Spinbox (dependencies: lv_ta)*/
/*Switch (dependencies: lv_slider)*/
/*Text area (dependencies: lv_label, lv_page)*/
/*Table (dependencies: lv_label)*/
/*Tab (dependencies: lv_page, lv_btnm)*/
/*Time of slide animation [ms] (0: no animation)*/
/*Tileview (dependencies: lv_page) */
/*Window (dependencies: lv_cont, lv_btn, lv_label, lv_img, lv_page)*/
* Non-user section
/*--END OF LV_CONF_H--*/
/*Be sure every define has a default value*/
主要分辨率要选成自己的屏幕对于的,并关闭系统支持~
下面我们对底层进行移植:
主要是lcd驱动及TOUCH驱动,我们把LVGL里面porting文件夹里面的temp进行修改:
其中:
lv_port_dis.c
* @file lv_port_disp.c
/*Copy this file as "lv_port_disp.c" and set this value to "1" to enable content*/
* INCLUDES
* DEFINES
* TYPEDEFS
* STATIC PROTOTYPES
static void disp_init(void);
static void disp_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p);
static void gpu_blend(lv_color_t * dest, const lv_color_t * src, uint32_t length, lv_opa_t opa);
static void gpu_fill(lv_color_t * dest, uint32_t length, lv_color_t color);
* STATIC VARIABLES
* MACROS
* GLOBAL FUNCTIONS
void lv_port_disp_init(void)
* Initialize your display
disp_init();
* Create a buffer for drawing
/* Example for 1) */
static lv_disp_buf_t disp_buf_1;
static lv_color_t buf1_1[LV_HOR_RES_MAX * 10]; /*A buffer for 10 rows*/
lv_disp_buf_init(&disp_buf_1, buf1_1, NULL, LV_HOR_RES_MAX * 10); /*Initialize the display buffer*/
* Register the display in LittlevGL
lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
lv_disp_drv_init(&disp_drv); /*Basic initialization*/
/*Set up the functions to access to your display*/
/*Set the resolution of the display*/
//适配多个屏幕
disp_drv.hor_res = lcddev.width;
disp_drv.ver_res = lcddev.height;
/*Used to copy the buffer's content to the display*/
disp_drv.flush_cb = disp_flush;
/*Set a display buffer*/
disp_drv.buffer = &disp_buf_1;
/*Optionally add functions to access the GPU. (Only in buffered mode, LV_VDB_SIZE != 0)*/
/*Blend two color array using opacity*/
disp_drv.gpu_blend = gpu_blend;
/*Fill a memory array with a color*/
disp_drv.gpu_fill = gpu_fill;
/*Finally register the driver*/
lv_disp_drv_register(&disp_drv);
* STATIC FUNCTIONS
/* Initialize your display and the required peripherals. */
/*You code here*/
/* Flush the content of the internal buffer the specific area on the display
* You can use DMA or any hardware acceleration to do this operation in the background but
* 'lv_disp_flush_ready()' has to be called when finished. */
LCD_Color_Fill(area->x1,area->y1,area->x2,area->y2,(u16*)color_p);
/* IMPORTANT!!!
* Inform the graphics library that you are ready with the flushing*/
lv_disp_flush_ready(disp_drv);
/*OPTIONAL: GPU INTERFACE*/
/* If your MCU has hardware accelerator (GPU) then you can use it to blend to memories using opacity
* It can be used only in buffered mode (LV_VDB_SIZE != 0 in lv_conf.h)*/
static void gpu_blend(lv_disp_drv_t * disp_drv, lv_color_t * dest, const lv_color_t * src, uint32_t length, lv_opa_t opa)
/*It's an example code which should be done by your GPU*/
uint32_t i;
for(i = 0; i < length; i++) {
dest[i] = lv_color_mix(dest[i], src[i], opa);
/* If your MCU has hardware accelerator (GPU) then you can use it to fill a memory with a color
static void gpu_fill_cb(lv_disp_drv_t * disp_drv, lv_color_t * dest_buf, lv_coord_t dest_width,
const lv_area_t * fill_area, lv_color_t color);
uint32_t x, y;
dest_buf += dest_width * fill_area->y1; /*Go to the first line*/
for(y = fill_area->y1; y < fill_area->y2; y++) {
for(x = fill_area->x1; x < fill_area->x2; x++) {
dest_buf[x] = color;
dest_buf+=dest_width; /*Go to the next line*/
/* This dummy typedef exists purely to silence -Wpedantic. */
typedef int keep_pedantic_happy;
lv_port_indev.c
* @file lv_port_indev.c
/*Copy this file as "lv_port_indev.c" and set this value to "1" to enable content*/
* INCLUDES
* DEFINES
* TYPEDEFS
* STATIC PROTOTYPES
static bool touchpad_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data);
* STATIC VARIABLES
* MACROS
* GLOBAL FUNCTIONS
void lv_port_indev_init(void)
lv_indev_drv_t indev_drv;
* Touchpad
/*Register a touchpad input device*/
lv_indev_drv_init(&indev_drv);
indev_drv.type = LV_INDEV_TYPE_POINTER;
indev_drv.read_cb = touchpad_read;
lv_indev_drv_register(&indev_drv);
* STATIC FUNCTIONS
/* Will be called by the library to read the touchpad */
static uint16_t last_x = 0;
static uint16_t last_y = 0;
if(tp_dev.sta&TP_PRES_DOWN)//触摸按下了
last_x = tp_dev.x[0];
last_y = tp_dev.y[0];
data->point.x = last_x;
data->point.y = last_y;
data->state = LV_INDEV_STATE_PR;
}else{
data->state = LV_INDEV_STATE_REL;
/*Return `false` because we are not buffering and no more data to read*/
return false;
在新建一个GUI_APP文件夹,把里面我们要展示的例子,添加进去~
在main函数里面调用:
LCD_Init();
tp_dev.init();//触摸初始化
lv_init(); //lvgl系统初始化
lv_port_disp_init(); //lvgl显示接口初始化,放在lv_init()的后面
lv_port_indev_init(); //lvgl输入接口初始化,放在lv_init()的后面
//通过TEST_NUM的值来选择运行不同的例程
demo_create();
lv_test_theme_1(lv_theme_night_init(210, NULL));
lv_test_theme_2();
while(1)
tp_dev.scan(0);
lv_task_handler();
编译,查看效果。如前图。好了LVGL的移植就到这了。谢谢大家观看~
移植
1文章
379浏览量
28124 -
函数
3文章
4326浏览量
62558 -
开发板
25文章
5027浏览量
97363 -
LVGL
1文章
83浏览量
2956
原文标题:【技术分享】星空派GD32开发板LVGL移植经验分享
文章出处:【微信号:gh_9b9470648b3c,微信公众号:电子发烧友论坛】欢迎添加关注!文章转载请注明出处。
