1、在用户设备树中 pl-custom中
/delete-node/ &axi_dma_0;
axi_dma_0: dma@a0000000 {
#dma-cells = ;
clock-names = "s_axi_lite_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
clocks = , , ;
compatible = "xlnx,axi-dma-7.1", "xlnx,axi-dma-1.00.a";
interrupt-names = "mm2s_introut", "s2mm_introut";
interrupt-parent = ;
interrupts = ;
reg = ;
xlnx,addrwidth = ;
xlnx,sg-length-width = ;
dma-channel@a0000000 {
compatible = "xlnx,axi-dma-mm2s-channel";
dma-channels = ;
interrupts = ;
xlnx,datawidth = ;
xlnx,device-id = ;
xlnx,include-dre ;
dma-channel@a0000030 {
compatible = "xlnx,axi-dma-s2mm-channel";
dma-channels = ;
interrupts = ;
xlnx,datawidth = ;
xlnx,device-id = ;
xlnx,include-dre ;
2 、在用户system-user中
/include/ "system-conf.dtsi"
/include/ "pl-custom.dtsi"
axidma_chrdev: axidma_chrdev@0 {
compatible = "xlnx,axidma-chrdev";
dmas = ;
dma-names = "tx_channel", "rx_channel";
&axi_dma_0 {
dma-coherent;
status = "okay";
3、device-tree.bbappend
SRC_URI += "file://system-user.dtsi"
SRC_URI += "file://pl-custom.dtsi"
4 、teminal
petalinux-create -t modules -n xilinx-axidma --enable
5 、github上下载dma驱动,xilinx_axidma-master.zip 并解压,由于内核的改变,对下列部分文件做出改变。
(1) makefile
DRIVER_NAME = xilinx-axidma
$(DRIVER_NAME)-objs = axi_dma.o axidma_chrdev.o axidma_dma.o axidma_of.o
obj-m := $(DRIVER_NAME).o
(2)xilinx-axidma.bb
SRC_URI = "file://Makefile \
file://axi_dma.c \
file://axidma_chrdev.c \
file://axidma_dma.c \
file://axidma_of.c \
file://axidma.h \
file://axidma_ioctl.h \
file://COPYING \
(3)axi_dma.c
#include
// new
(4)axidma_chrdev.c
linux 内核4.x到5.x,参数减少,查看内核函数,无影响
https://elixir.bootlin.com/linux/v4.9.251/source/include/linux/of_device.h
https://elixir.bootlin.com/linux/v4.9.251/source/include/linux/uaccess.h
在 static bool axidma_access_ok(const void __user *arg, size_t size, bool readonly)函数中
// if (!readonly && !access_ok(VERIFY_WRITE, arg, size)) {
if (!readonly && !access_ok(arg, size)) {
// } else if (!access_ok(VERIFY_READ, arg, size)) {
} else if (!access_ok(arg, size)) {
//of_dma_configure(struct device->dev, NULL);
of_dma_configure(struct device->dev, NULL,true);
(5)axidma_dma.c
#include
// new
static void axidma_dma_callback(void *data)
struct kernel_siginfo sig_info;
6、petalinux-build petalinux-build --sdk petalinux-package --sysroot
7、配置qt的环境。
8 qt 将example中的axidma_benchmark.c复制到qt,并添加其他所需文件。
(1)**.pro
SOURCES += \
gpio.cpp \
libaxidma.c \
main.cpp \
util.c
HEADERS += \
axidma_ioctl.h \
conversion.h \
gpio.h \
libaxidma.h \
util.h
(2)main.cpp() 由于是将C文件改为c++文件,所以此文件中这个函数需要做改变((void *)和(char *)相同)
static int single_transfer_test(axidma_dev_t dev, int tx_channel, void *tx_buf,
int tx_size, struct axidma_video_frame *tx_frame, int rx_channel,
void *rx_buf, int rx_size, struct axidma_video_frame *rx_frame)
int rc;
// Initialize the buffer region we're going to transmit
init_data((char *)tx_buf, (char *)rx_buf, tx_size, rx_size);
// Perform the DMA transaction
rc = axidma_twoway_transfer(dev, tx_channel, (char *)tx_buf, tx_size, tx_frame,
rx_channel, (char *)rx_buf, rx_size, rx_frame, true);
if (rc return rc;
// Verify that the data in the buffer changed
return verify_data((char *)tx_buf, (char *)rx_buf, tx_size, rx_size);
(3)在所有的 **.h中,为了使用QT的类功能,尽量用C++编程,对C文件的头文件做如下改变。
#ifdef __cplusplus
extern "C"{
#endif
#endif /* UTIL_H_ */
#ifdef __cplusplus
#endif
9、加载驱动
root@u3_save:/lib/modules/5.4.0-xilinx-v2020.1/extra# insmod xilinx-axidma.ko
[ 1637.846215] axidma: axidma_dma.c: axidma_dma_init: 725: DMA: Found 1 transmit channels and 1 receive channels.
[ 1637.856240] axidma: axidma_dma.c: axidma_dma_init: 727: VDMA: Found 0 transmit channels and 0 receive channels.
10、测试 因为dma的输入输出并没有还起来,所以只能看到发出去,看不到接收的
root@u3_save:/mnt# ./u3_dma_save
AXI DMA Benchmark Parameters:
Transmit Buffer Size: 7.91 MiB
R[ 1661.465441] axidma axidma: DMA mask not set
eceive Buffer Size: 7.91 MiB
Number of DMA Transfers: 1000 transfers
Using transmit channel 0 and receive channel 1.
[ 1671.710879] axidma: axidma_dma.c: axidma_start_transfer: 309: DMA receive transaction timed out.
[ 1672.719678] xilinx-vdma a0000000.dma: Cannot stop channel 00000000145aa465: 0
Failed to perform the AXI DMA read-write transfer: Timer expired
11、当使用环回时
root@u3_dma_test:/# ./mnt/u3_dma_save
Receive Buffer Size: 7.91 MiB
Single transfer test successfully completed!
Beginning performance analysis of the DMA engine.
DMA Timing Statistics:
Elapsed Time: 41.49 s
Transmit Throughput: 190.66 MiB/s
Receive Throughput: 190.66 MiB/s
Total Throughput: 381.32 MiB/s
root@u3_dma_test:/#
13、qt and opencv 的配置
(1)安装sdk.sh
(2)在qt的pro中添加
INCLUDEPATH += /home/lcl/Soft/Sdk/sysroots/aarch64-xilinx-linux/usr/include
LIBS += \
-lopencv_imgcodecs \
-lopencv_highgui \
-lopencv_imgproc \
-lopencv_core \
即可。
14、接口改为128
Transmit Buffer Size: 16.00 MiB
Receive Buffer Size: 16.00 MiB
Elapsed Time: 0.25 s
Elapsed Time: 12.39 s
Transmit Throughput: 1291.32 MiB/s
Receive Throughput: 1291.32 MiB/s
Total Throughput: 2582.65 MiB/s
root@u3_dma_test:/#
15、第一个Elapsed Time: 0.25 s是当我把数据从缓冲区复制到其他位置消耗的时间,也就是16MB的数据需要250ms的时间,速率也就在60M左右,也验证以前的贴子,dma的实现方式(UIO或者内核驱动)与数据从缓冲区copy到别的地方的速率是没有关系的。
16、速度慢是缓冲区的问题 https://github.com/bperez77/xilinx_axidma/issues/69
(1)在设备树中
dmas = ;
dma-coherent;
&axi_dma_0 {
dma-coherent;
status = "okay";
在测试代码中加速加入测速代码
rc = single_transfer_test(axidma_dev, tx_channel, tx_buf, tx_size,
tx_frame, rx_channel, rx_buf, rx_size, rx_frame);
if (rc goto free_rx_buf;
struct timeval start_time0, end_time0;
double elapsed_time0;
// Begin timing
gettimeofday(&start_time0, NULL);
memcpy(image_mid0, rx_buf, 2048*4096*4);
gettimeofday(&end_time0, NULL);
elapsed_time0 = TVAL_TO_SEC(end_time0) - TVAL_TO_SEC(start_time0);
printf("\tElapsed Time0: %0.2f s\n", elapsed_time0);
struct timeval start_time1, end_time1;
double elapsed_time1;
// Begin timing
gettimeofday(&start_time1, NULL);
memcpy(image_mid1, image_mid0, 2048*4096*4);
gettimeofday(&end_time1, NULL);
elapsed_time1 = TVAL_TO_SEC(end_time1) - TVAL_TO_SEC(start_time1);
printf("\tElapsed Time1: %0.2f s\n", elapsed_time1);
(3)测试结果
Transmit Buffer Size: 32.00 MiB
[ 84.709677] axidma axidma: DMA mask not set
Receive Buffer Size: 32.00 MiB
Elapsed Time0: 0.07 s
Elapsed Time1: 0.07 s
Elapsed Time: 24.75 s
Transmit Throughput: 1292.82 MiB/s
Receive Throughput: 1292.82 MiB/s
Total Throughput: 2585.64 MiB/s
root@u3_dma_test:/#
最后测得速率 32MB/70ms=450MB。
17、虽然速度是提高了,但是读写的数据是不对的
https://forums.xilinx.com/t5/%E5%B5%8C%E5%85%A5%E5%BC%8F-%E7%A1%AC%E4%BB...
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842098/Zynq+Ultr...
审核编辑:符乾江
驱动
12文章
1988浏览量
88683 -
Linux
88文章
11806浏览量
219508
如何理解Linux内核中的PCIe驱动
Visionfive的串口调试与编译内核
Linux内核驱动开发的技术核心精要
【「Linux 设备驱动开发(第 2 版)」阅读体验】Linux内核平台抽线共和设备驱动程序
GCC -O0 编译内核:调试党的 “救命神器”,这些优势 90% 开发者没吃透!
硬件调试:JLink 驱动配置与调试技巧
mtb-example-usb-device-hid-generic在配置DMA时失败了,为什么?
调试变频器详细说明
在任何平台上使用PetaLinux的先决条件
Petalinux2020.01 内核DMA驱动调试说明
