摘要
本文简单介绍Hi3861WiFi操作,怎么连接到热点,查看IP,ping服务器等。适合群体
适用于润和Hi3861开发板的开发。1、AT指令操作WiFi
我们可以使用AT指令进行Hi3861 WiFi操作,连接热点、ping服务器等。
但是很多时候,我们需要实现开机后自动连接到某个热点,光靠AT指令不行。
Hi3861 为我们提供了WiFi操作的相关API,方便我们编写代码,实现热点连接。
2、代码实现
先直接上代码和操作演示,跟我们最早的hello world代码一样,在app下新增业务demo_wifi_sta,其中demo_wifi_sta.c为业务代码,BUILD.gn为编译脚本,具体规划目录结构如下:
其中BUILD.gn文件内容如下:
static_library("demo_wifi_sta") {
sources = [
"demo_wifi_sta.c"
include_dirs = [
"//utils/native/lite/include",
"//kernel/liteos_m/components/cmsis/2.0",
"//base/iot_hardware/peripheral/interfaces/kits",
"//device/soc/hisilicon/hi3861v100/hi3861_adapter/hals/communication/wifi_lite/wifiservice",
"//device/soc/hisilicon/hi3861v100/hi3861_adapter/kal",
"//device/soc/hisilicon/hi3861v100/sdk_liteos/third_party/lwip_sack/include",
向右滑动查看完整代码
hi_wifi_start_sta函数:设置WiFi参数、扫描热点
int hi_wifi_start_sta(void)
int ret;
char ifname[WIFI_IFNAME_MAX_SIZE + 1] = {0};
int len = sizeof(ifname);
const unsigned char wifi_vap_res_num = APP_INIT_VAP_NUM;
const unsigned char wifi_user_res_num = APP_INIT_USR_NUM;
unsigned int num = WIFI_SCAN_AP_LIMIT;
//这里不需要重复进行WiFi init,因为系统启动后就自己会做WiFi init
printf("_______>>>>>>>>>> %s %d ", __FILE__, __LINE__);
ret = hi_wifi_init(wifi_vap_res_num, wifi_user_res_num);
if (ret != HISI_OK) {
return -1;
ret = hi_wifi_sta_start(ifname, &len);
return -1;
/* register call back function to receive wifi event, etc scan results event,
* connected event, disconnected event.
ret = hi_wifi_register_event_callback(wifi_wpa_event_cb);
printf("register wifi event callback failed ");
/* acquire netif for IP operation */
g_lwip_netif = netifapi_netif_find(ifname);
if (g_lwip_netif == NULL) {
printf("%s: get netif failed ", __FUNCTION__);
return -1;
/* 开始扫描附件的WiFi热点 */
ret = hi_wifi_sta_scan();
return -1;
sleep(5); /* sleep 5s, waiting for scan result. */
hi_wifi_ap_info *pst_results = malloc(sizeof(hi_wifi_ap_info) * WIFI_SCAN_AP_LIMIT);
if (pst_results == NULL) {
return -1;
//把扫描到的热点结果存储起来
ret = hi_wifi_sta_scan_results(pst_results, &num);
free(pst_results);
return -1;
//打印扫描到的所有热点
for (unsigned int loop = 0; (loop < num) && (loop < WIFI_SCAN_AP_LIMIT); loop++) {
printf("SSID: %s ", pst_results[loop].ssid);
free(pst_results);
/* 开始接入热点 */
ret = hi_wifi_start_connect();
if (ret != 0) {
return -1;
return 0;
向右滑动查看完整代码
连接热点:
int hi_wifi_start_connect(void)
int ret;
errno_t rc;
hi_wifi_assoc_request assoc_req = {0};
/* copy SSID to assoc_req */
rc = memcpy_s(assoc_req.ssid, HI_WIFI_MAX_SSID_LEN + 1, "RedmiK40", 8); /* 9:ssid length */
if (rc != EOK) {
return -1;
//热点加密方式
assoc_req.auth = HI_WIFI_SECURITY_WPA2PSK;
/* 热点密码 */
memcpy(assoc_req.key, "07686582488", 11);
ret = hi_wifi_sta_connect(&assoc_req);
return -1;
return 0;
向右滑动查看完整代码
热点连接结果回调函数
void wifi_wpa_event_cb(const hi_wifi_event *hisi_event)
if (hisi_event == NULL)
return;
switch (hisi_event->event) {
case HI_WIFI_EVT_SCAN_DONE:
printf("WiFi: Scan results available ");
break;
case HI_WIFI_EVT_CONNECTED:
printf("WiFi: Connected ");
netifapi_dhcp_start(g_lwip_netif);
break;
case HI_WIFI_EVT_DISCONNECTED:
printf("WiFi: Disconnected ");
netifapi_dhcp_stop(g_lwip_netif);
hi_sta_reset_addr(g_lwip_netif);
break;
case HI_WIFI_EVT_WPS_TIMEOUT:
printf("WiFi: wps is timeout ");
break;
default:
break;
向右滑动查看完整代码
hi_sta_reset_addr:重新复位sta的地址、网关等参数。
/* clear netif's ip, gateway and netmask */
void hi_sta_reset_addr(struct netif *pst_lwip_netif)
ip4_addr_t st_gw;
ip4_addr_t st_ipaddr;
ip4_addr_t st_netmask;
if (pst_lwip_netif == NULL) {
printf("hisi_reset_addr::Null param of netdev ");
return;
IP4_ADDR(&st_gw, 0, 0, 0, 0);
IP4_ADDR(&st_ipaddr, 0, 0, 0, 0);
IP4_ADDR(&st_netmask, 0, 0, 0, 0);
netifapi_netif_set_addr(pst_lwip_netif, &st_ipaddr, &st_netmask, &st_gw);
向右滑动查看完整代码
3、WiFi相关API
Hi3861 提供了非常多的wifi相关API,主要文件是 hi_wifi_api.h,我们这里只列举最重要的几个API(1)开启STA
int hi_wifi_sta_start(char *ifname, int *len);
向右滑动查看完整代码
(2)停止STA
int hi_wifi_sta_stop(void);
向右滑动查看完整代码
(3)扫描附件的热点
int hi_wifi_sta_scan(void);
向右滑动查看完整代码
(4)连接热点
int hi_wifi_sta_connect(hi_wifi_assoc_request *req);
向右滑动查看完整代码
其中hi_wifi_assoc_request *req 结构的定义如下:
typedef struct {
char ssid[HI_WIFI_MAX_SSID_LEN + 1]; /**< SSID. CNcomment: SSID 只支持ASCII字符.CNend */
hi_wifi_auth_mode auth; /**< Authentication mode. CNcomment: 认证类型.CNend */
char key[HI_WIFI_MAX_KEY_LEN + 1]; /**< Secret key. CNcomment: 秘钥.CNend */
unsigned char bssid[HI_WIFI_MAC_LEN]; /**< BSSID. CNcomment: BSSID.CNend */
hi_wifi_pairwise pairwise; /**< Encryption type. CNcomment: 加密方式,不需指定时置0.CNend */
} hi_wifi_assoc_request;
向右滑动查看完整代码
这里需要注意的是,通常加密方式是:HI_WIFI_SECURITY_WPA2PSK
例如我家的热点的连接方式的代码实现如下:
int ret;
errno_t rc;
if (rc != EOK) {
return -1;
//热点加密方式
/* 热点密码 */
return -1;
return 0;
向右滑动查看完整代码
本小节文章就到这里了,后续文章会持续更新,欢迎大家持续关注哦~
原文标题:OpenHarmony轻量系统开发【9】WiFi之STA模式连接热点
文章出处:【微信公众号:HarmonyOS官方合作社区】欢迎添加关注!文章转载请注明出处。
审核编辑:汤梓红
服务器
12文章
9295浏览量
85954 -
WIFI
81文章
5308浏览量
204587 -
热点
11浏览量
2547 -
Hi3861
1文章
62浏览量
6595
文章出处:【微信号:HarmonyOS_Community,微信公众号:电子发烧友开源社区】欢迎添加关注!文章转载请注明出处。
