tcpdump用于捕获和分析网络流量。系统管理员可以使用它来查看实时流量或将输出保存到文件中并在以后进行分析。下面列出6个常用选项。
-D 选项
tcpdump的
-D
获取接口设备列表。看到此列表后,可以决定要在哪个接口上捕获流量。它还告诉你接口是否已启动、正在运行,以及它是否是环回接口,如下所示:
[root@localhost~]#tcpdump-D
1.ens160[Up,Running]
2.lo[Up,Running,Loopback]
3.any(Pseudo-devicethatcapturesonallinterfaces)[Up,Running]
4.bluetooth-monitor(BluetoothLinuxMonitor)[none]
5.nflog(Linuxnetfilterlog(NFLOG)interface)[none]
6.nfqueue(Linuxnetfilterqueue(NFQUEUE)interface)[none]
7.usbmon0(AllUSBbuses)[none]
8.usbmon1(USBbusnumber1)
9.usbmon2(USBbusnumber2)
-c [数字]选项
-c
选项捕获X个数据包,然后停止。否则,tcpdump 将无限地继续运行。因此,当只想捕获一小部分数据包样本时,可以使用此选项。但是如果接口上没有数据流量,tcpdump 会一直等待。
[root@localhost~]#tcpdump-c5-iany
droppedprivstotcpdump
tcpdump:verboseoutputsuppressed,use-vor-vvforfullprotocoldecode
listeningonany,link-typeLINUX_SLL(Linuxcooked),capturesize262144bytes
1747.713379IPlocalhost.localdomain.ssh>192.168.43.1.39970:Flags[P.],seq714380127:714380371,ack1854022435,win388,length244
1747.713785IPlocalhost.localdomain.36821>_gateway.domain:36365+PTR?1.43.168.192.in-addr.arpa.(43)
1747.713939IP192.168.43.1.39970>localhost.localdomain.ssh:Flags[.],ack244,win4104,length0
1747.716053IP_gateway.domain>localhost.localdomain.36821:36365NXDomain0/1/0(78)
1747.716543IPlocalhost.localdomain.57441>_gateway.domain:61445+PTR?131.43.168.192.in-addr.arpa.(45)
5packetscaptured
9packetsreceivedbyfilter
0packetsdroppedbykernel
-n 选项
-n
选项不将IP地址解析为域名,直接以IP地址显示:
[root@localhost~]#tcpdump-c5-iany-n
1738.980756IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq714383039:714383283,ack1854024303,win388,length244
1738.981032IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq244:440,ack1,win388,length196
1738.981096IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq440:604,ack1,win388,length164
1738.981153IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq604:768,ack1,win388,length164
1738.981208IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq768:932,ack1,win388,length164
5packetscaptured
5packetsreceivedbyfilter
-s 选项
带有
-sXXX
的 tcpdump 可帮助你控制捕获数据包的大小。在上一个输出的第三行中,可以看到它表示捕获大小 262144 字节。可以使用-s
选项更改捕获数据大小。如果你只想检查数据包标头,则可以使用较小的大小进行捕获:
[root@localhost~]#tcpdump-c5-iany-n-s64
listeningonany,link-typeLINUX_SLL(Linuxcooked),capturesize64bytes
1744.437891IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq714405271:714405515,ack1854033767,win388,length244
1744.438153IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq244:440,ack1,win388,length196
1744.438220IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq440:604,ack1,win388,length164
1744.438301IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq604:768,ack1,win388,length164
1744.438361IP192.168.43.131.ssh>192.168.43.1.39970:Flags[P.],seq768:932,ack1,win388,length164
5packetscaptured
端口捕获
port
选项前加上 src/dst。如src port 53
或dst port 53
并进一步过滤它。
[root@localhost~]#tcpdump-ianyport53-n
1748.158109IP192.168.43.131.47054>192.168.43.2.domain:58704+A?www.baidu.com.(31)
1748.158152IP192.168.43.131.47054>192.168.43.2.domain:60504+AAAA?www.baidu.com.(31)
1748.159180IP192.168.43.2.domain>192.168.43.131.47054:605041/1/0CNAMEwww.a.shifen.com.(115)
1748.162018IP192.168.43.2.domain>192.168.43.131.47054:587043/0/0CNAMEwww.a.shifen.com.,A180.101.49.11,A180.101.49.12(90)
下面只获取源端口为53的数据包,其中
-nn
选项表示不解析IP地址和端口:
[root@localhost~]#tcpdump-c5-ianysrcport53-nn-s64
1841.604216IP192.168.43.2.53>192.168.43.131.48245:50676[|domain]
1841.606390IP192.168.43.2.53>192.168.43.131.48245:19947[|domain]
1841.631001IP192.168.43.2.53>192.168.43.131.54536:31350NXDomain[|domain]
1846.110591IP192.168.43.2.53>192.168.43.131.42379:17512[|domain]
1846.110603IP192.168.43.2.53>192.168.43.131.42379:40562[|domain]
5packetscaptured
下面只获取目的端口为53的数据包:
[root@localhost~]#tcpdump-c5-ianydstport53-nn-s64
1822.568585IP192.168.43.131.49444>192.168.43.2.53:27625+[|domain]
1822.568623IP192.168.43.131.49444>192.168.43.2.53:42481+[|domain]
1822.595257IP192.168.43.131.45790>192.168.43.2.53:28116+[|domain]
1823.850730IP192.168.43.131.34861>192.168.43.2.53:23444+[|domain]
1823.850762IP192.168.43.131.34861>192.168.43.2.53:23964+[|domain]
5packetscaptured
-w 选项
如果要将 tcpdump 的输出写入文件,请使用选项
-w
选项写入文件。如果想查看写了多少数据包,可以加-v
选项。
[root@localhost~]#tcpdump-c4-ianyport53-nn-wdns.pcap-v
tcpdump:listeningonany,link-typeLINUX_SLL(Linuxcooked),capturesize262144bytes
4packetscaptured
6packetsreceivedbyfilter
总结
tcpdump 用于收集有关网络流量数据的出色工具。数据包捕获为故障排除和安全分析提供了有用的信息。
原文标题:tcpdump 命令的常用选项
文章出处:【微信公众号:Linux爱好者】欢迎添加关注!文章转载请注明出处。
审核编辑:汤梓红
举报投诉
接口
33文章
8575浏览量
151014 -
网络
14文章
7553浏览量
88729 -
设备
2文章
4502浏览量
70598
文章出处:【微信号:LinuxHub,微信公众号:Linux爱好者】欢迎添加关注!文章转载请注明出处。
Linux tcpdump命令示例 如何在Linux中安装tcpdump
在这里,我们将展示如何安装 tcpdump,然后讨论并介绍一些有用的命令以及它们的实际示例。
发表于 08-06 11:11
•3688次阅读
tcpdump命令介绍
, 以及一个可能的网络接口描述。其中网络接口名字和数字编号可以用在tcpdump的-i [flag]选项(nt:把名字或数字代替flag), 来指定要在其上抓包的网络接口。此选项在不支
发表于 04-08 06:02
sd可以实现六个面对应六个不同文件夹sd音乐吗?
想做一个感应正方体音乐盒,通过三轴加速度计去感应六个面的变化,从而去读取sd不同文件夹的音乐,六个面对应六个不同文件夹sd音乐,而且文件夹里面的音乐是可以换的,我知道单独设置一
发表于 08-12 22:09
linux常用命令实例详解
,就必须从Linux命令学起,通过基础的命令学习可以进一步理解Linux系统。不同Linux发行版的命令数量不一样,但Linux发行版本最少的命令也有200多个。这里笔者把比较重要和使
发表于 11-03 10:19
•5541次阅读
tcpdump的安装以及通过实例来演示如何使用 tcpdump 命令
在本文中,我们将会通过一些实例来演示如何使用 tcpdump 命令,但首先让我们来看看在各种 Linux 操作系统中是如何安装 tcpdump 的。
grep命令常用的选项详解
说明:在Rocky8系统中,grep默认帮我们把匹配到的字符串标注了红色,这点还是挺贴心的。其实大家可以用which命令看一下grep,你会发现grep其实是grep --color=auto,这个选项就是颜色显示。
tcpdump常用的选项参数详细总结
常用选项通过上述的实战案例,相信大家已经掌握的 tcpdump 基本用法,在这里来详细总结一下常用的选项参数。 (一)基础
