NeoPixelLED眼球
我使用了NeoPixelLED作为“眼球”部分。
LED用双面胶带固定在“碗”背上,并按以下顺序接线。
眼动追踪
原理图
传感器
我使用了两个传感器QTR-1A进行眼动追踪。QTR-1A放置在塑料片上,之间距离大约是双眼距离。
Arduino代码
当虹膜接近一个传感器时,反射光减少,传感器值增加。相反,当虹膜移开时,反射光增加,光反射器的传感器值减小。
LED眼球瞳孔的左右运动,感知一个传感器值的增减,并对其进行控制。
眨眼时,两个传感器值都会减小,所以如果两个传感器值同时减小,LED“眼球”的外壳部分就会往下掉。
#include
#include
#define NUM_SENSORS 2 // number of sensors used
#define NUM_SAMPLES_PER_SENSOR 10 // averaging
#define EMITTER_PIN QTR_NO_EMITTER_PIN
int iniSensorValL, sensorValL;
int iniSensorValR, sensorValR;
#define PIN A3
Adafruit_NeoPixel led = Adafruit_NeoPixel(68, PIN, NEO_GRB + NEO_KHZ800);
int blackNum = 24;
int pupilNum = 12;
uint32_t color;
int brightness = 40;
byte eyeColor;
int LR =7;
boolean lid = false;
int cnt = 0;
//Black eye L&R animation
int blackLED[15][24] = {{12,32,35,55,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{12,13,31,36,54,55,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{11,13,14,30,37,53,54,56,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{10,11,14,15,29,38,52,53,56,57,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{ 9,10,11,12,15,16,28,33,34,39,51,52,55,56,57,58,68,68,68,68,68,68,68,68},
{ 0, 8, 9,10,11,12,13,16,17,27,32,35,40,50,51,54,55,56,57,58,59,67,68,68},
{ 0, 1, 7, 8, 9,10,13,14,17,18,26,31,36,41,49,50,53,54,57,58,59,60,66,67},
{ 1, 2, 6, 7, 8, 9,14,15,18,19,25,30,37,42,48,49,52,53,58,59,60,61,65,66},
{ 2, 3, 5, 6, 7, 8,15,16,19,20,24,29,38,43,47,48,51,52,59,60,61,62,64,65},
{ 3, 4, 5, 6, 7,16,17,20,21,23,28,39,44,46,47,50,51,60,61,62,63,64,68,68},
{ 4, 5, 6,17,18,21,22,27,40,45,46,49,50,61,62,63,68,68,68,68,68,68,68,68},
{ 4, 5,18,19,26,41,48,49,62,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{ 4,19,20,25,42,47,48,63,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{20,21,24,43,46,47,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68},
{21,23,44,46,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68,68}};
//pupil L&R animation
int pupilLED[15][12] = {{33,34,68,68,68,68,68,68,68,68,68,68},
{32,33,34,35,68,68,68,68,68,68,68,68},
{12,31,32,33,34,35,36,55,68,68,68,68},
{12,13,30,31,32,33,34,35,36,37,54,55},
{13,14,29,30,31,32,35,36,37,38,53,54},
{14,15,28,29,30,31,36,37,38,39,52,53},
{15,16,27,28,29,30,37,38,39,40,51,52},
{16,17,26,27,28,29,38,39,40,41,50,51},
{17,18,25,26,27,28,39,40,41,42,49,50},
{18,19,24,25,26,27,40,41,42,43,48,49},
{19,20,23,24,25,26,41,42,43,44,47,48},
{20,21,22,23,24,25,42,43,44,45,46,47},
{21,22,23,24,43,44,45,46,68,68,68,68},
{22,23,44,45,68,68,68,68,68,68,68,68},
{22,45,68,68,68,68,68,68,68,68,68,68}};
//Blink animation
int eyelid = 0;
int eyelidNum[8] = {0,4,8,16,24,34,44,56};
int eyelidLED[56] = {64,65,66,67,58,59,60,61,56,57,62,63,49,50,51,52,47,48,53,54,38,39,40,41,46,55,36,37,42,43,26,27,28,29,35,44,24,25,30,31,15,16,17,18,34,45,23,32,13,14,19,20,6,7,8,9};
QTRSensorsAnalog qtra((unsigned char[]) {0, 1}, NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void blink(int eyelid, int LR) {
if (eyelid != 8){
//Pewter
for(uint16_t i=0; i
//Black eye
for(uint16_t i=0; i
//pupil
for(uint16_t i=0; i
//eyelid
for(int i=0; i < eyelidNum[eyelid]; i++) {
led.setPixelColor(eyelidLED[i], 0);
} else if (eyelid == 8){
led.clear();
led.show();
void setup() {
Serial.begin(115200);
led.begin();
led.setBrightness(brightness); // Initial Brightness 40
led.show(); // Initialize all pixels to 'off'
color = led.Color(0, 177, 55); //pupil color
delay(100);
qtra.read(sensorValues);
iniSensorValL = sensorValues[0];
iniSensorValR = sensorValues[1];
blink(eyelid, LR);
void loop() {
//QTR - 1A sensor value
sensorValL = sensorValues[0];
sensorValR = sensorValues[1];
double rasioL = (double)sensorValL / iniSensorValL;
double rasioR = (double)sensorValR / iniSensorValR;
Serial.print(rasioL);
Serial.print(" ");
Serial.println(rasioR);
if(rasioL > 0.985 && rasioR < 0.985){ //right
for(int i = LR; i < 12; i++){
blink(0, i);
delay(40);
LR = i;
}else if(rasioL < 0.985 && rasioR > 0.985){ //left
for(int i=LR; i>2; i--){
blink(0, i);
delay(40);
LR = i;
}else if(lid == false && rasioL < 0.96 && rasioR < 0.96){ //Blinking close
for(int i = 1; i < 9; i++){
blink(i, LR);
delay(40);
lid = true;
}else if(lid == true && rasioL > 0.96 && rasioR > 0.96){ //Blinking open
for(int i = 8; i > 0; i--){
blink(i, LR);
delay(40);
lid = false;
}else if(lid == false && rasioL > 0.96 && rasioR > 0.96) { //normal
//cnt++;
//eyelid = 0;
if(LR <= 7){
for(int i=LR; i<=7; i++){
blink(0, i);
delay(40);
LR = i;
}else {
for(int i=LR; i>=7; i--){
blink(0, i);
delay(40);
LR = i;
Serial.println("通常時");
//Initial value refresh
if (cnt > 10){
iniSensorValL = sensorValL;
iniSensorValR = sensorValR;
cnt = 0;
led
242文章
23347浏览量
662883 -
红外传感器
9文章
522浏览量
47674
