根据OpenHarmony官网组件,结合相关技术,尝试列表组件的封装,提高开发的效率。
效果展示:
实现步骤
①封装组件代码
hml 代码:
<divclass="container{{start?'background':''}}">
<divclass="underline">
<divclass="list-left">
<div>
<textclass="title">{{title}}text>
div>
<divclass="list-des"
if="{{subheading}}">
<textclass="list">
<span>{{subheading}}span>
text>
div>
div>
<divclass="list-right">
<switchclass="switch-list"
if="{{whether}}"
@change="switchHandle">
switch>
<imageelse@click="launch()"class="list-icon"src="../images/right.png">
image>
div>
div>
div>
css 代码:
.container{
justify-content:center;
align-items:center;
padding-left:48px;
padding-right:35px;
overscroll-effect:spring;
.background:active{
background-color:#f6f6f6;
.underline{
border-bottom:1pxsolid#ccc;
/*标题样式代码*/
.list-left{
flex:1;
flex-direction:column;
.title{
font-family:FZLTHJW--GB1-0;
font-size:32px;
color:rgba(0,0,0,0.9);
letter-spacing:0;
font-weight:400;
height:70px;
.list-des{
width:530px;
flex-wrap:wrap;
margin-bottom:10px;
.list{
font-family:HarmonyOS_Sans;
font-size:28px;
color:rgba(0,0,0,0.6);
letter-spacing:0;
line-height:35px;
font-weight:400;
padding-bottom:2px;
/*switch开关样式代码*/
.list-right{
justify-content:flex-end;
width:115px;
min-height:100px;
align-items:center;
.switch-list{
width:115px;
height:120px;
.list-icon{
width:14px;
height:26px;
right:20px;
js 代码:
exportdefault{
props:{
//数据绑定
title:{
default:''
//数据绑定
subheading:{
default:''
//true是switch开关,false是图标
whether:{
default:true,
type:Boolean
//判断是不是switch开关列表,不是就加点击阴影事件
start:{
default:true,
type:Boolean
computed:{
start(){
return!this.whether
*切换开关
switchHandle({checked:checkedValue}){
this.$emit('switchHandle',checkedValue);
this.checkStatus=checkedValue;
②引入组件代码,实现列表功能
hml 代码:
<elementname="list-page"src="../../common/listitem/listitem.hml">element>
<divclass="container">
<list-pagewhether="{{true}}"
@switch-handle="showDialog"
title="标题1"
subheading="副文本">
list-page>
title="标题2">
list-page>
<list-pagewhether="{{false}}"
title="标题3">
list-page>
title="标题4"
subheading="副文本">
list-page>
div>
css 代码:
.container{
color:#fff;
background-color:#fff;
效果图为:
③在标题 1 加弹窗
hml 代码:
<dialogid="dataRoamDialog"class="dialog-main">
<divclass="dialog-divroaming">
<textclass="text">什么弹窗text>
<divclass="inner-txt">
<textclass="txtdistance">弹窗text>
div>
<divclass="inner-btn">
<buttontype="capsule"
value="确定"
onclick="setList"
class="btn-txt">
button>
<divclass="btn-l">div>
value="取消"
onclick="setList"
class="btn-txt">
button>
div>
div>
dialog>
css 代码:
/*弹窗样式*/
.dialog-main{
width:95%;
.dialog-div{
align-items:flex-start;
.roaming{
height:340px;
.text{
font-family:HarmonyOS_Sans_Medium;
font-size:36px;
letter-spacing:0;
line-height:38px;
font-weight:bold;
height:112px;
padding:40px0040px;
.inner-txt{
width:90%;
.txt{
font-size:32px;
letter-spacing:0;
line-height:38px;
font-weight:400;
flex:1;
height:75px;
justify-content:space-between;
font-family:PingFangSC-Regular;
.distance{
padding-left:40px;
margin-top:20px;
.inner-btn{
width:100%;
height:120px;
line-height:80px;
align-items:center;
margin:10px20px020px;
.btn-txt{
width:230px;
height:80px;
font-size:32px;
text-color:#1e90ff;
text-align:left;
align-items:center;
flex:1;
text-align:center;
.btn-l{
width:2px;
height:50px;
background-color:#ccc;
margin:010px;
js 代码:
exportdefault{
*标题1弹窗开启
showDialog(){
this.$element('dataRoamDialog').show();
*标题1弹窗取消
setList(){
this.$element('dataRoamDialog').close();
效果图:
总结
以上是所有的代码,写这个不难。主要用到了数据绑定跟三元运算和弹窗组件。相当于学习了OpenHarmony的开发,自己尝试封装,让自己更加了解OpenHarmony开发。欢迎各位开发者一起讨论与研究,本次分享希望对大家的学习有所帮助。
审核编辑 :李倩
举报投诉
代码
30文章
4977浏览量
74402 -
封装组件
2浏览量
5276 -
HarmonyOS
80文章
2157浏览量
36300
原文标题:HarmonyOS自定义列表组件封装
文章出处:【微信号:gh_834c4b3d87fe,微信公众号:OpenHarmony技术社区】欢迎添加关注!文章转载请注明出处。
热点推荐
自定义卡片编辑组件
自定义卡片编辑页面从左到右分为功能区、预览画布区和属性配置区。
开发者可以拖动左边组件图标到中间画布区域,选中中间画布上某个组件时,右边会展示该组件的属性配置,修改属性配置可以实时在
发表于 04-22 11:11
MCUXpresso SDK创建自定义清单
概述
MCUXpresso SDK 24.12 介绍塞德恩汉CED支持自定义清单,使开发人员能够精确定义其工作区中包含哪些组件、驱动程序、中间件和板支持包。此功能在极简主义、可重复性和 CI/CD
发表于 04-07 07:11
极海APM32F427如何实现自定义USB HID设备与PC进行通信
最近需要使用到 APM32F427 枚举成Custom HID设备进行用户自定义通信,但是官方的例程只有提供的HID枚举为鼠标或者键盘类型的设备。这里记录一下,怎么使用Geehy官方的USB中间件,实现自定义的USB HID设备进行用户通信。
如何为 Vision Five 2 编译自定义 Linux 内核?
Vision Five 2 的 Debian 用户指南只提供了半页关于如何编译自己的内核的相当稀疏的内容。仅从该文档中,我无法制作我的自定义内核。那里的信息似乎相当不完整。如果有人能提供一些
发表于 02-24 07:44
无图形界面模式下自定义检查工具的应用
此前文章已介绍 ANSA 中的自定义检查工具。本文将探讨该功能在无图形界面(No-GUI)模式下的应用,旨在满足标准化工作流程的需求,适用于需要高度自动化的前处理场景。通过集成自定义检查,用户可实现工作流程的高效自动化运行。
采用汇编指示符来使用自定义指令
具体实现
1、采用.word .half .dword等汇编指示符直接插入自定义指令,这种方法需要自己指定寄存器。其中.word为插入一个字的数据即32位,.half为插入半字即16位
发表于 10-28 06:02
LOTO示波器自定义解码功能—CANFD解码
LOTO示波器软件更新了自定义解码功能,并在bilibili上传了演示视频,视频链接: https://www.bilibili.com/video/BV1wq3ezjEjQ
HarmonyOS实战:3秒实现一个自定义轮播图
那么简单,需要考虑的细节很多。不过在 HarmonyOS 中实现一个轮播图却是十分的简单,本篇文章教你在最短的时间内快速实现一个自定义的 轮播图,建议点赞收藏!
KiCad 中的自定义规则(KiCon 演讲)
“ Seth Hillbrand 在 KiCon US 2025 上为大家介绍了 KiCad 的规则系统,并详细讲解了自定义规则的设计与实例。 ” 演讲主要围绕 加强 KiCad 中的自定义
HarmonyOS实战:自定义时间选择器
前言 最近在日常鸿蒙开发过程中,经常会使用一些时间选择器,鸿蒙官方提供的时间选择器满足不了需求,所以自己动手自定义一些经常会使用到的时间选择器,希望能帮到你,建议点赞收藏! 实现效果 需求分析 默认
HarmonyOS实战:高德地图自定义定位图标展示
的问题,建议点赞收藏! 实现效果 需求分析 首先需要实现一个自定义的图标替代系统默认的箭头。 获取定位权限与位置信息。 获取定位结果并展示当前位置。 技术实现 在鸿蒙的实际开发过程中,地图定位权限首先需要申请两个权限,
HarmonyOS应用自定义键盘解决方案
自定义键盘是一种替换系统默认键盘的解决方案,可实现键盘个性化交互。允许用户结合业务需求与操作习惯,对按键布局进行可视化重构、设置多功能组合键位,使输入更加便捷和舒适。在安全防护层面,自定义键盘可以
如何使用自定义设置回调函数?
你好,我正在尝试编写自己的自定义设置回调函数,并使用 fastEnum=false。
是否有任何代码示例或资料可供我参考?
void CyU3PUsbRegisterSetupCallback
发表于 05-21 06:11
HarmonyOS自定义列表组件封装
