TorchScript介绍
TorchScript是PyTorch模型推理部署的中间表示,可以在高性能环境libtorch(C ++)中直接加载,实现模型推理,而无需Pytorch训练框架依赖。torch.jit是torchscript Python语言包支持,支持pytorch模型快速,高效,无缝对接到libtorch运行时,实现高效推理。它是Pytorch中除了训练部分之外,开发者最需要掌握的Pytorch框架开发技能之一。trace使用
Torchscript使用分为两个部分分别是script跟trace,其中trace是跟踪执行步骤,记录模型调用推理时执行的每个步骤,代码演示如下:
classMyCell(torch.nn.Module):
def__init__(self):
super(MyCell,self).__init__()
self.linear=torch.nn.Linear(4,4)
defforward(self,x,h):
new_h=torch.tanh(self.linear(x)+h)
returnnew_h,new_h
my_cell=MyCell()
x,h=torch.rand(3,4),torch.rand(3,4)
traced_cell=torch.jit.trace(my_cell,(x,h))
print(traced_cell)
traced_cell(x,h)
print(traced_cell.graph)
运行结果如下:
MyCell(
original_name=MyCell
(linear):Linear(original_name=Linear)
跟踪执行结果
graph(%self.1:__torch__.MyCell,
%input:Float(3:4,4:1,requires_grad=0,device=cpu),
%h:Float(3:4,4:1,requires_grad=0,device=cpu)):
%19:__torch__.torch.nn.modules.linear.Linear=prim::GetAttr[name="linear"](%self.1)
%21:Tensor=prim::CallMethod[name="forward"](%19,%input)
%12:int=prim::Constant[value=1]()#D:/python/pytorch_openvino_demo/ch5/faster_rcnn2onnx.py0
%13:Float(3:4,4:1,requires_grad=1,device=cpu)=aten::add(%21,%h,%12)#D:/python/pytorch_openvino_demo/ch5/faster_rcnn2onnx.py0
%14:Float(3:4,4:1,requires_grad=1,device=cpu)=aten::tanh(%13)#D:/python/pytorch_openvino_demo/ch5/faster_rcnn2onnx.py0
%15:(Float(3:4,4:1,requires_grad=1,device=cpu),Float(3:4,4:1,requires_grad=1,device=cpu))=prim::TupleConstruct(%14,%14)
return(%15)
script部分使用
script是导出模型为中间IR格式文件,支持高性能libtorch C++部署,我们以torchvision中Mask-RCNN导出中间格式IR为例,代码演示如下:
importtorch
importtorchvisionastv
num_classes=3
model=tv.models.detection.maskrcnn_resnet50_fpn(
pretrained=False,progress=True,
num_classes=num_classes,
pretrained_backbone=True)
im=torch.zeros(1,3,*(1333,800)).to("cpu")
model.load_state_dict(torch.load("D:/gaobao_model.pth"))
model=model.to("cpu")
model.eval()
ts=torch.jit.script(model)
ts.save("gaobao.ts")
loaded_trace=torch.jit.load("gaobao.ts")
loaded_trace.eval()
withtorch.no_grad():
print(loaded_trace(list(im)))
最终得到torchscript文件,支持直接通过libtorch部署,其中通过torchscript C++部分加载的代码如下:
#include//One-stopheader.
#include
#include
intmain(intargc,constchar*argv[]){
if(argc!=2){
std::cerr<< "usage:example-app
return-1;
//DeserializetheScriptModulefromafileusingtorch::load().
torch::Modulemodule=torch::load(argv[1]);
std::vectorinputs;
inputs.push_back(torch::randn({4,8}));
inputs.push_back(torch::randn({8,5}));
torch::Tensoroutput=module.forward(std::move(inputs)).toTensor();
std::cout<< output << std::endl;
上面代码来自官方测试程序,特别说明一下!
审核编辑 :李倩
举报投诉
开发
370浏览量
40834 -
C++
22文章
2108浏览量
73604 -
pytorch
2文章
806浏览量
13191
原文标题:轻松学Pytorch之torchscript使用!
文章出处:【微信号:CVSCHOOL,微信公众号:OpenCV学堂】欢迎添加关注!文章转载请注明出处。
