VL103节能单芯片概述、工作原理及特性
wxg13647947188 来源:wxg13647947188 作者:wxg13647947188 2022-05-23 14:21 次阅读
VL103是一款高度集成的节能单芯片显示端口Alt-mode和Power Delivery 3.0控制器,适用于USB-C设备,设计用于USB-C视频适配器和USB-C多功能对接站等应用。v103集成了USB-C充电UFP,可实现DP切换模式视频输出功能,检测到外接电源后,可同时对连接的PD主机充电。集成的第二个USB-C DRP既可以连接USB-C电源适配器为PD主机充电,也可以连接USB-C设备访问数据传输。集成了D+/D-充电ePHY,支持使用D+/D-引脚进行协议握手的充电器。VL103的设备策略管理器可以在DRP和UFP之间协商电源规则,然后实现电源充电。支持电池无电模式下对主机充电,支持PD3.0快速角色切换。内置SBU1/SBU2交换机,支持USB-C转接线功能。实现USB公告牌设备功能,满足“VESA DP Alt-Mode on USB Type-C”规范。VL103还支持智能自动待机功能,当所连接的接口处于空闲状态时,自动进入深度省电模式,适用于智能手机配件。
内置微调RC振荡器线性稳压器,Vbus电压检测器和Vbus电流检测器,VL103可以完美地工作在电源输入,无论是从Vconn电源或从Vbus电源,并可以监测异常的电源行为。高达11 GPIO引脚可用于电源放电控制,电源开关控制,数据开关控制,或其他特殊应用用途。SPI接口支持外接SPI flash或与VLI Hub控制器共享SPI flash进行固件升级。VL103可提供qfn48l (6x6x0.85 mm), pin-to-pin兼容VL102-Q4和qfn32l (5x5x0.85 mm), pin-to-pin兼容VL100-Q3。
VL103 is a highly integrated power-saving single chip DisplayPort Alt-mode and Power Delivery 3.0 controller for USB-C devices that designed for applications like USB-C video adapters and USB-C multi-function docking stations. Integrated USB-C charging UFP, VL103 can perform DP alt-mode video output functionality and simultaneously charging connected PD host once external power is detected. Integrated second USB-C DRP can either connect to USB-C power adapter to charge PD host or connect to USB-C devices to access data transfer. A D+/D- charging ePHY is integrated to support chargers using D+/D- pins to do protocol handshake. VL103’s Device Policy Manager could negotiate power rules between its DRP and UFP then enable power charging-through. Charging a host under dead battery mode and PD3.0 fast role swap are supported. SBU1/SBU2 switch is built-in to support USB-C cable flipping feature. USB Billboard device function is implemented to meet “VESA DP Alt-Mode on USB Type-C” spec. VL103 also support smart auto-standby that automatically entering deep power saving mode when connected interface are in idle state which is suitable for smart phone accessories.
Built-in trimmed RC oscillator, linear voltage regulators, Vbus voltage detector, and Vbus current detector, VL103 can work perfectly with power input either from Vconn power or from Vbus power and can monitor abnormal power behavior. Up to 11 GPIO pins are available for power discharge control, power switch control, data switch control, or other special application usage. The SPI interface can support external SPI flash or sharing SPI flash with VLI Hub controller for firmware upgrade. VL103 is available in QFN 48L (6x6x0.85 mm) that pin-to-pin compatible to VL102-Q4 and QFN 32L (5x5x0.85 mm) that pin-to-pin compatible to VL100-Q3.
CC Logic & PD 3.0引擎支持一个充电UFP和一个DRP
-符合USB - c型电缆和连接器规范修订1.2
—符合USB电源交付规范修订3.0版本1.0a
-集成c型收发器,支持一个充电UFP和一个DRP
-内置上/下拉电阻,包括Rp, Rd和Ra
—内置Vconn电源开关dp alt模式配置
-兼容VESA DisplayPort Alt Mode on USB Type-C Standard Version 1.0a
—DP方式发现/进入/退出
—DP配置、状态更新、源/接收连接检测
—内置Aux_CH开关usb - c充电UFP能力
—外部电源供电时,对已连接的PD主机进行充电
—支持提供者和消费者角色
—支持100W的PD电源规则
—支持电池无电充电和快速角色SwapUSB-C DRP功能
—支持提供者和消费者角色
-支持PD功率规则,可达100W作为Sink, 15W作为Source
-内置D+/D-充电ePHY充电器使用D+/D-作为协议握手
—内置USB HS数据开关USB公告牌设备
-符合USB设备类定义的公告牌设备修订1.21
-集成内部USB2.0全速PHYFast 8051宏单元80c32兼容微控制器
-标准1T 8051指令集
-嵌入式掩模ROM和SRAM -支持外部SPI flash或共享SPI flash与VLI Hub控制器固件升级内置振荡器,电压调节器,电压检测器和电流检测器
-内置修剪RC振荡器
- 5.0 v -3.3 v LDO和3.3 v -1.8 v LDO
- Vbus和Vconn之间的自动电源选择
- Vbus电压检测器和Vbus电流检测器,用于监控电源安全智能待机
—当连接的接口处于空闲状态时,自动进入深度省电模式。特殊功能和控制接口
- 11个gpio在QFN48/VFBGA45和7个gpio在QFN32的应用定制和一个I2C主接口物理
- QFN 48绿色封装(6x6x0.85 mm),适用于VL103-Q4、VL103R-Q4和VL103S-Q4;pin-to-pin兼容VL102-Q4
QFN 32绿色包装(5x5x0.85 mm)用于VL103-Q3;pin-to-pin兼容vl100 - q3认证
- VL103-Q3 PD 2.0认证TID: 1060047;VL103-Q4 PD 2.0认证TID: 1060043
—USB-C视频适配器
- USB-C多功能底座
审核编辑:汤梓红
  • 控制器
  • 单芯片
  • USB-C
    东软载波荣获2024节能服务产业科技进步奖
    近日,由中国节能协会指导,中国节能协会节能服务产业委员会(EMCA)主办的“2024节能服务产业年度峰会”召开,青岛东软载波科技股份有限公司(下简称“东软载波”)凭借其在
    的头像 发表于 12-23 09:57 158次阅读
    一文读懂灯控制器工作原理
    一文读懂灯控制器工作原理
    的头像 发表于 11-11 13:13 285次阅读
    一文读懂<b class='flag-5'>单</b>灯控制器<b class='flag-5'>工作原理</b>
    单结晶体管的工作原理和伏安特性
    单结晶体管(Unipolar Junction Transistor,简称UJT),又称基极二极管或单晶二极管,是一种具有独特工作原理和伏安特性的半导体器件。以下将详细阐述单结晶体管的工作原理和伏安
    的头像 发表于 09-23 17:29 1694次阅读
    单结晶体管的<b class='flag-5'>工作原理</b>和伏安<b class='flag-5'>特性</b>
    管正激电路工作原理是什么
    管正激电路是一种开关电源拓扑结构,广泛应用于各种电子设备中,如计算机、手机、家用电器等。它的工作原理涉及到电力电子学、控制理论、电磁学等多个领域。 管正激电路的工作原理
    的头像 发表于 09-18 11:18 777次阅读
    锂电池电源管理芯片有哪些?
    锂电池电源管理芯片在市场上有多种,它们通常用于管理电池的充电和放电过程,以确保电池安全和延长使用寿命。以下是一些常见的锂电池电源管理
    的头像 发表于 09-11 16:54 1168次阅读
    电机的工作原理特性是什么
    电机的工作原理与特点,并探讨其在实际应用中的表现。 一、普通电机的工作原理 普通电机的工作原理基于电磁感应定律。当交流电流流经电机的定子绕组时,产生一个旋转磁场。这个旋转磁场与电机转子中的导体相互作用,根据洛伦兹力定
    的头像 发表于 08-23 11:34 1004次阅读
    功率合成器工作原理是什么
    功率合成器是一种将多个功率放大器的输出信号进行合成,以实现更高的输出功率和更好的信号质量的电子设备。其工作原理涉及到多个方面的知识,包括信号合成、功率放大、滤波器设计等。 信号合成原理 信号合成
    的头像 发表于 08-13 14:32 508次阅读
    VL805和VL806的技术资料
    PCIe转USB3.0芯片VL805和VL806相关资料,包含Datasheet、原理图、PCB等。
    发表于 07-29 13:19 22次下载
    电磁继电器的工作原理、结构及特性
    电磁继电器是一种利用电磁原理实现控制电路中开关功能的重要元件。它的工作原理确实与电流的磁效应密切相关。在本文中,我们将详细探讨电磁继电器的工作原理、结构、特性以及应用等方面的内容。 一、电磁继电器
    的头像 发表于 06-21 09:13 2773次阅读
    蜂鸣器的工作原理特性
    蜂鸣器,作为一种常见的电子发声器件,广泛应用于各种电子设备中,如计算机、打印机、报警器、电子玩具等。其独特的发声原理和多样化的特性,使得蜂鸣器在电子领域占据了重要的地位。本文将详细阐述蜂鸣器的工作原理特性,旨在为读者提供深入的
    的头像 发表于 05-28 15:04 2377次阅读
    VL813/VL817/VL820 HUB USB3.0集线器HUB拓展坞芯片对比及应用
    VL8系列简介 VL813 VL817 VL820 是USB 3.0集线器芯片VL813可以转
    的头像 发表于 05-09 15:50 1955次阅读
    <b class='flag-5'>VL</b>813/<b class='flag-5'>VL</b>817/<b class='flag-5'>VL</b>820 HUB USB3.0集线器HUB拓展坞<b class='flag-5'>芯片</b>对比及应用
    器的工作原理及特点是什么
    器(Energy Storage)是一种能够将电能、机械、化学等转换并且储存起来的装置。它在现代生活中扮演着重要的角色,充当着电网调峰、储备电力以及应对突发事件等方面的功能。储
    的头像 发表于 04-14 11:26 3092次阅读
    光电集成芯片工作原理是什么
    光电集成芯片工作原理涉及了光学和电子学的深度融合,展现了科技的前沿魅力。这种芯片结合了光子和电子的特性,通过精密的设计和制造工艺,实现了光信号和电信号之间的高效转换和处理。
    的头像 发表于 03-20 16:06 935次阅读
    集成芯片测量工作原理
    集成芯片测量工作原理主要涉及到一系列的技术和步骤,用以验证芯片的功能和性能。
    的头像 发表于 03-19 16:55 839次阅读
    基准电压芯片工作原理是什么?
    基准电压芯片工作原理是什么? 基准电压芯片是一种常用于电子设备中的重要元件,用于产生稳定的电压信号。其工作原理涉及到稳压原理、参考电压和反馈控制等方面,下面将详细介绍基准电压
    的头像 发表于 01-29 15:33 3284次阅读
