故障现象
远端模块下挂的PD(比如下挂的AP、话机、摄像头等)不能正常上电。
2原理描述
远端模块作为中心交换机的PD,使用中心交换机PoE给远端模块供电。
此场景下,中心交换机通过XLDP心跳报文定期将端口PoE功率发送给远端模块,远端模块根据接收的功率,减去损耗,设置对外PoE功率。未接收到心跳报文时,远端模块保持PoE功率不变。默认对外PoE功率60W。 -
远端模块使用电源适配器供电。
此场景下,远端模块PoE供电功率为固定值。
处理步骤
步骤 1 查看远端模块设备PoE信息,供电功率是否足够。# 执行命令行display remote-unit poe查看远端模块PoE信息,确认远端模块供电功率是否充足,电压等信息是否正常,比如,总供电为60W,电压50V左右时是正常的。
ESN :21980117760123xxxxxxxx
Device type :S5731-L4P2HW-RUA
Connect interface :GigabitEthernet0/0/4
PSE information :
PoE power supply(mW) :60000
Total available power(mW) :60000
Total power consumption(mW) :0
Power peak value(mW) :0
Power voltage(V) :54
PSE reset times :0
PoE failure :NO
# 执行命令行display remote-unitport poe查看远端模块端口PoE信息,确认端口供电等级、参考功率、供电模式、端口状态是否和下挂的PD匹配。
ESN :219801177601xxxxxxxx
Device type :-
GE1 PoE information:
PD class :4
PD reference power(mW) :30000
PD current power(mW) :4200
PD peak power(mW) :4200
PD average power(mW) :4200
Power-up mode :at
Force power :Disable
Power ON/OFF :On
Power-on delay(s) :0
Power status :Powered
Current(mA) :78
Voltage(V) :53
GE2 PoE information:
PD class :0
PD reference power(mW) :0
PD current power(mW) :2900
PD peak power(mW) :2900
PD average power(mW) :2900
Power-up mode :af
Power ON/OFF :On
Current(mA) :53
Voltage(V) :54
# 执行命令行display poe power查看中心交换机端口PoE功能状态是否正常。
[HUAWEI] display poe powerCodes: REFPW(Reference power), USMPW(User set max power),CURPW(Current power), PKPW(Peak power), AVGPW(Average power)
PortName Class REFPW(mW) USMPW(mW) CURPW(mW) PKPW(mW) AVGPW(mW)
GigabitEthernet0/0/1 - - 90000 0 0 0
GigabitEthernet0/0/2 4 30000 90000 4200 4400 4133
GigabitEthernet0/0/3 - - 90000 0 0 0
GigabitEthernet0/0/4 - - 90000 0 0 0
GigabitEthernet0/0/5 - - 90000 0 0 0
GigabitEthernet0/0/6 - - 90000 0 0 0
GigabitEthernet0/0/7 - - 90000 0 0 0
GigabitEthernet0/0/8 - - 90000 0 0 0
GigabitEthernet0/0/9 - - 90000 0 0 0
GigabitEthernet0/0/10 - - 90000 0 0 0
GigabitEthernet0/0/11 - - 90000 0 0 0
GigabitEthernet0/0/12 - - 90000 0 0 0
GigabitEthernet0/0/13 - - 90000 0 0 0
GigabitEthernet0/0/14 - - 90000 0 0 0
GigabitEthernet0/0/15 - - 90000 0 0 0
GigabitEthernet0/0/16 - - 90000 0 0 0
GigabitEthernet0/0/17 - - 90000 0 0 0
GigabitEthernet0/0/18 - - 90000 0 0 0
GigabitEthernet0/0/19 - - 90000 0 0 0
GigabitEthernet0/0/20 - - 90000 0 0 0步骤 4对于远端模块作为中心交换机的PD场景,检查XLDP PoE协商状态。# 参考远端模块上线异常,确认XLDP心跳报文是否正常。
# 对于S5732-H48XUM2CC款型,使用第一代光电复合缆连接远端模块,电口供电,光口通信,需通过命令行 poe xldp-proxy interfacemultige interface-number绑定光口与电口,光口代理电口发送PoE功率给远端模块,如果不配置该命令,远端模块默认60W对外PoE供电。
[HUAWEI] interface XGigabitEthernet 0/0/1
[HUAWEI-XGigabitEthernet0/0/1] poe xldp-proxy interface MultiGE 0/0/1
# 对于非标PD不能正常上电,可通过命令行poe force-power port number 使能端口强制供电,或通过命令行poe af-inrush enable port number 配置端口供电方式。然后通过步骤2、3查询远端模块端口供电是否正常。
[HUAWEI]remote-unit 3
[HUAWEI-remote-unit-3] poe force-power port 1
[HUAWEI-remote-unit-3] poe af-inrush enable port 2
[HUAWEI-remote-unit-3] commit
[HUAWEI-remote-unit-3] quit
步骤 6请收集日志信息和配置信息,并联系技术支持人员。设备诊断信息可以通过displaydiagnostic-information命令收集。
交换机
21文章
2661浏览量
100253 -
PoE
7文章
469浏览量
56384 -
远端模块
11浏览量
6385
原文标题:小行星远端模块下挂PD PoE供电异常如何处理?
文章出处:【微信号:huaweidoc,微信公众号:华为产品资料】欢迎添加关注!文章转载请注明出处。
常见处理器故障及解决方法
电⼦尺常⻅故障现象及处理⽅法
![电⼦尺常⻅<b class='flag-5'>故障</b><b class='flag-5'>现象</b>及<b class='flag-5'>处理</b>⽅法](https://file1.elecfans.com/web3/M00/03/C6/wKgZO2drwRGACUDIAANYs9JWhPA459.png)
